    4. SmartControladapter hängt *gelöst*
    • G
      gluecksmann last edited by gluecksmann
      smartcontrol.0
      	2023-12-01 07:41:07.221	warn	Issue #1: [Config Table 'Target Devices'] State 'hue.0.Keller_Switch_LED_Blau.on' does not exist.
      smartcontrol.0
      	2023-12-01 07:41:07.220	error	[User Error (Anwenderfehler)] - 1 error(s) found in adapter configuration. You must fix these issue(s) to use this adapter.
      smartcontrol.0
      	2023-12-01 07:41:06.717	info	starting. Version 2.0.1 in /opt/iobroker/node_modules/iobroker.smartcontrol, node: v16.20.2, js-controller: 5.0.16
      smartcontrol.0
      	2023-12-01 07:41:00.947	info	terminating
      smartcontrol.0
      	2023-12-01 07:41:00.444	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      smartcontrol.0
      	2023-12-01 07:41:00.439	info	terminating
      smartcontrol.0
      	2023-12-01 07:41:00.438	info	Stopping adapter instance successfully proceeded...
      smartcontrol.0
      	2023-12-01 07:41:00.436	info	(0) schedules cleared...
      smartcontrol.0
      	2023-12-01 07:41:00.435	info	(0) timers were active and have been cleared...
      smartcontrol.0
      	2023-12-01 07:41:00.429	info	Got terminate signal TERMINATE_YOURSELF
      smartcontrol.0
      	2023-12-01 07:40:11.654	warn	Issue #1: [Config Table 'Target Devices'] State 'hue.0.Keller_Switch_LED_Blau.on' does not exist.
      smartcontrol.0
      	2023-12-01 07:40:11.652	error	[User Error (Anwenderfehler)] - 1 error(s) found in adapter configuration. You must fix these issue(s) to use this adapter.
      smartcontrol.0
      	2023-12-01 07:40:11.019	info	starting. Version 2.0.1 in /opt/iobroker/node_modules/iobroker.smartcontrol, node: v16.20.2, js-controller: 5.0.16
      Guten Morgen, auch wenn ich IOBroker schon lange nutze, denke ich das mein Niveau imme noch eines Anfängers würdig ist 😉 Was möchte mir dieses Log sagen?
      Thomas Braun Codierknecht 2 Replies Last reply Reply Quote 0
        Thomas Braun Most Active @gluecksmann last edited by Thomas Braun
        @gluecksmann sagte in SmartControladapter hängt:
        node: v16.20.2
        Losgelöst vom Fehler in deiner Konfiguration:
        Bring das auf nodejs@18.
        iob stop
        iob fix
        iob nodejs-update
        • Codierknecht
          Codierknecht Developer Most Active @gluecksmann last edited by
          Dass ein bestimmter DP nicht existiert?
          G 2 Replies Last reply Reply Quote 0
          • G
            gluecksmann @Codierknecht last edited by
            @codierknecht
            Ich forsche gerade...danke ...
            • G
              @codierknecht
              Datenpunkt gefunden...gelöscht.. läuft... DAs Update mache ich gerade... Danke für eure Hilfe
