    4. VIS fehlt
    VIS fehlt
      toki1973 last edited by
      Nun ist der Umzug auf ein neues System fast abgeschlossen, aber scheinbar fehlt die VIS. Als Instanz ist sie angelegt kann aber nicht gestartet werden.
      vis.0
      86380	2023-11-20 12:31:06.178	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
      vis.0
      86380	2023-11-20 12:31:06.177	info	terminating
      vis.0
      86380	2023-11-20 12:31:05.658	error	Not exists
      vis.0
      86380	2023-11-20 12:31:05.658	error	Error: Not exists at ObjectsInRedisClient._readFile (/opt/iobroker/node_modules/@iobroker/db-objects-redis/build/lib/objects/objectsInRedisClient.js:854:19) at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-objects-redis/build/lib/objects/objectsInRedisClient.js:891:59) at process.processImmediate (node:internal/timers:478:21)
      vis.0
      86380	2023-11-20 12:31:05.656	error	unhandled promise rejection: Not exists
      vis.0
      86380	2023-11-20 12:31:05.655	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      vis.0
      86380	2023-11-20 12:31:04.311	info	starting. Version 1.5.1 in /opt/iobroker/node_modules/iobroker.vis, node: v18.18.2, js-controller: 5.0.16
      Nachinstallieren über NPM des Adapters ergibt folgendes
      $ iobroker url iobroker.vis@latest --host iobroker --debug
      install iobroker.vis@latest
      NPM version: 9.8.1Installing iobroker.vis@latest... (System call)
      npm ERR! code 6
      npm ERR! path /opt/iobroker/node_modules/iobroker.visnpm ERR! command failednpm ERR! command sh -c node main.js --install
      npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-11-20T11_39_41_160Z-debug-0.log
      npm ERR! code 6npm ERR! path /opt/iobroker/node_modules/iobroker.visnpm ERR! command failednpm ERR! command sh -c node main.js --installnpm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-11-20T11_39_41_160Z-debug-0.log
      host.iobroker Cannot install iobroker.vis@latest: 6
      ERROR: Process exited with code 25
      Codierknecht Homoran 2 Replies Last reply Reply Quote 0
      • Codierknecht
        Codierknecht Developer Most Active @toki1973 last edited by
        @toki1973
        Hast Du vor dem Restore des Backup auch Vis manuell installiert?
          Homoran Global Moderator Administrators @toki1973 last edited by
          @toki1973 Backup wiederhergestellt??
          vis vorher manuell installiert gehabt?
            toki1973 @Homoran last edited by
            Hm das kann ich nicht mehr sagen ob ich vis manuell installiert hatte. Normalerweise nicht. Aber den Adapter selbst finde ich nicht unter den Adaptern. Das war ein Versuch ihn wieder zu bekommen.
            Was kann ich noch versuchen?
            Das Backup habe ich wieder hergestellt. Aber im Backup Adapter gibt es kein Häkchen für VIS Backup. Ich kann auch notfalls die VIS manuell vom alten System rüber kopieren.
              @toki1973 vis ist im Backup drin!!
              AAABER
              du musst es auf dem neuen System vor dem Restore manuell installiert gehabt habrn.
              ist leider ein Bug
                @homoran Und wie bekomme ich es nun? Und was ist mit den vis-projekten?
                  @toki1973 sagte in VIS fehlt:
                  sollten alle da sein!
                  iob install vis@1.4.10 dann iob upload vis
                  danach vis auf aktuellen Stand updaten
                  T 1 Reply Last reply Reply Quote 2
                    @homoran said in VIS fehlt:
                    iob upload vis
                    Super alles wieder da 🙂
                      Natürlich!
                      mit vorheriger Installation wäre alles sofort da gewesen.
                        @toki1973 nochmal...
                        358
