    4. Zigbee Adapter startet nicht mehr
      anselra last edited by anselra
      Systemdata Bitte Ausfüllen
      Hardwaresystem: Pi4
      Arbeitsspeicher: 4GB
      Festplattenart: SSD
      Betriebssystem: Raspberry PI OS Lite 32 Bookworm
      Node-Version: v18.18.2
      Nodejs-Version: v18.18.2
      NPM-Version: 9.8.1
      Image genutzt: Nein
      ``zigbee.0
      2023-10-21 18:36:14.689	error	Error herdsman start
      zigbee.0
      2023-10-21 18:36:14.689	error	Failed to start Zigbee
      zigbee.0
      2023-10-21 18:36:14.688	error	Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
      zigbee.0
      2023-10-21 18:36:14.382	info	Installed Version: ioBroker/ioBroker.zigbee#e233808d509f6fc4ddb3176d79633f4492146a83
      zigbee.0
      2023-10-21 18:36:14.341	debug	Starting zigbee-herdsman...
      zigbee.0
      2023-10-21 18:36:14.331	info	Starting Zigbee npm ...
      zigbee.0
      2023-10-21 18:36:14.329	info	Try to reconnect. 1 attempts left
      zigbee.0
      2023-10-21 18:36:04.327	error	Error herdsman start
      zigbee.0
      2023-10-21 18:36:04.326	error	Failed to start Zigbee
      zigbee.0
      2023-10-21 18:36:04.326	error	Starting zigbee-herdsman problem : "Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)"
      zigbee.0
      2023-10-21 18:35:44.357	debug	Backup /opt/iobroker/iobroker-data/zigbee_0/backup_2023_10_21-18_35_43.tar.gz success
      zigbee.0
      2023-10-21 18:35:43.926	info	Installed Version: ioBroker/ioBroker.zigbee#e233808d509f6fc4ddb3176d79633f4492146a83
      zigbee.0
      2023-10-21 18:35:43.625	debug	Starting zigbee-herdsman...
      zigbee.0
      2023-10-21 18:35:43.576	info	Starting Zigbee npm ...
      zigbee.0
      2023-10-21 18:35:43.463	debug	Using zigbee-herdsman with settings: {"network":{"panID":6754,"channelList":[11],"networkKey":[1,3,5,7,9,11,13,15,0,2,4,6,8,10,12,13],"extenedPanID":[221,221,221,221,221,221,221,221]},"databasePath":"/opt/iobroker/iobroker-data/zigbee_0/shepherd.db","backupPath":"/opt/iobroker/iobroker-data/zigbee_0/nvbackup.json","serialPort":{"baudRate":115200,"rtscts":false,"path":"/dev/serial/by-id/usb-Texas_Instruments_XDS110__03.00.00.15__Embed_with_CMSIS-DAP_L1100GZZ-if03","adapter":"zstack"},"adapter":{"forceStartWithInconsistentAdapterConfiguration":false}}
      zigbee.0
      2023-10-21 18:35:43.393	info	starting. Version 1.8.24 (non-npm: ioBroker/ioBroker.zigbee#e233808d509f6fc4ddb3176d79633f4492146a83) in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.18.2, js-controller: 5.0.12
      zigbee.0
      2023-10-21 18:35:43.067	info	Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
      zigbee.0
      2023-10-21 18:35:43.058	debug	Plugin sentry Initialize Plugin (enabled=true)
      zigbee.0
      2023-10-21 18:35:42.465	debug	States connected to redis: 127.0.0.1:9000
      zigbee.0
      2023-10-21 18:35:42.235	debug	States create User PubSub Client
      zigbee.0
      2023-10-21 18:35:42.234	debug	States create System PubSub Client
      zigbee.0
      2023-10-21 18:35:42.064	debug	Redis States: Use Redis connection: 127.0.0.1:9000
      zigbee.0
      2023-10-21 18:35:41.875	debug	Objects connected to redis: 127.0.0.1:9001
      zigbee.0
      2023-10-21 18:35:41.867	debug	Objects client initialize lua scripts
      zigbee.0
      2023-10-21 18:35:41.571	debug	Objects create User PubSub Client
      zigbee.0
      2023-10-21 18:35:41.570	debug	Objects create System PubSub Client
      zigbee.0
      2023-10-21 18:35:41.567	debug	Objects client ready ... initialize now
      zigbee.0
      2023-10-21 18:35:41.421	debug	Redis Objects: Use Redis connection: 127.0.0.1:9001`
      code_text
      Hallo zusammen, leider bin ich in der Suche nicht fündig geworden. Ich habe das System neu aufgesetzt und zurück gesichert, leider wird mein Zigbee Adapter nicht mehr grün. Hoffe ich habe alle Angaben gemacht und jemand hat einen Tipp für mich.
      Gruß Ralf
      Thomas Braun ? 2 Replies Last reply Reply Quote 0
        Thomas Braun Most Active @anselra last edited by
        @anselra
        Und mit welcher Meldung im Log startet der Adapter nicht mehr?
          anselra @Thomas Braun last edited by
          @thomas-braun sorry du warst zu schnell ich war noch am bearbeiten des Posts ✌
            @anselra
            Zieh den Stick raus, warte 1 Minute, steck den wieder rein.
            Sprichst du den über /dev/serial/by-id an?
              anselra @Thomas Braun last edited by anselra
              ja genau mit /dev/serial/by-id/usb-Texas_Instruments_XDS110__03.00.00.15__Embed_with_CMSIS-DAP_L1100GZZ-if03
              raus, warten rein hat leider nichts gebracht. Einzig was anders sein dürfte ist die Kombination npm und node
              Thomas Braun J 2 Replies Last reply Reply Quote 0
                @anselra sagte in Zigbee Adapter startet nicht mehr:
                Was meinst du damit?
                  dadurch, dass ich das System neu aufgesetzt habe denke ich habe ich jetzt die aktuellste Version und bin mir nicht sicher ob es vorher auch schon so war
                    @anselra
                    Mit nodejs und npm hat das aber auch nix zu tun, da wird der Stick bzw. dessen Geräte-Datei nicht erreicht.
                      vvlt noch zu erwähnen ist, dass auch pivccu auf dem selben pi läuft mit RPI-RF-Modul.
                      War aber auch auf dem Alten System so, dürfte aber auch nicht relevant sein
                        Jaksa @anselra last edited by
                        @anselra said in Zigbee Adapter startet nicht mehr:
                        Was wird dir angezeigt wenn du dir die Geräte mit "ls -l /dev/serial/by-id/" ausgeben lässt?
                          anselra @Jaksa last edited by
                          @jaksa
                          pi@iobroker:~ $ ls -l /dev/serial/by-id/
                          total 0
                          lrwxrwxrwx 1 root root 13 Oct 21 19:34 usb-Texas_Instruments_XDS110__03.00.00.15__Embed_with_CMSIS-DAP_L1100GZZ-if00 -> ../../ttyACM0
                          lrwxrwxrwx 1 root root 13 Oct 21 19:34 usb-Texas_Instruments_XDS110__03.00.00.15__Embed_with_CMSIS-DAP_L1100GZZ-if03 -> ../../ttyACM1
                          bringt nur den Zigbee Chip
                          ? 1Topf 2 Replies Last reply Reply Quote 0
                            A Former User @anselra last edited by A Former User
                            Moin,
                            bist Du sicher, dass es die 03 am Ende ist, nicht doch die 00?
                            VG
                            Bernd
                            P.S.: hier mal der Auzug von zigbee2mqtt
                            Which port should I use for Texas Instruments LAUNCHXL-CC26X2R1/CC1352P-2, /dev/ttyACM0 or /dev/ttyACM1?
                            The Texas Instruments launchpad has a build in debugger. This debugger also registers a port next to the device data port. Of course this is not necessarily number 0 and 1. But normally the lowest number is the device data port and the other the debugger.
                            To find the correct port, execute:
                            pi@raspberry:/ $ ls -l /dev/serial/by-id
                            total 0
                            lrwxrwxrwx 1 root root 13 Jan  6 19:07 usb-Texas_Instruments_XDS110__03.00.00.05__Embed_with_CMSIS-DAP_L1100BTD-if00 -> ../../ttyACM0
                            lrwxrwxrwx 1 root root 13 Jan  6 19:07 usb-Texas_Instruments_XDS110__03.00.00.05__Embed_with_CMSIS-DAP_L1100BTD-if03 -> ../../ttyACM1
                            The device with id ending with if00 is for device data. Use this port in your configuration.
                              anselra @Guest last edited by
                              @dp20eic
                              hab nochmal nachgeschaut,
                              mein com Anschlussname ist /dev/serial/by-id/usb-Texas_Instruments_XDS110__03.00.00.15__Embed_with_CMSIS-DAP_L1100GZZ-if03
                              J ? 2 Replies Last reply Reply Quote 0
                                @anselra
                                Das ist laut Doku der falsche. Ändere die 03 am Ende mal in 00 um.
                                  Moin,
                                  ja und was habe ich geschrieben, das Du mal den 00 nehmen sollst, sogar mit Erklärung 😉
                                  VG
                                  Bernd
                                    @jaksa
                                    leider das selbe Resultat
                                    zigbee.0
                                    2023-10-21 20:25:46.135	error	Error herdsman start
                                    zigbee.0
                                    2023-10-21 20:25:46.135	error	Failed to start Zigbee
                                    zigbee.0
                                    2023-10-21 20:25:46.134	error	Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: Device or resource busy, cannot open /dev/serial/by-id/usb-Texas_Instruments_XDS110__03.00.00.15__Embed_with_CMSIS-DAP_L1100GZZ-if00'"
                                    zigbee.0
                                    2023-10-21 20:25:45.862	info	Installed Version: ioBroker/ioBroker.zigbee#e233808d509f6fc4ddb3176d79633f4492146a83
                                    zigbee.0
                                    2023-10-21 20:25:45.817	debug	Starting zigbee-herdsman...
                                    zigbee.0
                                    2023-10-21 20:25:45.809	info	Starting Zigbee npm ...
                                    zigbee.0
                                    2023-10-21 20:25:45.807	info	Try to reconnect. 1 attempts left
                                    zigbee.0
                                    2023-10-21 20:25:35.806	error	Error herdsman start
                                    zigbee.0
                                    2023-10-21 20:25:35.806	error	Failed to start Zigbee
                                    zigbee.0
                                    2023-10-21 20:25:35.805	error	Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: Device or resource busy, cannot open /dev/serial/by-id/usb-Texas_Instruments_XDS110__03.00.00.15__Embed_with_CMSIS-DAP_L1100GZZ-if00'"
                                    zigbee.0
                                    2023-10-21 20:25:35.540	debug	Backup /opt/iobroker/iobroker-data/zigbee_0/backup_2023_10_21-20_25_34.tar.gz success
                                    zigbee.0
                                    2023-10-21 20:25:35.537	info	Installed Version: ioBroker/ioBroker.zigbee#e233808d509f6fc4ddb3176d79633f4492146a83
                                    zigbee.0
                                    2023-10-21 20:25:35.180	debug	Starting zigbee-herdsman...
                                    zigbee.0
                                    2023-10-21 20:25:34.788	info	Starting Zigbee npm ...
                                    zigbee.0
                                    2023-10-21 20:25:34.785	info	delete old Backup files. keep only last 10
                                    zigbee.0
                                    2023-10-21 20:25:34.689	debug	Using zigbee-herdsman with settings: {"network":{"panID":6754,"channelList":[11],"networkKey":[1,3,5,7,9,11,13,15,0,2,4,6,8,10,12,13],"extenedPanID":[221,221,221,221,221,221,221,221]},"databasePath":"/opt/iobroker/iobroker-data/zigbee_0/shepherd.db","backupPath":"/opt/iobroker/iobroker-data/zigbee_0/nvbackup.json","serialPort":{"baudRate":115200,"rtscts":false,"path":"/dev/serial/by-id/usb-Texas_Instruments_XDS110__03.00.00.15__Embed_with_CMSIS-DAP_L1100GZZ-if00","adapter":"zstack"},"adapter":{"forceStartWithInconsistentAdapterConfiguration":false}}
                                    zigbee.0
                                    2023-10-21 20:25:34.630	info	starting. Version 1.8.24 (non-npm: ioBroker/ioBroker.zigbee#e233808d509f6fc4ddb3176d79633f4492146a83) in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.18.2, js-controller: 5.0.12
                                    zigbee.0
                                    2023-10-21 20:25:34.336	info	Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
                                    zigbee.0
                                    2023-10-21 20:25:34.322	debug	Plugin sentry Initialize Plugin (enabled=true)
                                    zigbee.0
                                    2023-10-21 20:25:33.741	debug	States connected to redis: 127.0.0.1:9000
                                    zigbee.0
                                    2023-10-21 20:25:33.479	debug	States create User PubSub Client
                                    zigbee.0
                                    2023-10-21 20:25:33.478	debug	States create System PubSub Client
                                    zigbee.0
                                    2023-10-21 20:25:33.368	debug	Redis States: Use Redis connection: 127.0.0.1:9000
                                    zigbee.0
                                    2023-10-21 20:25:33.126	debug	Objects connected to redis: 127.0.0.1:9001
                                    zigbee.0
                                    2023-10-21 20:25:33.117	debug	Objects client initialize lua scripts
                                    zigbee.0
                                    2023-10-21 20:25:32.802	debug	Objects create User PubSub Client
                                    zigbee.0
                                    2023-10-21 20:25:32.800	debug	Objects create System PubSub Client
                                    zigbee.0
                                    2023-10-21 20:25:32.798	debug	Objects client ready ... initialize now
                                    zigbee.0
                                    2023-10-21 20:25:32.639	debug	Redis Objects: Use Redis connection: 127.0.0.1:9001
                                      Jaksa @anselra last edited by Jaksa
                                      @anselra
                                      Naja jetzt sieht es so aus als wäre das Gerät bereits in Benutzung durch was auch immer. Das war vorhin noch nicht der Fall.
                                      Versuch nochmal den Stick aus und wieder einzustecken bzw. die ganze Kiste einmal neu zu starten wenn ersteres nicht hilft.
                                      • 1Topf
                                        1Topf @anselra last edited by
                                        @jaksa
                                        total 0
                                        Wieso bringt es den denn 2mal? Der sollte dort nur 1mal auftauchen, da er ja auch nur 1mal drin steckt.
                                          Thomas Braun Most Active @1Topf last edited by
                                          @1topf sagte in Zigbee Adapter startet nicht mehr:
                                          Der Stick hat zwei Interfaces.
                                          lsof /dev/ttyACM0
                                          sagt? (lsof muss ggf. noch installiert werden)
                                            @jaksa
                                            Neustart erfolgt, leider immer noch nicht grün
                                            zigbee.0
                                            2023-10-21 20:47:46.819	error	Error herdsman start
                                            zigbee.0
                                            2023-10-21 20:47:46.819	error	Failed to start Zigbee
                                            zigbee.0
                                            2023-10-21 20:47:46.817	error	Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: Device or resource busy, cannot open /dev/serial/by-id/usb-Texas_Instruments_XDS110__03.00.00.15__Embed_with_CMSIS-DAP_L1100GZZ-if00'"
                                            zigbee.0
                                            2023-10-21 20:47:46.274	info	Installed Version: ioBroker/ioBroker.zigbee#e233808d509f6fc4ddb3176d79633f4492146a83
                                            zigbee.0
                                            2023-10-21 20:47:46.220	debug	Starting zigbee-herdsman...
                                            zigbee.0
                                            2023-10-21 20:47:39.042	info	Starting Zigbee npm ...
                                            zigbee.0
                                            2023-10-21 20:47:39.041	info	Try to reconnect. 1 attempts left
                                            zigbee.0
                                            2023-10-21 20:47:29.038	error	Error herdsman start
                                            zigbee.0
                                            2023-10-21 20:47:29.037	error	Failed to start Zigbee
                                            zigbee.0
                                            2023-10-21 20:47:29.035	error	Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: Device or resource busy, cannot open /dev/serial/by-id/usb-Texas_Instruments_XDS110__03.00.00.15__Embed_with_CMSIS-DAP_L1100GZZ-if00'"
                                            zigbee.0
                                            2023-10-21 20:47:28.177	info	Installed Version: ioBroker/ioBroker.zigbee#e233808d509f6fc4ddb3176d79633f4492146a83
                                            zigbee.0
                                            2023-10-21 20:47:27.582	debug	Starting zigbee-herdsman...
                                            zigbee.0
                                            2023-10-21 20:47:27.317	debug	Backup /opt/iobroker/iobroker-data/zigbee_0/backup_2023_10_21-20_47_27.tar.gz success
                                            zigbee.0
                                            2023-10-21 20:47:27.253	info	Starting Zigbee npm ...
                                            zigbee.0
                                            2023-10-21 20:47:27.239	info	delete old Backup files. keep only last 10
                                            zigbee.0
                                            2023-10-21 20:47:27.126	debug	Using zigbee-herdsman with settings: {"network":{"panID":6754,"channelList":[11],"networkKey":[1,3,5,7,9,11,13,15,0,2,4,6,8,10,12,13],"extenedPanID":[221,221,221,221,221,221,221,221]},"databasePath":"/opt/iobroker/iobroker-data/zigbee_0/shepherd.db","backupPath":"/opt/iobroker/iobroker-data/zigbee_0/nvbackup.json","serialPort":{"baudRate":115200,"rtscts":false,"path":"/dev/serial/by-id/usb-Texas_Instruments_XDS110__03.00.00.15__Embed_with_CMSIS-DAP_L1100GZZ-if00","adapter":"zstack"},"adapter":{"forceStartWithInconsistentAdapterConfiguration":false}}
                                            zigbee.0
                                            2023-10-21 20:47:26.997	info	starting. Version 1.8.24 (non-npm: ioBroker/ioBroker.zigbee#e233808d509f6fc4ddb3176d79633f4492146a83) in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.18.2, js-controller: 5.0.12
                                            3154
