    4. Installation
    5. Snap S7
    Snap S7
      MartinFriz last edited by
      Ich möchte unter WINDOWS 10 den Siemensadapter installieren-
      Ich bekomme folgende Fehlermeldung:
      iobroker npm ERR! code 1npm ERR! path C:\ioBroker\node_modules\node-snap7npm ERR! command failednpm ERR! command C:\WINDOWS\system32\cmd.exe /d /s /c prebuild-install || node-gyp rebuildnpm ERR! gyp ERR! find Python npm ERR! gyp ERR! find Python Python is not set from command line or npm configurationnpm ERR! gyp ERR! find Python Python is not set from environment variable PYTHONnpm ERR! gyp ERR! find Python checking if "python3" can be usednpm ERR! gyp ERR! find Python - "python3" is not in PATH or produced an errornpm ERR! gyp ERR! find Python checking if "python" can be usednpm ERR! gyp ERR! find Python - "python" is not in PATH or produced an errornpm ERR! gyp ERR! find Python checking if Python is C:\WINDOWS\system32\config\systemprofile\AppData\Local\Programs\Python\Python39\python.exenpm ERR! gyp ERR! find Python - "C:\WINDOWS\system32\config\systemprofile\AppData\Local\Programs\Python\Python39\python.exe" could not be runnpm ERR! gyp ERR! find Python checking if Python is C:\Program Files\Python39\python.exenpm ERR! gyp ERR! find Python - "C:\Program Files\Python39\python.exe" could not be runnpm ERR! gyp ERR! find Python checking if Python is C:\WINDOWS\system32\config\systemprofile\AppData\Local\Programs\Python\Python39-32\python.exenpm ERR! gyp ERR! find Python - "C:\WINDOWS\system32\config\systemprofile\AppData\Local\Programs\Python\Python39-32\python.exe" could not be runnpm ERR! gyp ERR! find Python checking if Python is C:\Program Files\Python39-32\python.exenpm ERR! gyp ERR! find Python - "C:\Program Files\Python39-32\python.exe" could not be runnpm ERR! gyp ERR! find Python checking if Python is C:\Program Files (x86)\Python39-32\python.exenpm ERR! gyp ERR! find Python - "C:\Program Files (x86)\Python39-32\python.exe" could not be runnpm ERR! gyp ERR! find Python checking if Python is C:\WINDOWS\system32\config\systemprofile\AppData\Local\Programs\Python\Python38\python.exenpm ERR! gyp ERR! find Python - "C:\WINDOWS\system32\config\systemprofile\AppData\Local\Programs\Python\Python38\python.exe" could not be runnpm ERR! gyp ERR! find Python checking if Python is C:\Program Files\Python38\python.exenpm ERR! gyp ERR! find Python - "C:\Program Files\Python38\python.exe" could not be runnpm ERR! gyp ERR! find Python checking if Python is C:\WINDOWS\system32\config\systemprofile\AppData\Local\Programs\Python\Python38-32\python.exenpm ERR! gyp ERR! find Python -
      Gibt es Dinge die vorher installiert werden müssen bzw. welche Voraussetzungen benötigt das System?
      Gibt es eine detailliert Beschreibung?
        Thomas Braun Most Active @MartinFriz last edited by
        @martinfriz
        node-snap7 funktioniert nicht mehr mit nodejs@18 und neuer.
        Das wird aber wenn ich das richtig sehe gerade angepackt.
        • apollon77
          apollon77 last edited by
          https://github.com/mathiask88/node-snap7/releases/tag/v1.0.7 release da ... ich schaue das ich zeitnah den Adapter update
