    4. Javascript Adapter starten nicht mehr
      rascal @michihorn last edited by rascal
      Hardwaresystem: Pi4
      Arbeitsspeicher: 8GB
      Festplattenart: SD-Karte
      Betriebssystem: Raspberrymatic
      Node-Version: 18.13.0
      Nodejs-Version: 18.13.0
      NPM-Version: 9.2.0
      Installationsart: Skript
      Image genutzt: Nein
      Guten Morgen,
      seit gestern funktionieren bei mir meine beiden Javascript-instanzen nicht mehr. Die Adapter lassen sich nicht starten und schreiben mir im Log:
      host.iobroker
      2023-10-22 10:12:29.234	info	system.adapter.javascript.1 will be rebuilt
      host.iobroker
      2023-10-22 10:12:29.234	info	Adapter system.adapter.javascript.1 needs rebuild and will be restarted afterwards.
      host.iobroker
      2023-10-22 10:12:29.233	error	instance system.adapter.javascript.1 terminated with code 1 (JS_CONTROLLER_STOPPED)
      host.iobroker
      2023-10-22 10:12:29.233	error	Caught by controller[0]: Node.js v18.13.0
      host.iobroker
      2023-10-22 10:12:29.232	error	Caught by controller[0]: }
      host.iobroker
      2023-10-22 10:12:29.232	error	Caught by controller[0]: ]
      host.iobroker
      2023-10-22 10:12:29.232	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.javascript/main.js'
      host.iobroker
      2023-10-22 10:12:29.232	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/index.js',
      host.iobroker
      2023-10-22 10:12:29.231	error	Caught by controller[0]: requireStack: [
      host.iobroker
      2023-10-22 10:12:29.231	error	Caught by controller[0]: code: 'MODULE_NOT_FOUND',
      host.iobroker
      2023-10-22 10:12:29.230	error	Caught by controller[0]: {
      host.iobroker
      2023-10-22 10:12:29.230	error	Caught by controller[0]: at node:internal/main/run_main_module:23:47
      host.iobroker
      2023-10-22 10:12:29.229	error	Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:81:12)
      host.iobroker
      2023-10-22 10:12:29.229	error	Caught by controller[0]: at Function.Module._load (node:internal/modules/cjs/loader:922:12)
      host.iobroker
      2023-10-22 10:12:29.229	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1081:32)
      host.iobroker
      2023-10-22 10:12:29.228	error	Caught by controller[0]: at Object.Module._extensions..js (node:internal/modules/cjs/loader:1272:10)
      host.iobroker
      2023-10-22 10:12:29.228	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1218:14)
      host.iobroker
      2023-10-22 10:12:29.228	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/main.js:47:23)
      host.iobroker
      2023-10-22 10:12:29.228	error	Caught by controller[0]: at require (node:internal/modules/cjs/helpers:103:18)
      host.iobroker
      2023-10-22 10:12:29.227	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1105:19)
      host.iobroker
      2023-10-22 10:12:29.227	error	Caught by controller[0]: at Function.Module._load (node:internal/modules/cjs/loader:922:12)
      host.iobroker
      2023-10-22 10:12:29.227	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1081:32)
      host.iobroker
      2023-10-22 10:12:29.226	error	Caught by controller[0]: at Object.Module._extensions..js (node:internal/modules/cjs/loader:1272:10)
      host.iobroker
      2023-10-22 10:12:29.226	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1218:14)
      host.iobroker
      2023-10-22 10:12:29.226	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/index.js:3:83)
      host.iobroker
      2023-10-22 10:12:29.225	error	Caught by controller[0]: at require (node:internal/modules/cjs/helpers:103:18)
      host.iobroker
      2023-10-22 10:12:29.225	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1105:19)
      host.iobroker
      2023-10-22 10:12:29.225	error	Caught by controller[0]: at Function.Module._load (node:internal/modules/cjs/loader:885:27)
      host.iobroker
      2023-10-22 10:12:29.225	error	Caught by controller[0]: at Function.Module._resolveFilename (node:internal/modules/cjs/loader:1039:15)
      host.iobroker
      2023-10-22 10:12:29.224	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.javascript/main.js
      host.iobroker
      2023-10-22 10:12:29.224	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/index.js
      host.iobroker
      2023-10-22 10:12:29.224	error	Caught by controller[0]: Require stack:
      host.iobroker
      2023-10-22 10:12:29.223	error	Caught by controller[0]: Error: Cannot find module './lib/schedule'
      host.iobroker
      2023-10-22 10:12:29.223	error	Caught by controller[0]: ^
      host.iobroker
      2023-10-22 10:12:29.222	error	Caught by controller[0]: throw err;
      host.iobroker
      2023-10-22 10:12:29.221	error	Caught by controller[0]: node:internal/modules/cjs/loader:1042
      host.iobroker
      2023-10-22 10:13:39.345	info	iobroker npm-rebuild: exit 1
      host.iobroker
      2023-10-22 10:13:38.302	error	iobroker npm-rebuild: Rebuilding native modules failed
      Ich habe schon folgendes versucht:
      rascal@iobroker:/opt/iobroker/node_modules/iobroker.javascript$ npm install  --production
      [sudo] password for rascal:
      npm WARN config production Use `--omit=dev` instead.
      npm ERR! code ENOTEMPTY
      npm ERR! syscall rename
      npm ERR! path /opt/iobroker/node_modules/iobroker.javascript/node_modules/acorn-globals
      npm ERR! dest /opt/iobroker/node_modules/iobroker.javascript/node_modules/.acorn-globals-Va5HVenm
      npm ERR! errno -39
      npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/iobroker.javascript/node_modules/acorn-globals' -> '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.acorn-globals-Va5HVenm'
      npm ERR!     /home/iobroker/.npm/_logs/2023-10-22T07_54_56_618Z-debug-0.log
      und
      rascal@iobroker:/opt/iobroker/node_modules/iobroker.javascript$ sudo npm install --omit=dev
      npm ERR! errno -39
      npm ERR!     /root/.npm/_logs/2023-10-22T08_01_46_368Z-debug-0.log
      und
      iob rebuild javascript
      iob fix
      hat alles nichts gebracht... bitte Hilfe 😢
        Homoran Global Moderator Administrators @rascal last edited by
        @rascal ich habe das mal von dem 3 1/2 Jahre alten Thread abgespalten.
        Ich glaube nicht, dass du mit controller v2 arbeitest.
        bitte entsprechende Informationen liefern und Threadtitel anpassen
          rascal @Homoran last edited by rascal
          Danke, habe ich versucht, er hat mich aber keinen neuen Thread anlegen lassen...
          Ich spiele gerade ein Backup ein, melde mich ob's wieder funktioniert
            Thomas Braun Most Active @rascal last edited by Thomas Braun
            @rascal
            Nodejs 18.13.0 ist 100% falsch.
            Mittels
            iob nodejs-update
            die aktuelle nodesource-Version einspielen.
            Und npm NICHT mit sudo einleiten, am besten gar nicht verwenden.
            javascript adapter rot
