    4. ioBroker auf einem Raspberry Pi5
    • hg6806
      hg6806 Most Active last edited by hg6806
      ich hatte das zwar schon in der Hardware Rubrik gepostet, aber ich denke in einem neuen Thread ist es besser aufgehoben.
      Gestern kam mein Raspberry Pi5 in 8GB, auf den ich dann versucht habe, ioBroker zu installieren.
      Ich habe auf eine SD Karte Bookworm 64Bit lite installiert, dann Expand Filesystem (muss man das überhaupt noch machen?), dann ein Update und dann über das Script
      curl -sLf https://iobroker.net/install.sh | bash -
      ...ioBroker installiert.
      Im Schritt 3 gab es folgende Fehlermeldungen:
          Installing prerequisites (1/4)
      Hit:4 http://archive.raspberrypi.com/debian bookworm InRelease
      Reading package lists... Done
          Node.js not found. Installing...
      Building dependency tree... Done
      ca-certificates is already the newest version (20230311).
      curl is already the newest version (7.88.1-10+deb12u4).
      gnupg is already the newest version (2.2.40-1.1).
      gnupg set to manually installed.
      0 upgraded, 0 newly installed, 0 to remove and 7 not upgraded.
      deb [signed-by=/etc/apt/keyrings/nodesource.gpg] https://deb.nodesource.com/node        _18.x nodistro main
       Processing triggers for man-db (2.11.2-2) ...ource1_arm64.deb ...led.)
      Installed nodejs
      Node.js Installed successfully!
      Changing npm registry to https://registry.npmjs.org
       Processing triggers for man-db (2.11.2-2) ...arm64.deb ... installed.)
      Installed acl
       Setting up libavahi-compat-libdnssd-dev:arm64 (0.8-10) ...-10_arm64.deb ...
      Installed libavahi-compat-libdnssd-dev
       Processing triggers for man-db (2.11.2-2) ...1) ...1_arm64.deb ...ed.)
      Installed libudev-dev
       Processing triggers for man-db (2.11.2-2) ...pt2) .....1+rpt2) ...2712v8......4.deb .......
      Installed libpam0g-dev
       Processing triggers for man-db (2.11.2-2) ...m64.deb ......installed.)
      Installed git
      Extracting templates from packages: 100%
       Setting up libcairo2-dev:arm64 (1.16.0-7+rpt1) ....u3) ...t1) .........rm64.deb ...
      Installed libcairo2-dev
       Processing triggers for libc-bin (2.36-9+rpt2+deb12u3) ...m64.deb ... ....
      Installed libpango1.0-dev
       Setting up libjpeg-dev:arm64 (1:2.1.5-2) ...5-2) ...4.deb ....deb ...)
      Installed libjpeg-dev
       Processing triggers for libc-bin (2.36-9+rpt2+deb12u3) ... installed.)
      Installed libgif-dev
       Processing triggers for libgdk-pixbuf-2.0-0:arm64 (2.42.10+dfsg-1+b1) ..........
      Installed librsvg2-dev
       Processing triggers for libc-bin (2.36-9+rpt2+deb12u3) .....nstalled.)
      Installed cmake
          Creating ioBroker user and directory (2/4)
      User iobroker created
      Created /etc/sudoers.d/iobroker
      Directory /opt/iobroker created
          Installing ioBroker (3/4)
      npm ERR! code ERR_SOCKET_TIMEOUT
      npm ERR! errno ERR_SOCKET_TIMEOUT
      npm ERR! network Invalid response body while trying to fetch https://registry.npmjs.org/@iobroker%2fdb-states-file: Socket timeout
      npm ERR! network This is a problem related to network connectivity.
      npm ERR! network In most cases you are behind a proxy or have bad network settings.
      npm ERR! network
      npm ERR! network If you are behind a proxy, please make sure that the
      npm ERR! network 'proxy' config is set properly.  See: 'npm help config'
      npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2023-11-09T17_43_57_638Z-debug-0.log
          Finalizing installation (4/4)
      Enabling autostart...
      Created symlink /etc/systemd/system/multi-user.target.wants/iobroker.service → /lib/systemd/system/iobroker.service.
      Autostart enabled!
          ioBroker was installed successfully
          Open http://192.168.178.93:8081 in a browser and start configuring!
      You need to re-login before doing anything else on the console!
      Also, einen Proxy oder was ähnliches habe ich nicht.
      Mit dem Netzwerk ist alles i.O. Der andere Pi4 mit ioBroker läuft im gleichen Netz.
      Über
      iob status
      gab es dann folgende Meldung:
      pi@RPI5:/opt/iobroker $ iob status
      node:internal/modules/cjs/loader:1080
        throw err;
          at Module._resolveFilename (node:internal/modules/cjs/loader:1077:15)
          at Module._load (node:internal/modules/cjs/loader:922:27)
          at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:86:12)
          at node:internal/main/run_main_module:23:47 {
        code: 'MODULE_NOT_FOUND',
        requireStack: []
      Node.js v18.18.2
      Daraufhin habe ich aufgeführt:
      pi@RPI5:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.js-controller
      npm WARN deprecated har-validator@5.1.5: this library is no longer supported
      npm WARN deprecated dgram@1.0.1: npm is holding this package for security reason                                                    s. As it's a core Node module, we will not transfer it over to other users. You                                                     may safely remove the package from your dependencies.
      npm WARN deprecated request@2.88.2: request has been deprecated, see https://git                                                    hub.com/request/request/issues/3142
      npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older v                                                    ersions may use Math.random() in certain circumstances, which is known to be pro                                                    blematic.  See https://v8.dev/blog/math-random for details.
      npm WARN cleanup Failed to remove some directories [
      npm WARN cleanup   [
      npm WARN cleanup     '/opt/iobroker/node_modules',
      npm WARN cleanup     [Error: ENOTEMPTY: directory not empty, rmdir '/opt/iobroke                                                    r/node_modules'] {
      npm WARN cleanup       errno: -39,
      npm WARN cleanup       code: 'ENOTEMPTY',
      npm WARN cleanup       syscall: 'rmdir',
      npm WARN cleanup       path: '/opt/iobroker/node_modules'
      npm WARN cleanup     }
      npm WARN cleanup   ]
      npm WARN cleanup ]
      npm ERR! code 24
      npm ERR! path /opt/iobroker/node_modules/iobroker.js-controller
      npm ERR! command failed
      npm ERR! command sh -c node iobroker.js setup first
      npm ERR! creating conf/iobroker.json
      npm ERR! Server Cannot start inMem-objects on port 9001: Failed to lock DB file                                                     "/opt/iobroker/iobroker-data/objects.jsonl"!
      {1}
      npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2                                                    023-11-09T21_42_08_685Z-debug-0.log
        throw err;
      {1}
        requireStack: []
      {1}
      Node.js v18.18.2
      Aber wahrscheinlich mangelt es erst einmal an Hardware um das nachzuvollziehen.
        Homoran Global Moderator Administrators @hg6806 last edited by
        @hg6806 sagte in ioBroker auf einem Raspberry Pi5:
        du bist zu spät
        https://forum.iobroker.net/post/1076821
        hg6806 1 Reply Last reply Reply Quote 0
        • hg6806
          hg6806 Most Active @Homoran last edited by
          Oh, ok, dort hatte ich nicht gesucht und die Suche hatte auch nichts ergeben.
            Darüber hab ich ihn gerade gefunden.
            ich mach dann hier mal zu
