    4. Installation
    5. Nach Update auf Debian12 npm "weg"
      RoccoNaut last edited by
      ich versuche seit heute früh mein System auf Debian12 upzudaten.
      Das Update läuft auch normal durch, nur der ioBroker funtkioniert nach dem Update nicht mehr.
      Vor dem Update Nodejs 16 und js COntroller 5.0.12
      Nach dem Upgrade ist Nodejs 18.13 installiert und npm ist nicht mehr da.
      Upgrade lief sauber durch unter Debian.
      log:
      ost.ioBroker-Debian10
      	2023-11-02 13:35:11.609	error	instance system.adapter.info.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      host.ioBroker-Debian10
      	2023-11-02 13:35:11.608	error	Caught by controller[1]: Node.js v18.13.0
      	2023-11-02 13:35:11.608	error	Caught by controller[1]: at node:internal/main/run_main_module:23:47
      	2023-11-02 13:35:11.608	error	Caught by controller[1]: at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:81:12)
      	2023-11-02 13:35:11.608	error	Caught by controller[1]: at Module._load (node:internal/modules/cjs/loader:922:12)
      	2023-11-02 13:35:11.608	error	Caught by controller[1]: at Module.load (node:internal/modules/cjs/loader:1081:32)
      	2023-11-02 13:35:11.608	error	Caught by controller[1]: at Module._extensions..js (node:internal/modules/cjs/loader:1272:10)
      	2023-11-02 13:35:11.608	error	Caught by controller[1]: at Module._compile (node:internal/modules/cjs/loader:1218:14)
      	2023-11-02 13:35:11.608	error	Caught by controller[1]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.info/main.js:58:18)
      	2023-11-02 13:35:11.608	error	Caught by controller[1]: at getSystemVersions (/opt/iobroker/node_modules/iobroker.info/main.js:89:11)
      	2023-11-02 13:35:11.608	error	Caught by controller[1]: TypeError: Cannot read properties of undefined (reading 'log')
      	2023-11-02 13:35:11.607	error	Caught by controller[1]: ^
      	2023-11-02 13:35:11.607	error	Caught by controller[1]: adapter.log.error("Could not check npm version: " + e);
      	2023-11-02 13:35:11.607	error	Caught by controller[1]: /opt/iobroker/node_modules/iobroker.info/main.js:89
      	2023-11-02 13:35:11.607	error	Caught by controller[0]: /bin/sh: 1: npm: not found
      Wo kann da der Fehler liegen?
      Thomas Braun MartinP 3 Replies Last reply Reply Quote 0
        Thomas Braun Most Active @RoccoNaut last edited by
        @rocconaut
        iob fix
        iob nodejs-update
          @rocconaut
          Falls es mit den vorgenannten Befehlen nicht funktioniert, Versuch diese Version:
          https://forum.iobroker.net/topic/68035/iob-node-fix-skript
          • MartinP
            MartinP @RoccoNaut last edited by
            @rocconaut Die Node Version war vor dem Update viel zu alt
            So sieht es bei mir aus:
            *** NodeJS-Installation ***
            /usr/bin/nodejs v18.18.2
            /usr/bin/node v18.18.2
            /usr/bin/npm 9.8.1
            /usr/bin/npx 9.8.1
            /usr/bin/corepack 0.19.0
            Core adapters versions
            js-controller: 5.0.12
            admin: 6.12.0
            javascript: 7.1.4
            Es ist sicherlich angebracht, vor dem Betriebssystem - Update erstmal die ioBroker Installation auf Stand zu bringen ...
            Ich habe aber die starke Hoffnung, dass die Fix-Skripte da Heilung auch nach dem Debian 12 bringen ...
            Thomas Braun 1 Reply Last reply Reply Quote 1
              Thomas Braun Most Active @MartinP last edited by
              @martinp
              Ja, stimmt.
              Der eigentliche Grund ist, dass auf dem Alt-System die Quelle 'nodesource' auf 16 stand und nicht auf 18.
              Durch das Upgrade auf Debian 12 zieht nun die dortige dfsg-Version zuerst, weil die aus nodejs@18 gebaut wurde, also eine höhere Versionsnummer hat.
              Die muss jetzt rausgekratzt werden und die nodesource-Version muss eingebaut werden. Macht aber spätestens die Beta-Version von 'iob nodejs-update'.
                besten Dank schon mal bis hierhin.
                Das iob nodejs-update war mir neu...
                Habe ein Backup eingespielt und nun ioBroker komplett upgedated.
                npm 9.8.1.
                nodejs 18.18.2
                js controller 5.0.12
                admin 6.12.0
                jetzt schmiert nur laufend der Roborock Adapter ab. Der ist auch up to date.
                Dann ziehe ich jetzt ein neues Backup und versuche das Upgrad auf Debian 12 erneut.
                  @rocconaut sagte in Nach Update auf Debian12 npm "weg":
                  Was soll das bringen?
                    was genau?
                    Das Backup oder das update?
                      @rocconaut
                      Ein Backup mit dem gleichen alten Stand.
                      Du musst schauen wie es jetzt in deinem Setup klemmt.
                        ich habe ioBroker jetzt up to date auf Debian11
                        Davon ziehe ich gerade ein Backup.
                        Dann versuche ich das Update auf Debian 12 noch mal.
                        Wenn es an der veralteten installation lag, dann müsste es doch jetzt durch laufen?!
                          @rocconaut
                          Aber du hattest das doch auf Debian12 jetzt mit
                          nodejs-update gefixt, oder nicht? Was soll da ein Backup bringen?
                            nein, ich habe ein altes Backup eingespielt. Ich bin jetzt auf dem Stand von heute früh 6 Uhr.
                            Den Stand habe ich jetzt unter Debian11 komplett aktualisiert auf diese Versionen:
                            npm 9.8.1.
                            nodejs 18.18.2
                            admin 6.12.0
                            und jetzt wollte ich das upgrade auf Debian12 machen.
                            Wenn die veraltete ioBroker Installation schuld war, dann sollte es ja jetzt durchlaufen.
                              @rocconaut
                              Zumindest wird jetzt (wenn das auch richtig geändert wurde) nodejs aus dem nodesource-Repo gezogen werden, weil da eine aktuellere nodejs@18 drin liegt.
                              Ein Rückschritt auf 'heute 6 Uhr' wäre aber unnötig gewesen, das hätte man auch im Debian12 noch gerade rücken können. Mit 'iob nodejs-update' halt.
                                So, jetzt ist alles auf aktuellem Stand und läuft 🙂
                                Lag tatsächlich an der alten Version.
                                Danke euch 👍
                                  Natürlich...
                                  686
