    4. Shuttercontrol keine Astrowerte [gelöst]
      Achim Wirtz last edited by Achim Wirtz
      mein erster Post, hoffe ich mach das nun halbwegs korrekt.
      Anscheinend bekommt Shuttercontrol keine Astrowerte, Logauszug:
      2023-10-22 15:28:21.181 - info: admin.0 (4337) ==> Connected system.user.admin from ::ffff:192.168.10.20
      2023-10-22 15:28:45.563 - info: host.maschinenraum stopInstance system.adapter.shuttercontrol.0 (force=false, process=true)
      2023-10-22 15:28:45.576 - info: host.maschinenraum stopInstance system.adapter.shuttercontrol.0 send kill signal
      2023-10-22 15:28:45.577 - info: shuttercontrol.0 (4999) Got terminate signal TERMINATE_YOURSELF
      2023-10-22 15:28:45.580 - info: shuttercontrol.0 (4999) cleaned everything up...
      2023-10-22 15:28:45.583 - info: shuttercontrol.0 (4999) terminating
      2023-10-22 15:28:45.586 - debug: shuttercontrol.0 (4999) Plugin sentry destroyed
      2023-10-22 15:28:45.588 - info: shuttercontrol.0 (4999) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2023-10-22 15:28:46.092 - info: shuttercontrol.0 (4999) terminating
      2023-10-22 15:28:46.201 - info: host.maschinenraum instance system.adapter.shuttercontrol.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-10-22 15:28:48.666 - info: host.maschinenraum instance system.adapter.shuttercontrol.0 started with pid 7517
      2023-10-22 15:28:51.598 - debug: shuttercontrol.0 (7517) Redis Objects: Use Redis connection: 0.0.0.0:6379
      2023-10-22 15:28:51.677 - debug: shuttercontrol.0 (7517) Objects client ready ... initialize now
      2023-10-22 15:28:51.682 - debug: shuttercontrol.0 (7517) Objects create System PubSub Client
      2023-10-22 15:28:51.686 - debug: shuttercontrol.0 (7517) Objects create User PubSub Client
      2023-10-22 15:28:52.139 - debug: shuttercontrol.0 (7517) Objects client initialize lua scripts
      2023-10-22 15:28:52.175 - debug: shuttercontrol.0 (7517) Objects connected to redis: 0.0.0.0:6379
      2023-10-22 15:28:52.220 - debug: shuttercontrol.0 (7517) Redis States: Use Redis connection: 0.0.0.0:6379
      2023-10-22 15:28:52.237 - debug: shuttercontrol.0 (7517) States create System PubSub Client
      2023-10-22 15:28:52.240 - debug: shuttercontrol.0 (7517) States create User PubSub Client
      2023-10-22 15:28:52.262 - debug: shuttercontrol.0 (7517) States connected to redis: 0.0.0.0:6379
      2023-10-22 15:28:52.336 - debug: shuttercontrol.0 (7517) Plugin sentry Initialize Plugin (enabled=true)
      2023-10-22 15:28:53.753 - info:
      shuttercontrol.0 (7517) starting. Version 1.6.2 in
      /opt/iobroker/node_modules/iobroker.shuttercontrol, node: v18.18.2,
      js-controller: 5.0.14
      2023-10-22 15:28:53.825 - debug: shuttercontrol.0 (7517) shutter Config Check started
      2023-10-22 15:28:53.827 - debug: shuttercontrol.0 (7517) shutter Config Check successfully completed
      2023-10-22 15:28:53.840 - debug: shuttercontrol.0 (7517) Shutter State: alias.0.Erdgeschoss.Wohnzimmer.Rolladen.Rollade_Wohnzimmer.Position
      2023-10-22 15:28:53.842 - warn: shuttercontrol.0 (7517) system settings cannot be called up. Please check configuration!
      2023-10-22 15:28:53.935 - debug: shuttercontrol.0 (7517) Wohnzimmer: save settings
      2023-10-22 15:28:57.182 - debug: shuttercontrol.0 (7517) Travel times of the shutters are calculated
      2023-10-22 15:28:57.186 - debug: shuttercontrol.0 (7517) calculate astrodata ...
      2023-10-22 15:28:57.188 - debug: shuttercontrol.0 (7517) goldenHourEnd today: aN:aN
      2023-10-22 15:28:57.190 - debug: shuttercontrol.0 (7517) goldenHour today: aN:aN
      2023-10-22 15:28:57.191 - debug: shuttercontrol.0 (7517) current day: NaN
      2023-10-22 15:28:57.193 - debug: shuttercontrol.0 (7517) Sunrise today: aN:aN
      2023-10-22 15:28:57.194 - debug: shuttercontrol.0 (7517) Sunset today: aN:aN
      2023-10-22 15:28:57.196 - debug: shuttercontrol.0 (7517) Starting up shutters GoldenHour area: 00:NaN
      2023-10-22 15:28:57.197 - debug: shuttercontrol.0 (7517) Shutdown shutters GoldenHour area: 00:NaN
      2023-10-22 15:28:57.197 - debug: shuttercontrol.0 (7517) Starting up shutters Sunrise area: 00:NaN
      2023-10-22 15:28:57.198 - debug: shuttercontrol.0 (7517) Shutdown shutters Sunset area: 00:NaN
      2023-10-22 15:28:57.204 - debug: shuttercontrol.0 (7517) Starting up shutters living area: undefined debug 0
      2023-10-22 15:28:57.215 - debug: shuttercontrol.0 (7517) Starting up shutters sleep area: undefined debug 0
      2023-10-22 15:28:57.236 - debug: shuttercontrol.0 (7517) Starting up shutters children area: undefined debug 0
      2023-10-22 15:28:57.263 - debug: shuttercontrol.0 (7517) Shutdown shutters living area: undefined debug 0
      2023-10-22 15:28:57.265 - debug: shuttercontrol.0 (7517) shutterDownLiving
      2023-10-22 15:28:57.271 - debug: shuttercontrol.0 (7517) Shutdown shutters children area: undefined debug 0
      2023-10-22 15:28:57.277 - debug: shuttercontrol.0 (7517) Shutdown shutters sleep area: undefined debug 0
      2023-10-22 15:28:57.284 - debug: shuttercontrol.0 (7517) complete down at 22:00
      Was mache ich falsch?
      OS: ubuntu 22.04
      Architektur: arm64
      Node.js: v18.18.2
      NPM: 9.8.1
      Repo: beta
      McFlyers
        paul53 @Achim Wirtz last edited by
        @mcflyers
        Sind die Ortskoordinaten in den Systemeinstellungen eingetragen?
          Achim Wirtz @paul53 last edited by
          @paul53 Ja, ich hatte Astrosteuerung mit Blockly schon am laufen.
            paul53 @Achim Wirtz last edited by paul53
            @mcflyers sagte: ich hatte Astrosteuerung mit Blockly schon am laufen.
            Mit den Ortskoordinaten aus dem System oder mit in der Javascript-Instanz eingetragenen Koordinaten?
            A 2 Replies Last reply Reply Quote 0
              @paul53 Müßten die aus System sein, da ich sonst nirgendwo die Koordinaten eingetragen habe (Iob), sind aber auch in den Shellys drin ... aber die Shelly Logik läuft nicht mit, ging rein über Blockly.
                Achim Wirtz @Achim Wirtz last edited by Achim Wirtz
                @mcflyers im js-controller hab ich "Häckchen" bei Systemeinstellungen verwenden
                  @paul53 sagte in Shuttercontrol keine Astrowerte:
                  Wenn ich die Ortskoordinaten direkt in der Javascript-Instanz eintrage ändert sich auch nichts.
                    @mcflyers sagte: Wenn ich die Ortskoordinaten direkt in der Javascript-Instanz eintrage ändert sich auch nichts.
                    Die wirken auch nur auf Skripte und nicht auf "Shuttercontrol".
                      @paul53 Ok, habe grade in Shuttercontroll selber nachgeschaut dort stehen die Koordinaten aus den Systemeinstellungen drin.
                        Jetzt hab ich wieder umgestellt auf Blockly, funktioniert.
                        Leider bin ich noch nicht fit genug in iob um den Fehler selber zu finden.
                        Was mir etwas merkwürdig vorkommt ist, dass trotz der Warnung
                        die Ortskoordinaten wohl im Adapter ankommen, aber anscheinend nicht verarbeitet werden und der Adapter selbst bei reiner Zeitsteuerung ohne Astrosteuerung nicht funsen will.
                        Gibt es irgendwelche Abhängigkeiten die ich überprüfen kann?
                        Da wohl nur ich dieses Problem habe schließe ich einen Bug aus.
                        Keine Ahnung wo ich noch suchen soll 😕
                          Habe die Ortskoordinaten gelöscht und neu konfiguriert, nun sieht's gut aus aus.
                          515
