    4. js-controller fehler
    • I
      ingenii last edited by
      Hallo, ich hab nach langen zeit ein update gemacht und nach neustart kommt dieser fehler:
      web.0
      	2023-10-30 16:33:38.715	info	starting. Version 6.1.2 in /opt/iobroker/node_modules/iobroker.web, node: v18.18.2, js-controller: 5.0.12
      web.0
      	2023-10-30 15:33:03.693	error	Parameter "id" needs to be of type "string" but type "undefined" has been passed
      web.0
      	2023-10-30 15:33:03.693	error	Error: Parameter "id" needs to be of type "string" but type "undefined" has been passed at Function.assertString (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/validator.ts:241:19) at AdapterClass.destroySession (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:1332:19) at Object.commands.logout (/opt/iobroker/node_modules/@iobroker/socket-classes/lib/socketCommands.js:863:26) at Socket.<anonymous> (/opt/iobroker/node_modules/@iobroker/socket-classes/lib/socketCommands.js:1786:43) at Socket.emit (node:events:517:28) at Socket.emit (node:domain:489:12) at /opt/iobroker/node_modules/socket.io/lib/socket.js:531:14 at processTicksAndRejections (node:internal/process/task_queues:77:11)
      web.0
      	2023-10-30 15:33:03.691	error	uncaught exception: Parameter "id" needs to be of type "string" but type "undefined" has been passed
      mcm1957 Homoran Thomas Braun 3 Replies Last reply Reply Quote 0
      • mcm1957
        mcm1957 @ingenii last edited by
        @ingenii
        Bitte die Raterunde entlasten:
        Versionen:
        adapter (web)
        js-controller
        admin
        node
        O/S
        Und wenn du den js-controlelr aktualisisert hat, hast du die Adapter aktualisisert?
        I 1 Reply Last reply Reply Quote 1
          Homoran Global Moderator Administrators @ingenii last edited by
          @ingenii sagte in js-controller fehler:
          dann sieh mal dort nach
            Thomas Braun Most Active @ingenii last edited by
            @ingenii
            Gib mal die Ausgabe von
            iob diag
            zum Besten.
            • I
              ingenii @mcm1957 last edited by
              @mcm57
              Adapter (web) v6.1.2
              admin v6.12.0
              node: v18.18.2
              Rasp 4 debian
              • I
                ingenii @Thomas Braun last edited by
                Skript v.2023-10-10
                *** BASE SYSTEM ***
                   Static hostname: iobroker-pi
                         Icon name: computer
                            Kernel: Linux 6.1.21-v8+
                      Architecture: arm64
                Model           : Raspberry Pi 4 Model B Rev 1.5
                Docker          : false
                Virtualization  : none
                Kernel          : aarch64
                Userland        : armhf
                Systemuptime and Load:
                 18:21:42 up  3:13,  3 users,  load average: 0.96, 0.84, 0.49
                CPU threads: 4
                *** RASPBERRY THROTTLING ***
                Current issues:
                Previously detected issues:
                *** Time and Time Zones ***
                               Local time: Mon 2023-10-30 18:21:42 GMT
                           Universal time: Mon 2023-10-30 18:21:42 UTC
                                 RTC time: n/a
                                Time zone: Europe/London (GMT, +0000)
                              NTP service: active
                          RTC in local TZ: no
                *** User and Groups ***
                admin
                /home/admin
                admin adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi
                *** X-Server-Setup ***
                X-Server:       false
                Desktop:
                Terminal:       tty
                *** MEMORY ***
                Mem:            7.9G        1.4G        5.4G        1.0M        1.1G        6.3G
                Swap:            99M          0B         99M
                Total:          8.0G        1.4G        5.5G
                         7862 M total memory
                         1391 M used memory
                         1396 M active memory
                          572 M inactive memory
                         5407 M free memory
                          178 M buffer memory
                          884 M swap cache
                           99 M total swap
                            0 M used swap
                           99 M free swap
                Raspberry only:
                oom events: 0
                *** FAILED SERVICES ***
                0 loaded units listed.
                *** FILESYSTEM ***
                /dev/root      ext4      235G   30G  195G  14% /
                devtmpfs       devtmpfs  3.6G     0  3.6G   0% /dev
                tmpfs          tmpfs     1.6G  1.1M  1.6G   1% /run
                /dev/mmcblk0p1 vfat      255M   51M  205M  20% /boot
                tmpfs          tmpfs     787M     0  787M   0% /run/user/0
                tmpfs          tmpfs     787M     0  787M   0% /run/user/1002
                tmpfs          tmpfs     787M     0  787M   0% /run/user/1000
                [Mon Oct 30 15:08:36 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=D8:3A:DD:1E:08:F2 vc_mem.mem_base=0x3f000000 vc_mem.mem_size=0x3f600000  console=ttyS0,115200 console=tty1 root=PARTUUID=ba329448-02 rootfstype=ext4 fsck.repair=yes rootwait
                [Mon Oct 30 15:08:37 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
                [Mon Oct 30 15:08:37 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                [Mon Oct 30 15:08:40 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
                TARGET  SOURCE         FSTYPE OPTIONS
                /       /dev/mmcblk0p2 ext4   rw,noatime
                `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                /var:
                685M    /var/
                311M    /var/cache
                306M    /var/cache/apt
                241M    /var/cache/apt/archives
                180M    /var/log
                Archived and active journals take up 176.0M in the file system.
                /opt/iobroker/backups:
                1.3G    /opt/iobroker/backups/
                228K    /opt/iobroker/backups/Heizung_1
                132K    /opt/iobroker/backups/Licht
                44K     /opt/iobroker/backups/Rollo
                20K     /opt/iobroker/backups/Bewässerung
                /opt/iobroker/iobroker-data:
                24G     /opt/iobroker/iobroker-data/
                23G     /opt/iobroker/iobroker-data/history
                886M    /opt/iobroker/iobroker-data/files
                210M    /opt/iobroker/iobroker-data/backup-objects
                121M    /opt/iobroker/iobroker-data/history/20211110
                41M     /opt/iobroker/iobroker-data/files/material/static/js/main.c5478f66.js.map
                35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
                24M     /opt/iobroker/iobroker-data/objects.jsonl
                23M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.eb0afecd.js.map
                23M     /opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.7952f0f7.js.map
                USB-Devices by-id:
                *** NodeJS-Installation ***
                /usr/bin/nodejs         v18.18.2
                /usr/bin/node           v18.18.2
                /usr/bin/npm            9.8.1
                /usr/bin/npx            9.8.1
                /usr/bin/corepack       0.19.0
                nodejs:
                  Version table:
                 *** 18.18.2-1nodesource1 1001
                        500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
                        100 /var/lib/dpkg/status
                     18.18.1-1nodesource1 1001
                     18.18.0-1nodesource1 1001
                     18.17.1-1nodesource1 1001
                     18.17.0-1nodesource1 1001
                     18.16.1-1nodesource1 1001
                     18.16.0-1nodesource1 1001
                     18.15.0-1nodesource1 1001
                     18.14.2-1nodesource1 1001
                     18.14.1-1nodesource1 1001
                     18.14.0-1nodesource1 1001
                     18.13.0-1nodesource1 1001
                     18.12.0-1nodesource1 1001
                     18.11.0-1nodesource1 1001
                     18.10.0-1nodesource1 1001
                     18.9.1-1nodesource1 1001
                     18.9.0-1nodesource1 1001
                     18.8.0-1nodesource1 1001
                     18.7.0-1nodesource1 1001
                     18.6.0-1nodesource1 1001
                     18.5.0-1nodesource1 1001
                     18.4.0-1nodesource1 1001
                     18.3.0-1nodesource1 1001
                     18.2.0-1nodesource1 1001
                     18.1.0-1nodesource1 1001
                     18.0.0-1nodesource1 1001
                     12.22.12~dfsg-1~deb11u4 500
                No problems detected
                Errors in npm tree:
                npm ERR! code ELSPROBLEMS
                npm ERR! missing: homebridge@^1.5.0, required by iobroker.ham@5.3.1
                npm ERR! A complete log of this run can be found in: /home/admin/.npm/_logs/2023-10-30T18_21_53_311Z-debug-0.log
                *** ioBroker-Installation ***
                ioBroker Status
                Objects type: jsonl
                States  type: jsonl
                Core adapters versions
                admin:          6.12.0
                javascript:     7.1.4
                Adapters from github:   0
                Adapter State
                + system.adapter.admin.0                  : admin                 : iobroker-pi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                  system.adapter.alarm.0                  : alarm                 : iobroker-pi                              - disabled
                  system.adapter.alexa2.0                 : alexa2                : iobroker-pi                              - disabled
                + system.adapter.backitup.0               : backitup              : iobroker-pi                              -  enabled
                + system.adapter.cloud.0                  : cloud                 : iobroker-pi                              -  enabled
                  system.adapter.countdown.0              : countdown             : iobroker-pi                              - disabled
                  system.adapter.daswetter.0              : daswetter             : iobroker-pi                              - disabled
                  system.adapter.device-reminder.0        : device-reminder       : iobroker-pi                              - disabled
                  system.adapter.devices.0                : devices               : iobroker-pi                              -  enabled
                  system.adapter.discovergy.0             : discovergy            : iobroker-pi                              - disabled
                + system.adapter.discovery.0              : discovery             : iobroker-pi                              -  enabled
                + system.adapter.echarts.0                : echarts               : iobroker-pi                              -  enabled
                  system.adapter.email.0                  : email                 : iobroker-pi                              - disabled
                  system.adapter.flot.0                   : flot                  : iobroker-pi                              -  enabled
                  system.adapter.habpanel.0               : habpanel              : iobroker-pi                              -  enabled
                  system.adapter.ham.0                    : ham                   : iobroker-pi                              - disabled
                + system.adapter.history.0                : history               : iobroker-pi                              -  enabled
                + system.adapter.hm-rega.0                : hm-rega               : iobroker-pi                              -  enabled
                + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker-pi                              -  enabled, port: 0
                + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker-pi                              -  enabled, port: 0
                  system.adapter.homeconnect.0            : homeconnect           : iobroker-pi                              - disabled
                  system.adapter.ical.0                   : ical                  : iobroker-pi                              -  enabled
                  system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: iobroker-pi                              -  enabled
                  system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : iobroker-pi                              -  enabled
                  system.adapter.icons-icons8.0           : icons-icons8          : iobroker-pi                              -  enabled
                  system.adapter.icons-material-png.0     : icons-material-png    : iobroker-pi                              -  enabled
                  system.adapter.icons-material-svg.0     : icons-material-svg    : iobroker-pi                              -  enabled
                  system.adapter.icons-mfd-png.0          : icons-mfd-png         : iobroker-pi                              -  enabled
                  system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker-pi                              -  enabled
                  system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: iobroker-pi                              -  enabled
                  system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : iobroker-pi                              -  enabled
                + system.adapter.info.0                   : info                  : iobroker-pi                              -  enabled
                  system.adapter.iogopro.0                : iogopro               : iobroker-pi                              - disabled
                  system.adapter.iot.0                    : iot                   : iobroker-pi                              - disabled
                + system.adapter.iqontrol.0               : iqontrol              : iobroker-pi                              -  enabled
                  system.adapter.jarvis.0                 : jarvis                : iobroker-pi                              - disabled
                + system.adapter.javascript.0             : javascript            : iobroker-pi                              -  enabled
                  system.adapter.javascript.1             : javascript            : iobroker-pi                              - disabled
                  system.adapter.link.0                   : link                  : iobroker-pi                              - disabled
                  system.adapter.linkeddevices.0          : linkeddevices         : iobroker-pi                              - disabled
                  system.adapter.lovelace.0               : lovelace              : iobroker-pi                              - disabled, port: 8091, bind: 0.0.0.0, run as: admin
                  system.adapter.material.0               : material              : iobroker-pi                              -  enabled
                + system.adapter.midea.0                  : midea                 : iobroker-pi                              -  enabled
                  system.adapter.mobile.0                 : mobile                : iobroker-pi                              - disabled
                + system.adapter.modbus.0                 : modbus                : iobroker-pi                              -  enabled
                + system.adapter.modbus.1                 : modbus                : iobroker-pi                              -  enabled
                  system.adapter.moma.0                   : moma                  : iobroker-pi                              - disabled
                  system.adapter.ping.0                   : ping                  : iobroker-pi                              - disabled
                  system.adapter.rickshaw.0               : rickshaw              : iobroker-pi                              -  enabled
                  system.adapter.scenes.0                 : scenes                : iobroker-pi                              - disabled
                + system.adapter.shelly.0                 : shelly                : iobroker-pi                              -  enabled, port: 1882, bind: 0.0.0.0
                  system.adapter.shuttercontrol.0         : shuttercontrol        : iobroker-pi                              - disabled
                  system.adapter.smartcontrol.0           : smartcontrol          : iobroker-pi                              - disabled
                + system.adapter.solax.0                  : solax                 : iobroker-pi                              -  enabled
                  system.adapter.solax.1                  : solax                 : iobroker-pi                              - disabled
                + system.adapter.sonoff.0                 : sonoff                : iobroker-pi                              -  enabled, port: 1883, bind: 0.0.0.0
                  system.adapter.sourceanalytix.0         : sourceanalytix        : iobroker-pi                              - disabled
                  system.adapter.sql.0                    : sql                   : iobroker-pi                              - disabled, port: 0
                + system.adapter.statistics.0             : statistics            : iobroker-pi                              -  enabled
                  system.adapter.systeminfo.0             : systeminfo            : iobroker-pi                              - disabled
                  system.adapter.text2command.0           : text2command          : iobroker-pi                              - disabled
                + system.adapter.trashschedule.0          : trashschedule         : iobroker-pi                              -  enabled
                  system.adapter.unifi.0                  : unifi                 : iobroker-pi                              - disabled
                  system.adapter.viessmannapi.0           : viessmannapi          : iobroker-pi                              - disabled
                  system.adapter.virtualpowermeter.0      : virtualpowermeter     : iobroker-pi                              - disabled
                  system.adapter.vis-3dmodel.0            : vis-3dmodel           : iobroker-pi                              -  enabled
                  system.adapter.vis-bars.0               : vis-bars              : iobroker-pi                              -  enabled
                  system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : iobroker-pi                              -  enabled
                  system.adapter.vis-colorpicker.0        : vis-colorpicker       : iobroker-pi                              -  enabled
                  system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : iobroker-pi                              -  enabled
                  system.adapter.vis-google-fonts.0       : vis-google-fonts      : iobroker-pi                              -  enabled
                  system.adapter.vis-history.0            : vis-history           : iobroker-pi                              -  enabled
                  system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker-pi                              -  enabled
                  system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker-pi                              -  enabled
                + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker-pi                              -  enabled
                  system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker-pi                              -  enabled
                  system.adapter.vis-justgage.0           : vis-justgage          : iobroker-pi                              -  enabled
                  system.adapter.vis-keyboard.0           : vis-keyboard          : iobroker-pi                              -  enabled
                  system.adapter.vis-lcars.0              : vis-lcars             : iobroker-pi                              -  enabled
                  system.adapter.vis-material-advanced.0  : vis-material-advanced : iobroker-pi                              -  enabled
                  system.adapter.vis-material-webfont.0   : vis-material-webfont  : iobroker-pi                              -  enabled
                  system.adapter.vis-material.0           : vis-material          : iobroker-pi                              -  enabled
                  system.adapter.vis-materialdesign.0     : vis-materialdesign    : iobroker-pi                              -  enabled
                  system.adapter.vis-metro.0              : vis-metro             : iobroker-pi                              -  enabled
                  system.adapter.vis-plumb.0              : vis-plumb             : iobroker-pi                              -  enabled
                  system.adapter.vis-rgraph.0             : vis-rgraph            : iobroker-pi                              -  enabled
                  system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker-pi                              -  enabled
                  system.adapter.vis-weather.0            : vis-weather           : iobroker-pi                              -  enabled
                  system.adapter.vis.0                    : vis                   : iobroker-pi                              -  enabled
                + system.adapter.web.0                    : web                   : iobroker-pi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                  system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : iobroker-pi                              - disabled
                + system.adapter.yahka.1                  : yahka                 : iobroker-pi                              -  enabled
                + system.adapter.yahka.2                  : yahka                 : iobroker-pi                              -  enabled
                + instance is alive
                ioBroker-Repositories
                beta          : http://iobroker.live/repo/sources-dist-latest.json
                __b2          : http://download.iobroker.net/sources-dist-latest.json
                __b3          : http://iobroker.live/repo/sources-dist.json
                Active repo(s): stable
                Installed ioBroker-Instances
                Used repository: stable
                Adapter    "alarm"        : 3.4.0    , installed 3.4.0
                Adapter    "alexa2"       : 3.25.2   , installed 3.25.2
                Adapter    "backitup"     : 2.8.1    , installed 2.8.1
                Adapter    "countdown"    : 2.2.0    , installed 2.2.0
                Adapter    "daswetter"    : 3.1.10   , installed 3.1.10
                Adapter    "device-reminder": 3.0.0  , installed 3.0.0
                Adapter    "discovergy"   : 0.5.8    , installed 0.5.8
                Adapter    "discovery"    : 3.1.0    , installed 3.1.0
                Adapter    "echarts"      : 1.5.1    , installed 1.5.1
                Adapter    "email"        : 1.2.0    , installed 1.2.0
                Adapter    "habpanel"     : 0.5.0    , installed 0.5.0
                Adapter    "ham"          : 5.3.1    , installed 5.3.1
                Adapter    "hm-rega"      : 3.0.47   , installed 3.0.47
                Adapter    "homeconnect"  : 1.1.1    , installed 1.1.1
                Adapter    "homekit-controller": 0.5.8, installed 0.5.8
                Adapter    "icons-material-svg": 0.1.0, installed 0.1.0
                Adapter    "icons-mfd-png": 1.1.0    , installed 1.1.0
                Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.3
                Adapter    "iot"          : 1.14.5   , installed 1.14.5
                Adapter    "iqontrol"     : 2.3.0    , installed 2.3.0
                Adapter    "jarvis"       : 3.1.2    , installed 3.1.2
                Adapter    "javascript"   : 7.1.4    , installed 7.1.4
                Controller "js-controller": 5.0.12   , installed 5.0.12
                Adapter    "link"         : 0.5.12   , installed 0.5.12
                Adapter    "linkeddevices": 1.5.5    , installed 1.5.5
                Adapter    "lovelace"     : 3.0.1    , installed 3.0.1
                Adapter    "material"     : 1.3.1    , installed 1.3.1
                Adapter    "mbus"         : 2.4.0    , installed 2.4.0
                Adapter    "midea"        : 0.0.7    , installed 0.0.7
                Adapter    "mobile"       : 1.0.1    , installed 1.0.1
                Adapter    "modbus"       : 5.0.11   , installed 5.0.11
                Adapter    "moma"         : 1.2.9    , installed 1.2.9
                Adapter    "openhab"      : 1.1.0    , installed 1.1.0
                Adapter    "openweathermap": 0.3.9   , installed 0.3.9
                Adapter    "rickshaw"     : 1.0.0    , installed 1.0.0
                Adapter    "scheduler"    : 1.1.9    , installed 1.1.9
                Adapter    "shelly"       : 6.4.5    , installed 6.4.5
                Adapter    "shuttercontrol": 1.6.2   , installed 1.6.2
                Adapter    "smartcontrol" : 2.0.1    , installed 2.0.1
                Adapter    "socketio"     : 6.5.5    , installed 6.5.5
                Adapter    "solax"        : 0.7.7    , installed 0.7.7
                Adapter    "sonoff"       : 2.5.3    , installed 2.5.3
                Adapter    "sql"          : 2.2.0    , installed 2.2.0
                Adapter    "statistics"   : 2.3.0    , installed 2.3.0
                Adapter    "systeminfo"   : 1.1.0    , installed 1.1.0
                Adapter    "text2command" : 3.0.2    , installed 3.0.2
                Adapter    "trashschedule": 2.2.0    , installed 2.2.0
                Adapter    "unifi"        : 0.6.6    , installed 0.6.6
                Adapter    "viessmannapi" : 2.3.0    , installed 2.3.0
                Adapter    "virtualpowermeter": 1.4.6, installed 1.4.6
                Adapter    "vis"          : 1.4.16   , installed 1.4.16
                Adapter    "vis-icontwo"  : 0.96.0   , installed 0.96.0
                Adapter    "vis-justgage" : 1.0.2    , installed 1.0.2
                Adapter    "vis-keyboard" : 0.0.2    , installed 0.0.2
                Adapter    "vis-lcars"    : 1.1.1    , installed 1.1.1
                Adapter    "vis-weather"  : 2.5.6    , installed 2.5.6
                Adapter    "web"          : 6.1.2    , installed 6.1.2
                Adapter    "whatsapp-cmb" : 0.2.3    , installed 0.2.3
                Adapter    "ws"           : 2.5.5    , installed 2.5.5
                Adapter    "yahka"        : 1.0.3    , installed 1.0.3
                Objects and States
                Objects:        17001
                States:         14964
                Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
                Hit:2 https://deb.nodesource.com/node_18.x nodistro InRelease
                Hit:3 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                Reading package lists...
                Pending Updates: 0
                *** Listening Ports ***
                tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          11997      518/sshd: /usr/sbin
                tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       23155      2771/io.sonoff.0
                tcp        0      0 192.168.178.150:2001    0.0.0.0:*               LISTEN      1001       22255      2779/io.hm-rpc.0
                tcp        0      0 192.168.178.150:2010    0.0.0.0:*               LISTEN      1001       23260      2817/io.hm-rpc.1
                tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       22137      2692/iobroker.js-co
                tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       22144      2692/iobroker.js-co
                tcp        0      0 127.0.0.1:45071         0.0.0.0:*               LISTEN      1001       28239      3639/io.yahka.2
                tcp        0      0 127.0.0.1:45295         0.0.0.0:*               LISTEN      1001       28205      3579/io.yahka.1
                tcp6       0      0 :::22                   :::*                    LISTEN      0          11999      518/sshd: /usr/sbin
                tcp6       0      0 :::32961                :::*                    LISTEN      1001       28201      3579/io.yahka.1
                tcp6       0      0 :::39181                :::*                    LISTEN      1001       26284      3639/io.yahka.2
                tcp6       0      0 :::8081                 :::*                    LISTEN      1001       22194      2718/io.admin.0
                tcp6       0      0 :::8082                 :::*                    LISTEN      1001       30959      4111/io.web.0
                udp        0      0 0.0.0.0:54497           0.0.0.0:*                           108        15015      373/avahi-daemon: r
                udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        15013      373/avahi-daemon: r
                udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       23342      2877/io.shelly.0
                udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          12013      629/dhcpcd
                udp6       0      0 :::57557                :::*                                108        15016      373/avahi-daemon: r
                udp6       0      0 :::5353                 :::*                                108        15014      373/avahi-daemon: r
                2023-06-30 21:56:25.750  - info: host.openmediavault instance system.adapter.solax.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                2023-06-30 21:56:25.804  - info: host.openmediavault instance system.adapter.solax.1 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                2023-06-30 21:56:25.835  - info: host.openmediavault instance system.adapter.yahka.1 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                2023-06-30 21:56:26.161  - info: host.openmediavault instance system.adapter.hm-rpc.1 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                2023-06-30 21:56:26.184  - info: host.openmediavault instance system.adapter.modbus.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                2023-06-30 21:56:26.216  - info: host.openmediavault instance system.adapter.cloud.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                2023-06-30 21:56:26.266  - info: host.openmediavault instance system.adapter.statistics.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                2023-06-30 21:56:26.330  - info: host.openmediavault instance system.adapter.yahka.2 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                2023-06-30 21:56:26.355  - warn: host.openmediavault instance system.adapter.sonoff.0 terminated due to SIGTERM
                2023-06-30 21:56:26.355  - info: host.openmediavault instance system.adapter.sonoff.0 terminated with code null ()
                2023-06-30 21:56:26.381  - info: host.openmediavault instance system.adapter.hm-rega.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                2023-06-30 21:56:26.401  - info: host.openmediavault instance system.adapter.shelly.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                2023-06-30 21:56:26.436  - warn: host.openmediavault instance system.adapter.web.0 terminated due to SIGTERM
                2023-06-30 21:56:26.436  - info: host.openmediavault instance system.adapter.web.0 terminated with code null ()
                2023-06-30 21:56:26.457  - warn: host.openmediavault instance system.adapter.iqontrol.0 terminated due to SIGTERM
                2023-06-30 21:56:26.457  - info: host.openmediavault instance system.adapter.iqontrol.0 terminated with code null ()
                2023-06-30 21:56:26.489  - info: host.openmediavault instance system.adapter.backitup.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                2023-06-30 21:56:26.537  - warn: host.openmediavault instance system.adapter.echarts.0 terminated due to SIGTERM
                2023-06-30 21:56:26.537  - info: host.openmediavault instance system.adapter.echarts.0 terminated with code null ()
                2023-06-30 21:56:26.562  - info: host.openmediavault instance system.adapter.history.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                2023-06-30 21:56:34.206  - info: host.openmediavault stopInstance timeout 10000 system.adapter.sql.0 killing pid  1636
                2023-06-30 21:56:34.288  - warn: host.openmediavault instance system.adapter.sql.0 terminated due to SIGTERM
                2023-06-30 21:56:34.288  - info: host.openmediavault instance system.adapter.sql.0 terminated with code null ()
                2023-06-30 21:56:34.288  - info: host.openmediavault All instances are stopped.
                2023-06-30 21:56:34.396  - info: host.openmediavault terminated
                iob diag has finished.
                Press any key for a summary
                                        v.2023-10-10
                         Icon name: computer
                      Architecture: arm64
                Userland:               armhf
                Timezone:               Europe/London (GMT, +0000)
                User-ID:                1000
                X-Server:               false
                Pending OS-Updates:     0
                Pending iob updates:    0
                Nodejs-Installation:    /usr/bin/nodejs         v18.18.2
                                        /usr/bin/npm            9.8.1
                                        /usr/bin/npx            9.8.1
                Recommended versions are nodejs 18.18.2 and npm 9.8.1
                MEMORY:
                Swap:            99M          0B         99M
                Active iob-Instances:   25
                ioBroker Core:          js-controller           5.0.12
                Objects type: jsonl
                States  type: jsonl
                Objects:                17001
                States:                 14964
                Size of iob-Database:
                16M     /opt/iobroker/iobroker-data/objects.json.migrated
                16M     /opt/iobroker/iobroker-data/objects.json.bak.migrated
                11M     /opt/iobroker/iobroker-data/states.jsonl
                2.9M    /opt/iobroker/iobroker-data/states.json.migrated
                2.9M    /opt/iobroker/iobroker-data/states.json.bak.migrated
                  Vermutlich die falsche Zeitzone. Stell das richtig ein.
                  Installier den iobroker.ham nochmal.
                  Das ist der letzte Eintrag im Log? Was ist denn da los? Kann ja nicht sein, dass da seit Ende Juni nichts mehr passiert ist.
                  • I
                    mein problem ist das der VIS Geht nicht mehr.
                    und trashschedule hat mit verbindung ein problem.
                      @ingenii
                      Ja, das vielleicht auch. Zusätzlich zu den aufgeführten Problemen.
                      • I
                        hallo,
                        homebridge deinstalliert und zeit richtig aber VIS geht nicht.
                        im iob diag kein Fehler mehr.
                        kompletten update hab ich nach Anleitung gemacht:
                        iob backup
                        iob stop
                        iob update
                        iob upgrade self
                        iob start
                        und auch kein fehler auftreten.
                        • I
                          heute update WEB auf v6.12.0 hat auch das Problem nicht behoben, hat niemand eine Idee wo kann das Problem sein ?
                          582
