    4. Installation
    5. MBUS Installation unter Windows
      thaistatos last edited by
      Iobroker läuft unter Windows.
      Die Installation des MBUS Adapter schlägt fehl.
      Andere Adapter wie Modbus oder WMbus lassen sich aber installieren.
      Ich habe noch Python installiert und Node JS auf 20 irgendwas upgedatet.
      Mir sagt die (schlecht formatierte) Fehlerausgabe nichts:
      $ iobroker add mbus --host DESKTOP-T817QCF
      NPM version: 10.1.0
      Installing iobroker.mbus@2.4.0... (System call)
      npm ERR! code 1npm ERR! path C:\ioBroker\node_modules\node-mbusnpm ERR! command failednpm ERR! command C:\WINDOWS\system32\cmd.exe /d /s /c node-gyp rebuildnpm ERR! gyp ERR! find Python npm ERR! gyp ERR! find Python Python is not set from command line or npm configurationnpm ERR! gyp ERR! find Python Python is not set from environment variable PYTHONnpm ERR! gyp ERR! find Python checking if "python3" can be usednpm ERR! gyp ERR! find Python - "python3" is not in PATH or produced an errornpm ERR! gyp ERR! find Python checking if "python" can be usednpm ERR! gyp ERR! find Python - "python" is not in PATH or produced an errornpm ERR! gyp ERR! find Python checking if Python is C:\WINDOWS\system32\config\systemprofile\AppData\Local\Programs\Python\Python39\python.exenpm ERR! gyp ERR! find Python - "C:\WINDOWS\system32\config\systemprofile\AppData\Local\Programs\Python\Python39\python.exe" could not be runnpm ERR! gyp ERR! find Python checking if Python is C:\Program Files\Python39\python.exenpm ERR! gyp ERR! find Python - "C:\Program Files\Python39\python.exe" could not be runnpm ERR! gyp ERR! find Python checking if Python is C:\WINDOWS\system32\config\systemprofile\AppData\Local\Programs\Python\Python39-32\python.exenpm ERR! gyp ERR! find Python - "C:\WINDOWS\system32\config\systemprofile\AppData\Local\Programs\Python\Python39-32\python.exe" could not be runnpm ERR! gyp ERR! find Python checking if Python is C:\Program Files\Python39-32\python.exenpm ERR! gyp ERR! find Python - "C:\Program Files\Python39-32\python.exe" could not be runnpm ERR! gyp ERR! find Python checking if Python is C:\Program Files (x86)\Python39-32\python.exenpm ERR! gyp ERR! find Python - "C:\Program Files (x86)\Python39-32\python.exe" could not be runnpm ERR! gyp ERR! find Python checking if Python is C:\WINDOWS\system32\config\systemprofile\AppData\Local\Programs\Python\Python38\python.exenpm ERR! gyp ERR! find Python - "C:\WINDOWS\system32\config\systemprofile\AppData\Local\Programs\Python\Python38\python.exe" could not be runnpm ERR! gyp ERR! find Python checking if Python is C:\Program Files\Python38\python.exenpm ERR! gyp ERR! find Python - "C:\Program Files\Python38\python.exe" could not be runnpm ERR! gyp ERR! find Python checking if Python is C:\WINDOWS\system32\config\systemprofile\AppData\Local\Programs\Python\Python38-32\python.exenpm ERR! gyp ERR! find Python - "C:\WINDOWS\system32\config\systemprofile\AppData\Local\Programs\Python\Python38-32\python.exe" could not be runnpm ERR! gyp ERR! find Python checking if Python is C:\Program Files\Python38-32\python.exenpm ERR! gyp ERR! find Python - "C:\Program Files\Python38-32\python.exe" could not be runnpm ERR! gyp ERR! find Python checking if Python is C:\Program Files (x86)\Python38-32\python.exenpm ERR! gyp ERR! find Python - "C:\Program Files (x86)\Python38-32\python.exe" could not be runnpm ERR! gyp ERR! find Python checking if Python is C:\WINDOWS\system32\config\systemprofile\AppData\Local\Programs\Python\Python37\python.exenpm ERR! gyp ERR! find Python - "C:\WINDOWS\system32\config\systemprofile\AppData\Local\Programs\Python\Python37\python.exe" could not be runnpm ERR! gyp ERR! find Python checking if Python is C:\Program Files\Python37\python.exenpm ERR! gyp ERR! find Python - "C:\Program Files\Python37\python.exe" could not be runnpm ERR! gyp ERR! find Python checking if Python is C:\WINDOWS\system32\config\systemprofile\AppData\Local\Programs\Python\Python37-32\python.exenpm ERR! gyp ERR! find Python - "C:\WINDOWS\system32\config\systemprofile\AppData\Local\Programs\Python\Python37-32\python.exe" could not be runnpm ERR! gyp ERR! find Python checking if Python is C:\Program Files\Python37-32\python.exenpm ERR! gyp ERR! find Python - "C:\Program Files\Python37-32\python.exe" could not be runnpm ERR! gyp ERR! find Python checking if Python is C:\Program Files (x86)\Python37-32\python.exenpm ERR! gyp ERR! find Python - "C:\Program Files (x86)\Python37-32\python.exe" could not be runnpm ERR! gyp ERR! find Python checking if Python is C:\WINDOWS\system32\config\systemprofile\AppData\Local\Programs\Python\Python36\python.exenpm ERR! gyp ERR! find Python - "C:\WINDOWS\system32\config\systemprofile\AppData\Local\Programs\Python\Python36\python.exe" could not be runnpm ERR! gyp ERR! find Python checking if Python is C:\Program Files\Python36\python.exenpm ERR! gyp ERR! find Python - "C:\Program Files\Python36\python.exe" could not be runnpm ERR! gyp ERR! find Python checking if Python is C:\WINDOWS\system32\config\systemprofile\AppData\Local\Programs\Python\Python36-32\python.exenpm ERR! gyp ERR! find Python - "C:\WINDOWS\system32\config\systemprofile\AppData\Local\Programs\Python\Python36-32\python.exe" could not be runnpm ERR! gyp ERR! find Python checking if Python is C:\Program Files\Python36-32\python.exenpm ERR! gyp ERR! find Python - "C:\Program Files\Python36-32\python.exe" could not be runnpm ERR! gyp ERR! find Python checking if Python is C:\Program Files (x86)\Python36-32\python.exenpm ERR! gyp ERR! find Python - "C:\Program Files (x86)\Python36-32\python.exe" could not be runnpm ERR! gyp ERR! find Python checking if the py launcher can be used to find Python 3npm ERR! gyp ERR! find Python - "py.exe" is not in PATH or produced an errornpm ERR! gyp ERR! find Python npm ERR! gyp ERR! find Python **********************************************************npm ERR! gyp ERR! find Python You need to install the latest version of Python.npm ERR! gyp ERR! find Python Node-gyp should be able to find and use Python. If not,npm ERR! gyp ERR! find Python you can try one of the following options:npm ERR! gyp ERR! find Python - Use the switch --python="C:\Path\To\python.exe"npm ERR! gyp ERR! find Python (accepted by both node-gyp and npm)npm ERR! gyp ERR! find Python - Set the environment variable PYTHONnpm ERR! gyp ERR! find Python - Set the npm configuration variable python:npm ERR! gyp ERR! find Python npm config set python "C:\Path\To\python.exe"npm ERR! gyp ERR! find Python For more information consult the documentation at:npm ERR! gyp ERR! find Python https://github.com/nodejs/node-gyp#installationnpm ERR! gyp ERR! find Python **********************************************************npm ERR! gyp ERR! find Python npm ERR! gyp ERR! configure error npm ERR! gyp ERR! stack Error: Could not find any Python installation to usenpm ERR! gyp ERR! stack at PythonFinder.fail (C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\find-python.js:330:47)npm ERR! gyp ERR! stack at PythonFinder.runChecks (C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\find-python.js:159:21)npm ERR! gyp ERR! stack at PythonFinder.<anonymous> (C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\find-python.js:228:18)npm ERR! gyp ERR! stack at PythonFinder.execFileCallback (C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\find-python.js:294:16)npm ERR! gyp ERR! stack at exithandler (node:child_process:430:5)npm ERR! gyp ERR! stack at ChildProcess.errorhandler (node:child_process:442:5)npm ERR! gyp ERR! stack at ChildProcess.emit (node:events:514:28)npm ERR! gyp ERR! stack at ChildProcess._handle.onexit (node:internal/child_process:292:12)npm ERR! gyp ERR! stack at onErrorNT (node:internal/child_process:484:16)npm ERR! gyp ERR! stack at process.processTicksAndRejections (node:internal/process/task_queues:82:21)npm ERR! gyp ERR! System Windows_NT 10.0.19045npm ERR! gyp ERR! command "C:\\Program Files\\nodejs\\node.exe" "C:\\Program Files\\nodejs\\node_modules\\npm\\node_modules\\node-gyp\\bin\\node-gyp.js" "rebuild"npm ERR! gyp ERR! cwd C:\ioBroker\node_modules\node-mbusnpm ERR! gyp ERR! node -v v20.9.0npm ERR! gyp ERR! node-gyp -v v9.4.0npm ERR! gyp ERR! not oknpm ERR! A complete log of this run can be found in: C:\WINDOWS\system32\config\systemprofile\AppData\Local\npm-cache\_logs\2023-11-12T10_26_32_377Z-debug-0.log
      host.DESKTOP-T817QCF Cannot install iobroker.mbus@2.4.0: 1
      ERROR: Process exited with code 25
      Was ist zu tun?
      Ich hatte das schonmal unter Proxmox aufgesetzt und kann mich nicht an Probleme speziell mit dem Adapter erinnern.
