    4. Adapter Updates sehr langsam, viele Warnmeldungen
      loverz last edited by
      Jemand eine Idee, wie ich diese Meldungen wegbekomme?
      (Sie erscheinen bei jedem Apdaterupdate. Die Updates sind dadurch furchtbar langsam und dauern teilweise 5-10 Minuten)
      Hardware: Raspberry Pi 4 4GB (genug RAM frei)
      npm WARN deprecated dgram@1.0.1: npm is holding this package for security reasons. As it's a core Node module, we will not transfer it over to other users. You may safely remove the package from your dependencies.
      npm WARN deprecated @types/bl@5.1.0: This is a stub types definition. bl provides its own type definitions, so you do not need this installed.
      npm WARN deprecated topo@3.0.3: This module has moved and is now available at @hapi/topo. Please update your dependencies as this version is no longer maintained an may contain bugs and security issues.
      npm WARN deprecated request-promise-native@1.0.9: request-promise-native has been deprecated because it extends the now deprecated request package, see https://github.com/request/request/issues/3142
      npm WARN deprecated babel@6.23.0: In 6.x, the babel package has been deprecated in favor of babel-cli. Check https://opencollective.com/babel to support the Babel maintainers
      npm WARN deprecated string-similarity@4.0.4: Package no longer supported. Contact Support at https://www.npmjs.com/support for more info.
      npm WARN deprecated har-validator@5.1.5: this library is no longer supported
      npm WARN deprecated request-promise@4.2.6: request-promise has been deprecated because it extends the now deprecated request package, see https://github.com/request/request/issues/3142
      npm WARN deprecated hoek@6.1.3: This module has moved and is now available at @hapi/hoek. Please update your dependencies as this version is no longer maintained an may contain bugs and security issues.
      npm WARN deprecated querystring@0.2.1: The querystring API is considered Legacy. new code should use the URLSearchParams API instead.
      npm WARN deprecated circular-json@0.5.9: CircularJSON is in maintenance only, flatted is its successor.
      npm WARN deprecated xmldom@0.1.31: Deprecated due to CVE-2021-21366 resolved in 0.5.0
      npm WARN deprecated node-inspect@2.0.0: This module is part of Node.js core and does not need to be installed separately. It is now unmaintained.
      npm WARN deprecated uuid@3.4.0: Please upgrade to version 7 or higher. Older versions may use Math.random() in certain circumstances, which is known to be problematic. See https://v8.dev/blog/math-random for details.
      npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
      npm WARN deprecated joi@14.3.1: This module has moved and is now available at @hapi/joi. Please update your dependencies
      mikeal created this issue in request/request
      open Request’s Past, Present and Future #3142
      haselchen Thomas Braun 2 Replies Last reply Reply Quote 0
      • haselchen
        haselchen Most Active @loverz last edited by
        @loverz
        ohne
        iob diag
        kriegen wir die Kuh nicht vom Eis 😉
          Thomas Braun Most Active @loverz last edited by
          @loverz sagte in Adapter Updates sehr langsam, viele Warnmeldungen:
          Gar nicht. Muss im entsprechenden Adapter angegangen werden.
          Das bremst aber die Installation nicht aus, sind nur Hinweise.
            loverz @Thomas Braun last edited by
            @thomas-braun das kommt aber bei jedem Adapter Update.
            Hab 3 ioBroker Installationen, nur bei dieser einen kommen diese Meldungen und das langsame Verhalten.
            Auch wenn 3x derselbe Adapter auf allen 3 Rechnern upgedatet wird.
              Natürlich, weil diese Hinweise jedesmal kommen, wenn npm durch deine Installation schaut und diese Dinger entdeckt.
