    4. NSPanel Problem nodejs Version
      docf last edited by
      Hallo
      wie ich schon in einem Anderem Thread gemeldet, habe ich ein Problem beim Starten des Skriptes ns_Panels.
      im Log wird gemeldet.
      nodeJS must be at least v16.X.X. Currently: v14.19.0! Please Update your System!
      Hacken an der Sache ist nur, dass ich mit der aktuellsten 18.18.2 Version arbeite.
      Ein iob nodejs-update bring folgende Meldungen.
      Evtl. hat jemand da einen Tipp für mich.
      Nothing to do - Your installation is using the correct paths.
      You are running nodejs v18.18.0. Do you want to install recommended version 18.18.2?
      Press <y> to continue or any other key to quit
      Trying to update your installation now. Please be patient.
      find: '/run/user/1000/doc': Permission denied
      find: '/run/user/1000/gvfs': Permission denied
      find: '/run/user/127/doc': Permission denied
      find: '/run/user/127/gvfs': Permission denied
      Waiting for ioBroker to shut down - Give me a minute...
      *** These repos are active on your system:
      Hit:1 http://at.archive.ubuntu.com/ubuntu jammy InRelease
      Get:2 http://at.archive.ubuntu.com/ubuntu jammy-updates InRelease [119 kB]
      Get:3 http://at.archive.ubuntu.com/ubuntu jammy-backports InRelease [109 kB]
      Get:4 https://repos.influxdata.com/debian stable InRelease [6901 B]
      Get:5 http://security.ubuntu.com/ubuntu jammy-security InRelease [110 kB]
      Get:6 https://repos.influxdata.com/debian jammy InRelease [7046 B]
      Get:7 https://packages.grafana.com/enterprise/deb stable InRelease [5984 B]
      Get:8 http://at.archive.ubuntu.com/ubuntu jammy-updates/main amd64 DEP-11 Metadata [101 kB]
      Get:9 http://at.archive.ubuntu.com/ubuntu jammy-updates/universe amd64 DEP-11 Metadata [305 kB]
      Get:10 http://at.archive.ubuntu.com/ubuntu jammy-updates/multiverse amd64 DEP-11 Metadata [940 B]
      Get:11 http://at.archive.ubuntu.com/ubuntu jammy-backports/main amd64 DEP-11 Metadata [4936 B]
      Get:12 http://at.archive.ubuntu.com/ubuntu jammy-backports/universe amd64 DEP-11 Metadata [18.8 kB]
      Err:4 https://repos.influxdata.com/debian stable InRelease
        The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
      Err:6 https://repos.influxdata.com/debian jammy InRelease
      Err:7 https://packages.grafana.com/enterprise/deb stable InRelease
        The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 963FA27710458545
      Fetched 782 kB in 2s (421 kB/s)
      Reading package lists... Done
      W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://repos.influxdata.com/debian stable InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
      W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://repos.influxdata.com/debian jammy InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
      W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://packages.grafana.com/enterprise/deb stable InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 963FA27710458545
      W: Failed to fetch https://packages.grafana.com/enterprise/deb/dists/stable/InRelease  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 963FA27710458545
      W: Failed to fetch https://repos.influxdata.com/debian/dists/stable/InRelease  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
      W: Failed to fetch https://repos.influxdata.com/debian/dists/jammy/InRelease  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
      W: Some index files failed to download. They have been ignored, or old ones used instead.
      *** Installing ca-certificates, curl and gnupg, just in case they are missing.
      *** Creating new /etc/apt/sources.list.d/nodesource.list and pinning source
      deb [signed-by=/etc/apt/keyrings/nodesource.gpg] https://deb.nodesource.com/node_18.x nodistro main
      Package: nodejs
      Pin: origin deb.nodesource.com
      Pin-Priority: 1001
      *** These repos are active after the adjustments:
      Hit:2 http://at.archive.ubuntu.com/ubuntu jammy-updates InRelease
      Hit:3 http://at.archive.ubuntu.com/ubuntu jammy-backports InRelease
      Get:5 https://repos.influxdata.com/debian jammy InRelease [7046 B]
      Hit:6 http://security.ubuntu.com/ubuntu jammy-security InRelease
      Hit:8 https://deb.nodesource.com/node_18.x nodistro InRelease
      Err:5 https://repos.influxdata.com/debian jammy InRelease
      Fetched 13.9 kB in 2s (7748 B/s)
      N: Skipping acquire of configured file 'main/binary-i386/Packages' as repository 'https://deb.nodesource.com/node_18.x nodistro InRelease' doesn't support architecture 'i386'
      Installing the recommended nodejs version now!
      Installing the recommended nodejs version!
      (Reading database ... 207120 files and directories currently installed.)
      Preparing to unpack .../nodejs_18.18.2-1nodesource1_amd64.deb ...
      Detected old npm client, removing...
      Unpacking nodejs (18.18.2-1nodesource1) over (18.18.0-1nodesource1) ...
      Setting up nodejs (18.18.2-1nodesource1) ...
      Processing triggers for man-db (2.10.2-1) ...
      We tried our best to fix your nodejs. Please run iob diag again to verify.
      *** RESTARTING ioBroker NOW! ***
       Please refresh or restart your browser in a few moments.
        Thomas Braun Most Active @docf last edited by
        @docf
        Hat mir dem Problem zwar nichts zu tun:
        Schalt den Desktop-Mumpitz aus und räum das influx sowie das Grafana-Repo auf.
        Influxdb ist doppelt angelegt und sowohl bei influx wie auch bei grafana fehlt der aktuelle Schlüssel.
          docf last edited by
          Danke ja mache ich
