    4. iobroker diagnostics/node
      klaus88 last edited by
      Ich bräuchte bitte eure Hilfe !
      Bekomme folgende Fehlermeldung wenn ich den IOBROKER starten will:
      node:internal/modules/cjs/loader:446
            throw err;
      Error: Cannot find module '/opt/iobroker/node_modules/@dabh/diagnostics/node'. Please verify that the package.json has a valid "main" entry
          at tryPackage (node:internal/modules/cjs/loader:438:19)
          at Module._findPath (node:internal/modules/cjs/loader:680:18)
          at Module._resolveFilename (node:internal/modules/cjs/loader:1063:27)
          at Module._load (node:internal/modules/cjs/loader:922:27)
          at Module.require (node:internal/modules/cjs/loader:1143:19)
          at require (node:internal/modules/cjs/helpers:119:18)
          at Object.<anonymous> (/opt/iobroker/node_modules/winston/lib/winston/exception-handler.js:12:15)
          at Module._compile (node:internal/modules/cjs/loader:1256:14)
          at Module._extensions..js (node:internal/modules/cjs/loader:1310:10)
          at Module.load (node:internal/modules/cjs/loader:1119:32) {
        code: 'MODULE_NOT_FOUND',
        path: '/opt/iobroker/node_modules/@dabh/diagnostics/package.json',
        requestPath: '@dabh/diagnostics'
      Node.js v18.18.2
      Jeder Versuch irgend eine Info zu bekommen (z.B. die iobroker Version) endet in oben stehenden Fehler
      Aus iob diag kommt auch nichts raus - außer oben stehenden Fehler
      Kann mir irgendwer helfen? Danke vorab für eure Hilfe
      lg
      Klaus
        klaus88 @klaus88 last edited by
        Sorry sicherheitshalber den Inhalt der iob diag Summary:
                                v.2023-10-10
           Static hostname: iobroker
                 Icon name: computer
          Operating System: Debian GNU/Linux 11 (bullseye)
                    Kernel: Linux 6.1.21-v8+
              Architecture: arm64
        Userland:               arm64
        Timezone:               Europe/Vienna (CEST, +0200)
        User-ID:                1000
        X-Server:               false
        Pending OS-Updates:     0
              throw err;
        Node.js v18.18.2
        Pending iob updates:    0
        Nodejs-Installation:    /usr/bin/nodejs         v18.18.2
                                /usr/bin/node           v18.18.2
                                /usr/bin/npm            9.8.1
                                /usr/bin/npx            9.8.1
                                /usr/bin/corepack       0.19.0
        MEMORY:
        Mem:            3.8G        137M        3.0G        1.0M        692M        3.6G
        Swap:            99M          0B         99M
        Total:          3.9G        137M        3.1G
              throw err;
        Node.js v18.18.2
        Active iob-Instances:   0
              throw err;
        Node.js v18.18.2
              throw err;
        Node.js v18.18.2
        ioBroker Core:          js-controller
              throw err;
        Node.js v18.18.2
                                admin
              throw err;
        Node.js v18.18.2
        ioBroker Status:
              throw err;
        Node.js v18.18.2
        Objects:                0
        States:                 0
        Size of iob-Database:
        14M     /opt/iobroker/iobroker-data/objects.jsonl
        4.4M    /opt/iobroker/iobroker-data/states.jsonl
          Thomas Braun Most Active @klaus88 last edited by
          @klaus88
          Und wie kommst du dann an die Summary? Das ist der gleiche Lauf des Skripts. Bitte die Langfassung von iob diag.
            klaus88 @Thomas Braun last edited by klaus88
            Anbei die Langfassung:
            pi@iobroker:~ $ iob diag
            *** iob diag is starting up, please wait ***
                  throw err;
            Node.js v18.18.2
                  throw err;
            Node.js v18.18.2
                  throw err;
            Node.js v18.18.2
            *** ioBroker Diagnosis ***
            Please stretch the window of your terminal programm (puTTY) as wide as possible or switch to full screen
            The following checks may give hints to potential malconfigurations or errors, please post them in our forum:
            https://forum.iobroker.net
            Just copy and paste the Summary Page, including the ``` characters at start and end.
            It helps us to help you!
            Press any key to continue
            Skript v.2023-10-10
            *** BASE SYSTEM ***
                     Icon name: computer
                  Architecture: arm64
            Model           : Raspberry Pi 4 Model B Rev 1.1
            Docker          : false
            Virtualization  : none
            Kernel          : aarch64
            Userland        : arm64
            Systemuptime and Load:
             18:07:41 up 3 min,  1 user,  load average: 0.28, 0.34, 0.17
            CPU threads: 4
            *** RASPBERRY THROTTLING ***
            Current issues:
            Previously detected issues:
            *** Time and Time Zones ***
                           Local time: Sat 2023-10-21 18:07:41 CEST
                       Universal time: Sat 2023-10-21 16:07:41 UTC
                             RTC time: n/a
                            Time zone: Europe/Vienna (CEST, +0200)
                          NTP service: active
                      RTC in local TZ: no
            *** User and Groups ***
            pi
            /home/pi
            pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
            *** X-Server-Setup ***
            X-Server:       false
            Desktop:
            Terminal:       tty
            *** MEMORY ***
            Mem:            3.8G        156M        3.3G        1.0M        306M        3.6G
            Swap:            99M          0B         99M
            Total:          3.9G        156M        3.4G
                     3794 M total memory
                      157 M used memory
                      331 M active memory
                       47 M inactive memory
                     3330 M free memory
                       24 M buffer memory
                      282 M swap cache
                       99 M total swap
                        0 M used swap
                       99 M free swap
            Raspberry only:
            oom events: 0
            *** FAILED SERVICES ***
            0 loaded units listed.
            *** FILESYSTEM ***
            /dev/root      ext4      116G  7.2G  104G   7% /
            devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
            tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
            tmpfs          tmpfs     759M  1.1M  758M   1% /run
            /dev/mmcblk0p1 vfat      255M   31M  225M  13% /boot
            tmpfs          tmpfs     380M  4.0K  380M   1% /run/user/1000
            [Sat Oct 21 18:03:49 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:36:D9:66 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=401c1d47-02 rootfstype=ext4 fsck.repair=yes rootwait
            [Sat Oct 21 18:03:50 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
            [Sat Oct 21 18:03:50 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
            [Sat Oct 21 18:03:52 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
            TARGET  SOURCE         FSTYPE OPTIONS
            /       /dev/mmcblk0p2 ext4   rw,noatime
            `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
            /var:
            2.0G    /var/
            1.1G    /var/log
            953M    /var/log/journal/9394eca1e90d4271be439bf143c935f2
            680M    /var/cache
            Archived and active journals take up 952.1M in the file system.
            /opt/iobroker/backups:
            509M    /opt/iobroker/backups/
            /opt/iobroker/iobroker-data:
            1.2G    /opt/iobroker/iobroker-data/
            732M    /opt/iobroker/iobroker-data/history
            384M    /opt/iobroker/iobroker-data/files
            80M     /opt/iobroker/iobroker-data/backup-objects
            78M     /opt/iobroker/iobroker-data/files/icons-open-icon-library-png
            21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.edf7552a.js.map
            15M     /opt/iobroker/iobroker-data/files/telegram.admin/rules/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_d_ts-node_modules_io-1d9f06.44fe4a3f.chunk.js.map
            9.4M    /opt/iobroker/iobroker-data/files/vis.0/main/vis-views.json
            8.9M    /opt/iobroker/iobroker-data/files/scenes.admin/static/js/2.7de3299d.chunk.js.map
            USB-Devices by-id:
            /dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B0014B940FD-if00
            *** NodeJS-Installation ***
            /usr/bin/npm            9.8.1
            /usr/bin/npx            9.8.1
            nodejs:
              Version table:
             *** 18.18.2-1nodesource1 1001
                    100 /var/lib/dpkg/status
                 18.18.1-1nodesource1 1001
                 18.18.0-1nodesource1 1001
                 18.17.1-1nodesource1 1001
                 18.17.0-1nodesource1 1001
                 18.16.1-1nodesource1 1001
                 18.16.0-1nodesource1 1001
                 18.15.0-1nodesource1 1001
                 18.14.2-1nodesource1 1001
                 18.14.1-1nodesource1 1001
                 18.14.0-1nodesource1 1001
                 18.13.0-1nodesource1 1001
                 18.12.0-1nodesource1 1001
                 18.11.0-1nodesource1 1001
                 18.10.0-1nodesource1 1001
                 18.9.1-1nodesource1 1001
                 18.9.0-1nodesource1 1001
                 18.8.0-1nodesource1 1001
                 18.7.0-1nodesource1 1001
                 18.6.0-1nodesource1 1001
                 18.5.0-1nodesource1 1001
                 18.4.0-1nodesource1 1001
                 18.3.0-1nodesource1 1001
                 18.2.0-1nodesource1 1001
                 18.1.0-1nodesource1 1001
                 18.0.0-1nodesource1 1001
                 12.22.12~dfsg-1~deb11u4 500
                    500 http://deb.debian.org/debian bullseye/main arm64 Packages
                    500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
            No problems detected
            Errors in npm tree:
            *** ioBroker-Installation ***
            ioBroker Status
                  throw err;
            Node.js v18.18.2
            Core adapters versions
                  throw err;
            Node.js v18.18.2
            js-controller:
                  throw err;
            Node.js v18.18.2
            admin:
                  throw err;
            Node.js v18.18.2
            javascript:
            Adapters from github:   4
            Adapter State
                  throw err;
            Node.js v18.18.2
                  throw err;
            Node.js v18.18.2
            ioBroker-Repositories
                  throw err;
            Node.js v18.18.2
            Installed ioBroker-Instances
                  throw err;
            Node.js v18.18.2
            Objects and States
            Objects:        0
            States:         0
            Hit:1 http://deb.debian.org/debian bullseye InRelease
            Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
            Hit:3 http://security.debian.org/debian-security bullseye-security InRelease
            Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
            Hit:5 https://repos.influxdata.com/debian bullseye InRelease
            Hit:6 https://deb.nodesource.com/node_18.x nodistro InRelease
            Reading package lists...
            Pending Updates: 0
            *** Listening Ports ***
            tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          13640      535/sshd: /usr/sbin
            tcp6       0      0 :::22                   :::*                    LISTEN      0          13642      535/sshd: /usr/sbin
            udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        13581      387/avahi-daemon: r
            udp        0      0 0.0.0.0:52892           0.0.0.0:*                           108        13583      387/avahi-daemon: r
            udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          12018      655/dhcpcd
            udp6       0      0 :::5353                 :::*                                108        13582      387/avahi-daemon: r
            udp6       0      0 :::38316                :::*                                108        13584      387/avahi-daemon: r
            2023-10-21 09:00:39.963  - info: host.iobroker instance system.adapter.upnp.0 terminated with code 0 (NO_ERROR)
            2023-10-21 09:00:40.030  - info: host.iobroker instance system.adapter.energiefluss.0 terminated with code 0 (NO_ERROR)
            2023-10-21 09:00:40.030  - warn: host.iobroker instance system.adapter.admin.0 terminated due to SIGTERM
            2023-10-21 09:00:40.031  - info: host.iobroker instance system.adapter.admin.0 terminated with code null ()
            2023-10-21 09:00:40.160  - warn: host.iobroker instance system.adapter.ping.0 terminated due to SIGTERM
            2023-10-21 09:00:40.160  - info: host.iobroker instance system.adapter.ping.0 terminated with code null ()
            2023-10-21 09:00:40.160  - warn: host.iobroker instance system.adapter.sonoff.0 terminated due to SIGTERM
            2023-10-21 09:00:40.160  - info: host.iobroker instance system.adapter.sonoff.0 terminated with code null ()
            2023-10-21 09:00:40.221  - warn: host.iobroker instance system.adapter.zigbee.0 terminated due to SIGTERM
            2023-10-21 09:00:40.221  - info: host.iobroker instance system.adapter.zigbee.0 terminated with code null ()
            2023-10-21 09:00:40.222  - warn: host.iobroker instance system.adapter.fully-tablet-control.0 terminated due to SIGTERM
            2023-10-21 09:00:40.222  - info: host.iobroker instance system.adapter.fully-tablet-control.0 terminated with code null ()
            2023-10-21 09:00:40.275  - warn: host.iobroker instance system.adapter.parser.0 terminated due to SIGTERM
            2023-10-21 09:00:40.276  - info: host.iobroker instance system.adapter.parser.0 terminated with code null ()
            2023-10-21 09:00:40.368  - warn: host.iobroker instance system.adapter.hmip.0 terminated due to SIGTERM
            2023-10-21 09:00:40.369  - info: host.iobroker instance system.adapter.hmip.0 terminated with code null ()
            2023-10-21 09:00:40.369  - warn: host.iobroker instance system.adapter.web.0 terminated due to SIGTERM
            2023-10-21 09:00:40.369  - info: host.iobroker instance system.adapter.web.0 terminated with code null ()
            2023-10-21 09:00:40.402  - info: host.iobroker instance system.adapter.socketio.0 terminated with code 0 (NO_ERROR)
            2023-10-21 09:00:40.628  - warn: host.iobroker instance system.adapter.javascript.0 terminated due to SIGTERM
            2023-10-21 09:00:40.628  - info: host.iobroker instance system.adapter.javascript.0 terminated with code null ()
            2023-10-21 09:00:40.662  - info: host.iobroker instance system.adapter.influxdb.0 terminated with code 0 (NO_ERROR)
            2023-10-21 09:00:40.828  - info: host.iobroker instance system.adapter.history.0 terminated with code 0 (NO_ERROR)
            2023-10-21 09:00:40.829  - info: host.iobroker All instances are stopped.
            2023-10-21 09:00:41.037  - info: host.iobroker terminated
              @klaus88
              cd /opt/iobroker
              sudo -H -u iobroker npm install iobroker.js-controller
                @thomas-braun sagte in iobroker diagnostics/node:
                Meldung war:
                up to date in 9s
                117 packages are looking for funding
                  run `npm fund` for details
                npm fund brachte folgendes Ergebnis:
                pi@iobroker:/opt/iobroker $ npm fund
                iobroker.inst@3.0.0
                ├── https://github.com/sponsors/jaredhanson
                │   └── passport@0.6.0
                ├── https://github.com/sponsors/isaacs
                │   └── glob@9.2.1, minimatch@7.4.2, path-scurry@1.6.1, minimatch@7.4.6, rimraf@3.0.2, glob@7.2.3
                ├── https://github.com/sponsors/feross
                │   └── safe-buffer@5.2.1, base64-js@1.5.1, simple-concat@1.0.1, buffer@5.7.1, ieee754@1.2.1
                ├── https://github.com/sponsors/RubenVerborgh
                │   └── follow-redirects@1.15.2
                ├── https://github.com/sponsors/ljharb
                │   └── qs@6.11.0, side-channel@1.0.4, call-bind@1.0.2, get-intrinsic@1.2.0, has-symbols@1.0.3, object-inspect@1.12.3, resolve@1.22.1, is-core-module@2.11.0, supports-preserve-symlinks-flag@1.0.0, object.assign@4.1.4, define-properties@1.2.0, has-property-descriptors@1.0.0, minimist@1.2.8, is-nan@1.3.2, es-abstract@1.21.2, array-buffer-byte-length@1.0.0, available-typed-arrays@1.0.5, es-to-primitive@1.2.1, is-date-object@1.0.5, is-symbol@1.0.4, function.prototype.name@1.1.5, functions-have-names@1.2.3, get-symbol-description@1.0.0, globalthis@1.0.3, gopd@1.0.1, has-proto@1.0.1, is-array-buffer@3.0.2, is-callable@1.2.7, is-negative-zero@2.0.2, is-regex@1.1.4, is-shared-array-buffer@1.0.2, is-string@1.0.7, is-typed-array@1.1.10, is-weakref@1.0.2, regexp.prototype.flags@1.5.0, safe-regex-test@1.0.0, string.prototype.trim@1.2.7, string.prototype.trimend@1.0.6, string.prototype.trimstart@1.0.6, typed-array-length@1.0.4, unbox-primitive@1.0.2, has-bigints@1.0.2, which-boxed-primitive@1.0.2, is-bigint@1.0.4, is-boolean-object@1.1.2, is-number-object@1.0.7, which-typed-array@1.1.10, has-tostringtag@1.0.0
                ├── https://github.com/sponsors/sindresorhus
                │   └── is-stream@2.0.1, decompress-response@6.0.0, mimic-response@3.1.0, get-stream@6.0.1, lowercase-keys@3.0.0, responselike@3.0.0, mimic-response@4.0.0, normalize-url@8.0.0, quick-lru@5.1.1, make-dir@3.1.0, mimic-response@2.1.0, delay@5.0.0, onetime@5.1.2
                ├─┬ https://github.com/sindresorhus/got?sponsor=1
                │ │ └── got@12.6.0
                │ └── https://github.com/sindresorhus/is?sponsor=1
                │     └── @sindresorhus/is@5.6.0
                ├── https://github.com/sponsors/epoberezkin
                │   └── ajv@6.12.6
                ├── https://paypal.me/naturalintelligence
                │   └── fast-xml-parser@4.3.0
                ├─┬ https://opencollective.com/node-fetch
                │ │ └── node-fetch@3.3.2
                │ └── https://github.com/sponsors/jimmywarting
                │     └── fetch-blob@3.2.0, node-domexception@1.0.0
                ├── https://opencollective.com/serialport/donate
                │   └── serialport@11.0.1, @serialport/parser-byte-length@11.0.1, @serialport/parser-cctalk@11.0.1, @serialport/parser-inter-byte-timeout@11.0.1, @serialport/parser-readline@11.0.1, @serialport/parser-ready@11.0.1, @serialport/parser-regex@11.0.1, @serialport/parser-slip-encoder@11.0.1, @serialport/parser-spacepacket@11.0.1, @serialport/bindings-cpp@11.0.3, @serialport/parser-readline@11.0.0, @serialport/parser-delimiter@11.0.0, @serialport/parser-delimiter@11.0.1, @serialport/stream@11.0.1
                ├── https://tidelift.com/funding/github/npm/loglevel
                │   └── loglevel@1.8.1
                ├── https://www.buymeacoffee.com/systeminfo
                │   └── systeminformation@5.21.9
                ├── https://opencollective.com/ioredis
                │   └── ioredis@4.28.5
                ├── https://github.com/sindresorhus/execa?sponsor=1
                │   └── execa@5.1.1
                ├─┬ https://paulmillr.com/funding/
                │ │ └── chokidar@3.5.3
                │ └── https://github.com/sponsors/jonschlinkert
                │     └── picomatch@2.3.1
                ├─┬ https://github.com/chalk/wrap-ansi?sponsor=1
                │ │ └── wrap-ansi@7.0.0
                │ └── https://github.com/chalk/ansi-styles?sponsor=1
                │     └── ansi-styles@4.3.0
                └── https://github.com/sponsors/sibiraj-s
                    └── ci-info@3.8.0
                iobroker hat bei start gleiche Fehlermeldung
                  @klaus88
                  Installier es neu.
                    Alles klar - Danke vielmals für deine Hilfe! (vor allem um diese Uhrzeit!!) - Schönes Wochenende!
                    lg
                    Klaus
                    node.js
