    4. Fehlermeldung ERROR: Process exited with code 25
      Denzel 0 last edited by
      Hallo, ich habe das Problem, dass ich beim Update von Adaptern aus der Adminseite den oben genannten Fehler erhalte.
      Das sieht dann wie folgt aus:
      $ iobroker upgrade vis-icontwo@0.98.0
      Update vis-icontwo from @0.97.3 to @0.98.0
      NPM version: 9.8.1
      Installing iobroker.vis-icontwo@0.98.0... (System call)
      npm ERR! code EBUSYnpm ERR! syscall renamenpm ERR! path C:\ioBroker\node_modules\iobroker.adminnpm ERR! dest C:\ioBroker\node_modules.iobroker.admin-GBn0lhRQnpm ERR! errno -4082npm ERR! EBUSY: resource busy or locked, rename 'C:\ioBroker\node_modules\iobroker.admin' -> 'C:\ioBroker\node_modules.iobroker.admin-GBn0lhRQ'npm ERR! A complete log of this run can be found in: C:\Windows\system32\config\systemprofile\AppData\Local\npm-cache_logs\2023-11-26T10_42_52_881Z-debug-0.log
      host.ioBroker Cannot install iobroker.vis-icontwo@0.98.0: 4294963214
      Führe ich einen npm audit fix --force Befehl in der Console aus erhalte ich folgende Mitteilung:
      C:\ioBroker>npm audit fix --force
      npm WARN using --force Recommended protections disabled.
      npm WARN audit fix semver@5.3.0 node_modules/node-red-node-email/node_modules/semver
      npm WARN audit fix semver@5.3.0 is a bundled dependency of
      npm WARN audit fix semver@5.3.0 node-red-node-email@1.18.4 at node_modules/node-red-node-email
      npm WARN audit fix semver@5.3.0 It cannot be fixed automatically.
      npm WARN audit fix semver@5.3.0 Check for updates to the node-red-node-email package.
      npm WARN audit fix utf7@1.0.2 node_modules/node-red-node-email/node_modules/utf7
      npm WARN audit fix utf7@1.0.2 is a bundled dependency of
      npm WARN audit fix utf7@1.0.2 node-red-node-email@1.18.4 at node_modules/node-red-node-email
      npm WARN audit fix utf7@1.0.2 It cannot be fixed automatically.
      npm WARN audit fix utf7@1.0.2 Check for updates to the node-red-node-email package.
      npm WARN audit fix imap@0.8.19 node_modules/node-red-node-email/node_modules/imap
      npm WARN audit fix imap@0.8.19 is a bundled dependency of
      npm WARN audit fix imap@0.8.19 node-red-node-email@1.18.4 at node_modules/node-red-node-email
      npm WARN audit fix imap@0.8.19 It cannot be fixed automatically.
      npm WARN audit fix imap@0.8.19 Check for updates to the node-red-node-email package.
      npm WARN audit No fix available for iobroker.fronius-solarweb@*
      npm WARN audit Updating iobroker.homeconnect to 0.0.37, which is a SemVer major change.
      npm WARN audit Updating iobroker.ical to 1.13.0, which is a SemVer major change.
      npm WARN audit Updating iobroker.smartgarden to 0.5.0, which is a SemVer major change.
      npm WARN audit No fix available for iobroker.terminal@*
      npm WARN audit Updating iobroker.backitup to 0.2.7, which is a SemVer major change.
      npm WARN audit No fix available for iobroker.javascript@*
      npm WARN audit No fix available for iobroker.vw-connect@*
      npm WARN audit Updating iobroker.homee to 1.0.7, which is a SemVer major change.
      npm WARN audit Updating iobroker.bydbatt to 0.0.1, which is a SemVer major change.
      npm WARN audit Updating iobroker.hue to 0.6.0, which is a SemVer major change.
      npm WARN audit Updating iobroker.discovery to 0.4.0, which is a SemVer major change.
      npm WARN audit Updating iobroker.socketio to 6.5.8, which is a SemVer major change.
      npm WARN audit Updating iobroker.tuya to 2.0.4, which is a SemVer major change.
      npm WARN audit Updating iobroker.node-red to 1.2.0, which is a SemVer major change.
      npm WARN audit Updating iobroker.harmony to 1.1.0, which is a SemVer major change.
      npm WARN audit No fix available for iobroker.meross@*
      npm WARN audit Updating iobroker.js-controller to 1.5.3, which is a SemVer major change.
      npm WARN audit Updating iobroker.web to 5.2.2, which is a SemVer major change.
      npm WARN audit No fix available for iobroker.vis-inventwo@*
      npm WARN audit No fix available for iobroker.daikin-cloud@*
      npm ERR! code EBUSY
      npm ERR! A complete log of this run can be found in: C:\Users\Andreas\AppData\Local\npm-cache_logs\2023-11-26T08_29_38_633Z-debug-0.log
      Habt Ihr eine Idee?
      Gruß Andreas
      Systemdata Windows 11
      Hardwaresystem: NUC
      Arbeitsspeicher: 24GB
      Festplattenart: SSD
      Betriebssystem: Windows
      Nodejs-Version: v18.18.2
      NPM-Version: 9.8.1
      Installationsart: Skript
      Image genutzt: nein
      Jensen 1 Reply Last reply Reply Quote 0
      • Jensen
        Jensen @Denzel 0 last edited by
        @denzel-0
        Wie sah' die Lösung des Problems aus?
          Thomas Braun Most Active @Jensen last edited by
          @jensen
          Jedenfalls NICHT
          Finger weg von npm audit fix, insbesondere in der Kombination mit --force ist das tödlich.
          • Jensen
            Jensen @Thomas Braun last edited by
            Ist ja Windows, nicht so dein Ding, ich weiß, aber wo soll ich anfangen mit suchen?
              @jensen
              Lass es unter Linux laufen.
              Da wäre es vermutlich mit einem
              iob fix
              aus der Welt geschafft.
