    4. IoBroker reagiert nicht mehr
      Chris-D 0 last edited by Chris-D 0
      Mein IOBROKER ist nicht mehr erreichbar.
      Morgens aufgewacht und IOBROKER ist nicht mehr erreichbar.
      IOBROKER FIx hat auch nicht geholfen.
      pi@raspberrypi:~ $ iobroker update
      node:internal/modules/cjs/loader:1031
        throw err;
          at Function.Module._resolveFilename (node:internal/modules/cjs/loader:1028:15)
          at Function.Module._load (node:internal/modules/cjs/loader:873:27)
          at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:81:12)
          at node:internal/main/run_main_module:22:47 {
        code: 'MODULE_NOT_FOUND',
        requireStack: []
      IOB Diag Ausgabe wie folgt:
                              v.2023-10-10
         Static hostname: raspberrypi
               Icon name: computer
        Operating System: Raspbian GNU/Linux 10 (buster)
                  Kernel: Linux 5.10.103-v7l+
            Architecture: arm
      Kernel:                 armv7l
      Userland:               armhf
      User-ID:                1000
      X-Server:               false
      Pending OS-Updates:     30
        throw err;
      Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iob        roker.js'
          at Function.Module._resolveFilename (node:internal/modules/cjs/loader:1028:1        5)
          at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_ma        in:81:12)
        requireStack: []
      Pending iob updates:    0
      Nodejs-Installation:    /usr/bin/nodejs         v16.20.2
                              /usr/bin/node           v16.20.2
                              /usr/bin/npm            8.19.4
                              /usr/local/bin/npx              7.20.3
                              /usr/bin/corepack       0.17.0
      *** nodejs is NOT correctly installed ***
      Wrong installation path detected. This needs to be fixed.
      Please check
      https://forum.iobroker.net/topic/35090/howto-nodejs-installation-und-upgrades-unter-debian
      for more information on how to fix these errors.
      MEMORY:
      Mem:           3.8G         87M        3.3G        8.0M        438M        3.6G
      Swap:           99M          0B         99M
      Total:         3.9G         87M        3.4G
        throw err;
        requireStack: []
      Active iob-Instances:   0
        throw err;
        requireStack: []
        throw err;
        requireStack: []
      ioBroker Core:          js-controller
        throw err;
        requireStack: []
                              admin
        throw err;
        requireStack: []
      ioBroker Status:
        throw err;
        requireStack: []
      Objects:                0
      States:                 0
      Size of iob-Database:
      14M     /opt/iobroker/iobroker-data/objects.jsonl
      7.6M    /opt/iobroker/iobroker-data/objects.json.migrated
      7.6M    /opt/iobroker/iobroker-data/objects.json.bak.migrated
      0       /opt/iobroker/iobroker-data/objects.json.broken
      8.1M    /opt/iobroker/iobroker-data/states.jsonl
      1020K   /opt/iobroker/iobroker-data/states.json.migrated
      1020K   /opt/iobroker/iobroker-data/states.json.bak.migrated
      0       /opt/iobroker/iobroker-data/states.json.broken
      Was kann ich machen?
        Thomas Braun Most Active @Chris-D 0 last edited by Thomas Braun
        @chris-d-0
        (buster)
        Tot, installier da ein lebendiges Release.
        In der 64Bit-Lite-Version.
        Update-Stau, nodejs&Co. falsch installiert...
          Chris-D 0 @Thomas Braun last edited by
          @thomas-braun Danke für den Hinweis. Wie genau mache ich das?
            @chris-d-0
            Neuinstallation?
            Mit dem Raspberry OS Imager.
            Danach halt Backup des ioBroker einspielen.
              @thomas-braun Kompletter PI? Habe noch mehr darauf laufen...
              Gibt es keine Alternative?
                @chris-d-0
                Buster ist TOT.
                'nuff said. .
                Fur das was da sonst noch läuft hast du ja auch eine Backup-Strategie.
