    4. iob stürzt ab und startet dann neu
    • bahnuhr
      bahnuhr Forum Testing Most Active last edited by bahnuhr
      ist mir jetzt schon öfters aufgefallen, dass iob abstürzt und dann neu startet.
      Gefühlt so 1 x täglich.
      Heute Nacht um ca. 00:17 wieder, log hab ich mal dazu gelegt.
      (log gekürzt, weil länger als 10.000 Zeichen)
      2023-10-23 00:17:08.837  - info: web.0 (1427) <== Disconnect system.user.admin from ::ffff:192.168.243.102 vis.0
      2023-10-23 00:17:09.046  - info: admin.0 (564) <== Disconnect system.user.admin from ::ffff:192.168.243.100 admin
      2023-10-23 00:17:09.056  - info: mqtt.2 (886) Client [Wemos_Sauna_Klima] reconnected. Old secret 1698012110123_9718. New secret 1698013028211_1856
      2023-10-23 00:17:09.189  - info: mqtt.2 (886) Client [Wemos_Kueche_Klima] reconnected. Old secret 1698012110123_7633. New secret 1698013028540_3060
      2023-10-23 00:17:09.189  - info: mqtt.2 (886) Client [Wemos_Wohnzimmer_Klima] reconnected. Old secret 1698012111414_7033. New secret 1698013028540_8286
      2023-10-23 00:17:09.191  - info: mqtt.2 (886) Client [Wemos_Wohnzimmer_Klima] connection closed: closed
      2023-10-23 00:17:09.191  - info: mqtt.2 (886) Client [Wemos_Kueche_Klima] connection closed: closed
      2023-10-23 00:17:09.191  - info: mqtt.2 (886) Client [Wemos_Sauna_Klima] connection closed: closed
      2023-10-23 00:17:50.526  - info: admin.0 (564) <== Disconnect system.user.admin from ::ffff:192.168.243.102 admin
      2023-10-23 00:17:09.120  - info: web.0 (1427) <== Disconnect system.user.admin from ::ffff:192.168.243.109 vis.0
      2023-10-23 00:17:09.121  - info: web.0 (1427) <== Disconnect system.user.admin from ::ffff:192.168.243.100 vis.0
      2023-10-23 00:17:09.121  - info: web.0 (1427) <== Disconnect system.user.admin from ::ffff:192.168.243.122 vis.0
      2023-10-23 00:41:19.302  - error: influxdb.0 (718) States database error: read ECONNRESET
      2023-10-23 00:41:19.580  - warn: javascript.0 (602) script.js.Scripte.Geraete.Huawei: Error received reading address 37700 from id: 1 with error: undefined
      2023-10-23 00:41:19.943  - error: sql.0 (613) States database error: read ECONNRESET
      2023-10-23 00:41:20.051  - error: contact.0 (1107) States database error: write ECONNRESET
      2023-10-23 00:41:19.317  - error: imap.0 (1575) States database error: read ECONNRESET
      2023-10-23 00:41:20.876  - error: musiccast.0 (1207) States database error: write ECONNRESET
      2023-10-23 00:41:21.546  - error: web.0 (1427) States database error: write ECONNRESET
      2023-10-23 00:41:21.595  - error: admin.0 (564) States database error: write EPIPE
      2023-10-23 00:41:21.922  - error: wled.0 (50353) States database error: write ECONNRESET
      2023-10-23 00:41:21.921  - error: mihome-vacuum.0 (833) States database error: write ECONNRESET
      2023-10-23 00:41:22.018  - error: zigbee.0 (977) Objects database error: write ECONNRESET
      2023-10-23 00:41:22.557  - error: zigbee.0 (977) States database error: write EPIPE
      2023-10-23 00:41:22.730  - error: octoprint.0 (1260) States database error: write EPIPE
      2023-10-23 00:41:20.397  - error: telegram.1 (647) States database error: read ECONNRESET
      2023-10-23 00:41:21.074  - error: vis-inventwo.0 (1397) States database error: write ECONNRESET
      2023-10-23 00:41:22.834  - error: octoprint.0 (1260) Objects database error: read ECONNRESET
      2023-10-23 00:41:20.671  - error: asterisk.0 (1019) States database error: write ECONNRESET
      2023-10-23 00:41:20.296  - error: telegram.0 (632) States database error: read ECONNRESET
      2023-10-23 00:41:21.458  - error: proxmox.0 (1600) States database error: write EPIPE
      2023-10-23 00:41:20.827  - error: simple-api.0 (1334) States database error: read ECONNRESET
      2023-10-23 00:41:21.778  - error: rssfeed.0 (1457) States database error: write ECONNRESET
      2023-10-23 00:41:21.895  - error: tankerkoenig.0 (1351) States database error: write ECONNRESET
      2023-10-23 00:41:20.999  - error: openligadb.0 (1281) States database error: write ECONNRESET
      2023-10-23 00:41:23.404  - error: fritzbox.0 (736) States database error: write ECONNRESET
      2023-10-23 00:41:23.804  - error: sourceanalytix.0 (1474) States database error: write ECONNRESET
      2023-10-23 00:41:23.944  - info: sourceanalytix.0 (1474) SourceAnalytix stopped, now you have to calculate by yourself :'( ...
      2023-10-23 00:41:23.952  - error: tuya.0 (50983) States database error: write EPIPE
      2023-10-23 00:41:23.496  - error: bmw.0 (1046) States database error: write ECONNRESET
      2023-10-23 00:41:24.168  - error: hm-rega.0 (751) States database error: write ECONNRESET
      2023-10-23 00:41:24.205  - error: hm-rega.0 (751) Objects database error: read ECONNRESET
      2023-10-23 00:41:23.283  - error: parser.0 (1299) States database error: write ECONNRESET
      2023-10-23 00:41:24.021  - error: ws.0 (1442) States database error: write ECONNRESET
      2023-10-23 00:41:23.856  - error: sql.1 (681) States database error: write ECONNRESET
      2023-10-23 00:41:23.726  - error: logparser.0 (1179) States database error: write ECONNRESET
      2023-10-23 00:41:23.695  - error: mqtt.0 (871) States database error: write ECONNRESET
      2023-10-23 00:41:24.487  - info: mqtt.0 (871) Client [ROBONECT081603] connection closed: timeout
      2023-10-23 00:41:23.804  - error: libre.0 (1166) States database error: write ECONNRESET
      2023-10-23 00:41:24.620  - error: modbus.0 (856) Objects database error: write ECONNRESET
      2023-10-23 00:41:24.173  - error: bosch-ebike.0 (1073) States database error: write ECONNRESET
      2023-10-23 00:41:24.078  - error: email.0 (571) States database error: write ECONNRESET
      2023-10-23 00:41:24.379  - error: ping.0 (901) States database error: write ECONNRESET
      2023-10-23 00:41:24.913  - error: mqtt.2 (886) Objects database error: write EPIPE
      2023-10-23 00:41:24.215  - error: hm-rpc.2 (796) States database error: write ECONNRESET
      2023-10-23 00:41:24.635  - warn: modbus.0 (856) Poll error count: 1 code: "App Timeout"
      2023-10-23 00:41:24.939  - error: modbus.0 (856) States database error: write ECONNRESET
      2023-10-23 00:41:24.944  - error: modbus.0 (856) Socket Error
      2023-10-23 00:41:24.945  - error: modbus.0 (856) Client in error state.
      2023-10-23 00:41:24.945  - warn: modbus.0 (856) On error: {"errno":-104,"code":"ECONNRESET","syscall":"read"}
      2023-10-23 00:41:23.781  - error: fritzdect.0 (1160) States database error: write ECONNRESET
      2023-10-23 00:41:24.745  - error: javascript.1 (666) States database error: write ECONNRESET
      2023-10-23 00:41:25.097  - error: mqtt.2 (886) States database error: write ECONNRESET
      2023-10-23 00:41:24.443  - error: tr-064.0 (923) States database error: write ECONNRESET
      2023-10-23 00:41:25.060  - error: hm-rpc.0 (766) Objects database error: write ECONNRESET
      2023-10-23 00:41:25.428  - error: hm-rpc.0 (766) States database error: write ECONNRESET
      2023-10-23 00:41:25.193  - error: backitup.0 (990) States database error: write ECONNRESET
      2023-10-23 00:41:25.720  - error: pollenflug.0 (1316) States database error: write ECONNRESET
      2023-10-23 00:41:25.746  - error: sayit.4 (1557) States database error: write ECONNRESET
      2023-10-23 00:41:24.326  - error: yamaha.0 (959) Objects database error: write EPIPE
      2023-10-23 00:41:25.808  - error: yamaha.0 (959) States database error: write ECONNRESET
      2023-10-23 00:41:20.872  - error: viessmann.0 (1366) Timeout connection error!
      2023-10-23 00:41:25.286  - warn: viessmann.0 (1366) Reconnect time is wrong
      2023-10-23 00:41:25.824  - error: viessmann.0 (1366) States database error: write ECONNRESET
      2023-10-23 00:41:25.834  - error: sayit.3 (1535) States database error: write ECONNRESET
      2023-10-23 00:41:21.917  - info: cloud.0 (1092) Connection changed: disconnect
      2023-10-23 00:41:26.527  - error: cloud.0 (1092) States database error: write ECONNRESET
      2023-10-23 00:41:27.752  - error: sayit.2 (1492) States database error: write ECONNRESET
      2023-10-23 00:41:38.401  - info: host.iobroker iobroker.js-controller version 5.0.12 js-controller starting
      2023-10-23 00:41:38.403  - info: host.iobroker Copyright (c) 2014-2023 bluefox, 2014 hobbyquaker
      2023-10-23 00:41:38.403  - info: host.iobroker hostname: iobroker, node: v18.18.2
      2023-10-23 00:41:38.404  - info: host.iobroker ip addresses: 192.168.243.15 2a03:93e0:200:b70:8891:b1ff:fea3:66d8 fe80::8891:b1ff:fea3:66d8
      2023-10-23 00:41:46.928  - info: host.iobroker connected to Objects and States
      2023-10-23 00:41:46.985  - info: host.iobroker added notifications configuration of host
      2023-10-23 00:41:48.061  - info: host.iobroker Delete state "system.host.iobroker.versions.nodeCurrent"
      2023-10-23 00:41:48.062  - info: host.iobroker 88 instances found
      2023-10-23 00:41:48.208  - info: host.iobroker starting 72 instances
      2023-10-23 00:41:48.370  - info: host.iobroker Delete state "system.host.iobroker.versions.nodeNewest"
      2023-10-23 00:41:48.378  - info: host.iobroker Delete state "system.host.iobroker.versions.nodeNewestNext"
      2023-10-23 00:41:48.437  - info: host.iobroker instance system.adapter.admin.0 started with pid 143921
      2023-10-23 00:41:48.441  - info: host.iobroker Delete state "system.host.iobroker.versions.npmCurrent"
      2023-10-23 00:41:48.487  - info: host.iobroker Delete state "system.host.iobroker.versions.npmNewest"
      2023-10-23 00:41:48.531  - info: host.iobroker Delete state "system.host.iobroker.versions.npmNewestNext"
      2023-10-23 00:41:48.575  - info: host.iobroker Some obsolete host states deleted.
      2023-10-23 00:41:52.274  - error: admin.0 (143921) admin.0 already running
      2023-10-23 00:41:52.276  - warn: admin.0 (143921) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
      2023-10-23 00:41:52.294  - info: host.iobroker instance system.adapter.email.0 started with pid 143932
      2023-10-23 00:41:52.955  - error: host.iobroker instance system.adapter.admin.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      2023-10-23 00:41:52.955  - info: host.iobroker Restart adapter system.adapter.admin.0 because enabled
      2023-10-23 00:41:53.097  - error: email.0 (143932) email.0 already running
      2023-10-23 00:41:53.098  - warn: email.0 (143932) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
      2023-10-23 00:41:53.663  - error: host.iobroker instance system.adapter.email.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      2023-10-23 00:41:53.663  - info: host.iobroker Restart adapter system.adapter.email.0 because enabled
      2023-10-23 00:41:56.427  - info: host.iobroker instance system.adapter.javascript.0 started with pid 143943
      2023-10-23 00:42:00.355  - info: host.iobroker instance system.adapter.sql.0 started with pid 143950
      2023-10-23 00:42:02.610  - error: javascript.0 (143943) javascript.0 already running
      2023-10-23 00:42:02.611  - warn: javascript.0 (143943) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
      2023-10-23 00:42:03.105  - error: sql.0 (143950) sql.0 already running
      2023-10-23 00:42:03.106  - warn: sql.0 (143950) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
      2023-10-23 00:42:03.181  - error: host.iobroker instance system.adapter.javascript.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      2023-10-23 00:42:03.181  - info: host.iobroker Restart adapter system.adapter.javascript.0 because enabled
      2023-10-23 00:42:03.674  - error: host.iobroker instance system.adapter.sql.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      2023-10-23 00:42:03.674  - info: host.iobroker Restart adapter system.adapter.sql.0 because enabled
      2023-10-23 00:42:04.286  - info: host.iobroker instance system.adapter.telegram.0 started with pid 143965
      2023-10-23 00:42:08.303  - info: host.iobroker instance system.adapter.telegram.1 started with pid 143972
      2023-10-23 00:42:09.140  - error: telegram.0 (143965) telegram.0 already running
      2023-10-23 00:42:09.142  - warn: telegram.0 (143965) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
      2023-10-23 00:42:09.277  - error: telegram.1 (143972) telegram.1 already running
      2023-10-23 00:42:09.279  - warn: telegram.1 (143972) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
      2023-10-23 00:42:09.711  - error: host.iobroker instance system.adapter.telegram.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      2023-10-23 00:42:09.711  - info: host.iobroker Restart adapter system.adapter.telegram.0 because enabled
      2023-10-23 00:42:09.847  - error: host.iobroker instance system.adapter.telegram.1 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      2023-10-23 00:42:09.848  - info: host.iobroker Restart adapter system.adapter.telegram.1 because enabled
      2023-10-23 00:42:12.279  - info: host.iobroker instance system.adapter.javascript.1 started with pid 143987
      2023-10-23 00:42:13.378  - error: javascript.1 (143987) javascript.1 already running
      2023-10-23 00:42:13.379  - warn: javascript.1 (143987) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
      2023-10-23 00:42:13.951  - error: host.iobroker instance system.adapter.javascript.1 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      2023-10-23 00:42:13.951  - info: host.iobroker Restart adapter system.adapter.javascript.1 because enabled
      2023-10-23 00:42:16.281  - info: host.iobroker instance system.adapter.sql.1 started with pid 143998
      2023-10-23 00:42:17.045  - error: sql.1 (143998) sql.1 already running
      2023-10-23 00:42:17.046  - warn: sql.1 (143998) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
      2023-10-23 00:42:17.620  - error: host.iobroker instance system.adapter.sql.1 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      2023-10-23 00:42:17.620  - info: host.iobroker Restart adapter system.adapter.sql.1 because enabled
      2023-10-23 00:42:20.285  - info: host.iobroker instance system.adapter.influxdb.0 started with pid 144009
      2023-10-23 00:42:21.854  - error: influxdb.0 (144009) influxdb.0 already running
      2023-10-23 00:42:21.856  - warn: influxdb.0 (144009) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
      2023-10-23 00:42:22.430  - error: host.iobroker instance system.adapter.influxdb.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      2023-10-23 00:42:22.431  - info: host.iobroker Restart adapter system.adapter.influxdb.0 because enabled
      2023-10-23 00:42:23.026  - info: host.iobroker instance system.adapter.admin.0 started with pid 144020
      2023-10-23 00:42:23.773  - info: host.iobroker instance system.adapter.email.0 started with pid 144031
      2023-10-23 00:42:24.382  - info: host.iobroker instance system.adapter.fritzbox.0 started with pid 144042
      2023-10-23 00:42:24.603  - info: admin.0 (144020) starting. Version 6.10.1 in /opt/iobroker/node_modules/iobroker.admin, node: v18.18.2, js-controller: 5.0.12
      2023-10-23 00:42:24.625  - info: admin.0 (144020) requesting all objects
      2023-10-23 00:42:24.789  - info: email.0 (144031) starting. Version 1.2.0 in /opt/iobroker/node_modules/iobroker.email, node: v18.18.2, js-controller: 5.0.12
      2023-10-23 00:42:25.823  - info: admin.0 (144020) received all objects
      2023-10-23 00:42:26.778  - error: fritzbox.0 (144042) fritzbox.0 already running
      2023-10-23 00:42:26.779  - warn: fritzbox.0 (144042) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
      2023-10-23 00:42:26.903  - info: admin.0 (144020) Request actual repository...
      2023-10-23 00:42:26.912  - info: admin.0 (144020) socket.io server listening on port 8081
      2023-10-23 00:42:26.913  - info: admin.0 (144020) http server listening on port 8081
      2023-10-23 00:42:26.914  - info: admin.0 (144020) Use link "http://127.0.0.1:8081" to configure.
      2023-10-23 00:42:27.169  - error: admin.0 (144020) Cannot update news: TypeError: newNews.forEach is not a function
      2023-10-23 00:42:27.218  - info: admin.0 (144020) ==> Connected system.user.admin from ::ffff:192.168.243.102
      2023-10-23 00:42:29.462  - error: host.iobroker instance system.adapter.fritzbox.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      2023-10-23 00:42:29.463  - info: host.iobroker Restart adapter system.adapter.fritzbox.0 because enabled
      2023-10-23 00:42:29.486  - info: host.iobroker instance system.adapter.hm-rega.0 started with pid 144069
      2023-10-23 00:42:29.995  - info: host.iobroker Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
      2023-10-23 00:42:30.835  - info: admin.0 (144020) ==> Connected system.user.admin from ::ffff:192.168.243.100
      2023-10-23 00:42:31.603  - error: hm-rega.0 (144069) hm-rega.0 already running
      2023-10-23 00:42:31.605  - warn: hm-rega.0 (144069) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
      2023-10-23 00:42:31.860  - info: admin.0 (144020) Repository received successfully.
      2023-10-23 00:42:32.179  - error: host.iobroker instance system.adapter.hm-rega.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      2023-10-23 00:42:32.179  - info: host.iobroker Restart adapter system.adapter.hm-rega.0 because enabled
      2023-10-23 00:42:32.300  - info: host.iobroker instance system.adapter.hm-rpc.0 started with pid 144084
      2023-10-23 00:42:33.298  - info: host.iobroker instance system.adapter.javascript.0 started with pid 144096
      2023-10-23 00:42:33.541  - error: hm-rpc.0 (144084) hm-rpc.0 already running
      2023-10-23 00:42:33.542  - warn: hm-rpc.0 (144084) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
      2023-10-23 00:42:33.761  - info: host.iobroker instance system.adapter.sql.0 started with pid 144103
      2023-10-23 00:42:34.153  - error: host.iobroker instance system.adapter.hm-rpc.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      2023-10-23 00:42:34.153  - info: host.iobroker Restart adapter system.adapter.hm-rpc.0 because enabled
      2023-10-23 00:42:35.024  - info: javascript.0 (144096) starting. Version 7.1.4 (non-npm: ioBroker/ioBroker.javascript) in /opt/iobroker/node_modules/iobroker.javascript, node: v18.18.2, js-controller: 5.0.12
      2023-10-23 00:42:35.086  - info: sql.0 (144103) starting. Version 2.2.0 in /opt/iobroker/node_modules/iobroker.sql, node: v18.18.2, js-controller: 5.0.12
      2023-10-23 00:42:36.289  - info: host.iobroker instance system.adapter.hm-rpc.1 started with pid 144126
      2023-10-23 00:42:37.002  - error: hm-rpc.1 (144126) hm-rpc.1 already running
      2023-10-23 00:42:37.003  - warn: hm-rpc.1 (144126) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
      2023-10-23 00:42:37.584  - error: host.iobroker instance system.adapter.hm-rpc.1 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      2023-10-23 00:42:37.585  - info: host.iobroker Restart adapter system.adapter.hm-rpc.1 because enabled
      ... hier zahlreiche sql Einträge ...
      2023-10-23 00:42:38.329  - info: sql.0 (144103) enabled logging of javascript.0.Geräte.Photovoltaik.Auswertung.Jahr_Hochrechnung.Meter_eingespeist, Alias=false, 354 points now activated
      2023-10-23 00:42:38.329  - info: sql.0 (144103) enabled logging of javascript.0.Geräte.Photovoltaik.Auswertung.Jahr_Hochrechnung.Haus_Verbrauch, Alias=false, 355 points now activated
      2023-10-23 00:42:38.329  - info: sql.0 (144103) enabled logging of javascript.0.Geräte.Photovoltaik.Auswertung.Jahr_Hochrechnung.seit_Anfang.Leistung_alt, Alias=false, 356 points now activated
      2023-10-23 00:42:38.329  - info: sql.0 (144103) enabled logging of javascript.0.Geräte.Photovoltaik.Auswertung.Jahr_Hochrechnung.seit_Anfang.Leistung_neu, Alias=false, 357 points now activated
      2023-10-23 00:42:38.329  - info: sql.0 (144103) enabled logging of javascript.0.Geräte.Photovoltaik.Auswertung.Jahr_Hochrechnung.seit_Anfang.Leistung_alt_neu, Alias=false, 358 points now activated
      2023-10-23 00:42:38.329  - info: sql.0 (144103) enabled logging of javascript.0.Geräte.Photovoltaik.Auswertung.Jahr_Hochrechnung.seit_Anfang.Meter_bezogen, Alias=false, 359 points now activated
      2023-10-23 00:42:38.330  - info: sql.0 (144103) enabled logging of javascript.0.Geräte.Photovoltaik.Auswertung.Jahr_Hochrechnung.seit_Anfang.Meter_eingespeist, Alias=false, 360 points now activated
      2023-10-23 00:42:38.330  - info: sql.0 (144103) enabled logging of javascript.0.Geräte.Photovoltaik.Auswertung.Jahr_Hochrechnung.seit_Anfang.Haus_Verbrauch, Alias=false, 361 points now activated
      2023-10-23 00:42:38.855  - info: javascript.0 (144096) requesting all states
      2023-10-23 00:42:38.856  - info: javascript.0 (144096) requesting all objects
      2023-10-23 00:42:39.791  - info: host.iobroker instance system.adapter.telegram.0 started with pid 144137
      2023-10-23 00:42:40.063  - info: javascript.0 (144096) received all objects
      2023-10-23 00:42:40.079  - info: host.iobroker instance system.adapter.telegram.1 started with pid 144144
      2023-10-23 00:42:40.608  - info: javascript.0 (144096) received all states
      2023-10-23 00:42:40.649  - info: host.iobroker instance system.adapter.hm-rpc.2 started with pid 144155
      2023-10-23 00:42:41.765  - error: hm-rpc.2 (144155) hm-rpc.2 already running
      2023-10-23 00:42:41.767  - warn: hm-rpc.2 (144155) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
      2023-10-23 00:42:41.850  - info: telegram.0 (144137) starting. Version 1.16.0 in /opt/iobroker/node_modules/iobroker.telegram, node: v18.18.2, js-controller: 5.0.12
      2023-10-23 00:42:42.739  - error: host.iobroker instance system.adapter.hm-rpc.2 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      2023-10-23 00:42:42.739  - info: host.iobroker Restart adapter system.adapter.hm-rpc.2 because enabled
      2023-10-23 00:42:42.903  - info: telegram.1 (144144) starting. Version 1.16.0 in /opt/iobroker/node_modules/iobroker.telegram, node: v18.18.2, js-controller: 5.0.12
      2023-10-23 00:42:44.026  - info: host.iobroker instance system.adapter.javascript.1 started with pid 144178
      2023-10-23 00:42:44.328  - info: host.iobroker instance scheduled system.adapter.ical.0 0,15,30,45 * * * *
      2023-10-23 00:42:44.358  - info: host.iobroker instance system.adapter.ical.0 started with pid 144185
      2023-10-23 00:42:45.762  - info: javascript.1 (144178) starting. Version 7.1.4 (non-npm: ioBroker/ioBroker.javascript) in /opt/iobroker/node_modules/iobroker.javascript, node: v18.18.2, js-controller: 5.0.12
      2023-10-23 00:42:46.177  - info: ical.0 (144185) starting. Version 1.13.3 in /opt/iobroker/node_modules/iobroker.ical, node: v18.18.2, js-controller: 5.0.12
      2023-10-23 00:42:46.424  - info: javascript.1 (144178) requesting all states
      2023-10-23 00:42:46.425  - info: javascript.1 (144178) requesting all objects
      2023-10-23 00:42:46.938  - info: ical.0 (144185) processing URL: Märkte https://calendar.google.com/calendar/ical/mn7fmslmdftdee289a43jfk2p4%40group.calendar.google.com/private-a1b9d16955e1b026c97c9163f08d34a9/basic.ics
      2023-10-23 00:42:47.310  - info: javascript.0 (144096) Start javascript script.js.Scripte.Countdown.Countdown_-_Boost-Arbeitszimmer
      2023-10-23 00:42:47.524  - info: ical.0 (144185) processing URL: Müll https://calendar.google.com/calendar/ical/4v99ckgc7cn8ds7lifi58gq97o%40group.calendar.google.com/private-3fcd3288d403e0dd210afc8b4eec7699/basic.ics
      2023-10-23 00:42:47.641  - info: javascript.1 (144178) received all objects
      2023-10-23 00:42:47.940  - info: host.iobroker instance system.adapter.sql.1 started with pid 144208
      2023-10-23 00:42:48.031  - info: javascript.1 (144178) received all states
      2023-10-23 00:42:48.074  - info: ical.0 (144185) processing URL: Google https://calendar.google.com/calendar/ical/d.mueller3005%40googlemail.com/private-068d61660f2427d2f71024c407325b7c/basic.ics
      2023-10-23 00:42:48.306  - info: host.iobroker instance system.adapter.komoot.0 started with pid 144215
      2023-10-23 00:42:49.421  - info: sql.1 (144208) starting. Version 2.2.0 in /opt/iobroker/node_modules/iobroker.sql, node: v18.18.2, js-controller: 5.0.12
      2023-10-23 00:42:49.669  - info: sql.1 (144208) Connected to sqlite
      2023-10-23 00:42:52.298  - info: host.iobroker instance system.adapter.mihome-vacuum.0 started with pid 144230
      2023-10-23 00:42:52.565  - info: host.iobroker instance system.adapter.influxdb.0 started with pid 144244
      ca. 00:17, es kommt dann "disconnect system.user.admin"
      von 00:17 bis 00:41 keine Einträge im log
      ab 00:41; jede Menge error von den versch. Adaptern
      dann werden die Instanzen neu gestartet (wo aber immer steht: already running)
      ab 00:42 die ganzen sql Einträge, zigbee, etc.
      dann läuft es wieder.
      Anbei auch mal ein iob diag
      Skript v.2023-10-10
      *** BASE SYSTEM ***
      Static hostname: iobroker
      Icon name: computer-vm
      Chassis: vm
      Virtualization: kvm
      Operating System: Debian GNU/Linux 11 (bullseye)
      Kernel: Linux 5.10.0-25-amd64
      Architecture: x86-64
      model name : Common KVM processor
      Docker : false
      Virtualization : kvm
      Kernel : x86_64
      Userland : amd64
      Systemuptime and Load:
      08:18:12 up 2 days, 5:07, 1 user, load average: 2.33, 2.25, 2.17
      CPU threads: 8
      *** Time and Time Zones ***
      Local time: Mon 2023-10-23 08:18:12 CEST
      Universal time: Mon 2023-10-23 06:18:12 UTC
      RTC time: Mon 2023-10-23 06:18:13
      NTP service: active
      RTC in local TZ: no
      *** User and Groups ***
      dieter
      /home/dieter
      dieter cdrom floppy sudo audio dip video plugdev netdev iobroker
      *** X-Server-Setup ***
      X-Server: false
      Desktop:
      Terminal: tty
      Boot Target: graphical.target
      *** MEMORY ***
      total used free shared buff/cache available
      Mem: 5.9G 4.7G 556M 0.0K 632M 956M
      Swap: 974M 36M 938M
      Total: 6.9G 4.8G 1.5G
           5928 M total memory
           4740 M used memory
            262 M active memory
           4805 M inactive memory
            556 M free memory
             89 M buffer memory
            542 M swap cache
            974 M total swap
             36 M used swap
            938 M free swap
      *** FAILED SERVICES ***
      0 loaded units listed.
      *** FILESYSTEM ***
      Filesystem Type Size Used Avail Use% Mounted on
      udev devtmpfs 2.9G 0 2.9G 0% /dev
      tmpfs tmpfs 593M 524K 593M 1% /run
      /dev/sda1 ext4 31G 14G 16G 46% /
      tmpfs tmpfs 2.9G 0 2.9G 0% /dev/shm
      tmpfs tmpfs 5.0M 0 5.0M 0% /run/lock
      //192.168.243.100/1_Sound cifs 238G 124G 115G 52% /mnt
      tmpfs tmpfs 593M 0 593M 0% /run/user/1000
      [Sat Oct 21 03:10:38 2023] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
      [Sat Oct 21 03:10:45 2023] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro
      [Mon Oct 23 00:41:14 2023] ext4_filemap_fault+0x2d/0x50 [ext4]
      Show mounted filesystems (real ones only):
      TARGET SOURCE FSTYPE OPTIONS
      / /dev/sda1 ext4 rw,relatime,errors=remount-ro
      `-/mnt //192.168.243.100/1_Sound cifs rw,relatime,vers=3.1.1,cache=strict,username=dieter,uid=0,noforceuid,gid=0,noforcegid,addr=192.168.243.100,file_mode=0777,dir_mode=0777,soft,nounix,serverino,mapposix,rsize=4194304,wsize=4194304,bsize=1048576,echo_interval=60,actimeo=1
      /var:
      1.5G /var/
      874M /var/log
      857M /var/log/journal/dd59139b4ae040898d227e04f86103f0
      443M /var/cache
      Archived and active journals take up 152.0M in the file system.
      /opt/iobroker/backups:
      2.9G /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      3.3G /opt/iobroker/iobroker-data/
      2.5G /opt/iobroker/iobroker-data/sqlite
      624M /opt/iobroker/iobroker-data/files
      303M /opt/iobroker/iobroker-data/files/vis.0
      248M /opt/iobroker/iobroker-data/files/vis.0/wav
      1.1G /opt/iobroker/iobroker-data/sqlite/sqlite202301.db
      948M /opt/iobroker/iobroker-data/sqlite/sqlitealt202207.db
      235M /opt/iobroker/iobroker-data/sqlite/sqlite.db
      201M /opt/iobroker/iobroker-data/sqlite/sqlite202303.db
      154M /opt/iobroker/iobroker-data/files/vis.0/wav/starker-regen-mit-gewitter-im.wav
      USB-Devices by-id:
      USB-Sticks - Avoid direct links to /dev/* in your adapter setups, please always prefer the links 'by-id':
      *** NodeJS-Installation ***
      /usr/bin/nodejs v18.18.2
      /usr/bin/node v18.18.2
      /usr/bin/npm 9.8.1
      /usr/bin/npx 9.8.1
      /usr/bin/corepack 0.19.0
      nodejs:
      Version table:
      *** 18.18.2-1nodesource1 1001
      500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
      100 /var/lib/dpkg/status
      18.18.1-1nodesource1 1001
      18.18.0-1nodesource1 1001
      18.17.1-1nodesource1 1001
      18.17.0-1nodesource1 1001
      18.16.1-1nodesource1 1001
      18.16.0-1nodesource1 1001
      18.15.0-1nodesource1 1001
      18.14.2-1nodesource1 1001
      18.14.1-1nodesource1 1001
      18.14.0-1nodesource1 1001
      18.13.0-1nodesource1 1001
      18.12.0-1nodesource1 1001
      18.11.0-1nodesource1 1001
      18.10.0-1nodesource1 1001
      18.9.1-1nodesource1 1001
      18.9.0-1nodesource1 1001
      18.8.0-1nodesource1 1001
      18.7.0-1nodesource1 1001
      18.6.0-1nodesource1 1001
      18.5.0-1nodesource1 1001
      18.4.0-1nodesource1 1001
      18.3.0-1nodesource1 1001
      18.2.0-1nodesource1 1001
      18.1.0-1nodesource1 1001
      18.0.0-1nodesource1 1001
      12.22.12~dfsg-1~deb11u4 500
      500 http://deb.debian.org/debian bullseye/main amd64 Packages
      500 http://security.debian.org/debian-security bullseye-security/main amd64 Packages
      No problems detected
      Errors in npm tree:
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States type: jsonl
      Core adapters versions
      admin: 6.10.1
      javascript: 7.1.4
      Adapters from github: 13
      Adapter State
      • system.adapter.admin.0 : admin : iobroker - enabled, port: 8081, bind: 0.0.0.0, run as: admin
        system.adapter.alias-manager.0 : alias-manager : iobroker - disabled
      • system.adapter.asterisk.0 : asterisk : iobroker - enabled, port: 5038
      • system.adapter.backitup.0 : backitup : iobroker - enabled
      • system.adapter.bmw.0 : bmw : iobroker - enabled
      • system.adapter.bosch-ebike.0 : bosch-ebike : iobroker - enabled
      • system.adapter.cloud.0 : cloud : iobroker - enabled
      • system.adapter.contact.0 : contact : iobroker - enabled, port: 8096
        system.adapter.daswetter.0 : daswetter : iobroker - enabled
        system.adapter.doorio.0 : doorio : iobroker - disabled, port: 4444
        system.adapter.dwd.0 : dwd : iobroker - enabled
      • system.adapter.email.0 : email : iobroker - enabled
        system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: iobroker - disabled
        system.adapter.feiertage.0 : feiertage : iobroker - enabled
        system.adapter.flot.0 : flot : iobroker - disabled
      • system.adapter.fritzbox.0 : fritzbox : iobroker - enabled
      • system.adapter.fritzdect.0 : fritzdect : iobroker - enabled
      • system.adapter.hm-rega.0 : hm-rega : iobroker - enabled
      • system.adapter.hm-rpc.0 : hm-rpc : iobroker - enabled, port: 0
      • system.adapter.hm-rpc.1 : hm-rpc : iobroker - enabled, port: 0
      • system.adapter.hm-rpc.2 : hm-rpc : iobroker - enabled, port: 0
        system.adapter.ical.0 : ical : iobroker - enabled
        system.adapter.icons-material-png.0 : icons-material-png : iobroker - disabled
        system.adapter.icons-mfd-png.0 : icons-mfd-png : iobroker - disabled
        system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: iobroker - disabled
      • system.adapter.imap.0 : imap : iobroker - enabled
      • system.adapter.influxdb.0 : influxdb : iobroker - enabled, port: 8086
      • system.adapter.javascript.0 : javascript : iobroker - enabled
      • system.adapter.javascript.1 : javascript : iobroker - enabled
      • system.adapter.komoot.0 : komoot : iobroker - enabled
      • system.adapter.libre.0 : libre : iobroker - enabled
        system.adapter.linux-control.0 : linux-control : iobroker - disabled
      • system.adapter.logparser.0 : logparser : iobroker - enabled
      • system.adapter.mbus.0 : mbus : Pi-Strom-Wasser - enabled, port: 3493
      • system.adapter.mihome-vacuum.0 : mihome-vacuum : iobroker - enabled, port: 54321
        system.adapter.mihome.0 : mihome : iobroker - disabled, port: 9898, bind: 192.168.243.12
      • system.adapter.modbus.0 : modbus : iobroker - enabled
        system.adapter.modbus.1 : modbus : iobroker - disabled
      • system.adapter.mqtt.0 : mqtt : iobroker - enabled, port: 1883, bind: 0.0.0.0
      • system.adapter.mqtt.2 : mqtt : iobroker - enabled, port: 1885, bind: 0.0.0.0
      • system.adapter.musiccast.0 : musiccast : iobroker - enabled
      • system.adapter.octoprint.0 : octoprint : iobroker - enabled
      • system.adapter.openligadb.0 : openligadb : iobroker - enabled
      • system.adapter.parser.0 : parser : iobroker - enabled
      • system.adapter.ping.0 : ping : iobroker - enabled
      • system.adapter.pollenflug.0 : pollenflug : iobroker - enabled
      • system.adapter.proxmox.0 : proxmox : iobroker - enabled, port: 8006
        system.adapter.rest-api.0 : rest-api : iobroker - disabled, port: 8093, bind: 0.0.0.0, run as: admin
      • system.adapter.rssfeed.0 : rssfeed : iobroker - enabled
      • system.adapter.sayit.2 : sayit : iobroker - enabled
      • system.adapter.sayit.3 : sayit : iobroker - enabled
      • system.adapter.sayit.4 : sayit : iobroker - enabled
        system.adapter.shelly.0 : shelly : iobroker - disabled, port: 1882, bind: 0.0.0.0
      • system.adapter.simple-api.0 : simple-api : iobroker - enabled, port: 8087, bind: 0.0.0.0, run as: admin
      • system.adapter.smartmeter.0 : smartmeter : Pi-Strom-Wasser - enabled
      • system.adapter.smartmeter.1 : smartmeter : Pi-Strom-Wasser - enabled
      • system.adapter.sourceanalytix.0 : sourceanalytix : iobroker - enabled
      • system.adapter.sql.0 : sql : iobroker - enabled, port: 3306
      • system.adapter.sql.1 : sql : iobroker - enabled
      • system.adapter.tankerkoenig.0 : tankerkoenig : iobroker - enabled
      • system.adapter.telegram.0 : telegram : iobroker - enabled, port: 8443, bind: 0.0.0.0
      • system.adapter.telegram.1 : telegram : iobroker - enabled, port: 8443, bind: 0.0.0.0
      • system.adapter.tr-064.0 : tr-064 : iobroker - enabled
      • system.adapter.tuya.0 : tuya : iobroker - enabled
      • system.adapter.viessmann.0 : viessmann : iobroker - enabled, port: 3002
        system.adapter.vis-bars.0 : vis-bars : iobroker - enabled
        system.adapter.vis-canvas-gauges.0 : vis-canvas-gauges : iobroker - enabled
        system.adapter.vis-colorpicker.0 : vis-colorpicker : iobroker - enabled
        system.adapter.vis-google-fonts.0 : vis-google-fonts : iobroker - enabled
        system.adapter.vis-history.0 : vis-history : iobroker - enabled
        system.adapter.vis-hqwidgets.0 : vis-hqwidgets : iobroker - enabled
      • system.adapter.vis-inventwo.0 : vis-inventwo : iobroker - enabled
        system.adapter.vis-jqui-mfd.0 : vis-jqui-mfd : iobroker - enabled
        system.adapter.vis-justgage.0 : vis-justgage : iobroker - enabled
        system.adapter.vis-map.0 : vis-map : iobroker - enabled
        system.adapter.vis-metro.0 : vis-metro : iobroker - enabled
        system.adapter.vis-players.0 : vis-players : iobroker - enabled
        system.adapter.vis-plumb.0 : vis-plumb : iobroker - enabled
        system.adapter.vis-rgraph.0 : vis-rgraph : iobroker - enabled
        system.adapter.vis-timeandweather.0 : vis-timeandweather : iobroker - enabled
        system.adapter.vis-weather.0 : vis-weather : iobroker - enabled
        system.adapter.vis.0 : vis : iobroker - enabled
      • system.adapter.web.0 : web : iobroker - enabled, port: 8082, bind: 0.0.0.0, run as: admin
        system.adapter.wiobrowser.0 : wiobrowser : iobroker - disabled, port: 5000
      • system.adapter.wled.0 : wled : iobroker - enabled
      • system.adapter.ws.0 : ws : iobroker - enabled, port: 8084, bind: 0.0.0.0, run as: admin
      • system.adapter.yamaha.0 : yamaha : iobroker - enabled
      • system.adapter.zigbee.0 : zigbee : iobroker - enabled, port: tcp://192.168.243.114:6638
      • instance is alive
      ioBroker-Repositories
      stable : http://download.iobroker.net/sources-dist.json
      beta : http://download.iobroker.net/sources-dist-latest.json
      Active repo(s): stable
      Installed ioBroker-Instances
      Used repository: stable
      Adapter "admin" : 6.10.1 , installed 6.10.1
      Adapter "alias-manager": 1.2.6 , installed 1.2.6
      Adapter "asterisk" : 1.0.6 , installed 1.0.6
      Adapter "backitup" : 2.8.1 , installed 2.8.1
      Adapter "bmw" : 2.5.7 , installed 2.6.1
      Adapter "bosch-ebike" : 0.0.3 , installed 0.0.3
      Adapter "cloud" : 4.4.1 , installed 4.4.1
      Adapter "daswetter" : 3.1.10 , installed 3.1.10
      Adapter "doorio" : 2.1.4 , installed 2.1.4
      Adapter "dwd" : 2.8.5 , installed 2.8.5
      Adapter "email" : 1.2.0 , installed 1.2.0
      Adapter "feiertage" : 1.1.4 , installed 1.1.4
      Adapter "flot" : 1.12.0 , installed 1.12.0
      Adapter "fritzbox" : 0.5.0 , installed 0.5.0
      Adapter "fritzdect" : 2.3.1 , installed 2.3.1
      Adapter "hm-rega" : 3.0.47 , installed 3.0.47
      Adapter "hm-rpc" : 1.15.19 , installed 1.15.19
      Adapter "ical" : 1.13.3 , installed 1.13.3
      Adapter "icons-material-png": 0.1.0, installed 0.1.0
      Adapter "icons-mfd-png": 1.1.0 , installed 1.1.0
      Adapter "icons-open-icon-library-png": 0.1.2, installed 0.1.2
      Adapter "imap" : 0.1.1 , installed 0.1.1
      Adapter "influxdb" : 3.2.0 , installed 3.2.0
      Adapter "javascript" : 7.1.4 , installed 7.1.4
      Controller "js-controller": 5.0.12 , installed 5.0.12
      Adapter "libre" : 0.0.4 , installed 0.0.5
      Adapter "linux-control": 1.1.5 , installed 1.1.5
      Adapter "logparser" : 2.2.0 , installed 2.2.0
      Adapter "mihome" : 1.4.0 , installed 1.4.0
      Adapter "mihome-vacuum": 4.0.0 , installed 4.0.0
      Adapter "modbus" : 5.0.11 , installed 5.0.11
      Adapter "mqtt" : 4.1.1 , installed 4.1.1
      Adapter "musiccast" : 1.1.3 , installed 1.1.3
      Adapter "octoprint" : 4.0.0 , installed 4.0.0
      Adapter "openligadb" : 1.2.4 , installed 1.3.4
      Adapter "parser" : 1.3.2 , installed 1.3.2
      Adapter "ping" : 1.6.2 , installed 1.6.2
      Adapter "pollenflug" : 1.0.6 , installed 1.0.6
      Adapter "proxmox" : 1.3.5 , installed 1.3.5
      Adapter "rest-api" : 1.1.0 , installed 1.1.0
      Adapter "rssfeed" : 2.6.1 , installed 2.6.1
      Adapter "sayit" : 3.0.5 , installed 3.0.5
      Adapter "shelly" : 6.4.1 , installed 6.4.1
      Adapter "simple-api" : 2.7.2 , installed 2.7.2
      Adapter "socketio" : 6.5.5 , installed 6.5.5
      Adapter "sql" : 2.2.0 , installed 2.2.0
      Adapter "tankerkoenig" : 3.3.7 , installed 3.3.7
      Adapter "telegram" : 1.16.0 , installed 1.16.0
      Adapter "tr-064" : 4.2.18 , installed 4.2.18
      Adapter "tuya" : 3.14.2 , installed 3.14.2
      Adapter "viessmann" : 1.4.4 , installed 1.4.4
      Adapter "vis" : 1.4.16 , installed 1.4.16
      Adapter "vis-bars" : 0.1.4 , installed 0.1.4
      Adapter "vis-canvas-gauges": 1.0.1, installed 1.0.1
      Adapter "vis-colorpicker": 2.0.3 , installed 2.0.3
      Adapter "vis-google-fonts": 1.0.4 , installed 1.0.4
      Adapter "vis-history" : 1.0.0 , installed 1.0.0
      Adapter "vis-hqwidgets": 1.4.0 , installed 1.4.0
      Adapter "vis-inventwo" : 3.3.3 , installed 3.3.3
      Adapter "vis-jqui-mfd" : 1.0.12 , installed 1.0.12
      Adapter "vis-justgage" : 1.0.2 , installed 1.0.2
      Adapter "vis-map" : 1.0.4 , installed 1.0.4
      Adapter "vis-metro" : 1.2.0 , installed 1.2.0
      Adapter "vis-players" : 0.1.6 , installed 0.1.6
      Adapter "vis-plumb" : 1.0.2 , installed 1.0.2
      Adapter "vis-rgraph" : 0.0.2 , installed 0.0.2
      Adapter "vis-timeandweather": 1.2.2, installed 1.2.2
      Adapter "vis-weather" : 2.5.6 , installed 2.5.6
      Adapter "web" : 6.1.2 , installed 6.1.10
      Adapter "wiobrowser" : 2.0.2 , installed 2.0.2
      Adapter "wled" : 0.7.1 , installed 0.7.1
      Adapter "ws" : 2.5.5 , installed 2.5.8
      Adapter "yamaha" : 0.5.3 , installed 0.5.3
      Adapter "zigbee" : 1.8.23 , installed 1.8.23
      Objects and States
      Objects: 24077
      States: 19957
      Hit:1 http://deb.debian.org/debian bullseye InRelease
      Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
      Hit:3 http://security.debian.org/debian-security bullseye-security InRelease
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      Proto Recv-Q Send-Q Local Address Foreign Address State User Inode PID/Program name
      tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN 0 12649 428/sshd: /usr/sbin
      tcp 0 0 192.168.243.15:2010 0.0.0.0:* LISTEN 1001 2957748 144381/io.hm-rpc.2
      tcp 0 0 0.0.0.0:1883 0.0.0.0:* LISTEN 1001 2957903 144489/io.mqtt.0
      tcp 0 0 0.0.0.0:1885 0.0.0.0:* LISTEN 1001 2958840 144522/io.mqtt.2
      tcp 0 0 192.168.243.15:8701 0.0.0.0:* LISTEN 1001 2957707 144348/io.hm-rpc.1
      tcp 0 0 0.0.0.0:9000 0.0.0.0:* LISTEN 1001 2952129 143903/iobroker.js-
      tcp 0 0 0.0.0.0:9001 0.0.0.0:* LISTEN 1001 2952108 143903/iobroker.js-
      tcp 0 0 0.0.0.0:5038 0.0.0.0:* LISTEN 108 11887 404/asterisk
      tcp 0 0 0.0.0.0:111 0.0.0.0:* LISTEN 0 2992 1/init
      tcp 0 0 192.168.243.15:2001 0.0.0.0:* LISTEN 1001 2957697 144322/io.hm-rpc.0
      tcp6 0 0 :::8084 :::* LISTEN 1001 2961066 145385/io.ws.0
      tcp6 0 0 :::22 :::* LISTEN 0 12651 428/sshd: /usr/sbin
      tcp6 0 0 :::8087 :::* LISTEN 1001 2962915 145245/io.simple-ap
      tcp6 0 0 :::111 :::* LISTEN 0 12368 1/init
      tcp6 0 0 :::8081 :::* LISTEN 1001 2957336 144020/io.admin.0
      tcp6 0 0 :::8082 :::* LISTEN 1001 2961012 145364/io.web.0
      udp 0 0 0.0.0.0:68 0.0.0.0:* 0 11706 356/dhclient
      udp 0 0 0.0.0.0:111 0.0.0.0:* 0 11535 1/init
      udp 0 0 0.0.0.0:41100 0.0.0.0:* 1001 2962835 145013/io.musiccast
      udp 0 0 0.0.0.0:53421 0.0.0.0:* 1001 2957823 144429/io.mihome-va
      udp 0 0 0.0.0.0:4569 0.0.0.0:* 108 11896 404/asterisk
      udp 0 0 0.0.0.0:5060 0.0.0.0:* 108 11897 404/asterisk
      udp 0 0 0.0.0.0:5353 0.0.0.0:* 1001 2963619 145563/io.wled.0
      udp 0 0 0.0.0.0:6666 0.0.0.0:* 1001 2956072 144612/io.tuya.0
      udp 0 0 0.0.0.0:6667 0.0.0.0:* 1001 2956073 144612/io.tuya.0
      udp 0 0 0.0.0.0:57049 0.0.0.0:* 108 14033 404/asterisk
      udp6 0 0 :::111 :::* 0 230 1/init
      udp6 0 0 :::55284 :::* 108 14034 404/asterisk
      2023-10-23 08:18:51.849 - info: javascript.0 (144096) script.js.Scripte.Geraete.Kombisensor: Auslöser Duration geändert
      2023-10-23 08:19:05.002 - info: javascript.0 (144096) script.js.Scripte.Geraete.Photovoltaik_2012: Auslöser: Schedule
      2023-10-23 08:19:05.003 - info: javascript.0 (144096) script.js.Scripte.Geraete.Photovoltaik_2012: Piko 5.5 auslesen
      2023-10-23 08:19:05.515 - info: javascript.0 (144096) script.js.Scripte.Geraete.Photovoltaik_2012: Leistung aktuell= 53 W // Tagesleistung= 0.01 kWh // Leistung alt gesamt= 56011 kWh // Leistung Strang 1= 36 W // Leistung Strang 2= 17 W
      2023-10-23 08:19:06.003 - info: javascript.0 (144096) script.js.Scripte.Geraete.Photovoltaik_2023: Leistung: alt = 53 W ; neu = 98 W ; alt+neu = 151 W
      2023-10-23 08:19:06.003 - info: javascript.0 (144096) script.js.Scripte.Geraete.Photovoltaik_2023: Batterie: 113 W ; Netz: -912 W ; Haus-Verbrauch: -950 W
      2023-10-23 08:19:06.003 - info: javascript.0 (144096) script.js.Scripte.Geraete.Photovoltaik_2023: Tagesleistung Heute: alt = 0.01 kWh ; neu = 0.04 kWh ; alt+neu = 0.05 kWh
      2023-10-23 08:19:09.294 - warn: modbus.0 (144459) Poll error count: 1 code: "App Timeout"
      2023-10-23 08:19:15.479 - info: admin.0 (144020) <== Disconnect system.user.admin from ::ffff:192.168.243.100 admin
      2023-10-23 08:19:15.551 - info: admin.0 (144020) <== Disconnect system.user.admin from ::ffff:192.168.243.100 admin
      2023-10-23 08:19:15.560 - info: admin.0 (144020) <== Disconnect system.user.admin from ::ffff:192.168.243.100 admin
      2023-10-23 08:19:15.564 - info: admin.0 (144020) <== Disconnect system.user.admin from ::ffff:192.168.243.102 admin
      2023-10-23 08:19:15.564 - info: admin.0 (144020) <== Disconnect system.user.admin from ::ffff:192.168.243.100 javascript
      2023-10-23 08:19:15.724 - info: admin.0 (144020) ==> Connected system.user.admin from ::ffff:192.168.243.100
      2023-10-23 08:19:17.576 - info: admin.0 (144020) ==> Connected system.user.admin from ::ffff:192.168.243.100
      2023-10-23 08:19:18.177 - info: admin.0 (144020) ==> Connected system.user.admin from ::ffff:192.168.243.100
      2023-10-23 08:19:18.178 - info: admin.0 (144020) ==> Connected system.user.admin from ::ffff:192.168.243.102
      2023-10-23 08:19:18.195 - info: admin.0 (144020) ==> Connected system.user.admin from ::ffff:192.168.243.100
      2023-10-23 08:19:20.348 - info: javascript.0 (144096) script.js.Scripte.Licht.Flur1_EG: Helligkeit = 34; Dimmer Flur 1 EG auf 40% eingeschaltet.
      2023-10-23 08:19:20.468 - info: javascript.0 (144096) script.js.Scripte.Licht.Kueche_Vorratsraum: Helligkeit = 34; Licht Küche Vorratsraum eingeschaltet.
      2023-10-23 08:19:21.160 - info: javascript.0 (144096) script.js.Scripte.Geraete.Wemos: Auslöser: SV Homeduino Barometer Tränke geändert
      2023-10-23 08:19:32.286 - info: octoprint.0 (145079) error EHOSTUNREACH from /api/version: connect EHOSTUNREACH 192.168.243.139:80
      2023-10-23 08:19:41.084 - info: mihome-vacuum.0 (144429) trigger cleaning segment 17
      2023-10-23 08:19:41.512 - info: javascript.0 (144096) script.js.Scripte.Licht.Bad_EG: Licht Bad EG nicht ausgeschaltet. Erneute Prüfung nach 2 min.
      2023-10-23 08:19:44.163 - info: octoprint.0 (145079) error ECONNABORTED from /api/version: timeout of 2000ms exceeded
      [/s]
      und summary
      [s=]
      v.2023-10-10
      Chassis: vm
      Virtualization: kvm
      Installation: kvm
      Kernel: x86_64
      Userland: amd64
      Timezone: Europe/Berlin (CEST, +0200)
      User-ID: 1000
      X-Server: false
      Pending OS-Updates: 0
      Pending iob updates: 0
      Nodejs-Installation: /usr/bin/nodejs v18.18.2
      /usr/bin/npm 9.8.1
      /usr/bin/npx 9.8.1
      Recommended versions are nodejs 18.18.2 and npm 9.8.1
      MEMORY:
      Mem: 5.9G 4.8G 588M 0.0K 543M 881M
      Swap: 974M 202M 772M
      Total: 6.9G 5.0G 1.4G
      Active iob-Instances: 56
      ioBroker Core: js-controller 5.0.12
      admin 6.10.1
      ioBroker Status: iobroker is running on this host.
      Objects type: jsonl
      States type: jsonl
      Objects: 24077
      States: 19957
      Size of iob-Database:
      51M /opt/iobroker/iobroker-data/objects.jsonl
      28M /opt/iobroker/iobroker-data/states.jsonl
      [/s]
      Hat jemand ne Idee ?
      mfg
      Dieter
      arteck ? ? 4 Replies Last reply Reply Quote 0
        arteck Developer Most Active @bahnuhr last edited by
        @bahnuhr das log ist nach dem neustart.. was ist davor ??? das wird gebraucht
        • bahnuhr
          bahnuhr Forum Testing Most Active @arteck last edited by bahnuhr
          @arteck sagte in iob stürzt ab und startet dann neu:
          00:17 ist doch dabei.
          davor normale log Einträge
          Nun mal seit 00:10 bis 00:17
          2023-10-23 00:10:00.036  - info: javascript.0 (602) script.js.Scripte.System.Drucker_3D: 3D Drucker ist per Ping nicht erreichbar !
          2023-10-23 00:10:00.040  - info: javascript.0 (602) script.js.Scripte.Sonstige.Diabetes: Diabetes: Sensor seit und noch ermittelt.
          2023-10-23 00:10:00.060  - info: javascript.0 (602) script.js.Scripte.Geraete.Maehroboter: json = {"name": "Robo-Maeh", "id": "081603", "status": {"status": 17, "distance": 0, "stopped": false, "dooropen": false, "duration": 19659, "mode": 0, "battery": 100, "hours": 1154}, "timer": {"status": 2, "next": {"date": "2023-10-24", "time": "10:00:00", "unix": 1698141600}}, "blades": {"quality": 0, "hours": 365, "days": 208}, "wlan": {"signal": -75}, "health": {"temperature": 22, "humidity": 27}, "clock": {"date": "2023-10-23", "time": "00:09:59", "unix": 1698019799}, "successful": true}
          2023-10-23 00:10:00.091  - info: host.iobroker instance system.adapter.dwd.0 started with pid 143502
          2023-10-23 00:10:00.150  - info: javascript.0 (602) script.js.Scripte.Geraete.Tablet: Tablet Surface: aktuelle Lautstärke ist: 80 %.
          2023-10-23 00:10:00.156  - info: javascript.0 (602) script.js.Scripte.Geraete.Tablet: Tablet Surface: aktuelle Helligkeit ist: 100 %.
          2023-10-23 00:10:00.314  - info: javascript.0 (602) script.js.Scripte.Geraete.Tablet: Tablet Surface: aktueller Akkustand ist: 100 %.
          2023-10-23 00:10:00.383  - info: javascript.0 (602) script.js.Scripte.Geraete.Tablet: Tablet Chuwi: aktuelle Lautstärke ist: 100 %.
          2023-10-23 00:10:00.416  - info: javascript.0 (602) script.js.Scripte.Geraete.Tablet: Tablet Chuwi: aktuelle Helligkeit ist: 50 %.
          2023-10-23 00:10:00.516  - info: javascript.0 (602) script.js.Scripte.Geraete.Tablet: Tablet Chuwi: aktueller Akkustand ist: 23 %.
          2023-10-23 00:10:02.095  - info: dwd.0 (143502) starting. Version 2.8.5 (non-npm: ioBroker/ioBroker.dwd) in /opt/iobroker/node_modules/iobroker.dwd, node: v18.18.2, js-controller: 5.0.12
          2023-10-23 00:10:03.765  - info: dwd.0 (143502) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
          2023-10-23 00:10:04.985  - info: host.iobroker instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
          2023-10-23 00:10:05.003  - info: javascript.0 (602) script.js.Scripte.Geraete.Photovoltaik_2012: Auslöser: Schedule
          2023-10-23 00:10:05.003  - info: javascript.0 (602) script.js.Scripte.Geraete.Photovoltaik_2012: Piko 5.5 auslesen
          2023-10-23 00:10:05.339  - info: javascript.0 (602) script.js.Scripte.Geraete.Photovoltaik_2012: Leistung aktuell= 0 W // Tagesleistung= 0 kWh // Leistung alt gesamt= 56011 kWh // Leistung Strang 1= 0 W // Leistung Strang 2= 0 W
          2023-10-23 00:10:05.361  - info: javascript.0 (602) script.js.Scripte.Geraete.Kombisensor_-_Windrose: Auslöser Windrichtung
          2023-10-23 00:10:06.004  - info: javascript.0 (602) script.js.Scripte.Geraete.Photovoltaik_2023: Leistung: alt = 0 W ; neu = 0 W ; alt+neu = 0 W
          2023-10-23 00:10:06.005  - info: javascript.0 (602) script.js.Scripte.Geraete.Photovoltaik_2023: Batterie: 0 W ; Netz: -656 W ; Haus-Verbrauch: -656 W
          2023-10-23 00:10:06.005  - info: javascript.0 (602) script.js.Scripte.Geraete.Photovoltaik_2023: Tagesleistung Heute: alt = 0 kWh ; neu = 0 kWh ; alt+neu = 0 kWh
          2023-10-23 00:11:00.020  - info: javascript.0 (602) script.js.Scripte.Geraete.Maehroboter: Auto_nachts ist: false
          2023-10-23 00:11:00.029  - info: javascript.0 (602) script.js.Scripte.Geraete.Shelly: Shellyflood-Heizung: letzte Abfrage war vor : 17 Tage / 1 Std. / 48 Min. / 6 Sek.
          2023-10-23 00:11:00.029  - info: javascript.0 (602) script.js.Scripte.Geraete.Shelly: Shellyflood-Kueche: letzte Abfrage war vor : 0 Tage / 6 Std. / 35 Min. / 5 Sek.
          2023-10-23 00:11:00.040  - info: javascript.0 (602) script.js.Scripte.System.CCU-Firmware_und_Lan-Gateway: Auslöser CCU-Firmware Schedule
          2023-10-23 00:11:00.147  - info: javascript.0 (602) script.js.Scripte.System.CCU-Firmware_und_Lan-Gateway: Installierte Firmware 3.65.11.20221005 der CCU ist nicht aktuell. Aktuell verfügbare Version: 3.71.12.20231020
          2023-10-23 00:11:05.002  - info: javascript.0 (602) script.js.Scripte.Geraete.Photovoltaik_2012: Auslöser: Schedule
          2023-10-23 00:11:05.002  - info: javascript.0 (602) script.js.Scripte.Geraete.Photovoltaik_2012: Piko 5.5 auslesen
          2023-10-23 00:11:05.330  - info: javascript.0 (602) script.js.Scripte.Geraete.Photovoltaik_2012: Leistung aktuell= 0 W // Tagesleistung= 0 kWh // Leistung alt gesamt= 56011 kWh // Leistung Strang 1= 0 W // Leistung Strang 2= 0 W
          2023-10-23 00:11:06.004  - info: javascript.0 (602) script.js.Scripte.Geraete.Photovoltaik_2023: Leistung: alt = 0 W ; neu = 0 W ; alt+neu = 0 W
          2023-10-23 00:11:06.004  - info: javascript.0 (602) script.js.Scripte.Geraete.Photovoltaik_2023: Batterie: 0 W ; Netz: -814 W ; Haus-Verbrauch: -814 W
          2023-10-23 00:11:06.004  - info: javascript.0 (602) script.js.Scripte.Geraete.Photovoltaik_2023: Tagesleistung Heute: alt = 0 kWh ; neu = 0 kWh ; alt+neu = 0 kWh
          2023-10-23 00:11:19.388  - info: javascript.0 (602) script.js.Scripte.Geraete.Wemos: Auslöser: Wemos Barometer Heizoel geändert
          2023-10-23 00:11:19.395  - info: javascript.0 (602) script.js.Scripte.Geraete.Wemos: Auslöser: Wemos Heizöl geändert
          2023-10-23 00:11:19.397  - info: javascript.0 (602) script.js.Scripte.Heizoel_Traenke_Zisterne_Brunnen.Heizoel_-_aktuell_Liter: Heizöl: 13.6 cm = aktuelle Liter = 4223
          2023-10-23 00:11:36.924  - info: javascript.0 (602) script.js.Scripte.Geraete.Waschmaschine: Auslöser Waschmaschine
          2023-10-23 00:12:00.061  - info: javascript.0 (602) script.js.Scripte.Geraete.Maehroboter: json = {"name": "Robo-Maeh", "id": "081603", "status": {"status": 17, "distance": 0, "stopped": false, "dooropen": false, "duration": 19779, "mode": 0, "battery": 100, "hours": 1154}, "timer": {"status": 2, "next": {"date": "2023-10-24", "time": "10:00:00", "unix": 1698141600}}, "blades": {"quality": 0, "hours": 365, "days": 208}, "wlan": {"signal": -75}, "health": {"temperature": 22, "humidity": 27}, "clock": {"date": "2023-10-23", "time": "00:11:59", "unix": 1698019919}, "successful": true}
          2023-10-23 00:12:05.007  - info: javascript.0 (602) script.js.Scripte.Geraete.Photovoltaik_2012: Auslöser: Schedule
          2023-10-23 00:12:05.007  - info: javascript.0 (602) script.js.Scripte.Geraete.Photovoltaik_2012: Piko 5.5 auslesen
          2023-10-23 00:12:05.103  - info: javascript.0 (602) script.js.Scripte.Geraete.Wemos: Auslöser: Wemos Barometer Zisterne geändert
          2023-10-23 00:12:05.108  - info: javascript.0 (602) script.js.Scripte.Geraete.Wemos: Auslöser: Wemos Zisterne geändert
          2023-10-23 00:12:05.345  - info: javascript.0 (602) script.js.Scripte.Geraete.Photovoltaik_2012: Leistung aktuell= 0 W // Tagesleistung= 0 kWh // Leistung alt gesamt= 56011 kWh // Leistung Strang 1= 0 W // Leistung Strang 2= 0 W
          2023-10-23 00:12:06.005  - info: javascript.0 (602) script.js.Scripte.Geraete.Photovoltaik_2023: Leistung: alt = 0 W ; neu = 0 W ; alt+neu = 0 W
          2023-10-23 00:12:06.005  - info: javascript.0 (602) script.js.Scripte.Geraete.Photovoltaik_2023: Batterie: 0 W ; Netz: -814 W ; Haus-Verbrauch: -814 W
          2023-10-23 00:12:06.005  - info: javascript.0 (602) script.js.Scripte.Geraete.Photovoltaik_2023: Tagesleistung Heute: alt = 0 kWh ; neu = 0 kWh ; alt+neu = 0 kWh
          2023-10-23 00:12:23.003  - info: javascript.0 (602) script.js.Scripte.System.Sonne_Mond: Sonne: Azimut: 340° / Sonne: Elevation: -49.1° / Mond: Azimut: 232° / Mond: Elevation: 1.1°
          2023-10-23 00:12:27.052  - info: javascript.0 (602) script.js.Scripte.Geraete.Kombisensor_-_Windrose: Auslöser Windrichtung
          2023-10-23 00:13:03.751  - info: javascript.0 (602) script.js.Scripte.Geraete.Wemos: Auslöser: SV Homeduino Barometer Tränke geändert
          2023-10-23 00:13:05.003  - info: javascript.0 (602) script.js.Scripte.Geraete.Photovoltaik_2012: Auslöser: Schedule
          2023-10-23 00:13:05.003  - info: javascript.0 (602) script.js.Scripte.Geraete.Photovoltaik_2012: Piko 5.5 auslesen
          2023-10-23 00:13:05.330  - info: javascript.0 (602) script.js.Scripte.Geraete.Photovoltaik_2012: Leistung aktuell= 0 W // Tagesleistung= 0 kWh // Leistung alt gesamt= 56011 kWh // Leistung Strang 1= 0 W // Leistung Strang 2= 0 W
          2023-10-23 00:13:06.005  - info: javascript.0 (602) script.js.Scripte.Geraete.Photovoltaik_2023: Leistung: alt = 0 W ; neu = 0 W ; alt+neu = 0 W
          2023-10-23 00:13:06.006  - info: javascript.0 (602) script.js.Scripte.Geraete.Photovoltaik_2023: Batterie: 0 W ; Netz: -737 W ; Haus-Verbrauch: -737 W
          2023-10-23 00:13:06.006  - info: javascript.0 (602) script.js.Scripte.Geraete.Photovoltaik_2023: Tagesleistung Heute: alt = 0 kWh ; neu = 0 kWh ; alt+neu = 0 kWh
          2023-10-23 00:14:00.051  - info: javascript.0 (602) script.js.Scripte.Geraete.Maehroboter: json = {"name": "Robo-Maeh", "id": "081603", "status": {"status": 17, "distance": 0, "stopped": false, "dooropen": false, "duration": 19899, "mode": 0, "battery": 100, "hours": 1154}, "timer": {"status": 2, "next": {"date": "2023-10-24", "time": "10:00:00", "unix": 1698141600}}, "blades": {"quality": 0, "hours": 365, "days": 208}, "wlan": {"signal": -75}, "health": {"temperature": 22, "humidity": 27}, "clock": {"date": "2023-10-23", "time": "00:13:59", "unix": 1698020039}, "successful": true}
          2023-10-23 00:14:05.009  - info: javascript.0 (602) script.js.Scripte.Geraete.Photovoltaik_2012: Auslöser: Schedule
          2023-10-23 00:14:05.010  - info: javascript.0 (602) script.js.Scripte.Geraete.Photovoltaik_2012: Piko 5.5 auslesen
          2023-10-23 00:14:05.437  - info: javascript.0 (602) script.js.Scripte.Geraete.Photovoltaik_2012: Leistung aktuell= 0 W // Tagesleistung= 0 kWh // Leistung alt gesamt= 56011 kWh // Leistung Strang 1= 0 W // Leistung Strang 2= 0 W
          2023-10-23 00:14:06.005  - info: javascript.0 (602) script.js.Scripte.Geraete.Photovoltaik_2023: Leistung: alt = 0 W ; neu = 0 W ; alt+neu = 0 W
          2023-10-23 00:14:06.005  - info: javascript.0 (602) script.js.Scripte.Geraete.Photovoltaik_2023: Batterie: 0 W ; Netz: -737 W ; Haus-Verbrauch: -737 W
          2023-10-23 00:14:06.005  - info: javascript.0 (602) script.js.Scripte.Geraete.Photovoltaik_2023: Tagesleistung Heute: alt = 0 kWh ; neu = 0 kWh ; alt+neu = 0 kWh
          2023-10-23 00:14:13.486  - info: javascript.0 (602) script.js.Scripte.Geraete.Drucksensor: Heizung: 10544 , 1.86
          2023-10-23 00:14:13.486  - info: javascript.0 (602) script.js.Scripte.Geraete.Drucksensor: FB-Heizung: 9936 , 1.72
          2023-10-23 00:14:13.486  - info: javascript.0 (602) script.js.Scripte.Geraete.Drucksensor: Wasser: 8848 , 3.51
          2023-10-23 00:14:34.914  - info: javascript.0 (602) script.js.Scripte.Geraete.Kombisensor_-_Windrose: Auslöser Windrichtung
          2023-10-23 00:15:00.035  - info: javascript.0 (602) script.js.Scripte.Sonstige.Diabetes: Diabetes: Sensor seit und noch ermittelt.
          2023-10-23 00:15:00.039  - info: javascript.0 (602) script.js.Scripte.System.Drucker_3D: 3D Drucker ist per Ping nicht erreichbar !
          2023-10-23 00:15:00.062  - info: javascript.0 (602) script.js.Scripte.System.View_wechseln: View auf 'Uhr' gewechselt.
          2023-10-23 00:15:00.077  - info: javascript.0 (602) script.js.Scripte.Haus.Dachfenster: Auslöser Dachfenster: 0:15 Uhr
          2023-10-23 00:15:00.078  - info: javascript.0 (602) script.js.Scripte.Haus.Dachfenster: Es ist 0 Uhr 15.: Alle Fenster im Dachgeschoss sind geschlossen.
          2023-10-23 00:15:00.090  - info: host.iobroker instance system.adapter.dwd.0 started with pid 143755
          2023-10-23 00:15:00.096  - info: javascript.0 (602) script.js.Scripte.Heizung.Heizung_nachts_auto_pruefen: hm-rpc.0.KEQ0574459.4 Fitnessraum false
          2023-10-23 00:15:00.096  - info: javascript.0 (602) script.js.Scripte.Heizung.Heizung_nachts_auto_pruefen: hm-rpc.0.KEQ0574613.4 Philipp L false
          2023-10-23 00:15:00.096  - info: javascript.0 (602) script.js.Scripte.Heizung.Heizung_nachts_auto_pruefen: hm-rpc.0.KEQ0574642.4 Rebecca L false
          2023-10-23 00:15:00.096  - info: javascript.0 (602) script.js.Scripte.Heizung.Heizung_nachts_auto_pruefen: hm-rpc.0.KEQ0576469.4 Philipp R false
          2023-10-23 00:15:00.096  - info: javascript.0 (602) script.js.Scripte.Heizung.Heizung_nachts_auto_pruefen: hm-rpc.0.KEQ0653104.4 Wohnzimmer false
          2023-10-23 00:15:00.096  - info: javascript.0 (602) script.js.Scripte.Heizung.Heizung_nachts_auto_pruefen: hm-rpc.0.KEQ0724743.4 Bad_OG false
          2023-10-23 00:15:00.096  - info: javascript.0 (602) script.js.Scripte.Heizung.Heizung_nachts_auto_pruefen: hm-rpc.0.KEQ1040434.4 Arbeitszimmer false
          2023-10-23 00:15:00.096  - info: javascript.0 (602) script.js.Scripte.Heizung.Heizung_nachts_auto_pruefen: hm-rpc.0.KEQ1040443.4 Schlafzimmer false
          2023-10-23 00:15:00.096  - info: javascript.0 (602) script.js.Scripte.Heizung.Heizung_nachts_auto_pruefen: hm-rpc.0.KEQ1040517.4 Hobbyraum false
          2023-10-23 00:15:00.096  - info: javascript.0 (602) script.js.Scripte.Heizung.Heizung_nachts_auto_pruefen: hm-rpc.0.KEQ1040651.4 Büro false
          2023-10-23 00:15:00.096  - info: javascript.0 (602) script.js.Scripte.Heizung.Heizung_nachts_auto_pruefen: hm-rpc.0.LEQ0107637.4 Bad_EG - Handtuch false
          2023-10-23 00:15:00.096  - info: javascript.0 (602) script.js.Scripte.Heizung.Heizung_nachts_auto_pruefen: hm-rpc.0.LEQ0782624.4 Rebecca R false
          2023-10-23 00:15:00.097  - info: javascript.0 (602) script.js.Scripte.Heizung.Heizung_nachts_auto_pruefen: hm-rpc.0.LEQ0783942.4 Bad_OG - Handtuch false
          2023-10-23 00:15:00.097  - info: javascript.0 (602) script.js.Scripte.Heizung.Heizung_nachts_auto_pruefen: hm-rpc.0.LEQ0784844.4 Sauna false
          2023-10-23 00:15:00.097  - info: javascript.0 (602) script.js.Scripte.Heizung.Heizung_nachts_auto_pruefen: hm-rpc.0.OEQ2092890.4 Bad_EG false
          2023-10-23 00:15:00.135  - info: javascript.0 (602) script.js.Scripte.System.Batterie: Auslöser: Schedule
          2023-10-23 00:15:00.139  - warn: javascript.0 (602) getState "hm-rpc.0.MEQ0675420.0.LOWBAT" not found (3)
          2023-10-23 00:15:00.141  - warn: javascript.0 (602)     at Ermittlung (script.js.Scripte.System.Batterie:18:22)
          2023-10-23 00:15:00.141  - warn: javascript.0 (602)     at Array.forEach (<anonymous>)
          2023-10-23 00:15:00.141  - warn: javascript.0 (602)     at weiter (script.js.Scripte.System.Batterie:15:13)
          2023-10-23 00:15:00.141  - warn: javascript.0 (602)     at Object.<anonymous> (script.js.Scripte.System.Batterie:70:5)
          2023-10-23 00:15:00.141  - warn: javascript.0 (602)     at Job.job (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1617:34)
          2023-10-23 00:15:00.141  - warn: javascript.0 (602)     at Job.invoke (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/Job.js:171:15)
          2023-10-23 00:15:00.141  - warn: javascript.0 (602)     at /opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/Invocation.js:268:28
          2023-10-23 00:15:00.141  - warn: javascript.0 (602)     at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/Invocation.js:228:7)
          2023-10-23 00:15:00.141  - warn: javascript.0 (602)     at listOnTimeout (node:internal/timers:569:17)
          2023-10-23 00:15:00.141  - warn: javascript.0 (602)     at processTimers (node:internal/timers:512:7)
          2023-10-23 00:15:00.141  - warn: javascript.0 (602) script.js.Scripte.System.Batterie: Object "hm-rpc.0.MEQ0675420.0.LOWBAT" does not exist
          2023-10-23 00:15:00.142  - error: javascript.0 (602) Error in callback: TypeError: Cannot read properties of null (reading 'common')
          2023-10-23 00:15:00.143  - error: javascript.0 (602)     at Ermittlung (script.js.Scripte.System.Batterie:20:34)
          2023-10-23 00:15:00.143  - error: javascript.0 (602)     at Array.forEach (<anonymous>)
          2023-10-23 00:15:00.143  - error: javascript.0 (602)     at weiter (script.js.Scripte.System.Batterie:15:13)
          2023-10-23 00:15:00.143  - error: javascript.0 (602)     at Object.<anonymous> (script.js.Scripte.System.Batterie:70:5)
          2023-10-23 00:15:00.143  - error: javascript.0 (602)     at Job.job (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1617:34)
          2023-10-23 00:15:00.143  - error: javascript.0 (602)     at Job.invoke (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/Job.js:171:15)
          2023-10-23 00:15:00.143  - error: javascript.0 (602)     at /opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/Invocation.js:268:28
          2023-10-23 00:15:00.143  - error: javascript.0 (602)     at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/Invocation.js:228:7)
          2023-10-23 00:15:00.143  - error: javascript.0 (602)     at listOnTimeout (node:internal/timers:569:17)
          2023-10-23 00:15:00.143  - error: javascript.0 (602)     at processTimers (node:internal/timers:512:7)
          2023-10-23 00:15:00.159  - info: javascript.0 (602) script.js.Scripte.Geraete.Tablet: Tablet Surface: aktuelle Helligkeit ist: 100 %.
          2023-10-23 00:15:00.190  - info: javascript.0 (602) script.js.Scripte.Geraete.Tablet: Tablet Surface: aktuelle Lautstärke ist: 80 %.
          2023-10-23 00:15:00.286  - info: javascript.0 (602) script.js.Scripte.Geraete.Tablet: Tablet Chuwi: aktuelle Lautstärke ist: 100 %.
          2023-10-23 00:15:00.321  - info: javascript.0 (602) script.js.Scripte.Geraete.Tablet: Tablet Surface: aktueller Akkustand ist: 100 %.
          2023-10-23 00:15:00.339  - info: javascript.0 (602) script.js.Scripte.Geraete.Tablet: Tablet Chuwi: aktuelle Helligkeit ist: 50 %.
          2023-10-23 00:15:00.371  - info: javascript.0 (602) script.js.Scripte.Geraete.Tablet: Tablet Chuwi: aktueller Akkustand ist: 21 %.
          2023-10-23 00:15:01.950  - info: dwd.0 (143755) starting. Version 2.8.5 (non-npm: ioBroker/ioBroker.dwd) in /opt/iobroker/node_modules/iobroker.dwd, node: v18.18.2, js-controller: 5.0.12
          2023-10-23 00:15:03.579  - info: dwd.0 (143755) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
          2023-10-23 00:15:04.977  - info: host.iobroker instance system.adapter.daswetter.0 started with pid 143780
          2023-10-23 00:15:05.002  - info: javascript.0 (602) script.js.Scripte.Geraete.Photovoltaik_2012: Auslöser: Schedule
          2023-10-23 00:15:05.002  - info: javascript.0 (602) script.js.Scripte.Geraete.Photovoltaik_2012: Piko 5.5 auslesen
          2023-10-23 00:15:05.238  - info: host.iobroker instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
          2023-10-23 00:15:05.427  - info: javascript.0 (602) script.js.Scripte.Geraete.Photovoltaik_2012: Leistung aktuell= 0 W // Tagesleistung= 0 kWh // Leistung alt gesamt= 56011 kWh // Leistung Strang 1= 0 W // Leistung Strang 2= 0 W
          2023-10-23 00:15:06.002  - info: javascript.0 (602) script.js.Scripte.Geraete.Photovoltaik_2023: Leistung: alt = 0 W ; neu = 0 W ; alt+neu = 0 W
          2023-10-23 00:15:06.003  - info: javascript.0 (602) script.js.Scripte.Geraete.Photovoltaik_2023: Batterie: 0 W ; Netz: -651 W ; Haus-Verbrauch: -651 W
          2023-10-23 00:15:06.003  - info: javascript.0 (602) script.js.Scripte.Geraete.Photovoltaik_2023: Tagesleistung Heute: alt = 0 kWh ; neu = 0 kWh ; alt+neu = 0 kWh
          2023-10-23 00:15:07.343  - info: daswetter.0 (143780) starting. Version 3.1.10 in /opt/iobroker/node_modules/iobroker.daswetter, node: v18.18.2, js-controller: 5.0.12
          2023-10-23 00:15:07.666  - info: javascript.0 (602) script.js.Scripte.Sonstige.Wetter: /vis.0/main/img/Wetter/3f.png
          2023-10-23 00:15:09.077  - info: host.iobroker instance system.adapter.ical.0 started with pid 143797
          2023-10-23 00:15:11.401  - info: ical.0 (143797) starting. Version 1.13.3 in /opt/iobroker/node_modules/iobroker.ical, node: v18.18.2, js-controller: 5.0.12
          2023-10-23 00:15:12.218  - info: ical.0 (143797) processing URL: Märkte https://calendar.google.com/calendar/ical/mn7fmslmdftdee289a43jfk2p4%40group.calendar.google.com/private-a1b9dd34a9/basic.ics
          2023-10-23 00:15:12.864  - info: ical.0 (143797) processing URL: Müll https://calendar.google.com/calendar/ical/4v99ckgoup.calendar.google.com/private-3fc7699/basic.ics
          2023-10-23 00:15:13.375  - info: ical.0 (143797) processing URL: Google https://calendar.google.com/calendar/ical/d.mueller3005%40googlemail.com/private-068d7325b7c/basic.ics
          2023-10-23 00:15:19.828  - info: ical.0 (143797) Terminated (NO_ERROR): Without reason
          2023-10-23 00:15:20.604  - info: host.iobroker instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
          2023-10-23 00:16:00.056  - info: javascript.0 (602) script.js.Scripte.Geraete.Maehroboter: json = {"name": "Robo-Maeh", "id": "081603", "status": {"status": 17, "distance": 0, "stopped": false, "dooropen": false, "duration": 20019, "mode": 0, "battery": 100, "hours": 1154}, "timer": {"status": 2, "next": {"date": "2023-10-24", "time": "10:00:00", "unix": 1698141600}}, "blades": {"quality": 0, "hours": 365, "days": 208}, "wlan": {"signal": -75}, "health": {"temperature": 22, "humidity": 27}, "clock": {"date": "2023-10-23", "time": "00:15:59", "unix": 1698020159}, "successful": true}
          2023-10-23 00:16:05.006  - info: javascript.0 (602) script.js.Scripte.Geraete.Photovoltaik_2012: Auslöser: Schedule
          2023-10-23 00:16:05.006  - info: javascript.0 (602) script.js.Scripte.Geraete.Photovoltaik_2012: Piko 5.5 auslesen
          2023-10-23 00:16:05.434  - info: javascript.0 (602) script.js.Scripte.Geraete.Photovoltaik_2012: Leistung aktuell= 0 W // Tagesleistung= 0 kWh // Leistung alt gesamt= 56011 kWh // Leistung Strang 1= 0 W // Leistung Strang 2= 0 W
          2023-10-23 00:16:06.005  - info: javascript.0 (602) script.js.Scripte.Geraete.Photovoltaik_2023: Leistung: alt = 0 W ; neu = 0 W ; alt+neu = 0 W
          2023-10-23 00:16:06.005  - info: javascript.0 (602) script.js.Scripte.Geraete.Photovoltaik_2023: Batterie: 0 W ; Netz: -679 W ; Haus-Verbrauch: -679 W
          2023-10-23 00:16:06.005  - info: javascript.0 (602) script.js.Scripte.Geraete.Photovoltaik_2023: Tagesleistung Heute: alt = 0 kWh ; neu = 0 kWh ; alt+neu = 0 kWh
          2023-10-23 00:16:15.175  - info: javascript.0 (602) script.js.Scripte.Geraete.Waschmaschine: Auslöser Waschmaschine
          2023-10-23 00:16:15.952  - error: sql.0 (613) Cannot insert INSERT INTO `iob_mariadb`.ts_number (id, ts, val, ack, _from, q) VALUES (379, 1698012975933, 48.25137083719676, 1, 28, 0);: Error: Duplicate entry '379-1698012975933' for key 'PRIMARY' (id: sourceanalytix.0.javascript__0__Geräte__Stromzähler_SDM72__Leistung_bezogen.cumulativeReading)
          2023-10-23 00:16:15.958  - error: sql.0 (613) Cannot insert INSERT INTO `iob_mariadb`.ts_number (id, ts, val, ack, _from, q) VALUES (379, 1698012975934, 48.25138052218287, 1, 28, 0);: Error: Duplicate entry '379-1698012975934' for key 'PRIMARY' (id: sourceanalytix.0.javascript__0__Geräte__Stromzähler_SDM72__Leistung_bezogen.cumulativeReading)
          2023-10-23 00:16:16.196  - error: sql.0 (613) Cannot insert INSERT INTO `iob_mariadb`.ts_number (id, ts, val, ack, _from, q) VALUES (380, 1698012976188, 0.165, 1, 28, 0);: Error: Duplicate entry '380-1698012976188' for key 'PRIMARY' (id: sourceanalytix.0.javascript__0__Geräte__Stromzähler_SDM72__Leistung_bezogen.currentYear.consumed.01_currentDay)
          2023-10-23 00:16:16.201  - error: sql.0 (613) Cannot insert INSERT INTO `iob_mariadb`.ts_number (id, ts, val, ack, _from, q) VALUES (380, 1698012976189, 0.165, 1, 28, 0);: Error: Duplicate entry '380-1698012976189' for key 'PRIMARY' (id: sourceanalytix.0.javascript__0__Geräte__Stromzähler_SDM72__Leistung_bezogen.currentYear.consumed.01_currentDay)
          2023-10-23 00:16:16.670  - info: daswetter.0 (143780) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
          2023-10-23 00:16:18.872  - info: javascript.0 (602) script.js.Scripte.Geraete.Wemos: Auslöser: Wemos Barometer Heizoel geändert
          2023-10-23 00:16:18.880  - info: javascript.0 (602) script.js.Scripte.Geraete.Wemos: Auslöser: Wemos Heizöl geändert
          2023-10-23 00:16:18.880  - info: javascript.0 (602) script.js.Scripte.Heizoel_Traenke_Zisterne_Brunnen.Heizoel_-_aktuell_Liter: Heizöl: 14.1 cm = aktuelle Liter = 4207
          2023-10-23 00:16:20.575  - info: daswetter.0 (143780) cleaned everything up...
          2023-10-23 00:16:23.127  - info: javascript.0 (602) script.js.Scripte.System.Sonne_Mond: Sonne: Azimut: 341° / Sonne: Elevation: -49.3° / Mond: Azimut: 233° / Mond: Elevation: 0.7°
          2023-10-23 00:16:24.590  - info: host.iobroker instance system.adapter.daswetter.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
          2023-10-23 00:17:08.837  - info: web.0 (1427) <== Disconnect system.user.admin from ::ffff:192.168.243.102 vis.0
          2023-10-23 00:17:09.046  - info: admin.0 (564) <== Disconnect system.user.admin from ::ffff:192.168.243.100 admin
          2023-10-23 00:17:09.056  - info: mqtt.2 (886) Client [Wemos_Sauna_Klima] reconnected. Old secret 1698012110123_9718. New secret 1698013028211_1856
          2023-10-23 00:17:09.189  - info: mqtt.2 (886) Client [Wemos_Kueche_Klima] reconnected. Old secret 1698012110123_7633. New secret 1698013028540_3060
          2023-10-23 00:17:09.189  - info: mqtt.2 (886) Client [Wemos_Wohnzimmer_Klima] reconnected. Old secret 1698012111414_7033. New secret 1698013028540_8286
          2023-10-23 00:17:09.191  - info: mqtt.2 (886) Client [Wemos_Wohnzimmer_Klima] connection closed: closed
          2023-10-23 00:17:09.191  - info: mqtt.2 (886) Client [Wemos_Kueche_Klima] connection closed: closed
          2023-10-23 00:17:09.191  - info: mqtt.2 (886) Client [Wemos_Sauna_Klima] connection closed: closed
          2023-10-23 00:17:50.526  - info: admin.0 (564) <== Disconnect system.user.admin from ::ffff:192.168.243.102 admin
          2023-10-23 00:17:09.120  - info: web.0 (1427) <== Disconnect system.user.admin from ::ffff:192.168.243.109 vis.0
          2023-10-23 00:17:09.121  - info: web.0 (1427) <== Disconnect system.user.admin from ::ffff:192.168.243.100 vis.0
          2023-10-23 00:17:09.121  - info: web.0 (1427) <== Disconnect system.user.admin from ::ffff:192.168.243.122 vis.0
            @bahnuhr die jsonl ist wech... warum auch immer.. machst du ne sicherung ?? davon manuell ??
            • bahnuhr
              jsonl
              was ist weg ?
              Ich mache täglich:
              proxmox backup Sicherung
              wöchentlich iob komplett copy auf nas
              täglich scripte sichern
              • bahnuhr
                der letzte copy war am 21.10.
                  @bahnuhr sagte in iob stürzt ab und startet dann neu:
                  Objects type: jsonl
                  States type: jsonl
                  ist weg... da liegen die states und objekte .... und die sind weg..
                  • bahnuhr
                    @arteck
                    meinst du diese ?
                    Die sind da.
                    Oder meinst du was anderes ?
                      arteck Developer Most Active @bahnuhr last edited by arteck
                      @bahnuhr die meine ich .. die Fehlermeldung besagt dass iobroker da nix reinschreiben kann.. also knallt der.. und startet neu
                      machmal bitte
                      iob fix
                      die sind relativ gross .. sollten dann komprimiert sein
                        A Former User @bahnuhr last edited by
                        @bahnuhr
                        kann das sein, dass du um diese Uhrzeit ein Backup machst, und daher die Dateien nicht geschrieben werden koennen?
                        • bahnuhr
                          bahnuhr Forum Testing Most Active @Guest last edited by
                          @ilovegym sagte in iob stürzt ab und startet dann neu:
                          ja, backitup macht da backup.
                          Kann aber doch eigentlich nicht sein, dass backitup das System zum Absturz bringt, oder doch ?
                          arteck Thomas Braun 2 Replies Last reply Reply Quote 0
                          • bahnuhr
                            erledigt.
                            Sind jetzt erheblich kleiner.
                              druckmal und schaun nach
                              bahnuhr 2 Replies Last reply Reply Quote 0
                                Thomas Braun Most Active @bahnuhr last edited by
                                Hängt halt davon ab, wieviele Ressourcen da zur Verfügung stehen und wie fett das Backup ist.
                                • bahnuhr
                                  bahnuhr Forum Testing Most Active @Thomas Braun last edited by
                                  @thomas-braun sagte in iob stürzt ab und startet dann neu:
                                  proxmox VM
                                  32 GB bootdisk-Größe
                                  6 GB Ram zugewiesen.
                                  Müsste doch eigentlich reichen, oder ?
                                  Thomas Braun ? ? 3 Replies Last reply Reply Quote 0
                                  • bahnuhr
                                    @arteck
                                    gestartet,
                                    schaun wir mal.
                                      Kann man so pauschal nicht sagen.
                                      Wenn ich mir die Frequenz anschaue, mit der da z. B. irgendwelche Logs gespeichert werden...
                                      • bahnuhr
                                        Was meinst du damit?
                                        Achte eigentlich immer darauf, nicht irgendwas im Sekundentakt zu machen.
                                        • bahnuhr
                                          @arteck
                                          backitup einwandfrei durchgelaufen.
                                          Dateien sind erzeugt.
                                            Moin,
                                            zu dem Zeitpunkt, an dem Du das iob diag durchgeführt hast, standen nur ~650 MB freier Speicher zur Verfügung, wenn das auch zu den Zeiten des Backups passiert, kann es sein, dass alle Dateien, die das Backup einsammelt, nicht in den freien Speicher passen und etwas geht krachen, dass der kernel etwas aus dem Speicher kickt.
                                            Wenn Du ein Monitoring am Laufen hast, dann beobachte mal den Speicherverbrauch zu den Zeiten des Backups und wie @arteck schon anmerkte, die Objekte und States mal komprimieren lassen iob fix
                                                Database maintenance (4/5)
                                            Checking for uncompressed JSONL databases... This might take a while!
                                            Compressing /opt/iobroker/iobroker-data/states.jsonl
                                            Compressing /opt/iobroker/iobroker-data/objects.jsonl
                                            Compressed 2 JSONL files. Done
                                            VG
                                            Bernd
                                            absturz error
                                            4113
