    4. NodeRed kaput, alles im Haus steht
    • E
      edstobi last edited by Negalein
      Hallo
      Mein NodeRed hat den Dienst versagt und nichts geht mehr. Es startet laut IObroker log kontinuierlich immer durch.
      node-red.0
      2023-10-28 23:44:51.098	info	Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
      node-red.0
      2023-10-28 23:44:46.095	info	node-red exited with 6
      node-red.0
      [2023-10-28 23:44:45.661	error	28 Oct 23:44:45 - [error] [function:schreibe daten in flow] Error: Invalid property expression: unexpected ' ' at position 13]
      node-red.0
      2023-10-28 23:44:45.459	debug	28 Oct 23:44:45 - [info] [mqtt-broker:32723617.b884aa] Verbindung zum Broker mqtt://xxxx193:1883 aufgebaut
      node-red.0
      2023-10-28 23:44:45.438	debug	28 Oct 23:44:45 - [info] [mqtt-broker:1xxx160:1883] Verbindung zum Broker mqtt://xxx60:1883 aufgebaut
      node-red.0
      2023-10-28 23:44:45.426	debug	28 Oct 23:44:45 - [info] [tasmota-mqtt-broker:mqtt160] Connected to broker: mqtt://xxx160:1883
      node-red.0
      2023-10-28 23:44:44.743	warn	(node:28427) [DEP0128] DeprecationWarning: Invalid 'main' field in '/opt/iobroker/iobroker-data/node-red/node_modules/node-red-dashboard/package.json' of 'none'. Please either fix that or report it to the module author (Use `node --trace-deprecation ...` to show where the warning was created)
      node-red.0
      2023-10-28 23:44:43.794	debug	28 Oct 23:44:43 - [info] Flows sind gestartet
      node-red.0
      2023-10-28 23:44:42.896	debug	28 Oct 23:44:42 - [info] [whatsappLink:Web] Status : Initializing Whatsapp..
      node-red.0
      2023-10-28 23:44:41.274	debug	28 Oct 23:44:41 - [info] Flows werden gestartet
      node-red.0
      2023-10-28 23:44:40.706	debug	28 Oct 23:44:40 - [info] Flow-Datei: /opt/iobroker/iobroker-data/node-red/projects/pi4-iobroker/flows.json
      node-red.0
      2023-10-28 23:44:40.704	debug	28 Oct 23:44:40 - [info] Aktives Projekt: pi4-iobroker
      node-red.0
      2023-10-28 23:44:40.659	debug	28 Oct 23:44:40 - [info] Server wird jetzt auf http://127.0.0.1:1880/ ausgeführt
      node-red.0
      2023-10-28 23:44:40.418	debug	28 Oct 23:44:40 - [info] Projektverzeichnis: /opt/iobroker/iobroker-data/node-red/projects
      node-red.0
      2023-10-28 23:44:40.416	debug	28 Oct 23:44:40 - [info] Benutzerverzeichnis: /opt/iobroker/iobroker-data/node-red/
      node-red.0
      2023-10-28 23:44:40.323	debug	28 Oct 23:44:40 - [info] Kontextspeicher: default [module=memory]
      node-red.0
      2023-10-28 23:44:40.321	debug	28 Oct 23:44:40 - [info] Kontextspeicher: storeInFile [module=localfilesystem]
      node-red.0
      2023-10-28 23:44:40.313	debug	28 Oct 23:44:40 - [info] Einstellungsdatei: /opt/iobroker/iobroker-data/node-red/settings.js
      node-red.0
      2023-10-28 23:44:40.311	warn	28 Oct 23:44:40 - [warn] ------------------------------------------------------
      node-red.0
      2023-10-28 23:44:40.309	warn	28 Oct 23:44:40 - [warn] [node-red-contrib-moment2/moment] Der Typ 'moment' ist bereits von Modul 'node-red-contrib-moment' registriert
      node-red.0
      2023-10-28 23:44:40.304	warn	28 Oct 23:44:40 - [warn] ------------------------------------------------------
      node-red.0
      2023-10-28 23:44:39.139	debug	28 Oct 23:44:39 - [info] Polymer started at /polymer
      node-red.0
      2023-10-28 23:44:38.589	debug	28 Oct 23:44:38 - [info] Dashboard version 2.28.2 started at /ui
      node-red.0
      2023-10-28 23:44:32.183	debug	28 Oct 23:44:32 - [info] Paletten-Nodes werden geladen
      node-red.0
      2023-10-28 23:44:32.182	debug	28 Oct 23:44:32 - [info] Paletteneditor deaktiviert: Einstellungen
      node-red.0
      2023-10-28 23:44:32.172	debug	28 Oct 23:44:32 - [info] Linux 5.10.103-v7l+ arm LE
      node-red.0
      2023-10-28 23:44:32.170	debug	28 Oct 23:44:32 - [info] Node.js Version: v18.18.2
      node-red.0
      2023-10-28 23:44:32.169	debug	28 Oct 23:44:32 - [info] Node-RED Version: v3.0.2
      node-red.0
      2023-10-28 23:44:32.165	debug	28 Oct 23:44:32 - [info] Willkommen bei Node-RED ===================
      node-red.0
      2023-10-28 23:44:30.197	info	Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
      node-red.0
      2023-10-28 23:44:27.938	debug	Writing extended authentication for authType: "None" : {"type":"credentials","users":[],"default":{"permissions":"*"}}
      node-red.0
      2023-10-28 23:44:27.770	info	Requested NPM packages: ["node-red-dashboard","node-red-node-openweathermap","node-red-contrib-ui-led","node-red-node-mysql","node-red-contrib-schedex","node-red-node-ping","node-red-contrib-telegrambot","node-red-node-wemo","node-red-contrib-moment2","node-red-contrib-shift-register","node-red-contrib-ui-multistate-switch","node-red-contrib-s7","node-red-contrib-sun-position","node-red-contrib-simpletime","node-red-contrib-owfs","node-red-contrib-boolean-logic","node-red-contrib-toggle","node-red-node-random","node-red-contrib-buffer-parser","node-red-contrib-influxdb","node-red-contrib-tasmota","node-red-contrib-wled","node-red-contrib-wled2","node-red-contrib-nora","node-red-contrib-timeouttrigger","node-red-contrib-hysteresis","node-red-contrib-button-events","node-red-contrib-whatsapp-link"]
      node-red.0
      2023-10-28 23:44:27.729	info	starting. Version 4.0.3 in /opt/iobroker/node_modules/iobroker.node-red, node: v18.18.2, js-controller: 5.0.15
      Ich weiß nicht was ich aus den Fehlermeldungen ableiten kann/soll
      Ich habe vor einigen Stunden ein Backup von NodeRed mit Backitup auf mein Google Drive gemacht.
      Die Datei nodered.0_2023_10_28-21_40_42_Pi_backupiobroker.tar.gz habe ich mir auf meinen Windows Rechner zurück geladen. Wie sage ich Backitup das es diese Datei auf meinen PI IObroker zurückspielt.
      Ich habe Angst noch mehr zu zerstören und bitte um Hilfe, da in NodeRed Jahre an Arbeit stecken.
      Heute Abend mache ich nichts mehr, da ich zu hibbelig bin und hoffe morgen mit eurer Hilfe NodeRed im IO Broker wieder zum laufen zu bekommen.
      Marc
      Mod-Edit: Code/Log in Code Tags gepackt. Bitte benutzt die Code Tags Funktion -> </>
      Hier gehts zur Hilfe.
      DJMarc75 mickym 2 Replies Last reply Reply Quote 0
      • DJMarc75
        DJMarc75 @edstobi last edited by
        @edstobi
        Bitte Texte in Codetags packen, danke.
        • mickym
          mickym Most Active @edstobi last edited by mickym
          @edstobi Schalter den Sicherheitsmodus in Node-red und starte dann den Adapter neu.
          Dann suchst du diese function node und deaktivierst diese Node und versuchst dann normal zu starten. Dann musst du den fehlerhaften Code überarbeiten
          • E
            @mickym
            Danke für deine Antwort. Ich habe mit meinen reparaturversuchen mittlerweile den IOBROKER geschrottet das nichts mehr geht. Ich versuche jetzt (11:50) ein komplettes Backup welches ich vor dem letzten Update mit ioBrokerToo gemacht habe, zurück zu spielen. Die Hoffnung stirbt zuletzt.
            Magst du mir erklären wie man den heirsmodus einschaltet? und startet man dann NodeRed ganz normal?
            mickym Homoran 2 Replies Last reply Reply Quote 0
            • mickym
              @edstobi den Sicherheitsmodus aktivierst du in der Adapterkonfiguration. NodeRed startet dann, die Flows sind dann aber alle gestoppt. Du kannst dann die fehlerhafte Node deaktivieren oder den fehlerhaften Flow deaktivieren und dann alle Flows über das Übernehmen Menü starten. Dann starten alle Flows bis auf die deaktivierten Flows oder Nodes.
                Homoran Global Moderator Administrators @edstobi last edited by
                @edstobi sagte in NodeRed kaput, alles im Haus steht:
                Was ist denn das?
                ? E 2 Replies Last reply Reply Quote 0
                • mickym
                  mickym Most Active @mickym last edited by
                  @mickym wenn du im iobroker backitup eine node-red backup gemacht hast und das mit dem Sicherheitsmodus nicht klappt dann gibt’s noch ein paar Möglichkeiten- aber probiere erst mal den Sicherheitsmodus.
                    A Former User @Homoran last edited by
                    @homoran sagte in NodeRed kaput, alles im Haus steht:
                    Was ist denn das?
                    Moin,
                    auch ein Tool, dass mal vor 4 Jahren entstanden ist ⇒ https://www.elzershark.com/forum/index.php?thread/4-backup-reparatur-install-tool-iobroker/ wird wohl aber noch gepflegt. Initiator ist @Elzershark
                    VG
                    Bernd
                    • E
                      edstobi @Homoran last edited by Homoran
                      Schau einmal hier
                      "IoBroker Backitup Adapter einrichten und die Backups auf USB Stick speichern How To": https://www.youtube.com/watch?v=qQSefltobbY&t=531s
                      Was ich noch nicht kannte war der Sicherheitsmodus in node red. Der hätte mich bestimmt sehr viel besser schlafen lassen und ich hätte kein komplettes Backup zurückspielen müssen.
                      ABER es hat funktioniert!!🤸 🥂
                      • E
                        edstobi @mickym last edited by
                        @mickym
                        Dankeschön. Habe jetzt etwas gelernt was ich bestimmt nicht mehr vergessen werde. Dankschön.
                        Was ein kleiner Haken ✅ doch die Welt einfacher machen kann
                          Homoran Global Moderator Administrators @Guest last edited by
                          @dp20eic sagte in NodeRed kaput, alles im Haus steht:
                          auch ein Tool,
                          das hab ich fast befürchtet.
                          Scheint ein Rundumschlag mit root und Rechteverbiegung zu sein.
                          DJMarc75 E 2 Replies Last reply Reply Quote 1
                          • DJMarc75
                            DJMarc75 @Homoran last edited by
                            @homoran und zusätzlich vom "Entwickler" so kommentiert:
                            Es ist halt Node 16, statt Node 18. Aber es muss ja nicht das allerneuste sein. Trotzdem funzt es. Dauert nur. Ist halt sehr langsam.
                            Hast du es denn getestet??? Bei mir läuft das einwandfrei
                            Ich mach grad Popcorn 🤡
                            • E
                              Nein, es arbeitet mit den Berechtigungen welche der IO Broker hat.
                              sudo hat bei mir andere Berechtigungen auf dem PI.
                              Ist auch egal, es hat mir den Ars.. gerettet und auch schon einen Umzug erleichtert, wird weiterentwickelt, gepflegt und ist für nicht linux Leute toll. Einfach mal anschauen.
                              • mickym
                                Sorry für die Verwirrung - aber auf dem iPad tippt es sich nicht immer fehlerfrei. 😉
                                • E
                                  @mickym Es läuft alles wieder. Das ist die Hauptsache!!
                                  Ich habe etwas gelernt. Das ist Gut
                                  Und ich lasse jetzt die Finger von NodeRed WhatsApp, den das war der Bösewicht!
                                  Das werde ich die Tage auf einem Testsystem testen, Nicht mehr im Live system. Lesson learned
                                  mickym 1 Reply Last reply Reply Quote 1
                                  • mickym
                                    @edstobi ich dachte nach Deinem Log eher - dass es eine function Node war
                                    Das hätte ich als erstes versucht
                                      Thomas Braun Most Active @edstobi last edited by
                                      @edstobi
                                      Das dolle "Tool" ist vollkommene Grütze. Finger weg von dem Ding, das verbiegt dir alles auf der Kiste.
                                      • mickym
                                        mickym Most Active @Thomas Braun last edited by
                                        @thomas-braun sagte in NodeRed kaput, alles im Haus steht:
                                        @edstobi
                                        Was meinst Du damit?
                                          Thomas Braun Most Active @mickym last edited by
                                          @mickym
                                          Dieses krumme Ding vom Elsterhai oder wie der heißt.
                                          • mickym
                                            @thomas-braun Ach so - ich hab gar nicht gelesen, dass sowas verwendet wurde. 😞
                                            1142
