    4. Node-Red
    5. Vergleich 2 Werte wenn ungleich 1 Wert ausgeben
    • G
      geforce28 last edited by geforce28
      ich möchte gerne in NodeRed 2 eingehende Werte (aus 2 verschiedenen Nodes) miteinander vergleichen und, wenn sich diese unterscheiden den Wert aus dem 1. Node ausgeben / weiterverarbeiten...
      Wie kriege ich das hin ?
      • mickym
        mickym Most Active @geforce28 last edited by mickym
        @geforce28 du hast 3 Möglichkeiten:
        1- du holst dir beide Werte in ein Nachrichtenobjekt:
        1.a. Via iobroker get nodes
        1.b via join node
        2. du speicherst mind. 1 Wert in einem Kontext
        Vergleiche führst du mit einer Switch Node durch.
               "id": "bf18acfbac86d91c",
               "type": "tab",
               "label": "Werte vergleichen",
               "disabled": false,
               "info": "",
               "env": []
               "id": "84f4c2bcc8f52c2b",
               "type": "comment",
               "z": "bf18acfbac86d91c",
               "name": "Du speicherst einen oder ggf. beide Werte in einer oder mehreren Flowvariablen.",
               "info": "",
               "x": 380,
               "y": 140,
               "wires": []
               "id": "cdb69797b74f2807",
               "type": "ioBroker in",
               "name": "PV Tag Prognose",
               "topic": "0_userdata.0.Test.prognose",
               "payloadType": "value",
               "onlyack": "",
               "func": "all",
               "gap": "",
               "fireOnStart": "false",
               "outFormat": "MQTT",
               "x": 140,
               "y": 240,
               "wires": [
                       "b50f80bf8bcbc213"
               "id": "b88f4dd26163692b",
               "name": "PV Today bis jetzt",
               "topic": "0_userdata.0.Test.aktuell",
               "onlyack": "",
               "func": "all",
               "gap": "",
               "x": 150,
               "y": 300,
               "wires": [
                       "ae13ce4883489a74"
               "id": "b50f80bf8bcbc213",
               "type": "change",
               "name": "",
               "rules": [
                       "t": "set",
                       "p": "PV_Tag_Prognose",
                       "pt": "flow",
                       "to": "payload",
                       "tot": "msg"
               "action": "",
               "property": "",
               "from": "",
               "to": "",
               "reg": false,
               "x": 400,
               "y": 240,
               "wires": [
               "id": "ae13ce4883489a74",
               "type": "change",
               "name": "",
               "rules": [
                       "t": "set",
                       "p": "prognose",
                       "pt": "msg",
                       "to": "PV_Tag_Prognose",
                       "tot": "flow"
               "action": "",
               "property": "",
               "from": "",
               "to": "",
               "reg": false,
               "x": 380,
               "y": 300,
               "wires": [
                       "88273195c80c84f2"
               "id": "88273195c80c84f2",
               "type": "switch",
               "name": "payload > prognose",
               "property": "payload > prognose",
               "propertyType": "jsonata",
               "rules": [
                       "t": "true"
               "checkall": "true",
               "repair": false,
               "outputs": 1,
               "x": 610,
               "y": 300,
               "wires": [
                       "70bd4a0a0a2d4787"
               "id": "2c68eba46d5dbeef",
               "type": "debug",
               "name": "sende Nachricht (Beispiel Flowvariable)",
               "active": true,
               "tosidebar": true,
               "console": false,
               "tostatus": false,
               "complete": "payload",
               "targetType": "msg",
               "statusVal": "",
               "statusType": "auto",
               "x": 1060,
               "y": 300,
               "wires": []
               "id": "70bd4a0a0a2d4787",
               "type": "change",
               "name": "Nachricht",
               "rules": [
                       "t": "set",
                       "p": "payload",
                       "pt": "msg",
                       "to": "Prognose wurde überschritten",
                       "tot": "str"
               "action": "",
               "property": "",
               "from": "",
               "to": "",
               "reg": false,
               "x": 800,
               "y": 300,
               "wires": [
                       "2c68eba46d5dbeef"
               "id": "85702a2c7a400d9c",
               "type": "comment",
               "name": "Du sammelst die beiden Werte in einem Nachrichtenobjekt mit einer JOIN Node.",
               "info": "",
               "x": 380,
               "y": 440,
               "wires": []
               "id": "da0c33ab90da3dad",
               "onlyack": "",
               "func": "all",
               "gap": "",
               "x": 140,
               "y": 520,
               "wires": [
                       "0fa1b7591f0b4d26"
               "id": "89ef3782b3d5fbd7",
               "onlyack": "",
               "func": "all",
               "gap": "",
               "x": 150,
               "y": 600,
               "wires": [
                       "b2b601430ac7e80d"
               "id": "0fa1b7591f0b4d26",
               "type": "change",
               "name": "topic = prognose",
               "rules": [
                       "t": "set",
                       "p": "topic",
                       "pt": "msg",
                       "to": "prognose",
                       "tot": "str"
               "action": "",
               "property": "",
               "from": "",
               "to": "",
               "reg": false,
               "x": 390,
               "y": 520,
               "wires": [
                       "1c38bf5becbffb8a"
               "id": "b2b601430ac7e80d",
               "type": "change",
               "name": "topic = aktuell",
               "rules": [
                       "t": "set",
                       "p": "topic",
                       "pt": "msg",
                       "to": "aktuell",
                       "tot": "str"
               "action": "",
               "property": "",
               "from": "",
               "to": "",
               "reg": false,
               "x": 400,
               "y": 600,
               "wires": [
                       "1c38bf5becbffb8a"
               "id": "1c38bf5becbffb8a",
               "type": "join",
               "name": "",
               "mode": "custom",
               "build": "object",
               "property": "payload",
               "propertyType": "msg",
               "key": "topic",
               "joiner": "\\n",
               "joinerType": "str",
               "accumulate": true,
               "timeout": "",
               "count": "2",
               "reduceRight": false,
               "reduceExp": "",
               "reduceInit": "",
               "reduceInitType": "",
               "reduceFixup": "",
               "x": 590,
               "y": 560,
               "wires": [
                       "50445639c6bb29cc"
               "id": "50445639c6bb29cc",
               "type": "switch",
               "property": "payload.aktuell > payload.prognose",
               "rules": [
                       "t": "true"
               "checkall": "true",
               "repair": false,
               "outputs": 1,
               "x": 770,
               "y": 560,
               "wires": [
                       "8d562efab2cfff9a"
               "id": "42643fa00df8601f",
               "type": "debug",
               "name": "sende Nachricht (Beispiel JOIN)",
               "active": true,
               "tosidebar": true,
               "console": false,
               "tostatus": false,
               "statusVal": "",
               "x": 1190,
               "y": 560,
               "wires": []
               "id": "8d562efab2cfff9a",
               "type": "change",
               "rules": [
                       "t": "set",
                       "p": "payload",
                       "pt": "msg",
                       "tot": "str"
               "action": "",
               "property": "",
               "from": "",
               "to": "",
               "reg": false,
               "x": 960,
               "y": 560,
               "wires": [
                       "42643fa00df8601f"
               "id": "179914fd1a8968f2",
               "type": "comment",
               "name": "Wenn ein Wert getriggert ist und zum Beispiel im iobroker ein anderer ausgelesen werden soll, dann kann man das quasi Huckepack auslesen.",
               "info": "",
               "x": 570,
               "y": 700,
               "wires": []
               "id": "b94fd1601ba3f40c",
               "onlyack": "",
               "func": "all",
               "gap": "",
               "x": 170,
               "y": 800,
               "wires": [
                       "cc98ccdd4d05a363"
               "id": "cc98ccdd4d05a363",
               "type": "ioBroker get",
               "attrname": "prognose",
               "errOnInvalidState": "nothing",
               "x": 390,
               "y": 800,
               "wires": [
                       "242ef6373f0959c3"
               "id": "242ef6373f0959c3",
               "type": "switch",
               "rules": [
                       "t": "true"
               "checkall": "true",
               "repair": false,
               "outputs": 1,
               "x": 610,
               "y": 800,
               "wires": [
                       "7124503b946b2a85"
               "id": "78445ce181de5648",
               "type": "debug",
               "name": "sende Nachricht (Huckepack)",
               "active": true,
               "tosidebar": true,
               "console": false,
               "tostatus": false,
               "statusVal": "",
               "x": 1030,
               "y": 800,
               "wires": []
               "id": "7124503b946b2a85",
               "type": "change",
               "rules": [
                       "t": "set",
                       "p": "payload",
                       "pt": "msg",
                       "tot": "str"
               "action": "",
               "property": "",
               "from": "",
               "to": "",
               "reg": false,
               "x": 800,
               "y": 800,
               "wires": [
                       "78445ce181de5648"
