    5. JS-Adapter startet ständig neu: heap out of memory
      smhrambo last edited by smhrambo
      Hi, ich habe seit kurzem ein Problem mit meiner ioBroker Instanz.
      Mir ist aufgefallen, dass sich mein Log mit Fehlermeldungen füllt und der JS-Adapter immer neustartet.
      Ich habe auch schon meine Skripte deaktiviert, ohne Erfolg.
      Host: Raspberry Pi 4 (4GB)
      JS-Controller version: 5.0.16 (docker (official image - v9.0.1))
      Node version: v18.18.2
      Operating system: raspberrypi os bookworm arm64 6.1.21-v8+ (Docker version 24.0.7, build afdd53b)
      Log:
      host.iobroker
      	2023-11-27 00:40:15.140	warn	instance system.adapter.javascript.0 terminated due to SIGABRT
      host.iobroker
      	2023-11-27 00:40:15.139	error	Caught by controller[10]: 16: 0x167960c [io.javascript.0]
      host.iobroker
      	2023-11-27 00:40:15.139	error	Caught by controller[9]: 15: 0xdc93f8 v8::internal::Builtin_JsonParse(int, unsigned long*, v8::internal::Isolate*) [io.javascript.0]
      host.iobroker
      	2023-11-27 00:40:15.139	error	Caught by controller[8]: 14: 0x101c2c8 v8::internal::JsonParser<unsigned short>::ParseJson() [io.javascript.0]
      host.iobroker
      	2023-11-27 00:40:15.139	error	Caught by controller[7]: 13: 0x101b648 v8::internal::JsonParser<unsigned short>::ParseJsonValue() [io.javascript.0]
      host.iobroker
      	2023-11-27 00:40:15.139	error	Caught by controller[6]: 12: 0x101a0e8 v8::internal::JsonParser<unsigned short>::MakeString(v8::internal::JsonString const&, v8::internal::Handle<v8::internal::String>) [io.javascript.0]
      host.iobroker
      	2023-11-27 00:40:15.138	error	Caught by controller[5]: 11: 0xee6e84 v8::internal::FactoryBase<v8::internal::Factory>::NewRawOneByteString(int, v8::internal::AllocationType) [io.javascript.0]
      host.iobroker
      	2023-11-27 00:40:15.137	error	Caught by controller[4]: 10: 0xee4af4 v8::internal::FactoryBase<v8::internal::Factory>::AllocateRawWithImmortalMap(int, v8::internal::AllocationType, v8::internal::Map, v8::internal::AllocationAlignment) [io.javascript.0]
      host.iobroker
      	2023-11-27 00:40:15.137	error	Caught by controller[3]: 9: 0xeed87c v8::internal::Factory::AllocateRaw(int, v8::internal::AllocationType, v8::internal::AllocationAlignment) [io.javascript.0]
      host.iobroker
      	2023-11-27 00:40:15.136	error	Caught by controller[2]: 8: 0xf0b6c8 v8::internal::HeapAllocator::AllocateRawWithRetryOrFailSlowPath(int, v8::internal::AllocationType, v8::internal::AllocationOrigin, v8::internal::AllocationAlignment) [io.javascript.0]
      host.iobroker
      	2023-11-27 00:40:15.136	error	Caught by controller[1]: 7: 0xf0a6f0 v8::internal::HeapAllocator::AllocateRawWithLightRetrySlowPath(int, v8::internal::AllocationType, v8::internal::AllocationOrigin, v8::internal::AllocationAlignment) [io.javascript.0]
      host.iobroker
      	2023-11-27 00:40:15.136	error	Caught by controller[0]: 6: 0xf2e56c v8::internal::Heap::CollectGarbage(v8::internal::AllocationSpace, v8::internal::GarbageCollectionReason, v8::GCCallbackFlags) [io.javascript.0]
      host.iobroker
      	2023-11-27 00:40:15.136	error	Caught by controller[0]: 5: 0xf1c5d4 [io.javascript.0]
      host.iobroker
      	2023-11-27 00:40:15.135	error	Caught by controller[0]: 4: 0xd3dfe0 v8::internal::V8::FatalProcessOutOfMemory(v8::internal::Isolate*, char const*, bool) [io.javascript.0]
      host.iobroker
      	2023-11-27 00:40:15.135	error	Caught by controller[0]: 3: 0xd3de10 v8::Utils::ReportOOMFailure(v8::internal::Isolate*, char const*, bool) [io.javascript.0]
      host.iobroker
      	2023-11-27 00:40:15.135	error	Caught by controller[0]: 2: 0xa93f08 [io.javascript.0]
      host.iobroker
      	2023-11-27 00:40:15.135	error	Caught by controller[0]: 1: 0xb72e9c node::Abort() [io.javascript.0]
      host.iobroker
      	2023-11-27 00:40:15.135	error	Caught by controller[0]: FATAL ERROR: Reached heap limit Allocation failed - JavaScript heap out of memory
      host.iobroker
      	2023-11-27 00:40:15.135	error	Caught by controller[0]: <--- JS stacktrace --->
      host.iobroker
      	2023-11-27 00:40:15.134	error	Caught by controller[0]: of marking 130 ms) (average mu = 0.732, current mu = 0.751) finalize increment[1633:0x81873d0] 11852 ms: Mark-sweep 60.5 (97.8) -> 60.3 (99.3) MB, 27.5 / 0.0 ms (+ 2.7 ms in 11 steps since start of marking, biggest step 0.5 ms, walltime since start of marking 112 ms) (average mu = 0.903, current mu = 0.959) finalize incremental[1633:0x81873d0] 12487 ms: Mark-sweep 83.1 (106.0) -> 80.9 (119.8) MB, 167.3 / 0.0 ms (average mu = 0.809, current mu = 0.737) allocation failure; scavenge might not succeed
      host.iobroker
      	2023-11-27 00:40:15.133	error	Caught by controller[0]: <--- Last few GCs --->
      Einer meiner Skripte:
      code_on(["followthesun.0.current.altitude"], function (data) {
          var altitude = getState('followthesun.0.current.altitude').val;
          var hour = new Date().getHours();
          var State = 0;
          if (( 6 < hour && hour < 22) && altitude < 0) {
              State = 1;
          setState('hm-rpc.1.NEQ0369977.1.STATE', State);
          setState('hm-rpc.1.NEQ1660368.1.STATE', State);
          setState('hm-rpc.1.NEQ1660368.2.STATE', State);
      W OliverIO Homoran 3 Replies Last reply Reply Quote 0
      • crunchip
        @smhrambo sagte in JS-Adapter startet ständig neu: heap out of memory:
        das reicht nicht, wenn z.b noch irgendwelche Schleifen/Timeouts laufen
          Wildbill @smhrambo last edited by
          @smhrambo Alle Scripte anhalten und einen sauberen reboot machen. Anschließend 50% der Scripte starten und beobachten. Tritt der Fehler dann nicht mehr auf, von den restlichen 50% wieder die Hälfte starten und beobachten. Sobald der Fehler wieder auftritt, hast Du zumindest mal eingegrenzt, in welchem "Block" der Scripte das fehlerhafte liegen muss. So kannst Du es eingrenzen und dann genau das fehlerhafte Script verbessern.
          Ja, ist etwas Aufwand bei mehr als vielleicht 10 Scripten, aber anders bekommst Du nicht heraus, woher der Fehler stammt.
          Du könntest mal noch im JS-Editor oben links nach timeout und interval suchen und die zuerst beenden und beobachten. Das sind FUnktionen, die bei fehlerhafter Anwendung gerne unendliche Schleifen aufbauen und den RAM auffressen.
          Gruss, Jürgen
          • OliverIO
            OliverIO @smhrambo last edited by
            falls du alle skripte schon deaktiviert hast, dann schau mal was kurz vor den fehlermeldungen im log steht.
            evtl ist es ein anderer adapter, der viel speicher zieht. backitup ist da manchmal so ein kandidat, wenn das system eh schon ziemlich voll ist.
            was für ein system hast du den?
            wieviel speicher verbraucht es, wenn iobroker gestartet ist?
            wieviel ist normalerweise davon frei?
            Wieviele Adapter hast du den laufen.
            die meisten Informationen kannst du mit
            iob diag
            ausgeben lassen und hier reinkopieren
            wenn du ein system hast, bei dem schon 80% des RAMs im Normalbetrieb belegt ist,
            dann braucht man nicht mehr viel, das System in Not zu bringen.
              smhrambo @OliverIO last edited by
              So ich hatte ein bisschen was um die Ohren und nun habe ich mich drum gekümmert.
              ioBroker braucht ohne JS 37,8% vom RAM (Host Tab).
              Die Systemausgabe mit free zeigt folgendes an:
                        gesamt    benutzt   frei     gemns.   Puffer/Cache   verfügbar
              Speicher: 3936484   2406760   303056   33208    1352960        1529724
              Vorgehen:
              Skripte deaktiviert, JS deaktiviert, ioBroker neugestartet, JS aktivieren
              Das Problem bleibt.
              JS verbraucht beim Start ca. 125MB. (instances Tab)
              Speicher: 3936484   2543376   261364   32368    1313452        1393108
              Sobald ich JS aktiviere steht der selbe Fehler im Log.
              Kein anderer Adapter gibt irgendwelche Warnungen oder Fehlermeldungen raus.
              Ausgabe von iob diag:
              Skript v.2023-10-10
              *** BASE SYSTEM ***
              cat: /sys/devices/virtual/dmi/id/sys_vendor: No such file or directory
              Hardware Vendor :
              Kernel          : aarch64
              Userland        : arm64
              Docker          : v9.0.1
              Virtualization  : Docker
              Kernel          : aarch64
              Userland        : arm64
              Systemuptime and Load:
               20:59:28 up  4:39,  0 user,  load average: 2.60, 2.10, 2.11
              CPU threads: 4
              *** Time and Time Zones ***
              Fri Dec  1 19:59:28 UTC 2023
              Fri Dec  1 20:59:28 CET 2023
              CET +0100
              Etc/UTC
              *** User and Groups ***
              root
              /root
              root
              *** X-Server-Setup ***
              X-Server:       false
              Desktop:
              Terminal:
              *** MEMORY ***
              Mem:            4.0G        2.5G        441M         31M        1.2G        1.5G
              Swap:           104M         96M        7.9M
              Total:          4.1G        2.6G        449M
                       3844 M total memory
                       2390 M used memory
                       1914 M active memory
                       1122 M inactive memory
                        421 M free memory
                          7 M buffer memory
                       1138 M swap cache
                         99 M total swap
                         92 M used swap
                          7 M free swap
              *** FILESYSTEM ***
              Filesystem     Type     Size  Used Avail Use% Mounted on
              overlay        overlay  367G  134G  219G  38% /
              tmpfs          tmpfs     64M     0   64M   0% /dev
              shm            tmpfs     64M     0   64M   0% /dev/shm
              /dev/root      ext4     367G  134G  219G  38% /opt/iobroker
              tmpfs          tmpfs    1.9G     0  1.9G   0% /proc/asound
              tmpfs          tmpfs    1.9G     0  1.9G   0% /sys/firmware
              dmesg: read kernel buffer failed: Operation not permitted
              TARGET                      SOURCE        FSTYPE OPTIONS
              /usr/share/zoneinfo/Etc/UTC /dev/root[/usr/share/zoneinfo/Europe/Berlin]        ext4   ro,noatime
              /opt/iobroker               /dev/root[/docker/iobroker_stack/app/data]        ext4   rw,noatime
              /etc/resolv.conf            /dev/root[/var/lib/docker/containers/4a3c83a82a316faddcd4399d337ce519dfe8ec3a71983934fa4abc55970e3814/resolv.conf] ext4   rw,noatime
              /etc/hostname               /dev/root[/var/lib/docker/containers/4a3c83a82a316faddcd4399d337ce519dfe8ec3a71983934fa4abc55970e3814/hostname]    ext4   rw,noatime
              /etc/hosts                  /dev/root[/var/lib/docker/containers/4a3c83a82a316faddcd4399d337ce519dfe8ec3a71983934fa4abc55970e3814/hosts]       ext4   rw,noatime
              /var:
              16M     /var/
              13M     /var/lib/dpkg
              13M     /var/lib
              12M     /var/lib/dpkg/info
              1.9M    /var/cache
              /opt/iobroker/backups:
              319M    /opt/iobroker/backups/
              4.0K    /opt/iobroker/backups/redistmp
              /opt/iobroker/iobroker-data:
              377M    /opt/iobroker/iobroker-data/
              283M    /opt/iobroker/iobroker-data/files
              67M     /opt/iobroker/iobroker-data/files/javascript.admin
              55M     /opt/iobroker/iobroker-data/files/material
              53M     /opt/iobroker/iobroker-data/files/material/static
              41M     /opt/iobroker/iobroker-data/files/material/static/js/main.c5478f66.js.map
              22M     /opt/iobroker/iobroker-data/objects.jsonl
              21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js.map
              20M     /opt/iobroker/iobroker-data/states.jsonl
              18M     /opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.274a4d8d.js.map
              USB-Devices by-id:
              *** NodeJS-Installation ***
              /usr/bin/nodejs         v18.18.2
              /usr/bin/node           v18.18.2
              /usr/bin/npm            9.8.1
              /usr/bin/npx            9.8.1
              /usr/bin/corepack       0.19.0
              nodejs:
                Version table:
               *** 18.18.2-1nodesource1 100
                      100 /var/lib/dpkg/status
              No problems detected
              Errors in npm tree:
              *** ioBroker-Installation ***
              ioBroker Status
              Objects type: jsonl
              States  type: jsonl
              Core adapters versions
              js-controller:  5.0.16
              admin:          6.12.0
              javascript:     7.1.6
              Adapters from github:   0
              Adapter State
                system.adapter.adguard.0                : adguard               : iobroker                                 - disabled, compact disabled
              + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, compact disabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
                system.adapter.alarm.0                  : alarm                 : iobroker                                 - disabled, compact disabled
                system.adapter.alexa2.0                 : alexa2                : iobroker                                 - disabled, compact disabled
              + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled, compact disabled
                system.adapter.bidirectional-counter.0  : bidirectional-counter : iobroker                                 - disabled, compact disabled
                system.adapter.device-reminder.0        : device-reminder       : iobroker                                 - disabled, compact disabled
              + system.adapter.device-watcher.0         : device-watcher        : iobroker                                 -  enabled, compact disabled
                system.adapter.discovery.0              : discovery             : iobroker                                 - disabled, compact disabled
              + system.adapter.ems-esp.0                : ems-esp               : iobroker                                 -  enabled, compact disabled
                system.adapter.evcc.0                   : evcc                  : iobroker                                 - disabled, compact disabled, port: 7070
              + system.adapter.followthesun.0           : followthesun          : iobroker                                 -  enabled, compact disabled
                system.adapter.habpanel.0               : habpanel              : iobroker                                 -  enabled
              + system.adapter.history.0                : history               : iobroker                                 -  enabled, compact disabled
              + system.adapter.hm-rega.0                : hm-rega               : iobroker                                 -  enabled, compact disabled
              + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker                                 -  enabled, compact disabled, port: 0
                system.adapter.hue.0                    : hue                   : iobroker                                 - disabled, compact disabled, port: 443
                system.adapter.influxdb.0               : influxdb              : iobroker                                 - disabled, compact disabled, port: 8086
              + system.adapter.influxdb.1               : influxdb              : iobroker                                 -  enabled, compact disabled, port: 8086
                system.adapter.iqontrol.0               : iqontrol              : iobroker                                 - disabled, compact disabled
                system.adapter.jarvis.0                 : jarvis                : iobroker                                 - disabled, compact disabled
                system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled, compact disabled
                system.adapter.material.0               : material              : iobroker                                 -  enabled
              + system.adapter.modbus.0                 : modbus                : iobroker                                 -  enabled, compact disabled
              + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, compact disabled, port: 1883, bind: 0.0.0.0
                system.adapter.sayit.0                  : sayit                 : iobroker                                 - disabled, compact disabled, port: 0
              + system.adapter.shuttercontrol.0         : shuttercontrol        : iobroker                                 -  enabled, compact disabled
              + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, compact disabled, port: 8443, bind: 0.0.0.0
              + system.adapter.text2command.0           : text2command          : iobroker                                 -  enabled, compact disabled
              + system.adapter.weatherunderground.0     : weatherunderground    : iobroker                                 -  enabled, compact disabled
                system.adapter.weatherunderground.1     : weatherunderground    : iobroker                                 -  enabled, compact disabled
              + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, compact enabled (group 1), port: 8082, bind: 0.0.0.0 (SSL), run as: admin
                system.adapter.zigbee.0                 : zigbee                : iobroker                                 - disabled, compact disabled, port: /dev/ttyAMA0
              + system.adapter.zigbee2mqtt.0            : zigbee2mqtt           : iobroker                                 -  enabled, compact disabled
                system.adapter.zwave2.0                 : zwave2                : iobroker                                 - disabled, compact disabled
              + instance is alive
              ioBroker-Repositories
              Active repo(s): stable
              Installed ioBroker-Instances
              Used repository: stable
              Adapter    "adguard"      : 0.0.8    , installed 0.0.8
              Adapter    "alarm"        : 3.4.3    , installed 3.4.3
              Adapter    "alexa2"       : 3.26.3   , installed 3.26.3
              Adapter    "backitup"     : 2.8.7    , installed 2.8.7
              Adapter    "bidirectional-counter": 2.1.3, installed 2.1.3
              Adapter    "device-reminder": 3.0.0  , installed 3.0.0
              Adapter    "device-watcher": 2.9.6   , installed 2.9.6
              Adapter    "ems-esp"      : 2.6.1    , installed 2.6.1
              Adapter    "evcc"         : 0.0.10   , installed 0.0.10
              Adapter    "followthesun" : 0.4.2    , installed 0.4.2
              Adapter    "habpanel"     : 0.5.0    , installed 0.5.0
              Adapter    "hue"          : 3.10.1   , installed 3.10.1
              Adapter    "influxdb"     : 3.2.0    , installed 3.2.0
              Adapter    "iqontrol"     : 2.3.0    , installed 2.3.0
              Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
              Adapter    "javascript"   : 7.1.6    , installed 7.1.6
              Controller "js-controller": 5.0.16   , installed 5.0.16
              Adapter    "material"     : 1.3.1    , installed 1.3.1
              Adapter    "modbus"       : 5.0.11   , installed 5.0.11
              Adapter    "mqtt"         : 5.1.0    , installed 5.1.0
              Adapter    "sayit"        : 3.0.5    , installed 3.0.5
              Adapter    "shuttercontrol": 1.6.3   , installed 1.6.3
              Adapter    "telegram"     : 2.0.1    , installed 2.0.1
              Adapter    "text2command" : 3.0.2    , installed 3.0.2
              Adapter    "weatherunderground": 3.6.0, installed 3.6.0
              Adapter    "web"          : 6.1.10   , installed 6.1.10
              Adapter    "ws"           : 2.5.8    , installed 2.5.8
              Adapter    "zigbee"       : 1.8.24   , installed 1.8.24
              Adapter    "zigbee2mqtt"  : 2.13.3   , installed 2.13.3
              Adapter    "zwave2"       : 3.1.0    , installed 3.1.0
              Objects and States
              Objects:        11689
              States:         11035
              Hit:2 http://deb.debian.org/debian bookworm-updates InRelease
              Reading package lists...
              Pending Updates: 4
              *** Listening Ports ***
              tcp        0      0 172.18.2.2:2001         0.0.0.0:*               LISTEN      1010       213371     -
              tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1010       187168     -
              tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1010       186319     -
              tcp        0      0 127.0.0.11:36745        0.0.0.0:*               LISTEN      0          180394     -
              tcp6       0      0 :::8081                 :::*                    LISTEN      1010       188396     -
              tcp6       0      0 :::8082                 :::*                    LISTEN      1010       223772     -
              udp        0      0 127.0.0.11:47351        0.0.0.0:*                           0          180393     -
              2023-12-01 21:00:50.778  - error: host.iobroker Caught by controller[0]:  3: 0xd3de10 v8::Utils::ReportOOMFailure(v8::internal::Isolate*, char const*, bool) [io.javascript.0]
              2023-12-01 21:00:50.778  - error: host.iobroker Caught by controller[0]:  4: 0xd3dfe0 v8::internal::V8::FatalProcessOutOfMemory(v8::internal::Isolate*, char const*, bool) [io.javascript.0]
              2023-12-01 21:00:50.778  - error: host.iobroker Caught by controller[0]:  5: 0xf1c5d4  [io.javascript.0]
              2023-12-01 21:00:50.778  - error: host.iobroker Caught by controller[0]:  6: 0xf2e56c v8::internal::Heap::CollectGarbage(v8::internal::AllocationSpace, v8::internal::GarbageCollectionReason, v8::GCCallbackFlags) [io.javascript.0]
              2023-12-01 21:00:50.779  - error: host.iobroker Caught by controller[1]:  7: 0xf0a6f0 v8::internal::HeapAllocator::AllocateRawWithLightRetrySlowPath(int, v8::internal::AllocationType, v8::internal::AllocationOrigin, v8::internal::AllocationAlignment) [io.javascript.0]
              2023-12-01 21:00:50.779  - error: host.iobroker Caught by controller[2]:  8: 0xf0b6c8 v8::internal::HeapAllocator::AllocateRawWithRetryOrFailSlowPath(int, v8::internal::AllocationType, v8::internal::AllocationOrigin, v8::internal::AllocationAlignment) [io.javascript.0]
              2023-12-01 21:00:50.779  - error: host.iobroker Caught by controller[2]:  9: 0xeed87c v8::internal::Factory::AllocateRaw(int, v8::internal::AllocationType, v8::internal::AllocationAlignment) [io.javascript.0]
              2023-12-01 21:00:50.779  - error: host.iobroker Caught by controller[2]: 10: 0xee4af4 v8::internal::FactoryBase<v8::internal::Factory>::AllocateRawWithImmortalMap(int, v8::internal::AllocationType, v8::internal::Map, v8::internal::AllocationAlignment) [io.javascript.0]
              2023-12-01 21:00:50.779  - error: host.iobroker Caught by controller[3]: 11: 0xee71e0 v8::internal::FactoryBase<v8::internal::Factory>::NewDescriptorArray(int, int, v8::internal::AllocationType) [io.javascript.0]
              2023-12-01 21:00:50.779  - error: host.iobroker Caught by controller[4]: 12: 0x116b6e8 v8::internal::DescriptorArray::CopyUpTo(v8::internal::Isolate*, v8::internal::Handle<v8::internal::DescriptorArray>, int, int) [io.javascript.0]
              2023-12-01 21:00:50.779  - error: host.iobroker Caught by controller[5]: 13: 0x11534e0 v8::internal::Map::EnsureDescriptorSlack(v8::internal::Isolate*, v8::internal::Handle<v8::internal::Map>, int) [io.javascript.0]
              2023-12-01 21:00:50.780  - error: host.iobroker Caught by controller[6]: 14: 0x1156a4c v8::internal::Map::ShareDescriptor(v8::internal::Isolate*, v8::internal::Handle<v8::internal::Map>, v8::internal::Handle<v8::internal::DescriptorArray>, v8::internal::Descriptor*) [io.javascript.0]
              2023-12-01 21:00:50.780  - error: host.iobroker Caught by controller[7]: 15: 0x11570a4 v8::internal::Map::CopyWithField(v8::internal::Isolate*, v8::internal::Handle<v8::internal::Map>, v8::internal::Handle<v8::internal::Name>, v8::internal::Handle<v8::internal::FieldType>, v8::internal::PropertyAttributes, v8::internal::PropertyConstness, v8::internal::Representation, v8::internal::TransitionFlag) [io.javascript.0]
              2023-12-01 21:00:50.780  - error: host.iobroker Caught by controller[8]: 16: 0x1158e2c v8::internal::Map::TransitionToDataProperty(v8::internal::Isolate*, v8::internal::Handle<v8::internal::Map>, v8::internal::Handle<v8::internal::Name>, v8::internal::Handle<v8::internal::Object>, v8::internal::PropertyAttributes, v8::internal::PropertyConstness, v8::internal::StoreOrigin) [io.javascript.0]
              2023-12-01 21:00:50.780  - error: host.iobroker Caught by controller[9]: 17: 0x1146b38 v8::internal::LookupIterator::PrepareTransitionToDataProperty(v8::internal::Handle<v8::internal::JSReceiver>, v8::internal::Handle<v8::internal::Object>, v8::internal::PropertyAttributes, v8::internal::StoreOrigin) [io.javascript.0]
              2023-12-01 21:00:50.780  - error: host.iobroker Caught by controller[10]: 18: 0x1165080 v8::internal::Object::TransitionAndWriteDataProperty(v8::internal::LookupIterator*, v8::internal::Handle<v8::internal::Object>, v8::internal::PropertyAttributes, v8::Maybe<v8::internal::ShouldThrow>, v8::internal::StoreOrigin) [io.javascript.0]
              2023-12-01 21:00:50.780  - error: host.iobroker Caught by controller[11]: 19: 0x117ffa8 v8::internal::Object::AddDataProperty(v8::internal::LookupIterator*, v8::internal::Handle<v8::internal::Object>, v8::internal::PropertyAttributes, v8::Maybe<v8::internal::ShouldThrow>, v8::internal::StoreOrigin, v8::internal::EnforceDefineSemantics) [io.javascript.0]
              2023-12-01 21:00:50.780  - error: host.iobroker Caught by controller[12]: 20: 0x1112adc v8::internal::JSObject::DefineOwnPropertyIgnoreAttributes(v8::internal::LookupIterator*, v8::internal::Handle<v8::internal::Object>, v8::internal::PropertyAttributes, v8::Maybe<v8::internal::ShouldThrow>, v8::internal::JSObject::AccessorInfoHandling, v8::internal::EnforceDefineSemantics, v8::internal::StoreOrigin) [io.javascript.0]
              2023-12-01 21:00:50.780  - error: host.iobroker Caught by controller[13]: 21: 0x1112b3c v8::internal::JSObject::DefineOwnPropertyIgnoreAttributes(v8::internal::LookupIterator*, v8::internal::Handle<v8::internal::Object>, v8::internal::PropertyAttributes, v8::internal::JSObject::AccessorInfoHandling, v8::internal::EnforceDefineSemantics) [io.javascript.0]
              2023-12-01 21:00:50.781  - error: host.iobroker Caught by controller[14]: 22: 0x101af84 v8::internal::JsonParser<unsigned short>::BuildJsonObject(v8::internal::JsonParser<unsigned short>::JsonContinuation const&, v8::base::SmallVector<v8::internal::JsonProperty, 16ul, std::allocator<v8::internal::JsonProperty> > const&, v8::internal::Handle<v8::internal::Map>) [io.javascript.0]
              2023-12-01 21:00:50.781  - error: host.iobroker Caught by controller[14]: 23: 0x101bd88 v8::internal::JsonParser<unsigned short>::ParseJsonValue() [io.javascript.0]
              2023-12-01 21:00:50.781  - error: host.iobroker Caught by controller[15]: 24: 0x101c2c8 v8::internal::JsonParser<unsigned short>::ParseJson() [io.javascript.0]
              2023-12-01 21:00:50.781  - error: host.iobroker Caught by controller[16]: 25: 0xdc93f8 v8::internal::Builtin_JsonParse(int, unsigned long*, v8::internal::Isolate*) [io.javascript.0]
              2023-12-01 21:00:50.781  - error: host.iobroker Caught by controller[17]: 26: 0x167960c  [io.javascript.0]
              2023-12-01 21:00:50.781  - warn: host.iobroker instance system.adapter.javascript.0 terminated due to SIGABRT
                                      v.2023-10-10
              Model           : Raspberry Pi 4 Model B Rev 1.2
              Kernel          : aarch64
              Userland        : arm64
              Docker          : v9.0.1
              Installation:           Docker
              Userland:               arm64
              Timezone:               Etc/UTC
              User-ID:                0
              X-Server:               false
              Pending OS-Updates:     4
              Pending iob updates:    0
              Nodejs-Installation:    /usr/bin/nodejs         v18.18.2
                                      /usr/bin/npm            9.8.1
                                      /usr/bin/npx            9.8.1
              MEMORY:
              Mem:            4.0G        2.6G        351M         31M        1.3G        1.4G
              Swap:           104M        102M        2.5M
              Total:          4.1G        2.7G        353M
              Active iob-Instances:   17
              ioBroker Core:          js-controller           5.0.16
              Objects type: jsonl
              States  type: jsonl
              Objects:                11689
              States:                 11035
              Size of iob-Database:
              23M     /opt/iobroker/iobroker-data/objects.jsonl
              21M     /opt/iobroker/iobroker-data/states.jsonl
                paul53 @smhrambo last edited by
                @smhrambo sagte: JS aktivieren
                Das Problem bleibt.
                Obwohl kein Skript aktiviert ist?
                  smhrambo @paul53 last edited by
                  @paul53 Ja genau.
                  Ich habe in JS jeden Skript deaktiviert(Überall ist das rote Play-Zeichen).
                  Dann habe ich JS deaktiviert.
                  Dann habe ich noch Backitup deaktiviert.
                  Dann ioBroker neu gestartet.
                  Und JS wieder aktiviert.
                  Problem bleibt und Log füllt sich mit der folgender Fehlermeldung:
                  host.iobroker
                  	2023-12-01 22:10:43.156	warn	instance system.adapter.javascript.0 terminated due to SIGABRT
                  host.iobroker
                  	2023-12-01 22:10:43.156	error	Caught by controller[23]: 26: 0x167960c [io.javascript.0]
                  host.iobroker
                  	2023-12-01 22:10:43.155	error	Caught by controller[22]: 25: 0xdc93f8 v8::internal::Builtin_JsonParse(int, unsigned long*, v8::internal::Isolate*) [io.javascript.0]
                  host.iobroker
                  	2023-12-01 22:10:43.155	error	Caught by controller[21]: 24: 0x101c2c8 v8::internal::JsonParser<unsigned short>::ParseJson() [io.javascript.0]
                  host.iobroker
                  	2023-12-01 22:10:43.155	error	Caught by controller[20]: 23: 0x101bd88 v8::internal::JsonParser<unsigned short>::ParseJsonValue() [io.javascript.0]
                  host.iobroker
                  	2023-12-01 22:10:43.155	error	Caught by controller[19]: 22: 0x101af84 v8::internal::JsonParser<unsigned short>::BuildJsonObject(v8::internal::JsonParser<unsigned short>::JsonContinuation const&, v8::base::SmallVector<v8::internal::JsonProperty, 16ul, std::allocator<v8::internal::JsonProperty> > const&, v8::internal::Handle<v8::internal::Map>) [io.javascript.0]
                  host.iobroker
                  	2023-12-01 22:10:43.155	error	Caught by controller[18]: 21: 0x1112b3c v8::internal::JSObject::DefineOwnPropertyIgnoreAttributes(v8::internal::LookupIterator*, v8::internal::Handle<v8::internal::Object>, v8::internal::PropertyAttributes, v8::internal::JSObject::AccessorInfoHandling, v8::internal::EnforceDefineSemantics) [io.javascript.0]
                  host.iobroker
                  	2023-12-01 22:10:43.155	error	Caught by controller[17]: 20: 0x1112adc v8::internal::JSObject::DefineOwnPropertyIgnoreAttributes(v8::internal::LookupIterator*, v8::internal::Handle<v8::internal::Object>, v8::internal::PropertyAttributes, v8::Maybe<v8::internal::ShouldThrow>, v8::internal::JSObject::AccessorInfoHandling, v8::internal::EnforceDefineSemantics, v8::internal::StoreOrigin) [io.javascript.0]
                  host.iobroker
                  	2023-12-01 22:10:43.155	error	Caught by controller[16]: 19: 0x117ffa8 v8::internal::Object::AddDataProperty(v8::internal::LookupIterator*, v8::internal::Handle<v8::internal::Object>, v8::internal::PropertyAttributes, v8::Maybe<v8::internal::ShouldThrow>, v8::internal::StoreOrigin, v8::internal::EnforceDefineSemantics) [io.javascript.0]
                  host.iobroker
                  	2023-12-01 22:10:43.155	error	Caught by controller[15]: 18: 0x1165080 v8::internal::Object::TransitionAndWriteDataProperty(v8::internal::LookupIterator*, v8::internal::Handle<v8::internal::Object>, v8::internal::PropertyAttributes, v8::Maybe<v8::internal::ShouldThrow>, v8::internal::StoreOrigin) [io.javascript.0]
                  host.iobroker
                  	2023-12-01 22:10:43.154	error	Caught by controller[14]: 17: 0x1146b38 v8::internal::LookupIterator::PrepareTransitionToDataProperty(v8::internal::Handle<v8::internal::JSReceiver>, v8::internal::Handle<v8::internal::Object>, v8::internal::PropertyAttributes, v8::internal::StoreOrigin) [io.javascript.0]
                  host.iobroker
                  	2023-12-01 22:10:43.154	error	Caught by controller[13]: 16: 0x1158e2c v8::internal::Map::TransitionToDataProperty(v8::internal::Isolate*, v8::internal::Handle<v8::internal::Map>, v8::internal::Handle<v8::internal::Name>, v8::internal::Handle<v8::internal::Object>, v8::internal::PropertyAttributes, v8::internal::PropertyConstness, v8::internal::StoreOrigin) [io.javascript.0]
                  host.iobroker
                  	2023-12-01 22:10:43.154	error	Caught by controller[12]: 15: 0x11570a4 v8::internal::Map::CopyWithField(v8::internal::Isolate*, v8::internal::Handle<v8::internal::Map>, v8::internal::Handle<v8::internal::Name>, v8::internal::Handle<v8::internal::FieldType>, v8::internal::PropertyAttributes, v8::internal::PropertyConstness, v8::internal::Representation, v8::internal::TransitionFlag) [io.javascript.0]
                  host.iobroker
                  	2023-12-01 22:10:43.154	error	Caught by controller[11]: 14: 0x1156a4c v8::internal::Map::ShareDescriptor(v8::internal::Isolate*, v8::internal::Handle<v8::internal::Map>, v8::internal::Handle<v8::internal::DescriptorArray>, v8::internal::Descriptor*) [io.javascript.0]
                  host.iobroker
                  	2023-12-01 22:10:43.154	error	Caught by controller[10]: 13: 0x11534e0 v8::internal::Map::EnsureDescriptorSlack(v8::internal::Isolate*, v8::internal::Handle<v8::internal::Map>, int) [io.javascript.0]
                  host.iobroker
                  	2023-12-01 22:10:43.154	error	Caught by controller[9]: 12: 0x116b6e8 v8::internal::DescriptorArray::CopyUpTo(v8::internal::Isolate*, v8::internal::Handle<v8::internal::DescriptorArray>, int, int) [io.javascript.0]
                  host.iobroker
                  	2023-12-01 22:10:43.154	error	Caught by controller[8]: 11: 0xee71e0 v8::internal::FactoryBase<v8::internal::Factory>::NewDescriptorArray(int, int, v8::internal::AllocationType) [io.javascript.0]
                  host.iobroker
                  	2023-12-01 22:10:43.154	error	Caught by controller[7]: 10: 0xee4af4 v8::internal::FactoryBase<v8::internal::Factory>::AllocateRawWithImmortalMap(int, v8::internal::AllocationType, v8::internal::Map, v8::internal::AllocationAlignment) [io.javascript.0]
                  host.iobroker
                  	2023-12-01 22:10:43.153	error	Caught by controller[6]: 9: 0xeed87c v8::internal::Factory::AllocateRaw(int, v8::internal::AllocationType, v8::internal::AllocationAlignment) [io.javascript.0]
                  host.iobroker
                  	2023-12-01 22:10:43.153	error	Caught by controller[5]: 8: 0xf0b6c8 v8::internal::HeapAllocator::AllocateRawWithRetryOrFailSlowPath(int, v8::internal::AllocationType, v8::internal::AllocationOrigin, v8::internal::AllocationAlignment) [io.javascript.0]
                  host.iobroker
                  	2023-12-01 22:10:43.153	error	Caught by controller[4]: 7: 0xf0a6f0 v8::internal::HeapAllocator::AllocateRawWithLightRetrySlowPath(int, v8::internal::AllocationType, v8::internal::AllocationOrigin, v8::internal::AllocationAlignment) [io.javascript.0]
                  host.iobroker
                  	2023-12-01 22:10:43.153	error	Caught by controller[3]: 6: 0xf2e56c v8::internal::Heap::CollectGarbage(v8::internal::AllocationSpace, v8::internal::GarbageCollectionReason, v8::GCCallbackFlags) [io.javascript.0]
                  host.iobroker
                  	2023-12-01 22:10:43.153	error	Caught by controller[3]: 5: 0xf1c5d4 [io.javascript.0]
                  host.iobroker
                  	2023-12-01 22:10:43.153	error	Caught by controller[3]: 4: 0xd3dfe0 v8::internal::V8::FatalProcessOutOfMemory(v8::internal::Isolate*, char const*, bool) [io.javascript.0]
                  host.iobroker
                  	2023-12-01 22:10:43.153	error	Caught by controller[3]: 3: 0xd3de10 v8::Utils::ReportOOMFailure(v8::internal::Isolate*, char const*, bool) [io.javascript.0]
                  host.iobroker
                  	2023-12-01 22:10:43.153	error	Caught by controller[3]: 2: 0xa93f08 [io.javascript.0]
                  host.iobroker
                  	2023-12-01 22:10:43.152	error	Caught by controller[2]: 1: 0xb72e9c node::Abort() [io.javascript.0]
                  host.iobroker
                  	2023-12-01 22:10:43.152	error	Caught by controller[1]: FATAL ERROR: Reached heap limit Allocation failed - JavaScript heap out of memory
                  host.iobroker
                  	2023-12-01 22:10:43.152	error	Caught by controller[0]: <--- JS stacktrace --->
                  host.iobroker
                  	2023-12-01 22:10:43.152	error	Caught by controller[0]: of marking 95 ms) (average mu = 0.822, current mu = 0.892) finalize incremental [925:0xf6423d0] 11189 ms: Mark-sweep 61.1 (99.5) -> 59.2 (96.3) MB, 22.5 / 0.0 ms (+ 1.9 ms in 10 steps since start of marking, biggest step 0.4 ms, walltime since start of marking 129 ms) (average mu = 0.924, current mu = 0.967) finalize incremental [925:0xf6423d0] 11585 ms: Mark-sweep 82.2 (103.0) -> 79.8 (118.3) MB, 107.2 / 0.0 ms (average mu = 0.841, current mu = 0.730) allocation failure; scavenge might not succeed
                  host.iobroker
                  	2023-12-01 22:10:43.151	error	Caught by controller[0]: <--- Last few GCs --->
                  host.iobroker
                  	2023-12-01 22:09:56.365	warn	instance system.adapter.javascript.0 terminated due to SIGABRT
                  host.iobroker
                  	2023-12-01 22:09:56.365	error	Caught by controller[12]: 16: 0x167960c [io.javascript.0]
                  host.iobroker
                  	2023-12-01 22:09:56.364	error	Caught by controller[11]: 15: 0xdc93f8 v8::internal::Builtin_JsonParse(int, unsigned long*, v8::internal::Isolate*) [io.javascript.0]
                  host.iobroker
                  	2023-12-01 22:09:56.364	error	Caught by controller[10]: 14: 0x101c2c8 v8::internal::JsonParser<unsigned short>::ParseJson() [io.javascript.0]
                  host.iobroker
                  	2023-12-01 22:09:56.364	error	Caught by controller[9]: 13: 0x101b648 v8::internal::JsonParser<unsigned short>::ParseJsonValue() [io.javascript.0]
                  host.iobroker
                  	2023-12-01 22:09:56.364	error	Caught by controller[8]: 12: 0x101a0e8 v8::internal::JsonParser<unsigned short>::MakeString(v8::internal::JsonString const&, v8::internal::Handle<v8::internal::String>) [io.javascript.0]
                  host.iobroker
                  	2023-12-01 22:09:56.364	error	Caught by controller[7]: 11: 0xee6e84 v8::internal::FactoryBase<v8::internal::Factory>::NewRawOneByteString(int, v8::internal::AllocationType) [io.javascript.0]
                  host.iobroker
                  	2023-12-01 22:09:56.364	error	Caught by controller[6]: 10: 0xee4af4 v8::internal::FactoryBase<v8::internal::Factory>::AllocateRawWithImmortalMap(int, v8::internal::AllocationType, v8::internal::Map, v8::internal::AllocationAlignment) [io.javascript.0]
                  host.iobroker
                  	2023-12-01 22:09:56.364	error	Caught by controller[5]: 9: 0xeed87c v8::internal::Factory::AllocateRaw(int, v8::internal::AllocationType, v8::internal::AllocationAlignment) [io.javascript.0]
                  host.iobroker
                  	2023-12-01 22:09:56.364	error	Caught by controller[4]: 8: 0xf0b6c8 v8::internal::HeapAllocator::AllocateRawWithRetryOrFailSlowPath(int, v8::internal::AllocationType, v8::internal::AllocationOrigin, v8::internal::AllocationAlignment) [io.javascript.0]
                  host.iobroker
                  	2023-12-01 22:09:56.363	error	Caught by controller[3]: 7: 0xf0a6f0 v8::internal::HeapAllocator::AllocateRawWithLightRetrySlowPath(int, v8::internal::AllocationType, v8::internal::AllocationOrigin, v8::internal::AllocationAlignment) [io.javascript.0]
                  host.iobroker
                  	2023-12-01 22:09:56.363	error	Caught by controller[2]: 6: 0xf2e56c v8::internal::Heap::CollectGarbage(v8::internal::AllocationSpace, v8::internal::GarbageCollectionReason, v8::GCCallbackFlags) [io.javascript.0]
                  host.iobroker
                  	2023-12-01 22:09:56.363	error	Caught by controller[1]: 5: 0xf1c5d4 [io.javascript.0]
                  host.iobroker
                  	2023-12-01 22:09:56.363	error	Caught by controller[0]: 4: 0xd3dfe0 v8::internal::V8::FatalProcessOutOfMemory(v8::internal::Isolate*, char const*, bool) [io.javascript.0]
                  host.iobroker
                  	2023-12-01 22:09:56.363	error	Caught by controller[0]: 3: 0xd3de10 v8::Utils::ReportOOMFailure(v8::internal::Isolate*, char const*, bool) [io.javascript.0]
                  host.iobroker
                  	2023-12-01 22:09:56.363	error	Caught by controller[0]: 2: 0xa93f08 [io.javascript.0]
                  host.iobroker
                  	2023-12-01 22:09:56.363	error	Caught by controller[0]: 1: 0xb72e9c node::Abort() [io.javascript.0]
                  host.iobroker
                  	2023-12-01 22:09:56.363	error	Caught by controller[0]: FATAL ERROR: Reached heap limit Allocation failed - JavaScript heap out of memory
                  host.iobroker
                  	2023-12-01 22:09:56.362	error	Caught by controller[0]: <--- JS stacktrace --->
                  host.iobroker
                  	2023-12-01 22:09:56.362	error	Caught by controller[0]: of marking 97 ms) (average mu = 0.849, current mu = 0.918) finalize incrementa[860:0x2f7203d0] 11393 ms: Mark-sweep 61.5 (97.6) -> 61.3 (99.6) MB, 36.2 / 0.0 ms (+ 23.0 ms in 36 steps since start of marking, biggest step 5.9 ms, walltime since start of marking 99 ms) (average mu = 0.814, current mu = 0.769) finalize incremental[860:0x2f7203d0] 11859 ms: Mark-sweep 84.7 (106.5) -> 81.8 (120.0) MB, 130.8 / 0.0 ms (average mu = 0.756, current mu = 0.719) allocation failure; scavenge might not succeed
                  host.iobroker
                  	2023-12-01 22:09:56.361	error	Caught by controller[0]: <--- Last few GCs --->
                  host.iobroker
                  	2023-12-01 22:09:10.024	warn	instance system.adapter.javascript.0 terminated due to SIGABRT
                  host.iobroker
                  	2023-12-01 22:09:10.024	error	Caught by controller[5]: 16: 0x167960c [io.javascript.0]
                  host.iobroker
                  	2023-12-01 22:09:10.024	error	Caught by controller[4]: 15: 0xdc93f8 v8::internal::Builtin_JsonParse(int, unsigned long*, v8::internal::Isolate*) [io.javascript.0]
                  host.iobroker
                  	2023-12-01 22:09:10.024	error	Caught by controller[3]: 14: 0x101c2c8 v8::internal::JsonParser<unsigned short>::ParseJson() [io.javascript.0]
                  host.iobroker
                  	2023-12-01 22:09:10.024	error	Caught by controller[3]: 13: 0x101b648 v8::internal::JsonParser<unsigned short>::ParseJsonValue() [io.javascript.0]
                  host.iobroker
                  	2023-12-01 22:09:10.024	error	Caught by controller[3]: 12: 0x101a0e8 v8::internal::JsonParser<unsigned short>::MakeString(v8::internal::JsonString const&, v8::internal::Handle<v8::internal::String>) [io.javascript.0]
                  host.iobroker
                  	2023-12-01 22:09:10.023	error	Caught by controller[3]: 11: 0xee6e84 v8::internal::FactoryBase<v8::internal::Factory>::NewRawOneByteString(int, v8::internal::AllocationType) [io.javascript.0]
                  host.iobroker
                  	2023-12-01 22:09:10.023	error	Caught by controller[3]: 10: 0xee4af4 v8::internal::FactoryBase<v8::internal::Factory>::AllocateRawWithImmortalMap(int, v8::internal::AllocationType, v8::internal::Map, v8::internal::AllocationAlignment) [io.javascript.0]
                  host.iobroker
                  	2023-12-01 22:09:10.023	error	Caught by controller[2]: 9: 0xeed87c v8::internal::Factory::AllocateRaw(int, v8::internal::AllocationType, v8::internal::AllocationAlignment) [io.javascript.0]
                  host.iobroker
                  	2023-12-01 22:09:10.023	error	Caught by controller[2]: 8: 0xf0b6c8 v8::internal::HeapAllocator::AllocateRawWithRetryOrFailSlowPath(int, v8::internal::AllocationType, v8::internal::AllocationOrigin, v8::internal::AllocationAlignment) [io.javascript.0]
                  host.iobroker
                  	2023-12-01 22:09:10.022	error	Caught by controller[1]: 7: 0xf0a6f0 v8::internal::HeapAllocator::AllocateRawWithLightRetrySlowPath(int, v8::internal::AllocationType, v8::internal::AllocationOrigin, v8::internal::AllocationAlignment) [io.javascript.0]
                  host.iobroker
                  	2023-12-01 22:09:10.022	error	Caught by controller[0]: 6: 0xf2e56c v8::internal::Heap::CollectGarbage(v8::internal::AllocationSpace, v8::internal::GarbageCollectionReason, v8::GCCallbackFlags) [io.javascript.0]
                  host.iobroker
                  	2023-12-01 22:09:10.022	error	Caught by controller[0]: 5: 0xf1c5d4 [io.javascript.0]
                  host.iobroker
                  	2023-12-01 22:09:10.022	error	Caught by controller[0]: 4: 0xd3dfe0 v8::internal::V8::FatalProcessOutOfMemory(v8::internal::Isolate*, char const*, bool) [io.javascript.0]
                  host.iobroker
                  	2023-12-01 22:09:10.021	error	Caught by controller[0]: 3: 0xd3de10 v8::Utils::ReportOOMFailure(v8::internal::Isolate*, char const*, bool) [io.javascript.0]
                  host.iobroker
                  	2023-12-01 22:09:10.021	error	Caught by controller[0]: 2: 0xa93f08 [io.javascript.0]
                  host.iobroker
                  	2023-12-01 22:09:10.021	error	Caught by controller[0]: 1: 0xb72e9c node::Abort() [io.javascript.0]
                  host.iobroker
                  	2023-12-01 22:09:10.021	error	Caught by controller[0]: FATAL ERROR: Reached heap limit Allocation failed - JavaScript heap out of memory
                  host.iobroker
                  	2023-12-01 22:09:10.020	error	Caught by controller[0]: <--- JS stacktrace --->
                  host.iobroker
                  	2023-12-01 22:09:10.020	error	Caught by controller[0]: of marking 94 ms) (average mu = 0.744, current mu = 0.452) finalize incrementa[809:0x2387f3d0] 10322 ms: Mark-sweep 59.3 (94.6) -> 59.2 (95.8) MB, 22.6 / 0.0 ms (+ 2.0 ms in 10 steps since start of marking, biggest step 0.4 ms, walltime since start of marking 136 ms) (average mu = 0.893, current mu = 0.953) finalize incremental[809:0x2387f3d0] 10693 ms: Mark-sweep 82.2 (102.5) -> 79.8 (118.0) MB, 103.0 / 0.0 ms (average mu = 0.807, current mu = 0.722) allocation failure; scavenge might not succeed
                  host.iobroker
                  	2023-12-01 22:09:10.019	error	Caught by controller[0]: <--- Last few GCs --->
                  host.iobroker
                  	2023-12-01 22:08:24.219	warn	instance system.adapter.javascript.0 terminated due to SIGABRT
                  host.iobroker
                  	2023-12-01 22:08:24.219	error	Caught by controller[22]: 26: 0x167960c [io.javascript.0]
                  host.iobroker
                  	2023-12-01 22:08:24.218	error	Caught by controller[21]: 25: 0xdc93f8 v8::internal::Builtin_JsonParse(int, unsigned long*, v8::internal::Isolate*) [io.javascript.0]
                  host.iobroker
                  	2023-12-01 22:08:24.218	error	Caught by controller[21]: 24: 0x101c2c8 v8::internal::JsonParser<unsigned short>::ParseJson() [io.javascript.0]
                  host.iobroker
                  	2023-12-01 22:08:24.218	error	Caught by controller[20]: 23: 0x101bd88 v8::internal::JsonParser<unsigned short>::ParseJsonValue() [io.javascript.0]
                  host.iobroker
                  	2023-12-01 22:08:24.218	error	Caught by controller[20]: 22: 0x101af84 v8::internal::JsonParser<unsigned short>::BuildJsonObject(v8::internal::JsonParser<unsigned short>::JsonContinuation const&, v8::base::SmallVector<v8::internal::JsonProperty, 16ul, std::allocator<v8::internal::JsonProperty> > const&, v8::internal::Handle<v8::internal::Map>) [io.javascript.0]
                  host.iobroker
                  	2023-12-01 22:08:24.218	error	Caught by controller[19]: 21: 0x1112b3c v8::internal::JSObject::DefineOwnPropertyIgnoreAttributes(v8::internal::LookupIterator*, v8::internal::Handle<v8::internal::Object>, v8::internal::PropertyAttributes, v8::internal::JSObject::AccessorInfoHandling, v8::internal::EnforceDefineSemantics) [io.javascript.0]
                  host.iobroker
                  	2023-12-01 22:08:24.218	error	Caught by controller[18]: 20: 0x1112adc v8::internal::JSObject::DefineOwnPropertyIgnoreAttributes(v8::internal::LookupIterator*, v8::internal::Handle<v8::internal::Object>, v8::internal::PropertyAttributes, v8::Maybe<v8::internal::ShouldThrow>, v8::internal::JSObject::AccessorInfoHandling, v8::internal::EnforceDefineSemantics, v8::internal::StoreOrigin) [io.javascript.0]
                  host.iobroker
                  	2023-12-01 22:08:24.218	error	Caught by controller[17]: 19: 0x117ffa8 v8::internal::Object::AddDataProperty(v8::internal::LookupIterator*, v8::internal::Handle<v8::internal::Object>, v8::internal::PropertyAttributes, v8::Maybe<v8::internal::ShouldThrow>, v8::internal::StoreOrigin, v8::internal::EnforceDefineSemantics) [io.javascript.0]
                  host.iobroker
                  	2023-12-01 22:08:24.217	error	Caught by controller[16]: 18: 0x1165080 v8::internal::Object::TransitionAndWriteDataProperty(v8::internal::LookupIterator*, v8::internal::Handle<v8::internal::Object>, v8::internal::PropertyAttributes, v8::Maybe<v8::internal::ShouldThrow>, v8::internal::StoreOrigin) [io.javascript.0]
                  host.iobroker
                  	2023-12-01 22:08:24.217	error	Caught by controller[15]: 17: 0x1146b38 v8::internal::LookupIterator::PrepareTransitionToDataProperty(v8::internal::Handle<v8::internal::JSReceiver>, v8::internal::Handle<v8::internal::Object>, v8::internal::PropertyAttributes, v8::internal::StoreOrigin) [io.javascript.0]
                  host.iobroker
                  	2023-12-01 22:08:24.217	error	Caught by controller[14]: 16: 0x1158e2c v8::internal::Map::TransitionToDataProperty(v8::internal::Isolate*, v8::internal::Handle<v8::internal::Map>, v8::internal::Handle<v8::internal::Name>, v8::internal::Handle<v8::internal::Object>, v8::internal::PropertyAttributes, v8::internal::PropertyConstness, v8::internal::StoreOrigin) [io.javascript.0]
                  host.iobroker
                  	2023-12-01 22:08:24.216	error	Caught by controller[13]: 15: 0x11570a4 v8::internal::Map::CopyWithField(v8::internal::Isolate*, v8::internal::Handle<v8::internal::Map>, v8::internal::Handle<v8::internal::Name>, v8::internal::Handle<v8::internal::FieldType>, v8::internal::PropertyAttributes, v8::internal::PropertyConstness, v8::internal::Representation, v8::internal::TransitionFlag) [io.javascript.0]
                  host.iobroker
                  	2023-12-01 22:08:24.216	error	Caught by controller[12]: 14: 0x1156a4c v8::internal::Map::ShareDescriptor(v8::internal::Isolate*, v8::internal::Handle<v8::internal::Map>, v8::internal::Handle<v8::internal::DescriptorArray>, v8::internal::Descriptor*) [io.javascript.0]
                  host.iobroker
                  	2023-12-01 22:08:24.216	error	Caught by controller[11]: 13: 0x11534e0 v8::internal::Map::EnsureDescriptorSlack(v8::internal::Isolate*, v8::internal::Handle<v8::internal::Map>, int) [io.javascript.0]
                  host.iobroker
                  	2023-12-01 22:08:24.216	error	Caught by controller[10]: 12: 0x116b6e8 v8::internal::DescriptorArray::CopyUpTo(v8::internal::Isolate*, v8::internal::Handle<v8::internal::DescriptorArray>, int, int) [io.javascript.0]
                  host.iobroker
                  	2023-12-01 22:08:24.216	error	Caught by controller[9]: 11: 0xee71e0 v8::internal::FactoryBase<v8::internal::Factory>::NewDescriptorArray(int, int, v8::internal::AllocationType) [io.javascript.0]
                  host.iobroker
                  	2023-12-01 22:08:24.216	error	Caught by controller[8]: 10: 0xee4af4 v8::internal::FactoryBase<v8::internal::Factory>::AllocateRawWithImmortalMap(int, v8::internal::AllocationType, v8::internal::Map, v8::internal::AllocationAlignment) [io.javascript.0]
                  host.iobroker
                  	2023-12-01 22:08:24.216	error	Caught by controller[7]: 9: 0xeed87c v8::internal::Factory::AllocateRaw(int, v8::internal::AllocationType, v8::internal::AllocationAlignment) [io.javascript.0]
                  host.iobroker
                  	2023-12-01 22:08:24.215	error	Caught by controller[6]: 8: 0xf0b6c8 v8::internal::HeapAllocator::AllocateRawWithRetryOrFailSlowPath(int, v8::internal::AllocationType, v8::internal::AllocationOrigin, v8::internal::AllocationAlignment) [io.javascript.0]
                  host.iobroker
                  	2023-12-01 22:08:24.215	error	Caught by controller[5]: 7: 0xf0a6f0 v8::internal::HeapAllocator::AllocateRawWithLightRetrySlowPath(int, v8::internal::AllocationType, v8::internal::AllocationOrigin, v8::internal::AllocationAlignment) [io.javascript.0]
                  host.iobroker
                  	2023-12-01 22:08:24.215	error	Caught by controller[4]: 6: 0xf2e56c v8::internal::Heap::CollectGarbage(v8::internal::AllocationSpace, v8::internal::GarbageCollectionReason, v8::GCCallbackFlags) [io.javascript.0]
                  host.iobroker
                  	2023-12-01 22:08:24.215	error	Caught by controller[3]: 5: 0xf1c5d4 [io.javascript.0]
                  host.iobroker
                  	2023-12-01 22:08:24.215	error	Caught by controller[2]: 4: 0xd3dfe0 v8::internal::V8::FatalProcessOutOfMemory(v8::internal::Isolate*, char const*, bool) [io.javascript.0]
                  host.iobroker
                  	2023-12-01 22:08:24.215	error	Caught by controller[1]: 3: 0xd3de10 v8::Utils::ReportOOMFailure(v8::internal::Isolate*, char const*, bool) [io.javascript.0]
                  host.iobroker
                  	2023-12-01 22:08:24.215	error	Caught by controller[1]: 2: 0xa93f08 [io.javascript.0]
                  host.iobroker
                  	2023-12-01 22:08:24.214	error	Caught by controller[1]: 1: 0xb72e9c node::Abort() [io.javascript.0]
                  host.iobroker
                  	2023-12-01 22:08:24.214	error	Caught by controller[0]: FATAL ERROR: Reached heap limit Allocation failed - JavaScript heap out of memory
                  host.iobroker
                  	2023-12-01 22:08:24.214	error	Caught by controller[0]: <--- JS stacktrace --->
                  host.iobroker
                  	2023-12-01 22:08:24.214	error	Caught by controller[0]: of marking 150 ms) (average mu = 0.945, current mu = 0.975) finalize increment[756:0x2e07a3d0] 11730 ms: Mark-sweep 59.5 (99.8) -> 59.0 (96.8) MB, 14.0 / 0.0 ms (+ 16.8 ms in 61 steps since start of marking, biggest step 0.8 ms, walltime since start of marking 98 ms) (average mu = 0.921, current mu = 0.750) finalize incremental[756:0x2e07a3d0] 12212 ms: Mark-sweep 81.9 (103.5) -> 79.7 (119.0) MB, 132.9 / 0.0 ms (average mu = 0.823, current mu = 0.724) allocation failure; scavenge might not succeed
                  host.iobroker
                  	2023-12-01 22:08:24.213	error	Caught by controller[0]: <--- Last few GCs --->
                  host.iobroker
                  	2023-12-01 22:07:36.113	warn	instance system.adapter.javascript.0 terminated due to SIGABRT
                  host.iobroker
                  	2023-12-01 22:07:36.113	error	Caught by controller[2]: 16: 0x167960c [io.javascript.0]
                  host.iobroker
                  	2023-12-01 22:07:36.113	error	Caught by controller[2]: 15: 0xdc93f8 v8::internal::Builtin_JsonParse(int, unsigned long*, v8::internal::Isolate*) [io.javascript.0]
                  host.iobroker
                  	2023-12-01 22:07:36.112	error	Caught by controller[2]: 14: 0x101c2c8 v8::internal::JsonParser<unsigned short>::ParseJson() [io.javascript.0]
                  host.iobroker
                  	2023-12-01 22:07:36.112	error	Caught by controller[2]: 13: 0x101b648 v8::internal::JsonParser<unsigned short>::ParseJsonValue() [io.javascript.0]
                  host.iobroker
                  	2023-12-01 22:07:36.112	error	Caught by controller[2]: 12: 0x101a0e8 v8::internal::JsonParser<unsigned short>::MakeString(v8::internal::JsonString const&, v8::internal::Handle<v8::internal::String>) [io.javascript.0]
                  host.iobroker
                  	2023-12-01 22:07:36.112	error	Caught by controller[2]: 11: 0xee6e84 v8::internal::FactoryBase<v8::internal::Factory>::NewRawOneByteString(int, v8::internal::AllocationType) [io.javascript.0]
                  host.iobroker
                  	2023-12-01 22:07:36.111	error	Caught by controller[1]: 10: 0xee4af4 v8::internal::FactoryBase<v8::internal::Factory>::AllocateRawWithImmortalMap(int, v8::internal::AllocationType, v8::internal::Map, v8::internal::AllocationAlignment) [io.javascript.0]
                  host.iobroker
                  	2023-12-01 22:07:36.111	error	Caught by controller[1]: 9: 0xeed87c v8::internal::Factory::AllocateRaw(int, v8::internal::AllocationType, v8::internal::AllocationAlignment) [io.javascript.0]
                  host.iobroker
                  	2023-12-01 22:07:36.110	error	Caught by controller[0]: 8: 0xf0b6c8 v8::internal::HeapAllocator::AllocateRawWithRetryOrFailSlowPath(int, v8::internal::AllocationType, v8::internal::AllocationOrigin, v8::internal::AllocationAlignment) [io.javascript.0]
                  host.iobroker
                  	2023-12-01 22:07:36.110	error	Caught by controller[0]: 7: 0xf0a6f0 v8::internal::HeapAllocator::AllocateRawWithLightRetrySlowPath(int, v8::internal::AllocationType, v8::internal::AllocationOrigin, v8::internal::AllocationAlignment) [io.javascript.0]
                  host.iobroker
                  	2023-12-01 22:07:36.109	error	Caught by controller[0]: 6: 0xf2e56c v8::internal::Heap::CollectGarbage(v8::internal::AllocationSpace, v8::internal::GarbageCollectionReason, v8::GCCallbackFlags) [io.javascript.0]
                  host.iobroker
                  	2023-12-01 22:07:36.109	error	Caught by controller[0]: 5: 0xf1c5d4 [io.javascript.0]
                  host.iobroker
                  	2023-12-01 22:07:36.108	error	Caught by controller[0]: 4: 0xd3dfe0 v8::internal::V8::FatalProcessOutOfMemory(v8::internal::Isolate*, char const*, bool) [io.javascript.0]
                  host.iobroker
                  	2023-12-01 22:07:36.108	error	Caught by controller[0]: 3: 0xd3de10 v8::Utils::ReportOOMFailure(v8::internal::Isolate*, char const*, bool) [io.javascript.0]
                  host.iobroker
                  	2023-12-01 22:07:36.108	error	Caught by controller[0]: 2: 0xa93f08 [io.javascript.0]
                  host.iobroker
                  	2023-12-01 22:07:36.107	error	Caught by controller[0]: 1: 0xb72e9c node::Abort() [io.javascript.0]
                  host.iobroker
                  	2023-12-01 22:07:36.106	error	Caught by controller[0]: FATAL ERROR: Reached heap limit Allocation failed - JavaScript heap out of memory
                  host.iobroker
                  	2023-12-01 22:07:36.106	error	Caught by controller[0]: <--- JS stacktrace --->
                  host.iobroker
                  	2023-12-01 22:07:36.105	error	Caught by controller[0]: of marking 68 ms) (average mu = 0.876, current mu = 0.621) finalize incremental[705:0xc63c3d0] 11027 ms: Mark-sweep 59.6 (94.6) -> 59.3 (95.1) MB, 23.2 / 0.0 ms (+ 2.2 ms in 10 steps since start of marking, biggest step 0.5 ms, walltime since start of marking 109 ms) (average mu = 0.909, current mu = 0.946) finalize incremental [705:0xc63c3d0] 11503 ms: Mark-sweep 82.4 (101.8) -> 79.9 (117.3) MB, 128.4 / 0.0 ms (average mu = 0.823, current mu = 0.730) allocation failure; scavenge might not succeed
                  host.iobroker
                  	2023-12-01 22:07:36.101	error	Caught by controller[0]: <--- Last few GCs --->
                  host.iobroker
                  	2023-12-01 22:06:49.468	warn	instance system.adapter.javascript.0 terminated due to SIGABRT
                  host.iobroker
                  	2023-12-01 22:06:49.468	error	Caught by controller[19]: 25: 0xdc93f8 v8::internal::Builtin_JsonParse(int, unsigned long*, v8::internal::Isolate*) [io.javascript.0]
                  host.iobroker
                  	2023-12-01 22:06:49.467	error	Caught by controller[18]: 24: 0x101c2c8 v8::internal::JsonParser<unsigned short>::ParseJson() [io.javascript.0]
                  host.iobroker
                  	2023-12-01 22:06:49.468	error	Caught by controller[20]: 26: 0x167960c [io.javascript.0]
                  host.iobroker
                  	2023-12-01 22:06:49.467	error	Caught by controller[17]: 23: 0x101bd88 v8::internal::JsonParser<unsigned short>::ParseJsonValue() [io.javascript.0]
                    paul53 @smhrambo last edited by paul53
                    @smhrambo sagte: Problem bleibt
                    Dann ist wohl etwas bei der Installation / beim Update des JS-Adapters schief gegangen?
                      Ich weiss zwar das es etwas offtopic ist, aber ich habe iobroker entfernt und alle Daten gelöscht.
                      Danach habe ich iobroker neu heruntergeladen und gestartet.
                      Neustart ging ohne Probleme, ich habe die Ersteinrichtung gemacht und danach ein Backup wiederhergestellt.
                      Jetzt passiert gar nichts, ich komme nicht ins Admin-Interface.
                      Logs sagen folgendes:
                      Starting ioBroker...
                      ##### #### ### ## # iobroker.js-controller log output # ## ### #### #####
                      host.iobroker check instance "system.adapter.admin.0" for host "iobroker"
                      host.iobroker check instance "system.adapter.history.0" for host "iobroker"
                      host.iobroker check instance "system.adapter.influxdb.0" for host "iobroker"
                      host.iobroker check instance "system.adapter.influxdb.1" for host "iobroker"
                      host.iobroker check instance "system.adapter.javascript.0" for host "iobroker"
                      host.iobroker check instance "system.adapter.telegram.0" for host "iobroker"
                      host.iobroker check instance "system.adapter.alexa2.0" for host "iobroker"
                      host.iobroker check instance "system.adapter.hm-rega.0" for host "iobroker"
                      host.iobroker check instance "system.adapter.hm-rpc.1" for host "iobroker"
                      host.iobroker check instance "system.adapter.hue.0" for host "iobroker"
                      host.iobroker check instance "system.adapter.modbus.0" for host "iobroker"
                      host.iobroker check instance "system.adapter.mqtt.0" for host "iobroker"
                      host.iobroker check instance "system.adapter.weatherunderground.0" for host "iobroker"
                      host.iobroker check instance "system.adapter.weatherunderground.1" for host "iobroker"
                      host.iobroker check instance "system.adapter.zigbee.0" for host "iobroker"
                      host.iobroker check instance "system.adapter.discovery.0" for host "iobroker"
                      host.iobroker check instance "system.adapter.backitup.0" for host "iobroker"
                      host.iobroker check instance "system.adapter.adguard.0" for host "iobroker"
                      host.iobroker check instance "system.adapter.alarm.0" for host "iobroker"
                      host.iobroker check instance "system.adapter.bidirectional-counter.0" for host "iobroker"
                      host.iobroker check instance "system.adapter.device-reminder.0" for host "iobroker"
                      host.iobroker check instance "system.adapter.device-watcher.0" for host "iobroker"
                      host.iobroker check instance "system.adapter.ems-esp.0" for host "iobroker"
                      host.iobroker check instance "system.adapter.evcc.0" for host "iobroker"
                      host.iobroker check instance "system.adapter.followthesun.0" for host "iobroker"
                      host.iobroker check instance "system.adapter.habpanel.0" for host "iobroker"
                      host.iobroker check instance "system.adapter.iqontrol.0" for host "iobroker"
                      host.iobroker check instance "system.adapter.jarvis.0" for host "iobroker"
                      host.iobroker check instance "system.adapter.material.0" for host "iobroker"
                      host.iobroker check instance "system.adapter.sayit.0" for host "iobroker"
                      host.iobroker check instance "system.adapter.shuttercontrol.0" for host "iobroker"
                      host.iobroker check instance "system.adapter.text2command.0" for host "iobroker"
                      host.iobroker check instance "system.adapter.web.0" for host "iobroker"
                      host.iobroker check instance "system.adapter.zigbee2mqtt.0" for host "iobroker"
                      host.iobroker check instance "system.adapter.zwave2.0" for host "iobroker"
                      Send diag info: {"uuid":"9ac691bb-cf3c-4fbd-9aa3-1466429d7467","language":"en","country":"Germany","hosts":[{"version":"5.0.16","platform":"Javascript/Node.js","type":"linux"}],"node":"v18.19.0","arch":"arm64","docker":true,"adapters":{"admin":{"version":"6.12.0","platform":"Javascript/Node.js"},"discovery":{"version":"4.2.0","platform":"Javascript/Node.js"},"backitup":{"version":"2.8.7","platform":"Javascript/Node.js"},"adguard":{"version":"0.0.8","platform":"Javascript/Node.js"},"alarm":{"version":"3.4.3","platform":"Javascript/Node.js"},"alexa2":{"version":"3.26.3","platform":"Javascript/Node.js"},"bidirectional-counter":{"version":"2.1.3","platform":"Javascript/Node.js"},"bshb":{"version":"0.1.20","platform":"Javascript/Node.js"},"device-reminder":{"version":"3.0.0","platform":"Javascript/Node.js"},"device-watcher":{"version":"2.9.6","platform":"Javascript/Node.js"},"ems-esp":{"version":"2.6.1","platform":"Javascript/Node.js"},"evcc":{"version":"0.0.10","platform":"Javascript/Node.js"},"followthesun":{"version":"0.4.2","platform":"Javascript/Node.js"},"habpanel":{"version":"0.5.0","platform":"Javascript/Node.js"},"history":{"version":"3.0.1","platform":"Javascript/Node.js"},"hm-rega":{"version":"4.0.0","platform":"Javascript/Node.js"},"hm-rpc":{"version":"1.15.19","platform":"Javascript/Node.js"},"hue":{"version":"3.10.1","platform":"Javascript/Node.js"},"influxdb":{"version":"3.2.0","platform":"Javascript/Node.js"},"iqontrol":{"version":"2.3.0","platform":"Javascript/Node.js"},"jarvis":{"version":"3.1.8","platform":"Javascript/Node.js"},"javascript":{"version":"7.1.6","platform":"Javascript/Node.js"},"material":{"version":"1.3.1","platform":"Javascript/Node.js"},"modbus":{"version":"5.0.11","platform":"Javascript/Node.js"},"mqtt":{"version":"5.1.0","platform":"Javascript/Node.js"},"sayit":{"version":"3.0.5","platform":"Javascript/Node.js"},"shuttercontrol":{"version":"1.6.3","platform":"Javascript/Node.js"},"snips":{"version":"1.5.1","platform":"Javascript/Node.js"},"socketio":{"version":"6.6.0","platform":"Javascript/Node.js"},"telegram":{"version":"2.0.1","platform":"Javascript/Node.js"},"text2command":{"version":"3.0.2","platform":"Javascript/Node.js"},"weatherunderground":{"version":"3.6.0","platform":"Javascript/Node.js"},"web":{"version":"6.1.10","platform":"Javascript/Node.js"},"ws":{"version":"2.5.8","platform":"Javascript/Node.js"},"zigbee":{"version":"1.8.24","platform":"Javascript/Node.js"},"zigbee2mqtt":{"version":"2.13.3","platform":"Javascript/Node.js"},"zwave2":{"version":"3.1.0","platform":"Javascript/Node.js"}},"statesType":"jsonl","objectsType":"jsonl","noInstances":35,"compactMode":true,"noCompactInstances":1,"model":"Cortex-A72","cpus":4,"mem":4030959616,"ostype":"Linux","city":"Hamburg"}
                        Thomas Braun Most Active @smhrambo last edited by
                        @smhrambo
                        Und was sagt
                        iob diag
                        dazu?
                          smhrambo @Thomas Braun last edited by
                          @thomas-braun said in JS-Adapter startet ständig neu: heap out of memory:
                          iob diag
                          Sorry hat sich nach einem Neustart des Pis erledigt.
                          Aber der JS Fehler ist immer noch da.
                          Es laufen nach der Neuinstallation nur folgende Adapter:
                          • admin.0
                          • backitup.0
                          • javascript.0
                          Die Skripte sind weiterhin deaktiviert.
                          iob diag:
                          Skript v.2023-10-10
                          *** BASE SYSTEM ***
                          Hardware Vendor :
                          Kernel          : aarch64
                          Userland        : arm64
                          Docker          : v9.0.1
                          Kernel          : aarch64
                          Userland        : arm64
                           00:42:10 up  8:22,  0 user,  load average: 1.45, 1.26, 1.15
                          CPU threads: 4
                          Fri Dec  1 23:42:10 UTC 2023
                          Sat Dec  2 00:42:10 CET 2023
                          CET +0100
                          Etc/UTC
                          root
                          /root
                          root
                          X-Server:       false
                          Desktop:
                          Terminal:
                          *** MEMORY ***
                          Mem:            4.0G        1.8G        418M         43M        2.0G        2.3G
                          Swap:           104M        104M        196K
                          Total:          4.1G        1.9G        418M
                                   3844 M total memory
                                   1695 M used memory
                                   1742 M active memory
                                   1288 M inactive memory
                                    398 M free memory
                                    114 M buffer memory
                                   1768 M swap cache
                                     99 M total swap
                                     99 M used swap
                                      0 M free swap
                          *** FILESYSTEM ***
                          overlay        overlay  367G  120G  233G  35% /
                          /dev/root      ext4     367G  120G  233G  35% /opt/iobroker
                          /etc/resolv.conf            /dev/root[/var/lib/docker/containers/dbae87321dd4fe0d2db919b36c1a52a9c4066f5d25c9c11ad75bfc291fdafb0f/resolv.conf] ext4   rw,noatime
                          /etc/hostname               /dev/root[/var/lib/docker/containers/dbae87321dd4fe0d2db919b36c1a52a9c4066f5d25c9c11ad75bfc291fdafb0f/hostname]    ext4   rw,noatime
                          /etc/hosts                  /dev/root[/var/lib/docker/containers/dbae87321dd4fe0d2db919b36c1a52a9c4066f5d25c9c11ad75bfc291fdafb0f/hosts]       ext4   rw,noatime
                          /var:
                          34M     /var/
                          31M     /var/lib
                          19M     /var/lib/apt/lists
                          19M     /var/lib/apt
                          13M     /var/lib/dpkg
                          2.2M    /opt/iobroker/backups/
                          298M    /opt/iobroker/iobroker-data/
                          280M    /opt/iobroker/iobroker-data/files
                          16M     /opt/iobroker/iobroker-data/objects.jsonl
                          9.9M    /opt/iobroker/iobroker-data/files/material/static/js/main.c5478f66.js
                          USB-Devices by-id:
                          /usr/bin/nodejs         v18.19.0
                          /usr/bin/node           v18.19.0
                          /usr/bin/npm            10.2.3
                          /usr/bin/npx            10.2.3
                          nodejs:
                            Installed: 18.19.0-1nodesource1
                            Candidate: 18.19.0-1nodesource1
                            Version table:
                           *** 18.19.0-1nodesource1 500
                               18.18.2-1nodesource1 500
                               18.18.1-1nodesource1 500
                               18.18.0-1nodesource1 500
                               18.17.1-1nodesource1 500
                               18.17.0-1nodesource1 500
                               18.16.1-1nodesource1 500
                               18.16.0-1nodesource1 500
                               18.15.0-1nodesource1 500
                               18.14.2-1nodesource1 500
                               18.14.1-1nodesource1 500
                               18.14.0-1nodesource1 500
                               18.13.0+dfsg1-1 500
                               18.13.0-1nodesource1 500
                               18.12.0-1nodesource1 500
                               18.11.0-1nodesource1 500
                               18.10.0-1nodesource1 500
                               18.9.1-1nodesource1 500
                               18.9.0-1nodesource1 500
                               18.8.0-1nodesource1 500
                               18.7.0-1nodesource1 500
                               18.6.0-1nodesource1 500
                               18.5.0-1nodesource1 500
                               18.4.0-1nodesource1 500
                               18.3.0-1nodesource1 500
                               18.2.0-1nodesource1 500
                               18.1.0-1nodesource1 500
                               18.0.0-1nodesource1 500
                          Errors in npm tree:
                          ioBroker Status
                          Objects type: jsonl
                          States  type: jsonl
                          admin:          6.12.0
                          javascript:     7.1.6
                          Adapter State
                            system.adapter.device-watcher.0         : device-watcher        : iobroker                                 - disabled, compact disabled
                            system.adapter.ems-esp.0                : ems-esp               : iobroker                                 - disabled, compact disabled
                            system.adapter.followthesun.0           : followthesun          : iobroker                                 - disabled, compact disabled
                            system.adapter.habpanel.0               : habpanel              : iobroker                                 - disabled
                            system.adapter.history.0                : history               : iobroker                                 - disabled, compact disabled
                            system.adapter.hm-rega.0                : hm-rega               : iobroker                                 - disabled, compact disabled
                            system.adapter.hm-rpc.1                 : hm-rpc                : iobroker                                 - disabled, compact disabled, port: 0
                            system.adapter.influxdb.1               : influxdb              : iobroker                                 - disabled, compact disabled, port: 8086
                          + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled, compact disabled
                            system.adapter.material.0               : material              : iobroker                                 - disabled
                            system.adapter.modbus.0                 : modbus                : iobroker                                 - disabled, compact disabled
                            system.adapter.mqtt.0                   : mqtt                  : iobroker                                 - disabled, compact disabled, port: 1883, bind: 0.0.0.0
                            system.adapter.shuttercontrol.0         : shuttercontrol        : iobroker                                 - disabled, compact disabled
                            system.adapter.telegram.0               : telegram              : iobroker                                 - disabled, compact disabled, port: 8443, bind: 0.0.0.0
                            system.adapter.text2command.0           : text2command          : iobroker                                 - disabled, compact disabled
                            system.adapter.weatherunderground.0     : weatherunderground    : iobroker                                 - disabled, compact disabled
                            system.adapter.weatherunderground.1     : weatherunderground    : iobroker                                 - disabled, compact disabled
                            system.adapter.web.0                    : web                   : iobroker                                 - disabled, compact enabled (group 1), port: 8082, bind: 0.0.0.0 (SSL), run as: admin
                            system.adapter.zigbee2mqtt.0            : zigbee2mqtt           : iobroker                                 - disabled, compact disabled
                          + instance is alive
                          Objects and States
                          Objects:        11697
                          States:         10875
                          Pending Updates: 0
                          tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1010       834014     -
                          tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1010       834021     -
                          tcp        0      0 127.0.0.11:39871        0.0.0.0:*               LISTEN      0          833571     -
                          tcp6       0      0 :::8081                 :::*                    LISTEN      1010       835040     -
                          udp        0      0 127.0.0.11:44813        0.0.0.0:*                           0          833570     -
                          2023-12-02 00:42:09.539  - error: host.iobroker Caught by controller[23]: 23: 0x101edb0 v8::internal::JsonParser<unsigned short>::ParseJsonValue() [io.javascript.0]
                          2023-12-02 00:42:09.539  - error: host.iobroker Caught by controller[24]: 24: 0x101f2f0 v8::internal::JsonParser<unsigned short>::ParseJson() [io.javascript.0]
                          2023-12-02 00:42:09.539  - error: host.iobroker Caught by controller[25]: 25: 0xdcc460 v8::internal::Builtin_JsonParse(int, unsigned long*, v8::internal::Isolate*) [io.javascript.0]
                          2023-12-02 00:42:09.539  - error: host.iobroker Caught by controller[26]: 26: 0x167c62c  [io.javascript.0]
                          2023-12-02 00:42:09.539  - warn: host.iobroker instance system.adapter.javascript.0 terminated due to SIGABRT
                          2023-12-02 00:42:56.132  - error: host.iobroker Caught by controller[0]: <--- Last few GCs --->
                          2023-12-02 00:42:56.134  - error: host.iobroker Caught by controller[0]:  of marking 163 ms) (average mu = 0.755, current mu = 0.754) finalize incremen[2987:0x1aa44870]    10656 ms: Mark-sweep 67.5 (97.7) -> 60.9 (101.0) MB, 41.9 / 0.0 ms  (+ 9.8 ms in 24 steps since start of marking, biggest step 3.0 ms, walltime since start of marking 165 ms) (average mu = 0.801, current mu = 0.843) finalize increment[2987:0x1aa44870]    11119 ms: Mark-sweep 84.3 (107.9) -> 81.5 (119.4) MB, 148.3 / 0.0 ms  (average mu = 0.728, current mu = 0.679) allocation failure; scavenge might not succeed
                          2023-12-02 00:42:56.135  - error: host.iobroker Caught by controller[0]: <--- JS stacktrace --->
                          2023-12-02 00:42:56.135  - error: host.iobroker Caught by controller[0]: FATAL ERROR: Reached heap limit Allocation failed - JavaScript heap out of memory
                          2023-12-02 00:42:56.135  - error: host.iobroker Caught by controller[1]:  1: 0xb7f974 node::Abort() [io.javascript.0]
                          2023-12-02 00:42:56.136  - error: host.iobroker Caught by controller[2]:  2: 0xa97f08  [io.javascript.0]
                          2023-12-02 00:42:56.136  - error: host.iobroker Caught by controller[3]:  3: 0xd40e78 v8::Utils::ReportOOMFailure(v8::internal::Isolate*, char const*, bool) [io.javascript.0]
                          2023-12-02 00:42:56.136  - error: host.iobroker Caught by controller[4]:  4: 0xd41048 v8::internal::V8::FatalProcessOutOfMemory(v8::internal::Isolate*, char const*, bool) [io.javascript.0]
                          2023-12-02 00:42:56.136  - error: host.iobroker Caught by controller[5]:  5: 0xf1f5fc  [io.javascript.0]
                          2023-12-02 00:42:56.137  - error: host.iobroker Caught by controller[6]:  6: 0xf31594 v8::internal::Heap::CollectGarbage(v8::internal::AllocationSpace, v8::internal::GarbageCollectionReason, v8::GCCallbackFlags) [io.javascript.0]
                          2023-12-02 00:42:56.137  - error: host.iobroker Caught by controller[7]:  7: 0xf0d718 v8::internal::HeapAllocator::AllocateRawWithLightRetrySlowPath(int, v8::internal::AllocationType, v8::internal::AllocationOrigin, v8::internal::AllocationAlignment) [io.javascript.0]
                          2023-12-02 00:42:56.137  - error: host.iobroker Caught by controller[8]:  8: 0xf0e6f0 v8::internal::HeapAllocator::AllocateRawWithRetryOrFailSlowPath(int, v8::internal::AllocationType, v8::internal::AllocationOrigin, v8::internal::AllocationAlignment) [io.javascript.0]
                          2023-12-02 00:42:56.137  - error: host.iobroker Caught by controller[9]:  9: 0xef0cc0 v8::internal::Factory::AllocateRawWithAllocationSite(v8::internal::Handle<v8::internal::Map>, v8::internal::AllocationType, v8::internal::Handle<v8::internal::AllocationSite>) [io.javascript.0]
                          2023-12-02 00:42:56.137  - error: host.iobroker Caught by controller[10]: 10: 0xefb464 v8::internal::Factory::NewJSObjectFromMap(v8::internal::Handle<v8::internal::Map>, v8::internal::AllocationType, v8::internal::Handle<v8::internal::AllocationSite>) [io.javascript.0]
                          2023-12-02 00:42:56.138  - error: host.iobroker Caught by controller[11]: 11: 0x101e04c v8::internal::JsonParser<unsigned short>::BuildJsonObject(v8::internal::JsonParser<unsigned short>::JsonContinuation const&, v8::base::SmallVector<v8::internal::JsonProperty, 16ul, std::allocator<v8::internal::JsonProperty> > const&, v8::internal::Handle<v8::internal::Map>) [io.javascript.0]
                          2023-12-02 00:42:56.138  - error: host.iobroker Caught by controller[12]: 12: 0x101edb0 v8::internal::JsonParser<unsigned short>::ParseJsonValue() [io.javascript.0]
                          2023-12-02 00:42:56.138  - error: host.iobroker Caught by controller[13]: 13: 0x101f2f0 v8::internal::JsonParser<unsigned short>::ParseJson() [io.javascript.0]
                          2023-12-02 00:42:56.138  - error: host.iobroker Caught by controller[14]: 14: 0xdcc460 v8::internal::Builtin_JsonParse(int, unsigned long*, v8::internal::Isolate*) [io.javascript.0]
                          2023-12-02 00:42:56.138  - error: host.iobroker Caught by controller[15]: 15: 0x167c62c  [io.javascript.0]
                          2023-12-02 00:42:56.138  - warn: host.iobroker instance system.adapter.javascript.0 terminated due to SIGABRT
                                                  v.2023-10-10
                          Kernel          : aarch64
                          Userland        : arm64
                          Docker          : v9.0.1
                          Userland:               arm64
                          Timezone:               Etc/UTC
                          User-ID:                0
                          X-Server:               false
                          Pending OS-Updates:     0
                          Nodejs-Installation:    /usr/bin/nodejs         v18.19.0
                                                  /usr/bin/npm            10.2.3
                                                  /usr/bin/npx            10.2.3
                          Recommended versions are nodejs 18.19.0 and npm 10.2.3
                          MEMORY:
                          Mem:            4.0G        1.8G        426M         43M        1.9G        2.2G
                          Total:          4.1G        2.0G        427M
                          Active iob-Instances:   3
                          Objects type: jsonl
                          States  type: jsonl
                          Objects:                11697
                          States:                 10875
                          3.2M    /opt/iobroker/iobroker-data/states.jsonl
                                                  v.2023-10-10
                          Kernel          : aarch64
                          Userland        : arm64
                          Docker          : v9.0.1
                          Userland:               arm64
                          Timezone:               Etc/UTC
                          User-ID:                0
                          X-Server:               false
                                                  /usr/bin/npm            10.2.3
                                                  /usr/bin/npx            10.2.3
                          MEMORY:
                          Objects type: jsonl
                          States  type: jsonl
                          Objects:                11697
                          States:                 10875
                            @smhrambo
                            Docker auf einem Raspberry?
                            Ich muss hier weg...
                              @thomas-braun Das ganze hat Jahre lang wunderbar funktioniert.
                              Habe ich so selbst in der Industrie schon gesehen.
                              Sehr praktisch zum testen und bereitsellen von Software, ohne sich das System voll zu müllen, da man sie Software Restlos entfernen kann.
                                Thomas Braun Most Active @smhrambo last edited by Thomas Braun
                                @smhrambo
                                Zum anschauen und testen von irgendwas ist das sinnvoll. Fur dauerhaften Betrieb ist es nur eine entbehrliche weitere Softwareschicht, die auch noch richtig unterhalten werden will.
                                Ist mir für den ioBroker nur ein unnötiger Ressourcenfresser.
                                Btw: Dir geht der für nodejs allokierte Arbeitsspeicher aus... 🙂
                                S 1 Reply Last reply Reply Quote -1
                                  @thomas-braun Es liegen 300MB freien RAM und 2GB an Verfügbaren RAM rum.
                                  Wenn ich den Container ohne Backup starte und dann JS laufen lasse habe ich das Problem nicht.
                                  Dann wird wohl docker nicht das Problem sein, sondern irgendwelche vorhandenen Daten oder ein Installationsprozess.
                                  Die Frage ist nur warum dieser Fehler bei einer Neuinstallation + Backup wieder "eingebaut" wird.
                                  Btw:
                                  Viele vergleichen Docker beim Resourcenverbrauch gerne mit VM, habe ich früher auch gemacht. Ich musste aber feststellen, dass dies nicht der Fall ist und der Overhead realtiv gering ist, wenn man weiss wie man die Container aufzubauen hat.
                                  One program per container.
                                  Wenn man sich daran hält ist man "fast" auf der Ebene eines chroot mit einem netten Verwaltungs und Sicherheitsbonus.
                                  Da iobroker mit seinen Adaptern recht Modular aufgebaut ist mag diese Philosophie hier nicht ganz zutreffen, aber das erklärt das oben beschriebene Verhalten trotzdem nicht.
                                  Ro75 1 Reply Last reply Reply Quote 0
                                  • Ro75
                                    Ro75 @smhrambo last edited by
                                    @smhrambo sagte in JS-Adapter startet ständig neu: heap out of memory:
                                    Nach einer Neuinstallation ohne Backup, ist da nicht viel los. Mit anderen Worten da wird nicht zu viel Speicher benötigt.
                                    Wenn das Backup drin ist, laufen ja wieder Adapter, Skripte,... und das braucht halt Speicher. Und mit jeder Weiterentwicklung von Adaptern gibt es mehr Funktionalität. An der Sicherheit wird auch gearbeitet - und das braucht halt mehr Speicher, als noch vor 5 Jahren.
                                    Aber das ist nicht nur beim ioBroker so. Gleiches Verhalten hast du auch bei Windows, Windows-Programmen und auch bi Linux. Früher war alles gefühlt schlanker, platzsparender und weniger speicherhungrig. Aber so ist nun mal der Lauf.
                                    Dir geht mit der Variante ioBroker im Docker einfach der Speicher auf deinem Raspi aus, auch bi einem 4GB Model. Ich hatte den ioBroker mehrere Jahre auf meinem Raspi (4GB) nornal, ohne Docker laufen mit mehr als 20 Adaptern, ohne Problem.
                                    Aus meiner Sicht:
                                    • wenn du weiterhin mit Docker arbeiten willst/musst dann brauchst du mehr RAM
                                    • RAM erweitern auf einem Raspi soll zwar gehen, mir aber zu kompliziert
                                    • neuer Raspi mit 8GB oder lieber gleich ein NUC
                                    Die 3 Punkte unter dem Gesichtspunkt, dass du mit Docker arbeiten willst. Alternativ verzichte auf Docker (zumindest ohne ioBroker, nur für andere Projekte).
                                    Ro75.
                                    S Marc Berg 2 Replies Last reply Reply Quote -1
                                      smhrambo @Ro75 last edited by
                                      @ro75 Im Log ist zu erkennen das nach dem Backup kein Adapter läuft und auch kein Skript.
                                      Das bedeutet auch das kein RAM benötigt wird.
                                      Nachmal, ALLE Adapter und Skripte sind nach dem Backup DEAKTIVIERT.
                                      Erst wenn ich nun den JS Adapter aktiviere und ich meine nur den JS Adapter, kommt der Fehler wieder.
                                      Wenn ich das Backup NICHT einspiele und selber ALLE Adapter installiere und aktiviere, kommt der Fehler nicht.
                                      Inzwischen laufen sogar wieder Sktipte ohne Fehlermeldung.
                                      Kein anderer Docker Container oder Prozess hat Probleme auf dem System.
                                      Besonders InfluxDB musste dann Fehler ohne Ende schmeißen.
                                      Ich glaube aber dem Fehler näher zu kommen.
                                      Wie kann man von allen Objekten den Raum und die Funktion aufeinmal entfernen, ohne das Objekt selber oder andere Einstellungen von den Objekten zu löschen?
                                      Ich möchte nicht meine Zeit damit verbringen alle Objekte wieder neu einzustellen bzgl. InfluxDB und co.
                                      Zudem denke ich das es auch im interesse der Community ist, wenn man der Ursache genau auf den Grund geht.
                                      Bzgl. der RAM verbrauchs:
                                      Ich bin Programmierer, ich habe bisher nur ein paar flüchtige Blicke in die Adapterprogrammierung geworfen. Trotzdem versteht ich nicht was dafür sorge, dass mein Weihnachtsscript (aus meinem ersten Post), den RAM Verbrauch vom JS Adapter um ca. 125MB steigen lässt. Da sind gerade mal 3 Integer Variablen, 6 Funktionsaufrufe und 3 Vergleiche drin.
                                        Homoran Global Moderator Administrators @smhrambo last edited by
                                        soweit ich weiß bezieht sich das nicht (nur) auf den javascript Adapter, sondern auf alles was mit js läuft.
                                        • Ro75
                                          Ro75 @smhrambo last edited by Ro75
                                          Ich programmiere auch seit 20 Jahren - nur Windows, seit 2020 auch JS, dank ioBroker. Aber um zu schauen was bei dir ist, müsste man schon das vollständige Skript mal sehen.
                                          Ro75.
                                            smhrambo @Homoran last edited by
                                            @homoran said in JS-Adapter startet ständig neu: heap out of memory:
                                            Dann stellt sich nur immernoch die Frage warum nur der JS Adapter davon betroffen ist.
                                            Soweit ich weiss läuft das gesamte ioBroker-System auf javascript.
                                            Und dies nicht bei einer Neuinstallation der Fall ist, sondern nur beim wiederherstellen alter Daten.
                                            55
                                            3084
