    3. Entwicklung
    4. Adapter mit debug output - zu viele Ausgaben wenn redis verwendet wird!
    • frankjoke
      frankjoke last edited by
      Hallo mitsammen,
      ich versuche einen (#5) Adapter zu programmieren und verwende auch etliche adapter.log.debug-Messages.
      Wenn man allerdings redis verwendet dann werden vom system alle updates zur adapter-maintenance
      broadlink2.0	2017-07-24 10:36:47.215	debug	redis publish io.system.adapter.broadlink2.0.alive {"val":true,"ack":true,"ts":1500885407192,"q":0,"from":"system.adapter.broadlink2.0","lc":1500884101309}
      broadlink2.0	2017-07-24 10:36:32.209	debug	redis publish io.system.adapter.broadlink2.0.outputCount {"val":8,"ack":true,"ts":1500885392203,"q":0,"from":"system.adapter.broadlink2.0","lc":1500884146307}
      broadlink2.0	2017-07-24 10:36:32.208	debug	redis publish io.system.adapter.broadlink2.0.inputCount {"val":0,"ack":true,"ts":1500885392201,"q":0,"from":"system.adapter.broadlink2.0","lc":1500884146304}
      broadlink2.0	2017-07-24 10:36:32.208	debug	redis publish io.system.adapter.broadlink2.0.uptime {"val":1294,"ack":true,"ts":1500885392199,"q":0,"from":"system.adapter.broadlink2.0","lc":1500885392199}
      broadlink2.0	2017-07-24 10:36:32.208	debug	redis publish io.system.adapter.broadlink2.0.memHeapUsed {"val":9.1,"ack":true,"ts":1500885392197,"q":0,"from":"system.adapter.broadlink2.0","lc":1500885392197}
      broadlink2.0	2017-07-24 10:36:32.207	debug	redis publish io.system.adapter.broadlink2.0.memHeapTotal {"val":12,"ack":true,"ts":1500885392196,"q":0,"from":"system.adapter.broadlink2.0","lc":1500884791833}
      broadlink2.0	2017-07-24 10:36:32.207	debug	redis publish io.system.adapter.broadlink2.0.memRss {"val":28.73,"ack":true,"ts":1500885392192,"q":0,"from":"system.adapter.broadlink2.0","lc":1500885392192}
      broadlink2.0	2017-07-24 10:36:32.207	debug	redis publish io.system.adapter.broadlink2.0.connected {"val":true,"ack":true,"ts":1500885392186,"q":0,"from":"system.adapter.broadlink2.0","lc":1500884101313}
      br
      ````ausgegeben.
      Kann man das nicht ändern und dem js-controller als Adapter zuordnen?
      Man kann den 'debug'-mode kaum verwenden wenn redis aktiv ist da alle 15 sekunden 8 Meldungen erzeugt werden die den Log überschwemmen!
      • apollon77
        apollon77 last edited by
        Ja, das ist nervig, aber faktisch gehört es nicht zum js-controller.
        Jeder Adapter nutzt eine eigene Verbindnung zum Redis und diese wird vom Adapterprozess direkt aufgebaut.
        grep -v "redis"
        nutze ich 🙂
        frankjoke 1 Reply Last reply Reply Quote 0
        • frankjoke
          frankjoke @apollon77 last edited by
          @apollon77 sagte in Adapter mit debug output - zu viele Ausgaben wenn redis verwendet wird!:
          grep -v "redis"
          nutze ich 🙂
          Kann man diesen loglevel bei den redis-logs nicht auf silly setzten? Dann wären sie da wo sie erwartet werden.
