    4. [Gelöst] SQL Adapter Installation schlägt fehl
      andyb last edited by
      Fehlermeldung:
      ! $ ./iobroker add sql
      ! npm install iobroker.sql –production --prefix "/opt/iobroker" (System call)
      ! npm
      ! WARN deprecated node-uuid@1.4.8: Use uuid module instead
      ! node-pre-gyp
      ! ERR! Tried to download(403): https://mapbox-node-binary.s3.amazonaws ... arm.tar.gz node-pre-gyp ERR! Pre-built binaries not found for sqlite3@3.1.7 and node@6.11.1 (node-v48 ABI) (falling back to source compile with node-gyp)
      ! ../src/database.cc: In static member function ‘static Nan::NAN_METHOD_RETURN_TYPE node_sqlite3::Database::New(Nan::NAN_METHOD_ARGS_TYPE)’:../src/database.cc:133:96: warning: ‘bool v8::Object::ForceSet(v8::Localv8::value, v8::Localv8::value, v8::PropertyAttribute)’ is deprecated (declared at /root/.node-gyp/6.11.1/include/node/v8.h:2694): Use CreateDataProperty / DefineOwnProperty [-Wdeprecated-declarations]
      ! info.This()->ForceSet(Nan::New("filename").ToLocalChecked(), info[0].As<string>(), ReadOnly);
      ! ../src/database.cc:134:86: warning: ‘bool v8::Object::ForceSet(v8::Localv8::value, v8::Localv8::value, v8::PropertyAttribute)’ is deprecated (declared at /root/.node-gyp/6.11.1/include/node/v8.h:2694): Use CreateDataProperty / DefineOwnProperty [-Wdeprecated-declarations] info.This()->ForceSet(Nan::New("mode").ToLocalChecked(), Nan::New(mode), ReadOnly);
      ! ../src/database.cc: In static member function ‘static void node_sqlite3::Database::Work_BeginOpen(node_sqlite3::Database::Baton*)’:
      ! ../src/database.cc:144:9: warning: unused variable ‘status’ [-Wunused-variable]
      ! int status = uv_queue_work(uv_default_loop(),
      ! ../src/database.cc: In static member function ‘static void node_sqlite3::Database::Work_BeginClose(node_sqlite3::Database::Baton*)’:
      ! ../src/database.cc:230:9: warning: unused variable ‘status’ [-Wunused-variable]
      ! ../src/database.cc: In static member function ‘static void node_sqlite3::Database::Work_BeginExec(node_sqlite3::Database::Baton*)’:
      ! ../src/database.cc:525:9: warning: unused variable ‘status’ [-Wunused-variable]
      ! ../src/database.cc: In static member function ‘static void node_sqlite3::Database::Work_BeginLoadExtension(node_sqlite3::Database::Baton*)’:
      ! ../src/database.cc:625:9: warning: unused variable ‘status’ [-Wunused-variable]
      ! ../src/statement.cc: In static member function ‘static Nan::NAN_METHOD_RETURN_TYPE node_sqlite3::Statement::New(Nan::NAN_METHOD_ARGS_TYPE)’:../src/statement.cc:103:74: warning: ‘bool v8::Object::ForceSet(v8::Localv8::value, v8::Localv8::value, v8::PropertyAttribute)’ is deprecated (declared at /root/.node-gyp/6.11.1/include/node/v8.h:2694): Use CreateDataProperty / DefineOwnProperty [-Wdeprecated-declarations]
      ! info.This()->ForceSet(Nan::New("sql").ToLocalChecked(), sql, ReadOnly);
      ! ../src/statement.cc: In static member function ‘static void node_sqlite3::Statement::Work_BeginPrepare(node_sqlite3::Database::Baton*)’:../src/statement.cc:118:9: warning: unused variable ‘status’ [-Wunused-variable]
      ! In file included from ../src/statement.cc:6:0:../src/statement.cc: In static member function ‘static void node_sqlite3::Statement::Work_BeginBind(node_sqlite3::Statement::Baton*)’:
      ! ../src/macros.h:125:9: warning: unused variable ‘status’ [-Wunused-variable]
      ! ../src/statement.cc:322:5: note: in expansion of macro ‘STATEMENT_BEGIN’
      ! STATEMENT_BEGIN(Bind);
      ! ../src/statement.cc: In static member function ‘static void node_sqlite3::Statement::Work_BeginGet(node_sqlite3::Statement::Baton*)’:../src/macros.h:125:9: warning: unused variable ‘status’ [-Wunused-variable]
      ! ../src/statement.cc:370:5: note: in expansion of macro ‘STATEMENT_BEGIN’
      ! STATEMENT_BEGIN(Get);
      ! ../src/statement.cc: In static member function ‘static void node_sqlite3::Statement::Work_BeginRun(node_sqlite3::Statement::Baton*)’:../src/macros.h:125:9: warning: unused variable ‘status’ [-Wunused-variable]
      ! ../src/statement.cc:438:5: note: in expansion of macro ‘STATEMENT_BEGIN’
      ! STATEMENT_BEGIN(Run);
      ! ../src/statement.cc: In static member function ‘static void node_sqlite3::Statement::Work_BeginAll(node_sqlite3::Statement::Baton*)’:../src/macros.h:125:9: warning: unused variable ‘status’ [-Wunused-variable]
      ! ../src/statement.cc:504:5: note: in expansion of macro ‘STATEMENT_BEGIN’
      ! STATEMENT_BEGIN(All);
      ! ../src/statement.cc: In static member function ‘static void node_sqlite3::Statement::Work_BeginEach(node_sqlite3::Statement::Baton*)’:../src/macros.h:125:9: warning: unused variable ‘status’ [-Wunused-variable]
      ! ../src/statement.cc:601:5: note: in expansion of macro ‘STATEMENT_BEGIN’
      ! STATEMENT_BEGIN(Each);
      ! ../src/statement.cc: In static member function ‘static void node_sqlite3::Statement::Work_BeginReset(node_sqlite3::Statement::Baton*)’:../src/macros.h:125:9: warning: unused variable ‘status’ [-Wunused-variable]
      ! ../src/statement.cc:724:5: note: in expansion of macro ‘STATEMENT_BEGIN’
      ! STATEMENT_BEGIN(Reset);
      ! host.orangepiplus2e install adapter sql
      ! npm install –production (System call) in "/opt/iobroker/node_modules/iobroker.sql"
      ! npm
      ! node-pre-gyp
      ! ERR! Tried to download(403): https://mapbox-node-binary.s3.amazonaws ... arm.tar.gz node-pre-gyp ERR! Pre-built binaries not found for sqlite3@3.1.7 and node@6.11.1 (node-v48 ABI) (falling back to source compile with node-gyp)</v8::value></v8::value></v8::value></v8::value></string></v8::value></v8::value>
        Danke für die umfangreichen Informationen.
        @andyb:
        Installation schlägt fehl `
        wirklich?
        @andyb:
        Fehlermeldung: `
        ich sehe bein Überfliegen keine wirklichen Fehler.
        Lediglich, dass fertige Pakete fehlen und dein OPi sie deswegen selber basteln muss.
          Ich war vielleicht deshalb etwas vorschnell, weil es dann ca. 10Minuten gedauert hat bis das übliche Adaptersetupfenster kam [emoji3]
          • apollon77
            apollon77 last edited by
            Sehr ich wie Rainer. Oder sind da noch Fehler die nicht im log sind? Ist der Adapter danach vorhanden mit einer Instanz?
              Ja, Adapter ist vorhanden. Hab jetzt 2 Datenpunkte mal zugefügt, morgen mal schauen
