    4. Admin Upgrade via Gui -> Stop -> Reboot -> Alle Modules weg
      Highpressure last edited by
      Upgrade via Gui schlug bei mir heute Fehl.
      2017-09-04 20:44:52.947  - [32minfo[39m: iobroker npm
      2017-09-04 20:44:52.952  - [32minfo[39m: iobroker  WARN read-shrinkwrap This version of npm is compatible with lockfileVersion@1, but npm-shrinkwrap.json was generated for lockfileVersion@0\. I'll try to do my best with it!
      2017-09-04 20:46:08.102  - [31merror[39m: Cannot save /opt/iobroker/node_modules/iobroker.js-controller/lib/states/../../../../iobroker-data/states.json: Error: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.js-controller/lib/states/../../../../iobroker-data/states.json'
      2017-09-04 20:46:16.812  - [32minfo[39m: iobroker npm
      2017-09-04 20:46:16.814  - [32minfo[39m: iobroker  notice created a lockfile as package-lock.json. You should commit this file.
      2017-09-04 20:46:16.925  - [32minfo[39m: iobroker host.raspberrypi Adapter "system.adapter.admin.0" is started
      2017-09-04 20:46:16.949  - [32minfo[39m: host.raspberrypi object change system.adapter.admin.0
      2017-09-04 20:46:16.951  - [32minfo[39m: host.raspberrypi "system.adapter.admin.0" enabled
      2017-09-04 20:46:16.960  - [33mwarn[39m: host.raspberrypi startInstance cannot find adapter "admin". Try to install it... 1 attempt
      2017-09-04 20:46:16.962  - [32minfo[39m: iobroker install admin
      2017-09-04 20:46:16.992  - [31merror[39m: iobroker Cannot find io-package.json in /opt/iobroker/node_modules/iobroker.js-controller/adapter/admin
      2017-09-04 20:46:17.023  - [32minfo[39m: iobroker exit 10
      2017-09-04 20:46:17.778  - [31merror[39m: iobroker module.js:327    throw err;
          at Function.Module._resolveFilename (module.js:325:15)
          at Function.Module._load (module.js:276:25)
          at Function.Module.runMain (module.js:441:10)
          at startup (node.js:140:18)
          at node.js:1043:3
      2017-09-04 20:46:17.785  - [32minfo[39m: iobroker exit 1
      2017-09-04 20:46:18.791  - [33mwarn[39m: host.raspberrypi startInstance cannot find adapter "admin". Try to install it... 2 attempt
      2017-09-04 20:46:18.792  - [32minfo[39m: iobroker install admin
      2017-09-04 20:46:19.669  - [31merror[39m: iobroker module.js:327    throw err;
          at node.js:1043:3
      nun hab ich lauter unnötigen mist in /opt/iobroker/node_modules, die vorher nicht da waren, dafür sind bis auf admin und vuplus alle anderen module plus meine javascripts verschwunden
      klang erst mal nach dem hier: http://forum.iobroker.net/viewtopic.php?t=3345 aber nein leider
      ich hab auch mit find mal das system durchsucht aber nix.. samsung.js ist im system z.B. nicht mehr zu finden und auch iobroker.samsung hat nur noch die git infos / registrys im ./root übrig..
      heisst also zurück zum anfang.
      keine ahnung was da schief lief
      • AlCalzone
        Ich weiß zwar nicht was da passiert ist, aber…
        @Highpressure:
        nun hab ich lauter unnötigen mist in /opt/iobroker/node_modules `
        Hast du zufällig NodeJS aktualisiert in letzter Zeit? NPM ab Version 3 setzt auf eine flache Ordnerstruktur. Die Module in dem Ordner waren früher üblicherweise zigfach in den Unterordnern deiner Adapter abgelegt. D.h. in Summe hast du weniger "Mist".
          Ja, node hab ich letztens upgedated da ich noch auf einer uralt 2 irgendwas war und für den samsung adapter minimum 4 war
          aber seither hatte ich auch schon einen reboot hinter mir
          vor allem interessant das er eben zwei übrig gelassen hat.. aber da hat er wohl beim admin gefailed und deshalb dann nicht weiter gemacht
            @Highpressure:
            vor allem interessant das er eben zwei übrig gelassen hat.. aber da hat er wohl beim admin gefailed und deshalb dann nicht weiter gemacht ` :?: :?: :?:
            Hattest du vor dem Updates des Admin den js-controller auf den neuesten Stand gebracht?
              Nein, JS war unangetastet, da ich irgendwo im forum gelesen hatte, dass einer nach Update des JS Adapter seine Scripte verloren hatte - wovon ich leider auch einen Haufen schon hatte uff
                Ich meine nicht den JavaScript Adapter sondern den js-controller, die Engine von ioBroker.
                Die Versionsnummer findest du im Reiter hosts.
                Dieser muss immer als erstes aktualisiert werden.
                  Ahhh ok
                  Nein, den sicher nicht
                  Schade dass der admin adapter seine dependencies vorher nicht prüft
                  Hab das teil jetzt bei der gelegenheit komplett geplättet und werds auf meiner qnap in zukunft betreiben
                    @Highpressure:
                    Schade dass der admin adapter seine dependencies vorher nicht prüft `
                    Die Beschriftung des Reiters Hosts war bestimmt auf grün gewechselt.
                    Vielleicht sollte das auf rot wechseln 😉
