    4. Nach update - Yeelight geht im ganzen Haus nicht mehr!
      LaBamba last edited by LaBamba
      Hallo heute ein paar updates erneuert und plötzlich geht wieder einmal einiges nicht.
      Vorallem die Lichtsteuerung regt gerade richtig auf. Hier verwende ich im ganzen Haus Yeelights.
      host.raspberrypi
      	2023-10-25 21:48:23.205	error	instance system.adapter.yeelight-2.1 terminated with code 6 (UNCAUGHT_EXCEPTION)
      host.raspberrypi
      	2023-10-25 21:48:23.204	error	Caught by controller[1]: at TCP.<anonymous> (node:net:323:12)
      host.raspberrypi
      	2023-10-25 21:48:23.204	error	Caught by controller[1]: at Socket.emit (node:domain:489:12)
      host.raspberrypi
      	2023-10-25 21:48:23.204	error	Caught by controller[1]: at Socket.emit (node:events:526:35)
      host.raspberrypi
      	2023-10-25 21:48:23.204	error	Caught by controller[1]: at Object.onceWrapper (node:events:629:26)
      host.raspberrypi
      	2023-10-25 21:48:23.204	error	Caught by controller[1]: at Socket.onClose (node:net:912:10)
      host.raspberrypi
      	2023-10-25 21:48:23.204	error	Caught by controller[1]: at new NodeError (node:internal/errors:405:5)
      host.raspberrypi
      	2023-10-25 21:48:23.203	error	Caught by controller[1]: Error: Socket closed before the connection was established
      host.raspberrypi
      	2023-10-25 21:48:23.203	error	Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
      yeelight-2.1
      	2023-10-25 21:48:22.405	error	Exception-Code: ERR_SOCKET_CLOSED_BEFORE_CONNECTION: Socket closed before the connection was established
      yeelight-2.1
      	2023-10-25 21:48:22.403	error	Error: Socket closed before the connection was established at new NodeError (node:internal/errors:405:5) at Socket.onClose (node:net:912:10) at Object.onceWrapper (node:events:629:26) at Socket.emit (node:events:526:35) at Socket.emit (node:domain:489:12) at TCP.<anonymous> (node:net:323:12)
      yeelight-2.1
      	2023-10-25 21:48:22.402	error	unhandled promise rejection: Socket closed before the connection was established
      yeelight-2.1
      	2023-10-25 21:48:22.401	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      Weiß zufällig jemand an was das liegen könnte?
      Geupdatet habe ich die Adapter admin, history und zwei die ich nicht mehr weiss.
      Yeelight war aber nicht dabei. Gibt es irgendwo die Möglichkeit das nachzuschauen.
      @arteck
      @Feuersturm
      @Glasfaser
      @apollon77
        Thomas Braun Most Active @LaBamba last edited by Thomas Braun
        @labamba
        Und wie sieht deine Installation im Gesamten aus?
        iob diag
        anschauen.
        Könnte aber das sein:
        https://github.com/iobroker-community-adapters/ioBroker.yeelight-2/issues/222
        L Glasfaser 2 Replies Last reply Reply Quote 0
          LaBamba @Thomas Braun last edited by LaBamba
          Verwende node.js18
          Thomas Braun haselchen 2 Replies Last reply Reply Quote 0
            @labamba
            iob diag
            sagt?
            • Glasfaser
              Glasfaser @Thomas Braun last edited by Glasfaser
              @LaBamba
              sowas ähnliches war schonmal ... mit der gleichen Meldung
              #>Caught by controller ... at Socket.emit (node:domain:489:12) at TCP.<anonymous> (node:net:323:12)
              usw.
              aber da war mehr !
              https://forum.iobroker.net/topic/68891/iobroker-problem-js-controller-stürtzt-ab
              aber versuche erstmal
              iob fix
              • haselchen
                haselchen Most Active @LaBamba last edited by
                @labamba
                Habe auch den Adapter.
                Funktioniert mit Node 16 und jetzt mit Node 18.
                Anhand deines Logs kann ich leider nicht erkennen, welche Adapter Version Du hast.
                mcm1957 L 2 Replies Last reply Reply Quote 0
                • mcm1957
                  mcm1957 @haselchen last edited by
                  @haselchen
                  Das o.a. Issue beim Adapter bezieht sich lt. log auf 1.2.1 was auch die letzte Version in latest / stable ist.
                  Achtung in Github wird 1.1.2 angezeigt - da wurde wohl nicht immer eine GH Version agelegt :-(.
                  Aber gut zu wissen, dass der Adapter 'auch' funktioniert.
                  Leider gibt es derzeit niemand der die Zeit und die Möglichkeit hat sich den Adapter mal anzushen. Sorry. Aber neue Mitstreiter sind immer gern gesehen.
                    LaBamba @haselchen last edited by
                    @haselchen
                    Yeelight Version 1.8.24
                    Meine Vermutung ist es liegt am update vom Javascript Adapter auf 7.1.6.
                    Keine Änderung wenn ich zurück auf eine ältere Version gehe.
                    Thomas Braun mcm1957 haselchen 3 Replies Last reply Reply Quote 0
                      @labamba
                      Nochmal...
                      iob diag
                      sagt?
                      • mcm1957
                        mcm1957 @LaBamba last edited by
                        @labamba said in Nach update - Yeelight geht im ganzen Haus nicht mehr!:
                        @haselchen
                        Welchen Adapter benutzt du ???
                        Auf npm gibts nur iobroker.yeelight-2 mit Version 1.2.1. Eine Version 1.8.24 gibts da und auf Github nicht.
                        Und dass javascript einen Adapter Abstürzen läßt kann ich mir kaum vorstellen.
                          Thomas Braun Most Active @mcm1957 last edited by Thomas Braun
                          @mcm57 sagte in Nach update - Yeelight geht im ganzen Haus nicht mehr!:
                          Aber vom zigbee-Adapter. Der steht alphabetisch in der Nähe von yeelight. Vermutlich in der Zeile verrutscht. Aber mit Nacherzählungen kann man leider nicht viel anfangen.
                          • haselchen
                            @labamba
                            Kann ich @mcm57 nur zustimmen.
                            Diese Version habe ich auch.
                            Der Script Adapter macht bei mir keine Probleme diesbezüglich.
                              Würde ich ja gerne machen.
                              Mir hat jemand bei der Neuinstallation den Rat gegeben das Desktop auszustellen. Jetzt kann ich aber nicht mehr per RemoteDesktopverbindung auf die Befehlszeile zugreifen.
                              Per Filezilla kann ich aber zugreifen. Jedoch kenne ich mich da nicht aus.
                              Thomas Braun mcm1957 2 Replies Last reply Reply Quote 0
                                @labamba sagte in Nach update - Yeelight geht im ganzen Haus nicht mehr!:
                                Deswegen macht man sowas ja auch per SSH in einem Terminal. Da brauchts keinen Desktop, erst recht keinen Remote-Desktop.
                                • mcm1957
                                  mcm1957 @LaBamba last edited by mcm1957
                                  @labamba
                                  ssh zugriff sollte z.B. so gehen
                                  Windows - Eingabeaufforderung öffnen
                                  ssh <username>@<rechnername>
                                  Also z.B.
                                  ssh maxi@mypi
                                  ggF Frage bei ssh key bestätigen und Passwort eintippen
                                  Und ne dumme Frage: -
                                  Wie hast du in letzter Zeit bzw. seit der Installation updates des Betriebssystem gemacht ohne einzuloggen ?
                                    @haselchen
                                    @mcm57
                                    @Glasfaser
                                    Das Problem ist gelöst.
                                    Beim Yeelight Adapter müssen alle Lichtquellen aktiv sein. Also Strom haben!
                                    Wird dieser aus irgendwelchen Gründen neu gestartet und eine Lampe in der Adapter-Liste hat keinen Strom, zeigt er den Fehler an.
                                    Meine Tochter hat anscheinend eine Lampe über den Schalter stromlos gemacht.
                                    Danke an alle für die Unterstützung.
                                    P.S. Hatte damals Zugriff über Putty
                                      Und warum heute nicht mehr? puTTY ist ein SSH-fähiges Terminal-Programm.
                                      • haselchen
                                        @labamba
                                        Und schon zur Adoption freigegeben...... 😝
                                          @haselchen
                                          Haha, deswegen doch nicht 😉
                                          653
