    5. Material design calendar widget ical konvertierung
    • G
      grazer2500 last edited by
      Ich habe das material design widget und den ical Adapter installiert.
      Und auch soweit konfiguriert.
      Im ical Adapter werden alle Termine angezeigt. Aber bei der Visualisierung im material design calendar widget mit dem Script werden mir nicht alle Termine angezeigt.
      Welche Informationen braucht ihr um das nachzuvollziehen?
      // momentjs is required as dependecies in javascript adapter
      const moment = require("moment");
      var instances = $(`[id=ical.*.data.table]`);
      instances.on(ical2CalendarWidget);
      // remove this, if you know to use your own datapoint
      let datapointId = 'materialdesignwidgets.calendar.ical2calendar'
      createState(datapointId, "[]", {
        read: true,
        write: false,
        desc: "JSON String for Calendar Widget",
        type: "string",
        def: "[]"
      function ical2CalendarWidget() {
          try {
              let calList = [];
              for (var inst = 0; inst <= instances.length - 1; inst++) {
                  let icalObj = getState(instances[inst]).val;
                  if (icalObj) {
                      for (var i = 0; i <= icalObj.length - 1; i++) {
                          let item = icalObj[i];
                          // extract calendar color
                          let calendarName = item._class.split(' ')[0].replace('ical_', '');
                          let startTime = moment(item._date);
                          let endTime = moment(item._end);
                          let start = startTime.format("YYYY-MM-DD HH:mm");
                          let end = endTime.format("YYYY-MM-DD HH:mm");
                          if (startTime.format('HH:mm') === '00:00' && endTime.format('HH:mm') === '00:00') {
                              // is full-day event
                              if (endTime.diff(startTime, 'hours') === 24) {
                                  // full-day event, one day
                                  start = startTime.format("YYYY-MM-DD");
                                  end = startTime.format("YYYY-MM-DD");
                              } else {
                                  // full-day event, multiple days
                                  end = endTime.format("YYYY-MM-DD");
                          // create object for calendar widget
                          calList.push({
                              color: getMyCalendarColor(calendarName),
                              colorText: getMyCalendarTextColor(calendarName),
                              start: start,
                              end: end
                      function getMyCalendarColor(calendarName) {
                          // assign colors via the calendar names, use calendar name as set in ical
                          if (calendarName === 'calendar1') {
                              return '#FF0000';
                          } else if (calendarName === 'calendar2') {
                              return '#44739e'
                          } else if (calendarName === 'calendar3') {
                              return '#32a852'
                      function getMyCalendarTextColor(calendarName) {
                              return '#FFFFFF';
                              return '#FFFFFF'
                              return '#FFFFFF'
                  // Enter the destination data point that is to be used as object ID in the widget
                  setState(datapointId, JSON.stringify(calList), true);
          } catch (e) {
              console.error(`ical2MaterialDesignCalendarWidget: message: ${e.message}, stack: ${e.stack}`);
      ical2CalendarWidget();
      Habe alle Termine zensiert, sollte aber erkennbar sein das viele fehlen
      Bildschirmfoto vom 2023-11-29 10-06-54.png Bildschirmfoto vom 2023-11-29 10-07-21.png Bildschirmfoto vom 2023-11-29 10-07-08.png
