    4. Kein iobroker Backup mehr über BackitUp Adapter
      Laser @Marc Berg last edited by
      @marc-berg
      otto@raspberrypi:/etc $ ls -lah /var/lib/influxdb
      ls: cannot open directory '/var/lib/influxdb': Permission denied
      otto@raspberrypi:/etc $ sudo ls -lah /var/lib/influxdb
      total 296K
      drwxr-x---  4 influxdb influxdb 4.0K Nov 20 16:18 .
      drwxr-xr-x 30 root     root     4.0K Nov 20 16:16 ..
      drwxr-x---  3 influxdb influxdb 4.0K May 30 13:44 .cache
      drwxr-x---  5 influxdb influxdb 4.0K May 30 14:02 engine
      -rw-------  1 influxdb influxdb 256K Nov 20 16:18 influxd.bolt
      -rw-r-----  1 influxdb influxdb    7 Nov 20 16:18 influxd.pid
      -rw-r-----  1 influxdb influxdb 120K May 30 13:44 influxd.sqlite
      otto@raspberrypi:/etc $ sudo ls -lah /etc/influxdb
      total 16K
      drwxr-xr-x  2 root root 4.0K Nov 18 18:07 .
      drwxr-xr-x 89 root root 4.0K Nov 18 18:07 ..
      -rw-r--r--  1 root root   86 May 30 13:44 config.toml
      -rw-r--r--  1 root root   86 Nov 18 18:07 config.toml.defaults
      • Marc Berg
        Marc Berg Most Active @Laser last edited by
        @laser
        Okay, dann hast du wahrscheinlich mal ein Update von V1 gemacht. Also:
        influxd recovery auth create-operator --org privat --username iobroker --bolt-path /var/lib/influxdb/influxd.bolt
          Laser @Marc Berg last edited by Laser
          @marc-berg sagte in Kein iobroker Backup mehr über BackitUp Adapter:
          Ja, habe mal upgedatet!
          DerBefehl auch als "sudo"?
          otto@raspberrypi:/etc $ influxd recovery auth create-operator --org privat --username iobroker --bolt-path /var/lib/influxdb/influxd.bolt
          Error: stat /var/lib/influxdb/influxd.bolt: permission denied
          See 'influxd -h' for help
          otto@raspberrypi:/etc $ sudo influxd recovery auth create-operator --org privat --username iobroker --bolt-path /var/lib/influxdb/influxd.bolt
          2023-11-20T15:32:46.060743Z     info    Resources opened        {"log_id": "0lcLduR0000", "system": "bolt-kvstore", "path": "/var/lib/influxdb/influxd.bolt"}
          ID                      User Name       User ID                 Description                                     Token        Permissions
          0b485bd1c75e4000        iobroker        0b4721cca3305000        onboarding-cliWizard-token-1685530468858        zijB7piBzzSSLchg2TCyrp2MViRxSJ5_HQP_ynLZO_T8K6Wy-guPxh9uI75KjCKFKIhzTGhpSSeyMpp58Z_juw==        [read:orgs/56ed5fe7a100c804/annotations write:orgs/56ed5fe7a100c804/annotations read:orgs/56ed5fe7a100c804/authorizations write:orgs/56ed5fe7a100c804/authorizations read:orgs/56ed5fe7a100c804/buckets write:orgs/56ed5fe7a100c804/buckets read:orgs/56ed5fe7a100c804/checks write:orgs/56ed5fe7a100c804/checks read:orgs/56ed5fe7a100c804/dashboards write:orgs/56ed5fe7a100c804/dashboards read:orgs/56ed5fe7a100c804/dbrp write:orgs/56ed5fe7a100c804/dbrp read:orgs/56ed5fe7a100c804/documents write:orgs/56ed5fe7a100c804/documents read:orgs/56ed5fe7a100c804/labels write:orgs/56ed5fe7a100c804/labels read:orgs/56ed5fe7a100c804/notebooks write:orgs/56ed5fe7a100c804/notebooks read:orgs/56ed5fe7a100c804/notificationEndpoints write:orgs/56ed5fe7a100c804/notificationEndpoints read:orgs/56ed5fe7a100c804/notificationRules write:orgs/56ed5fe7a100c804/notificationRules read:orgs/56ed5fe7a100c804 read:orgs/56ed5fe7a100c804/remotes write:orgs/56ed5fe7a100c804/remotes read:orgs/56ed5fe7a100c804/replications write:orgs/56ed5fe7a100c804/replications read:orgs/56ed5fe7a100c804/scrapers write:orgs/56ed5fe7a100c804/scrapers read:orgs/56ed5fe7a100c804/secrets write:orgs/56ed5fe7a100c804/secrets read:orgs/56ed5fe7a100c804/sources write:orgs/56ed5fe7a100c804/sources read:orgs/56ed5fe7a100c804/tasks write:orgs/56ed5fe7a100c804/tasks read:orgs/56ed5fe7a100c804/telegrafs write:orgs/56ed5fe7a100c804/telegrafs read:users/0b4721cca3305000 write:users/0b4721cca3305000 read:orgs/56ed5fe7a100c804/variables write:orgs/56ed5fe7a100c804/variables read:orgs/56ed5fe7a100c804/views write:orgs/56ed5fe7a100c804/views]
          0c26fdf572986000        iobroker        0b4721cca3305000        onboarding-cliWizard-token-1700471139713        oodzlogKQY9O0tCtNNDYiFxomFcAWJXjd-RTbC738Fkna1nzQiVXRjNVaKZDFt_lvWEYrZWhpUNIxsnMISQejg==        [read:orgs/56ed5fe7a100c804/annotations write:orgs/56ed5fe7a100c804/annotations read:orgs/56ed5fe7a100c804/authorizations write:orgs/56ed5fe7a100c804/authorizations read:orgs/56ed5fe7a100c804/buckets write:orgs/56ed5fe7a100c804/buckets read:orgs/56ed5fe7a100c804/checks write:orgs/56ed5fe7a100c804/checks read:orgs/56ed5fe7a100c804/dashboards write:orgs/56ed5fe7a100c804/dashboards read:orgs/56ed5fe7a100c804/dbrp write:orgs/56ed5fe7a100c804/dbrp read:orgs/56ed5fe7a100c804/documents write:orgs/56ed5fe7a100c804/documents read:orgs/56ed5fe7a100c804/labels write:orgs/56ed5fe7a100c804/labels read:orgs/56ed5fe7a100c804/notebooks write:orgs/56ed5fe7a100c804/notebooks read:orgs/56ed5fe7a100c804/notificationEndpoints write:orgs/56ed5fe7a100c804/notificationEndpoints read:orgs/56ed5fe7a100c804/notificationRules write:orgs/56ed5fe7a100c804/notificationRules read:orgs/56ed5fe7a100c804 read:orgs/56ed5fe7a100c804/remotes write:orgs/56ed5fe7a100c804/remotes read:orgs/56ed5fe7a100c804/replications write:orgs/56ed5fe7a100c804/replications read:orgs/56ed5fe7a100c804/scrapers write:orgs/56ed5fe7a100c804/scrapers read:orgs/56ed5fe7a100c804/secrets write:orgs/56ed5fe7a100c804/secrets read:orgs/56ed5fe7a100c804/sources write:orgs/56ed5fe7a100c804/sources read:orgs/56ed5fe7a100c804/tasks write:orgs/56ed5fe7a100c804/tasks read:orgs/56ed5fe7a100c804/telegrafs write:orgs/56ed5fe7a100c804/telegrafs read:users/0b4721cca3305000 write:users/0b4721cca3305000 read:orgs/56ed5fe7a100c804/variables write:orgs/56ed5fe7a100c804/variables read:orgs/56ed5fe7a100c804/views write:orgs/56ed5fe7a100c804/views]
          0c2731d6a8bd8000        iobroker        0b4721cca3305000        iobroker                                        Z50uyViNwOSShEX2jY2A09cHyCCavlnqe1GFdkzGnYWZ4a2uQ2ghc9wahuCQwuNrpDuWHhGj7_wrrflgHMkpMA==        [read:orgs/56ed5fe7a100c804/annotations write:orgs/56ed5fe7a100c804/annotations read:orgs/56ed5fe7a100c804/authorizations write:orgs/56ed5fe7a100c804/authorizations read:orgs/56ed5fe7a100c804/buckets write:orgs/56ed5fe7a100c804/buckets read:orgs/56ed5fe7a100c804/checks write:orgs/56ed5fe7a100c804/checks read:orgs/56ed5fe7a100c804/dashboards write:orgs/56ed5fe7a100c804/dashboards read:orgs/56ed5fe7a100c804/dbrp write:orgs/56ed5fe7a100c804/dbrp read:orgs/56ed5fe7a100c804/documents write:orgs/56ed5fe7a100c804/documents read:orgs/56ed5fe7a100c804/labels write:orgs/56ed5fe7a100c804/labels read:orgs/56ed5fe7a100c804/notebooks write:orgs/56ed5fe7a100c804/notebooks read:orgs/56ed5fe7a100c804/notificationEndpoints write:orgs/56ed5fe7a100c804/notificationEndpoints read:orgs/56ed5fe7a100c804/notificationRules write:orgs/56ed5fe7a100c804/notificationRules read:orgs/56ed5fe7a100c804 read:orgs/56ed5fe7a100c804/remotes write:orgs/56ed5fe7a100c804/remotes read:orgs/56ed5fe7a100c804/replications write:orgs/56ed5fe7a100c804/replications read:orgs/56ed5fe7a100c804/scrapers write:orgs/56ed5fe7a100c804/scrapers read:orgs/56ed5fe7a100c804/secrets write:orgs/56ed5fe7a100c804/secrets read:orgs/56ed5fe7a100c804/sources write:orgs/56ed5fe7a100c804/sources read:orgs/56ed5fe7a100c804/tasks write:orgs/56ed5fe7a100c804/tasks read:orgs/56ed5fe7a100c804/telegrafs write:orgs/56ed5fe7a100c804/telegrafs read:users/0b4721cca3305000 write:users/0b4721cca3305000 read:orgs/56ed5fe7a100c804/variables write:orgs/56ed5fe7a100c804/variables read:orgs/56ed5fe7a100c804/views write:orgs/56ed5fe7a100c804/views]
          0c27485709bd8000        iobroker        0b4721cca3305000        neuer iobroker token                            Q494kw0QVOhk3if8D-cZsqjlggKCOIEJcD8gW1Za4vUzKGYYQO7RoraoIrmmPm-NjdaChpZAddzXtsQ7Mw5GBg==        [read:orgs/56ed5fe7a100c804/annotations write:orgs/56ed5fe7a100c804/annotations read:orgs/56ed5fe7a100c804/authorizations write:orgs/56ed5fe7a100c804/authorizations read:orgs/56ed5fe7a100c804/buckets write:orgs/56ed5fe7a100c804/buckets read:orgs/56ed5fe7a100c804/checks write:orgs/56ed5fe7a100c804/checks read:orgs/56ed5fe7a100c804/dashboards write:orgs/56ed5fe7a100c804/dashboards read:orgs/56ed5fe7a100c804/dbrp write:orgs/56ed5fe7a100c804/dbrp read:orgs/56ed5fe7a100c804/documents write:orgs/56ed5fe7a100c804/documents read:orgs/56ed5fe7a100c804/labels write:orgs/56ed5fe7a100c804/labels read:orgs/56ed5fe7a100c804/notebooks write:orgs/56ed5fe7a100c804/notebooks read:orgs/56ed5fe7a100c804/notificationEndpoints write:orgs/56ed5fe7a100c804/notificationEndpoints read:orgs/56ed5fe7a100c804/notificationRules write:orgs/56ed5fe7a100c804/notificationRules read:orgs/56ed5fe7a100c804 read:orgs/56ed5fe7a100c804/remotes write:orgs/56ed5fe7a100c804/remotes read:orgs/56ed5fe7a100c804/replications write:orgs/56ed5fe7a100c804/replications read:orgs/56ed5fe7a100c804/scrapers write:orgs/56ed5fe7a100c804/scrapers read:orgs/56ed5fe7a100c804/secrets write:orgs/56ed5fe7a100c804/secrets read:orgs/56ed5fe7a100c804/sources write:orgs/56ed5fe7a100c804/sources read:orgs/56ed5fe7a100c804/tasks write:orgs/56ed5fe7a100c804/tasks read:orgs/56ed5fe7a100c804/telegrafs write:orgs/56ed5fe7a100c804/telegrafs read:users/0b4721cca3305000 write:users/0b4721cca3305000 read:orgs/56ed5fe7a100c804/variables write:orgs/56ed5fe7a100c804/variables read:orgs/56ed5fe7a100c804/views write:orgs/56ed5fe7a100c804/views]
          0c27568e5bacd000        iobroker        0b4721cca3305000        iobroker's Recovery Token                       7wIc7VllUj3xRIfnu2jIxvPaLgMruI2ZHyUw2dYLeHSYrPQvPtS-1l8-_Jr43Nveb_aXW5cmzT11oM59gyKx6g==        [read:authorizations write:authorizations read:buckets write:buckets read:dashboards write:dashboards read:orgs write:orgs read:sources write:sources read:tasks write:tasks read:telegrafs write:telegrafs read:users write:users read:variables write:variables read:scrapers write:scrapers read:secrets write:secrets read:labels write:labels read:views write:views read:documents write:documents read:notificationRules write:notificationRules read:notificationEndpoints write:notificationEndpoints read:checks write:checks read:dbrp write:dbrp read:notebooks write:notebooks read:annotations write:annotations read:remotes write:remotes read:replications write:replications]
          otto@r
          simatec Marc Berg 2 Replies Last reply Reply Quote 0
          • simatec
            simatec Developer Most Active @Laser last edited by
            @laser
            influx auth list -t 7wIc7VllUj3xRIfnu2jIxvPaLgMruI2ZHyUw2dYLeHSYrPQvPtS-1l8-_Jr43Nveb_aXW5cmzT11oM59gyKx6g== --json
            • Marc Berg
              Marc Berg Most Active @Laser last edited by Marc Berg
              @laser
              Heureka!
              Jetzt nochmal den
              influx auth list -t 12345 --json
              Befehl mit dem zuletzt noch vorhandenen Token.
              EDIT: vorher die DB wieder starten
                @marc-berg soll ich den Token neu anlegen, oder den zuletzt notierten verwenden?
                influx auth list -t Q494kw0QVOhk3if8D-cZsqjlggKCOIEJcD8gW1Za4vUzKGYYQO7RoraoIrmmPm-NjdaChpZAddzXtsQ7Mw5GBg== --json
                • simatec
                  @laser Habe ich doch oben geschrieben
                  https://forum.iobroker.net/post/1083546
                    Laser @simatec last edited by Laser
                    @simatec
                    also:
                    otto@raspberrypi:/etc $ influx auth list -t 7wIc7VllUj3xRIfnu2jIxvPaLgMruI2ZHyUw2dYLeHSYrPQvPtS-1l8-_Jr43Nveb_aXW5cmzT11oM59gyKx6g== --json
                                    "id": "0b485bd1c75e4000",
                                    "description": "onboarding-cliWizard-token-1685530468858",
                                    "token": "zijB7piBzzSSLchg2TCyrp2MViRxSJ5_HQP_ynLZO_T8K6Wy-guPxh9uI75KjCKFKIhzTGhpSSeyMpp58Z_juw==",
                                    "status": "active",
                                    "userName": "iobroker",
                                    "userID": "0b4721cca3305000",
                                    "permissions": [
                                            "read:orgs/56ed5fe7a100c804/annotations",
                                            "write:orgs/56ed5fe7a100c804/annotations",
                                            "read:orgs/56ed5fe7a100c804/authorizations",
                                            "write:orgs/56ed5fe7a100c804/authorizations",
                                            "read:orgs/56ed5fe7a100c804/buckets",
                                            "write:orgs/56ed5fe7a100c804/buckets",
                                            "read:orgs/56ed5fe7a100c804/checks",
                                            "write:orgs/56ed5fe7a100c804/checks",
                                            "read:orgs/56ed5fe7a100c804/dashboards",
                                            "write:orgs/56ed5fe7a100c804/dashboards",
                                            "read:orgs/56ed5fe7a100c804/dbrp",
                                            "write:orgs/56ed5fe7a100c804/dbrp",
                                            "read:orgs/56ed5fe7a100c804/documents",
                                            "write:orgs/56ed5fe7a100c804/documents",
                                            "read:orgs/56ed5fe7a100c804/labels",
                                            "write:orgs/56ed5fe7a100c804/labels",
                                            "read:orgs/56ed5fe7a100c804/notebooks",
                                            "write:orgs/56ed5fe7a100c804/notebooks",
                                            "read:orgs/56ed5fe7a100c804/notificationEndpoints",
                                            "write:orgs/56ed5fe7a100c804/notificationEndpoints",
                                            "read:orgs/56ed5fe7a100c804/notificationRules",
                                            "write:orgs/56ed5fe7a100c804/notificationRules",
                                            "read:/orgs/56ed5fe7a100c804",
                                            "read:orgs/56ed5fe7a100c804/remotes",
                                            "write:orgs/56ed5fe7a100c804/remotes",
                                            "read:orgs/56ed5fe7a100c804/replications",
                                            "write:orgs/56ed5fe7a100c804/replications",
                                            "read:orgs/56ed5fe7a100c804/scrapers",
                                            "write:orgs/56ed5fe7a100c804/scrapers",
                                            "read:orgs/56ed5fe7a100c804/secrets",
                                            "write:orgs/56ed5fe7a100c804/secrets",
                                            "read:orgs/56ed5fe7a100c804/sources",
                                            "write:orgs/56ed5fe7a100c804/sources",
                                            "read:orgs/56ed5fe7a100c804/tasks",
                                            "write:orgs/56ed5fe7a100c804/tasks",
                                            "read:orgs/56ed5fe7a100c804/telegrafs",
                                            "write:orgs/56ed5fe7a100c804/telegrafs",
                                            "read:/users/0b4721cca3305000",
                                            "write:/users/0b4721cca3305000",
                                            "read:orgs/56ed5fe7a100c804/variables",
                                            "write:orgs/56ed5fe7a100c804/variables",
                                            "read:orgs/56ed5fe7a100c804/views",
                                            "write:orgs/56ed5fe7a100c804/views"
                                    "id": "0c26fdf572986000",
                                    "description": "onboarding-cliWizard-token-1700471139713",
                                    "token": "oodzlogKQY9O0tCtNNDYiFxomFcAWJXjd-RTbC738Fkna1nzQiVXRjNVaKZDFt_lvWEYrZWhpUNIxsnMISQejg==",
                                    "status": "active",
                                    "permissions": [
                                    "id": "0c2731d6a8bd8000",
                                    "description": "iobroker",
                                    "token": "Z50uyViNwOSShEX2jY2A09cHyCCavlnqe1GFdkzGnYWZ4a2uQ2ghc9wahuCQwuNrpDuWHhGj7_wrrflgHMkpMA==",
                                    "status": "active",
                                    "permissions": [
                                    "id": "0c27485709bd8000",
                                    "description": "neuer iobroker token",
                                    "token": "Q494kw0QVOhk3if8D-cZsqjlggKCOIEJcD8gW1Za4vUzKGYYQO7RoraoIrmmPm-NjdaChpZAddzXtsQ7Mw5GBg==",
                                    "status": "active",
                                    "permissions": [
                                    "id": "0c27568e5bacd000",
                                    "description": "iobroker's Recovery Token",
                                    "token": "7wIc7VllUj3xRIfnu2jIxvPaLgMruI2ZHyUw2dYLeHSYrPQvPtS-1l8-_Jr43Nveb_aXW5cmzT11oM59gyKx6g==",
                                    "status": "active",
                                    "permissions": [
                                            "read:/authorizations",
                                            "write:/authorizations",
                                            "read:/buckets",
                                            "write:/buckets",
                                            "read:/dashboards",
                                            "write:/dashboards",
                                            "read:/orgs",
                                            "write:/orgs",
                                            "read:/sources",
                                            "write:/sources",
                                            "read:/tasks",
                                            "write:/tasks",
                                            "read:/telegrafs",
                                            "write:/telegrafs",
                                            "read:/users",
                                            "write:/users",
                                            "read:/variables",
                                            "write:/variables",
                                            "read:/scrapers",
                                            "write:/scrapers",
                                            "read:/secrets",
                                            "write:/secrets",
                                            "read:/labels",
                                            "write:/labels",
                                            "read:/views",
                                            "write:/views",
                                            "read:/documents",
                                            "write:/documents",
                                            "read:/notificationRules",
                                            "write:/notificationRules",
                                            "read:/notificationEndpoints",
                                            "write:/notificationEndpoints",
                                            "read:/checks",
                                            "write:/checks",
                                            "read:/dbrp",
                                            "write:/dbrp",
                                            "read:/notebooks",
                                            "write:/notebooks",
                                            "read:/annotations",
                                            "write:/annotations",
                                            "read:/remotes",
                                            "write:/remotes",
                                            "read:/replications",
                                            "write:/replications"
                    Marc Berg simatec 2 Replies Last reply Reply Quote 0
                    • Marc Berg
                      @laser sagte in Kein iobroker Backup mehr über BackitUp Adapter:
                      Jetzt ist es NICHT MEHR der erste Eintrag, sondern der letzte:
                      "iobroker's Recovery Token", das ist jetzt dein neuer Operator Token:
                      Nicht wieder löschen.
                      simatec 1 Reply Last reply Reply Quote 1
                      • simatec
                        @laser Der letzte ist der Operator Token
                        • simatec
                          simatec Developer Most Active @Marc Berg last edited by
                          @marc-berg Ich schreib da mal ein Wiki Eintrag zu... Der externe Link ist ja tot...
                          Marc Berg 1 Reply Last reply Reply Quote 1
                          • Marc Berg
                            Marc Berg Most Active @simatec last edited by
                            @simatec sagte in Kein iobroker Backup mehr über BackitUp Adapter:
                            Ich habe ne Copy von der Seite, falls interessant.
                              @simatec Mein Gott, nun der Letzte- wie soll das ein Normalo kapieren?
                              Jetzt läuft der Testbefehl auf der Konsole erst mal an.
                              • Marc Berg
                                Wenn der Löschfinger nicht so locker sitzt, bleibt es ewig der erste Eintrag ... 🙂
                                  @marc-berg Den Löschfinger hatte ich lange im Griff. Aber dann kam der vermeintliche Ordnungssinn hervor!
                                  Der Backupbefehl auf der Konsole läuft erst mal. Wenn der fertig ist, mache ich das über BackItUp.
                                  oder kann man das gefahrlos mit "strg C" abbrechen?
                                  • Marc Berg
                                    Da passiert weiter nichts, außer ein paar Dateileichen. Ich würde mir aber Sorgen wegen der großen Datenmengen machen. Das ist auch nicht normal, wie sich das anhört.
                                      @marc-berg Ja, das sind riesige Dateimengen. Vermutlich lese ich Werte zu oft ein. Obwohl ich das schon einige Male durchgegangen bin.
                                      Muß jetzt erst mal kurz Feuer machen 10 Min...
                                      • Marc Berg
                                        Das kannst du mal in den Data Explorer geben und schauen, wo (besonders) der Schuh drückt:
                                        from(bucket: "iobroker")
                                          |> range(start: -10y)
                                          |> filter(fn: (r) => r["_field"] == "value")
                                          |> count()
                                          |> group()
                                          |> keep(columns: ["_measurement", "_value"])
                                          |> sort(columns: ["_value"], desc: true)
                                          |> rename(columns: {_value: "Anzahl"})
                                          @marc-berg Ist angelegt. Beobachte...
                                          Zu Beginn hatte ich wirklich im Sekundenabstand aufgezeichnet. Ist aber schon abgemildert. Aber die Altlasten sind noch da. Müßte die häufigen Aufzeichnungen "abschneiden" Die Werte von damals sind ohnehin nicht von Bedeutung gewesen.
                                          Und ich danke den Beteiligten für die Hilfe. Ich konnte jetzt auf "Bookworm" umziehen und dort das Backup wieder reinholen.
                                          • simatec
                                            simatec Developer Most Active last edited by
                                            So hier mal zum Abschluss noch der Wiki Beitrag.
                                            https://github.com/simatec/ioBroker.backitup/wiki/Diverse-Anleitungen-für-ioBroker.backitup#operator-token-für-influxdb-2x-wiederherstellen
                                            5235
