    4. [gelöst] Node-Red Update auf v5.0.0 | Error
    • Dillio
      Dillio last edited by Dillio
      beim Update des Adapters Node-Red auf die Version 5.0.0 erhalte ich folgende Fehlermeldung:
      pi@iobroker-slave:~ $ iobroker upgrade node-red --debug
      This upgrade of "node-red" will introduce the following changes:
      -> 5.0.0:
      *NodeJS 16.4.x is required**
      *Please check instance configuration and re-enter your passwords (encryption has changed).**
      Updated Node-RED to 3.1.0. Please check your nodes for compatibility!
      Admin 5/6 JSON config for instance configuration
      Added sendTo node with callback
      Allow custom attribute name for "ioBroker in" node
      Added option to select editor (monaco, ace)
      Added table for custom env vars to instance configuration
      BE CAREFUL: THIS IS A MAJOR UPGRADE, WHICH WILL MOST LIKELY INTRODUCE BREAKING CHANGES!
      Would you like to upgrade node-red from @4.0.3 to @5.0.0 now? [(y)es, (n)o]: y
      Update node-red from @4.0.3 to @5.0.0
      host.iobroker-slave Adapter "system.adapter.node-red.0" is stopped.
      NPM version: 9.6.7
      Installing iobroker.node-red@5.0.0... (System call)
      npm ERR! code 1
      npm ERR! path /opt/iobroker/node_modules/bcrypt
      npm ERR! command failed
      npm ERR! command sh -c node-pre-gyp install --fallback-to-build
      npm ERR! Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js clean' (1)
      npm ERR! node-pre-gyp info it worked if it ends with ok
      npm ERR! node-pre-gyp info using node-pre-gyp@1.0.11
      npm ERR! node-pre-gyp info using node@18.17.1 | linux | arm
      npm ERR! node-pre-gyp info check checked for "/opt/iobroker/node_modules/bcrypt/lib/binding/napi-v3/bcrypt_lib.node" (not found)
      npm ERR! node-pre-gyp http GET https://github.com/kelektiv/node.bcrypt.js/releases/download/v5.1.1/bcrypt_lib-v5.1.1-napi-v3-linux-arm-glibc.tar.gz
      npm ERR! node-pre-gyp ERR! install response status 404 Not Found on https://github.com/kelektiv/node.bcrypt.js/releases/download/v5.1.1/bcrypt_lib-v5.1.1-napi-v3-linux-arm-glibc.tar.gz
      npm ERR! node-pre-gyp WARN Pre-built binaries not installable for bcrypt@5.1.1 and node@18.17.1 (node-v108 ABI, glibc) (falling back to source compile with node-gyp)
      npm ERR! node-pre-gyp WARN Hit error response status 404 Not Found on https://github.com/kelektiv/node.bcrypt.js/releases/download/v5.1.1/bcrypt_lib-v5.1.1-napi-v3-linux-arm-glibc.tar.gz
      npm ERR! node:internal/modules/cjs/loader:1080
      npm ERR!   throw err;
      npm ERR!   ^
      npm ERR!
      npm ERR! Error: Cannot find module 'code-point-at'
      npm ERR! Require stack:
      npm ERR! - /usr/lib/node_modules/npm/node_modules/node-gyp/node_modules/string-width/index.js
      npm ERR! - /usr/lib/node_modules/npm/node_modules/node-gyp/node_modules/gauge/lib/wide-truncate.js
      npm ERR! - /usr/lib/node_modules/npm/node_modules/node-gyp/node_modules/gauge/lib/render-template.js
      npm ERR! - /usr/lib/node_modules/npm/node_modules/node-gyp/node_modules/gauge/lib/plumbing.js
      npm ERR! - /usr/lib/node_modules/npm/node_modules/node-gyp/node_modules/gauge/lib/index.js
      npm ERR! - /usr/lib/node_modules/npm/node_modules/node-gyp/node_modules/npmlog/lib/log.js
      npm ERR! - /usr/lib/node_modules/npm/node_modules/node-gyp/lib/node-gyp.js
      npm ERR! - /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js
      npm ERR!     at Module._resolveFilename (node:internal/modules/cjs/loader:1077:15)
      npm ERR!     at Module._load (node:internal/modules/cjs/loader:922:27)
      npm ERR!     at Module.require (node:internal/modules/cjs/loader:1143:19)
      npm ERR!     at require (node:internal/modules/cjs/helpers:121:18)
      npm ERR!     at Object.<anonymous> (/usr/lib/node_modules/npm/node_modules/node-gyp/node_modules/string-width/index.js:3:19)
      npm ERR!     at Module._compile (node:internal/modules/cjs/loader:1256:14)
      npm ERR!     at Module._extensions..js (node:internal/modules/cjs/loader:1310:10)
      npm ERR!     at Module.load (node:internal/modules/cjs/loader:1119:32)
      npm ERR!     at Module._load (node:internal/modules/cjs/loader:960:12)
      npm ERR!     at Module.require (node:internal/modules/cjs/loader:1143:19) {
      npm ERR!   code: 'MODULE_NOT_FOUND',
      npm ERR!   requireStack: [
      npm ERR!     '/usr/lib/node_modules/npm/node_modules/node-gyp/node_modules/string-width/index.js',
      npm ERR!     '/usr/lib/node_modules/npm/node_modules/node-gyp/node_modules/gauge/lib/wide-truncate.js',
      npm ERR!     '/usr/lib/node_modules/npm/node_modules/node-gyp/node_modules/gauge/lib/render-template.js',
      npm ERR!     '/usr/lib/node_modules/npm/node_modules/node-gyp/node_modules/gauge/lib/plumbing.js',
      npm ERR!     '/usr/lib/node_modules/npm/node_modules/node-gyp/node_modules/gauge/lib/index.js',
      npm ERR!     '/usr/lib/node_modules/npm/node_modules/node-gyp/node_modules/npmlog/lib/log.js',
      npm ERR!     '/usr/lib/node_modules/npm/node_modules/node-gyp/lib/node-gyp.js',
      npm ERR!     '/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js'
      npm ERR!   ]
      npm ERR! }
      npm ERR!
      npm ERR! Node.js v18.17.1
      npm ERR! node-pre-gyp ERR! build error
      npm ERR! node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js clean' (1)
      npm ERR! node-pre-gyp ERR! stack     at ChildProcess.<anonymous> (/opt/iobroker/node_modules/@mapbox/node-pre-gyp/lib/util/compile.js:89:23)
      npm ERR! node-pre-gyp ERR! stack     at ChildProcess.emit (node:events:514:28)
      npm ERR! node-pre-gyp ERR! stack     at maybeClose (node:internal/child_process:1091:16)
      npm ERR! node-pre-gyp ERR! stack     at ChildProcess._handle.onexit (node:internal/child_process:302:5)
      npm ERR! node-pre-gyp ERR! System Linux 5.10.103-v7l+
      npm ERR! node-pre-gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"
      npm ERR! node-pre-gyp ERR! cwd /opt/iobroker/node_modules/bcrypt
      npm ERR! node-pre-gyp ERR! node -v v18.17.1
      npm ERR! node-pre-gyp ERR! node-pre-gyp -v v1.0.11
      npm ERR! node-pre-gyp ERR! not ok
      npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-11-28T18_08_00_752Z-debug-0.log
      upload [15] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/bcrypt.min.js bcrypt.min.js application/javascript
      upload [14] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/i18n/de/translations.json i18n/de/translations.json application/json
      upload [13] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/i18n/en/translations.json i18n/en/translations.json application/json
      upload [12] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/i18n/es/translations.json i18n/es/translations.json application/json
      upload [11] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
      upload [10] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/i18n/it/translations.json i18n/it/translations.json application/json
      upload [9] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
      upload [8] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
      upload [7] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
      upload [6] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
      upload [5] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
      upload [4] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
      upload [3] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/index.html index.html text/html
      upload [2] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/index_m.html index_m.html text/html
      upload [1] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/node-red.png node-red.png image/png
      upload [0] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/words.js words.js application/javascript
      host.iobroker-slave Adapter "system.adapter.node-red.0" is started
      Ich kann damit leider nichts anfangen. Kann mir jemad helfen?
        Thomas Braun Most Active @Dillio last edited by
        @dillio
        Offenbar ist dein nodejs zu alt.
        iob nodejs-update
        Dillio 1 Reply Last reply Reply Quote 0
        • Dillio
          Dillio @Thomas Braun last edited by
          Laut System nicht:
          pi@iobroker-slave:~ $ nodejs -v
          v18.17.1
            @dillio
            Trotzdem nicht die aktuelle Version.
            • Dillio
              Wie bereits geschrieben, das System sagt was anderes:
              Es wird mir auch kein Update hierfür angezeigt. Welche Version sollte es denn sein?
                @dillio
                18.18.2
                Update wie oben geschrieben
                • Dillio
                  Du hattest Recht. Lag tatsächlich an der veralteten Nodejs Version. Ich habe es nach deiner Anleitung nochmal frisch neu installiert und dann ging es. Merkwürdig finde ich es aber trotzdem, dass mir dafür kein Update gezeigt wurde.
                  Naja, nun funktioniert wieder alles, danke! 🙂
                    @dillio sagte in Node-Red Update auf v5.0.0 | Error:
                    Da war noch das veraltete Repository aktiv.
                    Aktuelles kommt nur noch über das aktuelle Repo rein.
