    4. Objects database error: connect ECONNREFUSED 127.0.0.1:9001
      paul01 last edited by
      Hallo liebe comunity!
      seit dem letzten Neustart des PIs startet der iobroker nicht mehr. Folgenden Status liefert er:
      pi@iobroker:~ $ iobroker status
      Uncaught Rejection: Error: Cannot find module 'source-map'
      Require stack:
      - /opt/iobroker/node_modules/source-map-support/source-map-support.js
      - /opt/iobroker/node_modules/@iobroker/plugin-sentry/index.js
      - /opt/iobroker/node_modules/@iobroker/plugin-base/lib/PluginHandler.js
      - /opt/iobroker/node_modules/@iobroker/plugin-base/index.js
      - /opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js
      - /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js
          at Function.Module._resolveFilename (node:internal/modules/cjs/loader:995:15)
          at Function.Module._load (node:internal/modules/cjs/loader:841:27)
          at Module.require (node:internal/modules/cjs/loader:1067:19)
          at require (node:internal/modules/cjs/helpers:103:18)
          at Object.<anonymous> (/opt/iobroker/node_modules/source-map-support/source-map-support.js:1:25)
          at Module._compile (node:internal/modules/cjs/loader:1165:14)
          at Object.Module._extensions..js (node:internal/modules/cjs/loader:1219:10)
          at Module.load (node:internal/modules/cjs/loader:1043:32)
          at Function.Module._load (node:internal/modules/cjs/loader:878:12)
      kann mir hier jemand weiterhelfen?
      Danke!
      Paul
        Thomas Braun Most Active @paul01 last edited by
        @paul01
        iob diag
        sagt? In der Langfassung.
          paul01 @Thomas Braun last edited by
          Skript v.2023-10-10
          *** BASE SYSTEM ***
             Static hostname: iobroker
                   Icon name: computer
            Operating System: Raspbian GNU/Linux 10 (buster)
                      Kernel: Linux 5.10.103-v7l+
                Architecture: arm
          Model           : Raspberry Pi 4 Model B Rev 1.2
          Docker          : false
          Virtualization  : none
          Kernel          : armv7l
          Userland        : armhf
          Systemuptime and Load:
           14:09:39 up 44 min,  1 user,  load average: 0.76, 0.93, 1.03
          CPU threads: 4
          *** RASPBERRY THROTTLING ***
          Current issues:
          Previously detected issues:
          *** Time and Time Zones ***
                         Local time: Fri 2023-10-27 14:09:39 CEST
                     Universal time: Fri 2023-10-27 12:09:39 UTC
                           RTC time: n/a
                          Time zone: Europe/Vienna (CEST, +0200)
                        NTP service: active
                    RTC in local TZ: no
          *** User and Groups ***
          pi
          /home/pi
          pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
          *** X-Server-Setup ***
          X-Server:       false
          Desktop:
          Terminal:       tty
          *** MEMORY ***
          Mem:           3.8G        260M        2.8G         16M        791M        3.5G
          Swap:           99M          0B         99M
          Total:         3.9G        260M        2.9G
                   3838 M total memory
                    260 M used memory
                    395 M active memory
                    490 M inactive memory
                   2786 M free memory
                    171 M buffer memory
                    620 M swap cache
                     99 M total swap
                      0 M used swap
                     99 M free swap
          Raspberry only:
          oom events: 0
          *** FAILED SERVICES ***
            UNIT            LOAD   ACTIVE SUB    DESCRIPTION
          * dhcpcd.service  loaded failed failed dhcpcd on all interfaces
          * lightdm.service loaded failed failed Light Display Manager
          2 loaded units listed. Pass --all to see loaded but inactive units, too.
          To show all installed unit files use 'systemctl list-unit-files'.
          *** FILESYSTEM ***
          /dev/root      ext4       59G   18G   39G  32% /
          devtmpfs       devtmpfs  1.8G     0  1.8G   0% /dev
          tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
          tmpfs          tmpfs     1.9G   17M  1.9G   1% /run
          tmpfs          tmpfs     1.9G     0  1.9G   0% /sys/fs/cgroup
          /dev/mmcblk0p1 vfat      253M   49M  204M  20% /boot
          tmpfs          tmpfs     384M     0  384M   0% /run/user/1000
          [Fri Oct 27 13:24:41 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=DC:A6:32:A6:9D:71 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=6c586e13-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
          [Fri Oct 27 13:24:42 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
          [Fri Oct 27 13:24:42 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
          [Fri Oct 27 13:24:44 2023] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
          TARGET        SOURCE         FSTYPE OPTIONS
          /             /dev/mmcblk0p2 ext4   rw,noatime
          |-/sys/fs/bpf none           bpf    rw,nosuid,nodev,noexec,relatime,mode=700
          `-/boot       /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
          /var:
          1.1G    /var/
          463M    /var/lib
          304M    /var/cache
          298M    /var/cache/apt
          239M    /var/cache/apt/archives
          Archived and active journals take up 16.0M in the file system.
          /opt/iobroker/backups:
          11G     /opt/iobroker/backups/
          4.0K    /opt/iobroker/backups/influxDB_2022_08_21-02_00_17_backupiobroker
          4.0K    /opt/iobroker/backups/influxDB_2022_08_20-02_00_17_backupiobroker
          4.0K    /opt/iobroker/backups/influxDB_2022_08_19-02_00_17_backupiobroker
          4.0K    /opt/iobroker/backups/influxDB_2022_08_18-02_00_17_backupiobroker
          /opt/iobroker/iobroker-data:
          1.3G    /opt/iobroker/iobroker-data/
          918M    /opt/iobroker/iobroker-data/history
          255M    /opt/iobroker/iobroker-data/files
          105M    /opt/iobroker/iobroker-data/backup-objects
          72M     /opt/iobroker/iobroker-data/files/telegram.admin
          27M     /opt/iobroker/iobroker-data/files/material/static/js/2.73100bd6.chunk.js.map
          15M     /opt/iobroker/iobroker-data/files/telegram.admin/rules/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_d_ts-node_modules_io-1d9f06.44fe4a3f.chunk.js.map
          12M     /opt/iobroker/iobroker-data/objects.jsonl
          7.2M    /opt/iobroker/iobroker-data/files/telegram.admin/rules/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_d_ts-node_modules_io-1d9f06.44fe4a3f.chunk.js
          6.9M    /opt/iobroker/iobroker-data/files/telegram.admin/custom/static/js/vendors-node_modules_mui_icons-material_esm_index_js.8fdf8cb7.chunk.js.map
          USB-Devices by-id:
          /dev/serial/by-id/usb-Espressif_USB_JTAG_serial_debug_unit_DC:54:75:BA:43:98-if00
          /dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B0014D47D89-if00
          *** NodeJS-Installation ***
          /usr/bin/nodejs         v16.19.0
          /usr/bin/node           v16.19.0
          /usr/bin/npm            8.19.3
          /usr/bin/npx            8.19.3
          /usr/bin/corepack       0.15.1
          nodejs:
            Installed: 16.19.0-deb-1nodesource1
            Candidate: 16.20.2-deb-1nodesource1
            Version table:
               16.20.2-deb-1nodesource1 500
                  500 https://deb.nodesource.com/node_16.x buster/main armhf Packages
           *** 16.19.0-deb-1nodesource1 100
                  100 /var/lib/dpkg/status
               10.24.0~dfsg-1~deb10u3 500
          No problems detected
          Errors in npm tree:
          npm ERR! code ELSPROBLEMS
          npm ERR! extraneous: @buttercup/fetch@0.1.2 /opt/iobroker/node_modules/@buttercup/fetch
          npm ERR! extraneous: @googleapis/drive@5.1.0 /opt/iobroker/node_modules/@googleapis/drive
          npm ERR! extraneous: @microsoft/microsoft-graph-types@2.38.0 /opt/iobroker/node_modules/@microsoft/microsoft-graph-types
          npm ERR! extraneous: arrify@2.0.1 /opt/iobroker/node_modules/arrify
          npm ERR! extraneous: base-64@1.0.0 /opt/iobroker/node_modules/base-64
          npm ERR! extraneous: byte-length@1.0.2 /opt/iobroker/node_modules/byte-length
          npm ERR! extraneous: charenc@0.0.2 /opt/iobroker/node_modules/charenc
          npm ERR! extraneous: compress-json@2.1.2 /opt/iobroker/node_modules/compress-json
          npm ERR! extraneous: crypt@0.0.2 /opt/iobroker/node_modules/crypt
          npm ERR! extraneous: data-uri-to-buffer@4.0.1 /opt/iobroker/node_modules/data-uri-to-buffer
          npm ERR! extraneous: dropbox-v2-api@2.5.10 /opt/iobroker/node_modules/dropbox-v2-api
          npm ERR! extraneous: fast-text-encoding@1.0.6 /opt/iobroker/node_modules/fast-text-encoding
          npm ERR! extraneous: fast-xml-parser@3.21.1 /opt/iobroker/node_modules/fast-xml-parser
          npm ERR! extraneous: fetch-blob@3.2.0 /opt/iobroker/node_modules/fetch-blob
          npm ERR! extraneous: form-data-encoder@2.1.4 /opt/iobroker/node_modules/form-data-encoder
          npm ERR! extraneous: formdata-polyfill@4.0.10 /opt/iobroker/node_modules/formdata-polyfill
          npm ERR! extraneous: ftp@0.3.10 /opt/iobroker/node_modules/ftp
          npm ERR! extraneous: gaxios@5.1.0 /opt/iobroker/node_modules/gaxios
          npm ERR! extraneous: gcp-metadata@5.2.0 /opt/iobroker/node_modules/gcp-metadata
          npm ERR! extraneous: google-p12-pem@4.0.1 /opt/iobroker/node_modules/google-p12-pem
          npm ERR! extraneous: gtoken@6.1.2 /opt/iobroker/node_modules/gtoken
          npm ERR! extraneous: he@1.2.0 /opt/iobroker/node_modules/he
          npm ERR! extraneous: hot-patcher@1.0.0 /opt/iobroker/node_modules/hot-patcher
          npm ERR! missing: iobroker.backitup@2.6.19, required by iobroker.inst@2.0.3
          npm ERR! invalid: iobroker.flot@1.12.0 /opt/iobroker/node_modules/iobroker.flot
          npm ERR! extraneous: is-buffer@1.1.6 /opt/iobroker/node_modules/is-buffer
          npm ERR! extraneous: is-empty-object@1.1.1 /opt/iobroker/node_modules/is-empty-object
          npm ERR! extraneous: layerr@0.1.2 /opt/iobroker/node_modules/layerr
          npm ERR! extraneous: md5@2.3.0 /opt/iobroker/node_modules/md5
          npm ERR! extraneous: nested-property@4.0.0 /opt/iobroker/node_modules/nested-property
          npm ERR! extraneous: node-domexception@1.0.0 /opt/iobroker/node_modules/node-domexception
          npm ERR! extraneous: node-wol@0.1.1 /opt/iobroker/node_modules/node-wol
          npm ERR! extraneous: path-posix@1.0.0 /opt/iobroker/node_modules/path-posix
          npm ERR! extraneous: readable-stream@1.1.14 /opt/iobroker/node_modules/readable-stream
          npm ERR! extraneous: url-join@4.0.1 /opt/iobroker/node_modules/url-join
          npm ERR! extraneous: url-template@2.0.8 /opt/iobroker/node_modules/url-template
          npm ERR! extraneous: web-streams-polyfill@3.2.1 /opt/iobroker/node_modules/web-streams-polyfill
          npm ERR! extraneous: xregexp@2.0.0 /opt/iobroker/node_modules/xregexp
          npm ERR! extraneous: node-fetch@3.3.2 /opt/iobroker/node_modules/@buttercup/fetch/node_modules/node-fetch
          npm ERR! missing: googleapis-common@^6.0.3, required by @googleapis/drive@5.1.0
          npm ERR! invalid: @iobroker/adapter-core@2.6.0 /opt/iobroker/node_modules/@iobroker/adapter-core
          npm ERR! invalid: axios@0.27.2 /opt/iobroker/node_modules/axios
          npm ERR! extraneous: form-data@4.0.0 /opt/iobroker/node_modules/iobroker.info/node_modules/form-data
          npm ERR! invalid: @types/node@14.18.36 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/node
          npm ERR! extraneous: isarray@0.0.1 /opt/iobroker/node_modules/readable-stream/node_modules/isarray
          npm ERR! missing: source-map@^0.6.0, required by source-map-support@0.5.21
          npm ERR!     /home/pi/.npm/_logs/2023-10-27T12_09_48_576Z-debug-0.log
          *** ioBroker-Installation ***
          ioBroker Status
          Require stack:
          Core adapters versions
          js-controller:  4.0.23
          admin:          6.12.0
          javascript:     6.1.4
          npm ERR!     /home/pi/.npm/_logs/2023-10-27T12_10_36_692Z-debug-0.log
          Adapters from github:   0
          Adapter State
           States database error: connect ECONNREFUSED 127.0.0.1:9000
           redis get system.host.iobroker.alive, error - Connection is closed.
           redis get system.host.iobroker.plugins.sentry.enabled, error - Connection is closed.
          Require stack:
           Cannot load "redlock_acquire": Connection is closed.
           Cannot load "redlock_extend": Connection is closed.
           Cannot load "redlock_release": Connection is closed.
           Cannot load "script": Connection is closed.
           Cannot initialize database scripts: Cannot load "script" into objects database: Connection is closed.
          Require stack:
          ioBroker-Repositories
          Require stack:
          Installed ioBroker-Instances
          Require stack:
          Objects and States
          Objects:        7
          States:         6
          W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://repos.influxdata.com/debian buster InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
          W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://packages.grafana.com/oss/deb stable InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 963FA27710458545
          W: Failed to fetch https://packages.grafana.com/oss/deb/dists/stable/InRelease  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 963FA27710458545
          W: Failed to fetch https://repos.influxdata.com/debian/dists/buster/InRelease  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
          W: Some index files failed to download. They have been ignored, or old ones used instead.
          Hit:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
          Get:2 https://repos.influxdata.com/debian buster InRelease [7047 B]
          Hit:3 http://archive.raspberrypi.org/debian buster InRelease
          Hit:4 https://deb.nodesource.com/node_16.x buster InRelease
          Hit:5 https://repo.ebusd.eu/apt/default/buster buster InRelease
          Get:6 https://packages.grafana.com/oss/deb stable InRelease [5984 B]
          Err:2 https://repos.influxdata.com/debian buster InRelease
          Err:6 https://packages.grafana.com/oss/deb stable InRelease
          Fetched 7047 B in 2s (3863 B/s)
          Reading package lists...
          Pending Updates: 140
          *** Listening Ports ***
          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          17601      624/sshd
          tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      999        17656      596/influxd
          tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       93822      10860/iobroker.js-c
          tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       91866      10860/iobroker.js-c
          tcp        0      0 127.0.0.1:6379          0.0.0.0:*               LISTEN      109        16291      626/redis-server 12
          tcp6       0      0 :::8086                 :::*                    LISTEN      999        21054      596/influxd
          tcp6       0      0 :::22                   :::*                    LISTEN      0          17603      624/sshd
          tcp6       0      0 :::3000                 :::*                    LISTEN      115        20987      747/grafana-server
          tcp6       0      0 :::3306                 :::*                    LISTEN      114        19459      679/mysqld
          tcp6       0      0 ::1:6379                :::*                    LISTEN      109        16292      626/redis-server 12
          udp        0      0 0.0.0.0:49154           0.0.0.0:*                           108        14026      412/avahi-daemon: r
          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        14024      412/avahi-daemon: r
          udp6       0      0 :::5353                 :::*                                108        14025      412/avahi-daemon: r
          udp6       0      0 :::42381                :::*                                108        14027      412/avahi-daemon: r
          Require stack:
          - /opt/iobroker/node_modules/iobroker.js-controller/main.js
          - /opt/iobroker/node_modules/iobroker.js-controller/controller.js
          2023-10-27 14:14:50.816  - error: host.iobroker Error: Cannot find module 'source-map'
          Require stack:
            Thomas Braun Most Active @paul01 last edited by Thomas Braun
            @paul01
            Buster ist tot, installier da Debian 12 'Bookworm' (64Bit Lite) neu und spiel dann dein Update ein.
            Und das neue System dann besser pflegen. 140 hängende Updates und veraltete Repos zeigen ein versumpftes Ding an.
              ich denke das ding ist nun komplett zerschossen, upgrade auf bookworm hat ihm den rest gegeben. danke für deinen support! werde nicht um einen kompletten neustart herumkommen. wie du schreibst, pflege hat in letzter zeit leider sehr gelitten.
                @paul01
                Ich hatte doch geschrieben, du sollst das NEUinstallieren. Als 64Bit-Version.
