    4. Error im admin.0 [Alias subscription error]
      Flopsi last edited by Flopsi
      Systemdata
      Hardwaresystem: PI4
      Arbeitsspeicher: 8GB
      Festplattenart: SSD
      Betriebssystem: Linux
      Node-Version: 18.18.2
      Nodejs-Version: 18.18.2
      NPM-Version: 9.8.1
      Installationsart: -
      Image genutzt: -
      Ort/Name der Imagedatei: -
      Ich habe hin und wieder folgenden ERROR :
      admin.0
      	2023-11-01 09:44:26.972	error	Alias subscription error. Please check your alias definitions: sourceId=zwave2.0.Node_065.Binary_Sensor.motion, sourceObj={"type":"state","common":{"role":"indicator","read":true,"write":false,"name":"Sensor state (Motion)","type":"boolean"},"native":{"nodeId":65,"valueId":{"commandClass":48,"endpoint":0,"property":"Motion"}},"from":"system.adapter.zwave2.0","user":"system.user.admin","ts":1698334268930,"_id":"zwave2.0.Node_065.Binary_Sensor.motion","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
      admin.0
      	2023-11-01 09:44:26.973	error	Alias subscription error. Please check your alias definitions: sourceId=zwave2.0.Node_065.Multilevel_Sensor.humidity, sourceObj={"type":"state","common":{"role":"value","read":true,"write":false,"name":"Humidity","type":"number","unit":"%"},"native":{"nodeId":65,"valueId":{"commandClass":49,"endpoint":0,"property":"Humidity"}},"from":"system.adapter.zwave2.0","user":"system.user.admin","ts":1698334270043,"_id":"zwave2.0.Node_065.Multilevel_Sensor.humidity","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
      admin.0
      	2023-11-01 09:44:26.974	error	Alias subscription error. Please check your alias definitions: sourceId=zwave2.0.Node_065.Multilevel_Sensor.illuminance, sourceObj={"type":"state","common":{"role":"value","read":true,"write":false,"name":"Illuminance","type":"number","unit":"Lux"},"native":{"nodeId":65,"valueId":{"commandClass":49,"endpoint":0,"property":"Illuminance"}},"from":"system.adapter.zwave2.0","user":"system.user.admin","ts":1698334269984,"_id":"zwave2.0.Node_065.Multilevel_Sensor.illuminance","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
      admin.0
      	2023-11-01 09:44:26.975	error	Alias subscription error. Please check your alias definitions: sourceId=zwave2.0.Node_065.Multilevel_Sensor.airTemperature, sourceObj={"type":"state","common":{"role":"value","read":true,"write":false,"name":"Air temperature","type":"number","unit":"°C"},"native":{"nodeId":65,"valueId":{"commandClass":49,"endpoint":0,"property":"Air temperature"}},"from":"system.adapter.zwave2.0","user":"system.user.admin","ts":1698334269209,"_id":"zwave2.0.Node_065.Multilevel_Sensor.airTemperature","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
      admin.0
      	2023-11-01 09:44:26.975	error	Alias subscription error. Please check your alias definitions: sourceId=zwave2.0.Node_064.Binary_Sensor.motion, sourceObj={"type":"state","common":{"role":"indicator","read":true,"write":false,"name":"Sensor state (Motion)","type":"boolean"},"native":{"nodeId":64,"valueId":{"commandClass":48,"endpoint":0,"property":"Motion"}},"from":"system.adapter.zwave2.0","user":"system.user.admin","ts":1697812897069,"_id":"zwave2.0.Node_064.Binary_Sensor.motion","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
      admin.0
      	2023-11-01 09:44:26.976	error	Alias subscription error. Please check your alias definitions: sourceId=zwave2.0.Node_064.Multilevel_Sensor.humidity, sourceObj={"type":"state","common":{"role":"value","read":true,"write":false,"name":"Humidity","type":"number","unit":"%","custom":{"history.0":{"enabled":true,"aliasId":"","debounceTime":0,"blockTime":0,"changesOnly":true,"changesRelogInterval":0,"changesMinDelta":0,"ignoreBelowNumber":"","disableSkippedValueLogging":false,"retention":31536000,"customRetentionDuration":365,"maxLength":960,"enableDebugLogs":false,"debounce":1000}}},"native":{"nodeId":64,"valueId":{"commandClass":49,"endpoint":0,"property":"Humidity"}},"_id":"zwave2.0.Node_064.Multilevel_Sensor.humidity","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"},"from":"system.adapter.zwave2.0","user":"system.user.admin","ts":1698827722577}
      admin.0
      	2023-11-01 09:44:26.977	error	Alias subscription error. Please check your alias definitions: sourceId=zwave2.0.Node_064.Multilevel_Sensor.illuminance, sourceObj={"type":"state","common":{"role":"value","read":true,"write":false,"name":"Illuminance","type":"number","unit":"Lux","custom":{"history.0":{"enabled":true,"aliasId":"","debounceTime":0,"blockTime":0,"changesOnly":true,"changesRelogInterval":0,"changesMinDelta":0,"ignoreBelowNumber":"","disableSkippedValueLogging":false,"retention":31536000,"customRetentionDuration":365,"maxLength":960,"enableDebugLogs":false,"debounce":1000}}},"native":{"nodeId":64,"valueId":{"commandClass":49,"endpoint":0,"property":"Illuminance"}},"_id":"zwave2.0.Node_064.Multilevel_Sensor.illuminance","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"},"from":"system.adapter.zwave2.0","user":"system.user.admin","ts":1698827724985}
      admin.0
      	2023-11-01 09:44:26.977	error	Alias subscription error. Please check your alias definitions: sourceId=zwave2.0.Node_064.Multilevel_Sensor.airTemperature, sourceObj={"type":"state","common":{"role":"value","read":true,"write":false,"name":"Air temperature","type":"number","unit":"°C"},"native":{"nodeId":64,"valueId":{"commandClass":49,"endpoint":0,"property":"Air temperature"}},"from":"system.adapter.zwave2.0","user":"system.user.admin","ts":1697812898332,"_id":"zwave2.0.Node_064.Multilevel_Sensor.airTemperature","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
      Die Fehlermeldungen sind erst seitdem ich meine beiden Multi 7 Sensoren von Aeotec über Zwave 2 eingebunden habe.
      Die Sensoren funktionieren eigentlich so wie sie sollen.
      Weis wer was hier den Fehler verursacht ?
      @AlCalzone evtl. ?
      Thomas Braun haus-automatisierung 2 Replies Last reply Reply Quote 0
        Thomas Braun Most Active @Flopsi last edited by
        @flopsi
        Nodejs-Version: 18.17.1
        Du stehst offenbar auf dem Abstellgleis, was nodejs angeht
        iob nodejs-update
        ausführen, ggfs. zuvor iob fix
          Flopsi @Thomas Braun last edited by
          ioBroker nodejs fixer 2023-10-13
          Recommended nodejs-version is: 18.18.2
          Checking your installation now. Please be patient!
          Your current setup is:
          /usr/bin/nodejs         v18.17.1
          /usr/bin/node           v18.17.1
          /usr/bin/npm            9.6.7
          /usr/bin/npx            9.6.7
          /usr/bin/corepack       0.18.0
          We found these nodejs versions available for installation:
          nodejs:
            Installed: 18.17.1-deb-1nodesource1
            Candidate: 18.17.1-deb-1nodesource1
            Version table:
           *** 18.17.1-deb-1nodesource1 500
                  500 https://deb.nodesource.com/node_18.x bullseye/main arm64 Packages
                  100 /var/lib/dpkg/status
               12.22.12~dfsg-1~deb11u4 500
                  500 http://deb.debian.org/debian bullseye/main arm64 Packages
                  500 http://security.debian.org/debian-security bullseye-security/main ar                                          m64 Packages
          Nothing to do - Your installation is using the correct paths.
          You are running nodejs v18.17.1. Do you want to install recommended version 18.1                                          8.2?
          Press <y> to continue or any other key to quit
            @flopsi
            Siehste. 18.18.2 ist aktuell angesagt...
              OK bin auf der neusten Version dann schaue ich erstmal ob der Error wieder auftritt ...
                @flopsi
                Nein, der hat damit nix zu tun. War aber dennoch falsch.
                  Zu meinem eigentlichen Problem hast du keine Idee ?
                    @flopsi
                    Dann hätte ich dazu was geschrieben.
                    • haus-automatisierung
                      haus-automatisierung Developer Most Active @Flopsi last edited by
                      @flopsi Dann zeig doch mal, wie der Alias definiert ist
                        Flopsi @haus-automatisierung last edited by
                        createAlias('zwave2.0.Node_065.Multilevel_Sensor.illuminance','Flur.Multisensor.Aeotec_7.Lux');
                        createAlias('zwave2.0.Node_065.Multilevel_Sensor.airTemperature','Flur.Multisensor.Aeotec_7.Temp');
                        createAlias('zwave2.0.Node_065.Binary_Sensor.motion','Flur.Multisensor.Aeotec_7.Bewegung');
                        createAlias('zwave2.0.Node_065.Multilevel_Sensor.humidity','Flur.Multisensor.Aeotec_7.Luftfeuchtigkeit');
                        createAlias('zwave2.0.Node_064.Multilevel_Sensor.illuminance','Kueche.Multisensor.Aeotec_7.Lux');
                        createAlias('zwave2.0.Node_064.Multilevel_Sensor.airTemperature','Kueche.Multisensor.Aeotec_7.Temp');
                        createAlias('zwave2.0.Node_064.Binary_Sensor.motion','Kueche.Multisensor.Aeotec_7.Bewegung');
                        createAlias('zwave2.0.Node_064.Multilevel_Sensor.humidity','Kueche.Multisensor.Aeotec_7.Luftfeuchtigkeit');
                          haus-automatisierung Developer Most Active @Flopsi last edited by haus-automatisierung
                          @flopsi Ich meine die Objekt-Definition vom erstellten Alias
                          EDIT: Du benutzt createAlias falsch. Gerade mal in die Doku geschaut.
                          • name ist die ID des Alias und
                          • alias ist die ID, auf welcher sich dieser bezieht.
                          Also die Parameter einmal umdrehen jeweils.
                            @haus-automatisierung sagte in Error im admin.0 [Alias subscription error]:
                            createAlias
                            Versteh nicht was ich umdrehen soll ? Kannst du mir ein Beispiel zeigen ?
                            Ich erstelle all meine Alias nach dem Schema nie probleme gehabt erst seit den neuen Sensoren...
                            Ich nutze das folgendes Skript für:
                            Github - https://github.com/xCruziX/ioBroker-Creating-Alias/blob/master/CreateAlias.js
                            				Changelog
                            Version 1.1.3
                              - use callbacks in alias-path
                            Version 1.1.2
                              - fix log message 'Created Alias-Path '
                            Version 1.1.1
                              - Bugfixing, clean functions
                            Version 1.1.0
                              - added function for cleaning enums
                            Version 1.0.6
                              - use callback functions for safety call
                            Version 1.0.5
                              - decrease timeout assing enum
                            Version 1.0.4
                              - Bugfixing array id lenght
                            Version 1.0.3
                              - Githublink
                            Version 1.0.2
                              - existsObject for Alias in the timeout
                              - remove lowerCase enum
                              - improved logs
                            Version 1.0.1
                              - Rooms and functions casesensitive
                            Version 1.0
                            		Flags /
                            		Variablen
                            // typeAlias = 'boolean'; // oder 'number'
                            // read = "val == 'Ein' ? true : false"; // Erkennung "Aus" --> false erfolgt automatisch
                            // write = "val ? 'Ein' : 'Aus'";
                            // nameAlias = 'Licht Haustür';
                            // role = 'switch';
                            // desc = 'per Script erstellt';
                            // min = 0; // nur Zahlen
                            // max = 100; // nur Zahlen
                            // unit = '%'; // nur für Zahlen
                            // states = {0: 'Aus', 1: 'Auto', 2: 'Ein'}; // Zahlen (Multistate) oder Logikwert (z.B. Aus/Ein)
                            let bCreateAliasPath = false;  // If this flag is true, each folder is created seperately so rooms and functions can be assigned.
                            Requirements: bCreateAliasPath == true
                            If this flag is true, existing folders in the path will be converted so rooms and functions can be assigned.
                            let bConvertExistingPath = false;
                            	Don't change anything from here /
                            	Ab hier nichts verändern
                            let arEnum = [];
                            let arId = [];
                            let timeoutAssignEnum;
                            function createAlias(idSrc, idDst,raum, gewerk,typeAlias, read, write, nameAlias, role, desc, min, max, unit, states) {
                              if(!idDst.includes('alias.0.'))
                                  idDst = 'alias.0.' + idDst;
                              if(!existsObject(idSrc))
                                  log('Source-Id ' + idSrc +' does not exists.','warn');
                                  return;
                              // Create the object Path for alias id,
                              // so you can assign rooms and function to the parents
                              var createAliasPath = (id) => {
                                   if(bCreateAliasPath){
                                        let lisMergedIds = [];
                                        let mergedId = 'alias.0';
                                        id = id.replace(mergedId + '.', ''); // Remove prefix alias so it will not be changed
                                        let split = id.split('.');
                                        for(let i=0;i<split.length-1;i++){
                                            mergedId += '.' + split[i];
                                            lisMergedIds.push(mergedId);
                                        function path(){
                                            if(lisMergedIds.length == 0) {// Zu Ende erstellt
                                                alias();
                                                return;
                                            let tmpId = lisMergedIds[0];
                                            lisMergedIds.splice(0,1); // entferne element
                                            if(!existsObject(tmpId) || bConvertExistingPath){ // not exists
                                                let obj;
                                                if(existsObject(tmpId))
                                                    obj = getObject(tmpId);
                                                else
                                                    obj = {};
                                                if(obj.type == undefined || obj.type != 'meta')
                                                    obj.type = 'meta';
                                                if(obj.common == undefined || obj.common != {})
                                                    obj.common = {};
                                                if(obj.common.type == undefined || obj.common.type != 'meta.folder')
                                                    obj.common.type = 'meta.folder';
                                                if(obj.common.desc == undefined || obj.common.desc != 'createAliasPath')
                                                    obj.common.desc = 'createAliasPath';
                                                if(obj.common.def == undefined || obj.common.def != false)
                                                    obj.common.def = false;
                                                if(obj.native == undefined || obj.native != {})
                                                    obj.native = {};
                                                setObject(tmpId, obj, (err) =>{
                                                    if(!err){
                                                        log('Created Alias-Path ' + tmpId);
                                                        path();
                                                    else
                                                        log('Error creating alias-path','error');
                                        path();
                                   else
                                     alias();
                                //   createAliasPath(idDst);
                              function alias(){
                                  // Create alias object
                                    if(!existsObject(idDst)){
                                        let obj = {};
                                        obj.type = 'state';
                                        obj.common = getObject(idSrc).common;
                                        obj.common.alias = {};
                                        obj.common.alias.id = idSrc;
                                        if(typeAlias !== undefined)
                                            obj.common.type = typeAlias;
                                        if(obj.common.read !== undefined)
                                            obj.common.alias.read = read;
                                        if(obj.common.write !== undefined)
                                            obj.common.alias.write = write;
                                        if(nameAlias !== undefined)
                                            obj.common.name = nameAlias;
                                        if(role !== undefined)
                                            obj.common.role = role;
                                        if(desc !== undefined)
                                            obj.common.desc = desc;
                                        if(min !== undefined)
                                            obj.common.min = min;
                                        if(max !== undefined)
                                            obj.common.max = max;
                                        if(unit !== undefined)
                                            obj.common.unit = unit;
                                        if(states !== undefined)
                                            obj.common.states = states;
                                        obj.native = {};
                                        obj.common.custom = []; // Damit die Zuordnung zu iQontrol, Sql etc. nicht übernommen wird
                                        log('Created Alias-State ' + idDst);
                                        setObject(idDst, obj,(err) =>{
                                            if(!err)
                                                startAttach();
                                            else
                                                log('Error creating-alias','error');
                                    else
                                        startAttach();
                              // Save ID and Enum (room or function)
                              var attach = (id, enu,value) => {
                                  if(id.length == 0){
                                      log('ID has lenght 0, can not attach to enum','warn');
                                      return;
                                  if(value.length == 0){
                                      log('Value has lenght 0','warn');
                                      return;
                                  let sEnuId = 'enum.' + enu + '.' + value;
                                  if(enu.length > 0 && existsObject(sEnuId))
                                      let obj = getObject(sEnuId)
                                      let members = obj.common.members;
                                      if(!members.includes(id)){
                                          arEnum.push(sEnuId);
                                          arId.push(id);
                                  else
                               	      log('Can not find enum ' + sEnuId,'warn');
                             function startAttach(){
                                let bRoom = raum !== undefined && raum.length > 0;
                                let bGewerk = gewerk !== undefined && gewerk.length > 0;
                                if(bRoom)
                                    attach(idDst,'rooms',raum);
                                if(bGewerk)
                                    attach(idDst,'functions',gewerk);
                                if(bRoom || bGewerk){
                                        if(timeoutAssignEnum){
                                            clearTimeout(timeoutAssignEnum);
                                            timeoutAssignEnum = null;
                                        timeoutAssignEnum = setTimeout(finishScript,100);
                            function finishScript(){
                            	assignEnums();
                            // Add the saved IDs to the rooms/functions
                            function assignEnums(){
                             if(arEnum.length == 0 || arId.length == 0){
                                  return;
                             if(arEnum.length != arId.length){
                                  log('Arrays have different size','error');
                                  return;
                             let mapEnumId = new Map();
                             for(let i=0;i < arEnum.length; i++){
                                 let enu = arEnum[i];
                                 let id = arId[i];
                                 if(existsObject(id)){
                                	 let obj = getObject(enu)
                                	 let members;
                                	 if(!mapEnumId.has(enu)){
                                		 mapEnumId.set(enu,members);
                                	 else
                                		 members = mapEnumId.get(enu);
                                		  log("Adding " + id + " to " + enu);
                                		  members.push(id);
                                 else
                                     log('Can not find Alias ' + id,'error');
                              function setMembers(members,enu,map){
                                  let obj = getObject(enu);
                                  obj.common.members = members;
                                  setObject(enu,obj);
                              mapEnumId.forEach(setMembers);
                            Hier noch die Objekt-Definition: ( Ich hoffe es ist die richtige das gibt es ja zu jedem Datenpunkt eine ....
                              "type": "channel",
                              "common": {
                                "name": "alias.0.Flur.Multisensor.Aeotec_7"
                              "_id": "alias.0.Flur.Multisensor.Aeotec_7",
                              "native": {},
                              "user": "system.user.admin",
                              "ts": 1698686702683,
                              "acl": {
                                "object": 1636,
                                "owner": "system.user.admin",
                              @flopsi sagte in Error im admin.0 [Alias subscription error]:
                              Statt
                              createAlias('zwave2.0.Node_065.Multilevel_Sensor.illuminance', 'Flur.Multisensor.Aeotec_7.Lux');
                              muss es so aussehen:
                              createAlias('Flur.Multisensor.Aeotec_7.Lux', 'zwave2.0.Node_065.Multilevel_Sensor.illuminance');
                              dein Script lese ich mir jetzt nicht komplett durch
                              Ja, und da fehlt die ID, auf welcher sich der Alias beziehen soll. Daher die Fehler.
                                Okay, ich hab es mir nun doch angeschaut und frage mich, was der Sinn von diesem Script ist. Das kann der JavaScript-Adapter doch von Haus aus?
                                https://github.com/ioBroker/ioBroker.javascript/blob/master/docs/en/javascript.md#createalias
                                Wenn Du eigene Funktionen definierst (und diese auch noch genauso nennst, wie Standard-Funktionen im JavaScript-Adapter), dann wäre das schon eine Info im Ausgangspost wert 🙂
                                  ich habe das Skript einfach nur kopiert .....
                                  creates Alias ......
                                  die Alias erstellt und mich dann auf die Alias Datenpunkte bezogen.
                                  Wie machst du das denn mit den Alias ?
                                    @flopsi Manuell über den Geräte-Adapter erstellen
                                    Aber das löst ja dein Problem nicht. Jedenfalls erstellt dein Script den Alias Datenpunkt nicht korrekt. Würde ich nicht mehr verwenden, wenn der JavsScript Adapter das direkt mitbringt.
                                      Flopsi @haus-automatisierung last edited by Flopsi
                                      Problem erscheint schon zwei Tage nicht mehr
                                      habe folgendes geändert:
                                      ich habe diesen Texteil gelöscht
                                      .Aeotec_7
                                      so sieht es jetzt aus:
                                      createAlias('Flur.Multisensor.Lux', 'zwave2.0.Node_065.Multilevel_Sensor.illuminance');
                                      jetzt kommen keine Error mehr und die fehlende ID wurde auch erstellt
                                      897
