    4. Gelöst: Instanz lässt sich nur auf .1 anlegen
      MartyBr last edited by MartyBr
      Ich versuche gerade den Adapter Viessmann (VControld) wieder neu zu installieren. Als Instanz wird immer die .1 angelegt. Eine Auswahl über den Admin-Modus auf .0 wird nicht angelegt.
      Der Adapter lief früher ohne Probleme. Ich hatte ihn (leider) entfernt.
      • Instanz entfernt
      • Adapter entfernt
      Das hat bisher immer reibungslos funktioniert.
      Anbei das iob Diagnose File:
      iob_diag.log
      *** iob diag is starting up, please wait ***
      *** ioBroker Diagnosis ***
      Please stretch the window of your terminal programm (puTTY) as wide as possible or switch to full screen
      The following checks may give hints to potential malconfigurations or errors, please post them in our forum:
      https://forum.iobroker.net
      Just copy and paste the Summary Page, including the ``` characters at start and end.
      It helps us to help you!
      Press any key to continue
      Skript v.2023-10-10
      *** BASE SYSTEM ***
       Static hostname: iobroker
             Icon name: computer-container
               Chassis: container ☐
        Virtualization: lxc
                Kernel: Linux 6.5.11-6-pve
          Architecture: x86-64
      model name	: Intel(R) Core(TM) i5-8259U CPU @ 2.30GHz
      Docker          : false
      Virtualization  : lxc
      Kernel          : x86_64
      Userland        : amd64
      Systemuptime and Load:
       12:25:56 up 23:02,  2 users,  load average: 0.46, 0.62, 0.79
      CPU threads: 4
      *** Time and Time Zones ***
                     Local time: Fri 2023-12-01 12:25:56 CET
                 Universal time: Fri 2023-12-01 11:25:56 UTC
                       RTC time: n/a
                    NTP service: inactive
                RTC in local TZ: no
      *** User and Groups ***
      martin
      /home/martin
      martin sudo iobroker
      *** X-Server-Setup ***
      X-Server: 	false
      Desktop:
      Terminal: 	tty
      Boot Target: 	graphical.target
      *** MEMORY ***
      Mem:             10G        4.3G        5.8G        143K        467M        6.2G
      Swap:           5.2G          0B        5.2G
      Total:           15G        4.3G         11G
              10000 M total memory
               4053 M used memory
               3986 M active memory
                276 M inactive memory
               5500 M free memory
                  0 M buffer memory
                445 M swap cache
               5000 M total swap
                  0 M used swap
               5000 M free swap
      *** FAILED SERVICES ***
        UNIT                 LOAD   ACTIVE SUB    DESCRIPTION
      * run-rpc_pipefs.mount loaded failed failed RPC Pipe File System
      1 loaded units listed.
      *** FILESYSTEM ***
      Filesystem                       Type      Size  Used Avail Use% Mounted on
      /dev/mapper/pve-vm--100--disk--0 ext4       44G  4.9G   37G  12% /
      none                             tmpfs     492K  4.0K  488K   1% /dev
      udev                             devtmpfs   16G     0   16G   0% /dev/tty
      tmpfs                            tmpfs      16G     0   16G   0% /dev/shm
      tmpfs                            tmpfs     6.3G  136K  6.3G   1% /run
      tmpfs                            tmpfs     5.0M     0  5.0M   0% /run/lock
      tmpfs                            tmpfs     3.2G     0  3.2G   0% /run/user/1000
      TARGET SOURCE                           FSTYPE OPTIONS
      /      /dev/mapper/pve-vm--100--disk--0 ext4   rw,relatime,stripe=16
      /var:
      444M	/var/
      215M	/var/lib
      178M	/var/cache
      173M	/var/cache/apt
      140M	/var/lib/apt/lists
      Archived and active journals take up 13.0M in the file system.
      /opt/iobroker/backups:
      98M	/opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      1.2G	/opt/iobroker/iobroker-data/
      732M	/opt/iobroker/iobroker-data/files
      268M	/opt/iobroker/iobroker-data/backup-objects
      152M	/opt/iobroker/iobroker-data/files/vis.0
      90M	/opt/iobroker/iobroker-data/files/echarts.admin
      141M	/opt/iobroker/iobroker-data/objects.jsonl
      24M	/opt/iobroker/iobroker-data/files/echarts/static/js/main.5f66c5d9.js.map
      24M	/opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.9f2a6569.js.map
      24M	/opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.5f66c5d9.js.map
      21M	/opt/iobroker/iobroker-data/files/web.admin/static/js/main.e564fb87.js.map
      USB-Devices by-id:
      *** NodeJS-Installation ***
      /usr/bin/nodejs 	v18.19.0
      /usr/bin/node 		v18.19.0
      /usr/bin/npm 		10.2.3
      /usr/bin/npx 		10.2.3
      /usr/bin/corepack 	0.22.0
      nodejs:
        Installed: 18.19.0-1nodesource1
        Candidate: 18.19.0-1nodesource1
        Version table:
       *** 18.19.0-1nodesource1 500
              500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
              100 /var/lib/dpkg/status
           18.18.2-1nodesource1 500
           18.18.1-1nodesource1 500
           18.18.0-1nodesource1 500
           18.17.1-1nodesource1 500
           18.17.0-1nodesource1 500
           18.16.1-1nodesource1 500
           18.16.0-1nodesource1 500
           18.15.0-1nodesource1 500
           18.14.2-1nodesource1 500
           18.14.1-1nodesource1 500
           18.14.0-1nodesource1 500
           18.13.0+dfsg1-1 500
              500 http://deb.debian.org/debian bookworm/main amd64 Packages
           18.13.0-1nodesource1 500
           18.12.0-1nodesource1 500
           18.11.0-1nodesource1 500
           18.10.0-1nodesource1 500
           18.9.1-1nodesource1 500
           18.9.0-1nodesource1 500
           18.8.0-1nodesource1 500
           18.7.0-1nodesource1 500
           18.6.0-1nodesource1 500
           18.5.0-1nodesource1 500
           18.4.0-1nodesource1 500
           18.3.0-1nodesource1 500
           18.2.0-1nodesource1 500
           18.1.0-1nodesource1 500
           18.0.0-1nodesource1 500
      No problems detected
      Errors in npm tree:
      *** ioBroker-Installation ***
      ioBroker Status
      At least one iobroker host is running.
      Objects type: redis
      States  type: redis
      Core adapters versions
      js-controller: 	5.0.16
      admin: 		6.12.0
      javascript: 	7.1.6
      Adapters from github: 	0
      Adapter State
      + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      + system.adapter.alarm.0                  : alarm                 : iobroker                                 -  enabled
      + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
      + system.adapter.ble.0                    : ble                   : ioBroker-RasPi                           -  enabled
      + system.adapter.bring.0                  : bring                 : iobroker                                 -  enabled
        system.adapter.daswetter.0              : daswetter             : iobroker                                 -  enabled
      + system.adapter.device-reminder.0        : device-reminder       : iobroker                                 -  enabled
        system.adapter.device-watcher.0         : device-watcher        : iobroker                                 - disabled
      + system.adapter.doorbird.0               : doorbird              : iobroker                                 -  enabled
        system.adapter.dwd.0                    : dwd                   : iobroker                                 - disabled
      + system.adapter.echarts.0                : echarts               : iobroker                                 -  enabled
      + system.adapter.email.0                  : email                 : iobroker                                 -  enabled
      + system.adapter.enocean.0                : enocean               : iobroker-usb                             -  enabled
      + system.adapter.epson_ecotank_et_2750.0  : epson_ecotank_et_2750 : iobroker-usb                             -  enabled
      + system.adapter.eventlist.0              : eventlist             : iobroker                                 -  enabled
      + system.adapter.fb-checkpresence.0       : fb-checkpresence      : iobroker                                 -  enabled
        system.adapter.feiertage.0              : feiertage             : iobroker                                 -  enabled
        system.adapter.flot.0                   : flot                  : iobroker                                 - disabled
      + system.adapter.fullybrowser.0           : fullybrowser          : iobroker                                 -  enabled
      + system.adapter.geofency.0               : geofency              : iobroker-usb                             -  enabled, port: 7999, bind: 0.0.0.0
      + system.adapter.harmony.0                : harmony               : iobroker                                 -  enabled
      + system.adapter.hm-rega.0                : hm-rega               : iobroker                                 -  enabled
      + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 -  enabled, port: 0
      + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker                                 -  enabled, port: 0
      + system.adapter.hm-rpc.2                 : hm-rpc                : iobroker                                 -  enabled, port: 0
      + system.adapter.hm-rpc.3                 : hm-rpc                : iobroker                                 -  enabled, port: 0
      + system.adapter.homeconnect.0            : homeconnect           : iobroker                                 -  enabled
        system.adapter.homekit-controller.0     : homekit-controller    : iobroker-usb                             - disabled
        system.adapter.ical.0                   : ical                  : iobroker                                 - disabled
        system.adapter.ical.1                   : ical                  : iobroker                                 -  enabled
        system.adapter.ical.2                   : ical                  : iobroker                                 -  enabled
        system.adapter.ical.3                   : ical                  : iobroker                                 -  enabled
        system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : iobroker                                 - disabled
        system.adapter.icons-icons8.0           : icons-icons8          : iobroker                                 - disabled
        system.adapter.icons-material-png.0     : icons-material-png    : iobroker                                 - disabled
        system.adapter.icons-material-svg.0     : icons-material-svg    : iobroker                                 - disabled
        system.adapter.icons-mfd-png.0          : icons-mfd-png         : iobroker                                 - disabled
        system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 - disabled
      + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
      + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
      + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
      + system.adapter.javascript.1             : javascript            : iobroker                                 -  enabled
      + system.adapter.kostal-piko-ba.0         : kostal-piko-ba        : iobroker                                 -  enabled
      + system.adapter.lightcontrol.0           : lightcontrol          : iobroker                                 -  enabled
        system.adapter.linux-control.0          : linux-control         : iobroker                                 - disabled
      + system.adapter.logparser.0              : logparser             : iobroker                                 -  enabled
        system.adapter.luftdaten.0              : luftdaten             : iobroker-usb                             -  enabled
        system.adapter.meteoalarm.0             : meteoalarm            : iobroker                                 - disabled
      + system.adapter.modbus.0                 : modbus                : iobroker                                 -  enabled
      + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 192.168.178.100
      + system.adapter.nina.0                   : nina                  : iobroker                                 -  enabled
      + system.adapter.nuki-extended.0          : nuki-extended         : iobroker                                 -  enabled
      + system.adapter.nut.0                    : nut                   : iobroker                                 -  enabled
        system.adapter.odl.0                    : odl                   : iobroker                                 -  enabled
      + system.adapter.parcel.0                 : parcel                : iobroker                                 -  enabled
      + system.adapter.pollenflug.0             : pollenflug            : iobroker                                 -  enabled
      + system.adapter.proxmox.0                : proxmox               : iobroker                                 -  enabled, port: 8006
      + system.adapter.pushover.0               : pushover              : iobroker                                 -  enabled
      + system.adapter.pvforecast.0             : pvforecast            : iobroker                                 -  enabled
      + system.adapter.rest-api.0               : rest-api              : iobroker                                 -  enabled, port: 8093, bind: 192.168.178.100, run as: rest-api
      + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
      + system.adapter.shuttercontrol.0         : shuttercontrol        : iobroker                                 -  enabled
      + system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
      + system.adapter.smartcontrol.0           : smartcontrol          : iobroker                                 -  enabled
      + system.adapter.smartmeter.0             : smartmeter            : ioBroker-RasPi                           -  enabled
      + system.adapter.sourceanalytix.0         : sourceanalytix        : iobroker                                 -  enabled
      + system.adapter.sprinklecontrol.0        : sprinklecontrol       : iobroker-usb                             -  enabled
      + system.adapter.statistics.0             : statistics            : iobroker                                 -  enabled
        system.adapter.synology.0               : synology              : iobroker                                 - disabled, port: 5001
      + system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker                                 -  enabled
      + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
      + system.adapter.text2command.0           : text2command          : iobroker                                 -  enabled
      + system.adapter.time-switch.0            : time-switch           : iobroker                                 -  enabled
      + system.adapter.tr-064.0                 : tr-064                : iobroker                                 -  enabled
        system.adapter.traccar.0                : traccar               : iobroker                                 - disabled
      + system.adapter.trashschedule.0          : trashschedule         : iobroker                                 -  enabled
        system.adapter.trashschedule.1          : trashschedule         : iobroker                                 - disabled
      + system.adapter.tvprogram.0              : tvprogram             : iobroker                                 -  enabled
        system.adapter.tvspielfilm.0            : tvspielfilm           : iobroker                                 -  enabled
      + system.adapter.viessmann.1              : viessmann             : iobroker                                 -  enabled, port: 3002
        system.adapter.viessmannapi.0           : viessmann             : iobroker                                 - disabled, port: 3002
        system.adapter.vis-bars.0               : vis-bars              : iobroker                                 - disabled
        system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : iobroker                                 - disabled
        system.adapter.vis-colorpicker.0        : vis-colorpicker       : iobroker                                 - disabled
        system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : iobroker                                 - disabled
        system.adapter.vis-history.0            : vis-history           : iobroker                                 - disabled
        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 - disabled
        system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker                                 - disabled
      + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
        system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker                                 - disabled
        system.adapter.vis-justgage.0           : vis-justgage          : iobroker                                 - disabled
        system.adapter.vis-keyboard.0           : vis-keyboard          : iobroker                                 - disabled
        system.adapter.vis-material-advanced.0  : vis-material-advanced : iobroker                                 - disabled
        system.adapter.vis-material-webfont.0   : vis-material-webfont  : iobroker                                 - disabled
        system.adapter.vis-material.0           : vis-material          : iobroker                                 - disabled
        system.adapter.vis-materialdesign.0     : vis-materialdesign    : iobroker                                 - disabled
        system.adapter.vis-metro.0              : vis-metro             : iobroker                                 - disabled
        system.adapter.vis-players.0            : vis-players           : iobroker                                 - disabled
        system.adapter.vis-plumb.0              : vis-plumb             : iobroker                                 - disabled
        system.adapter.vis-rgraph.0             : vis-rgraph            : iobroker                                 - disabled
        system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 - disabled
        system.adapter.vis-weather.0            : vis-weather           : iobroker                                 - disabled
        system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
      + system.adapter.weather-warnings.0       : weather-warnings      : iobroker                                 -  enabled
        system.adapter.weatherunderground.0     : weatherunderground    : iobroker                                 -  enabled
      + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      + system.adapter.wireless-mbus.0          : wireless-mbus         : ioBroker-RasPi                           -  enabled
        system.adapter.worx.0                   : worx                  : iobroker-usb                             - disabled
      + system.adapter.ws.0                     : ws                    : iobroker                                 -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
      + system.adapter.yahka.0                  : yahka                 : iobroker-usb                             -  enabled
      + system.adapter.yamaha.0                 : yamaha                : iobroker-usb                             -  enabled
      + system.adapter.zigbee2mqtt.0            : zigbee2mqtt           : iobroker-usb                             -  enabled
      + system.adapter.zwave2.0                 : zwave2                : iobroker-usb                             -  enabled
      + instance is alive
      ioBroker-Repositories
      Stable (default): http://download.iobroker.net/sources-dist.json
      Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
      Installed ioBroker-Instances
      Adapter    "alarm"        : 3.4.3    , installed 3.4.3
      Adapter    "alexa2"       : 3.26.3   , installed 3.26.3
      Adapter    "bring"        : 1.8.4    , installed 1.8.4
      Adapter    "daswetter"    : 3.1.10   , installed 3.1.11
      Adapter    "device-reminder": 3.0.0  , installed 3.0.0
      Adapter    "device-watcher": 2.9.6   , installed 2.9.6
      Adapter    "doorbird"     : 1.3.0    , installed 1.3.0
      Adapter    "echarts"      : 1.5.4    , installed 1.5.4
      Adapter    "email"        : 1.2.0    , installed 1.2.0
      Adapter    "epson_ecotank_et_2750": 0.0.12, installed 0.0.12
      Adapter    "eventlist"    : 2.0.0    , installed 2.0.0
      Adapter    "fb-checkpresence": 1.2.2 , installed 1.2.2
      Adapter    "feiertage"    : 1.1.4    , installed 1.1.4
      Adapter    "fullybrowser" : 3.0.6    , installed 3.0.7
      Adapter    "harmony"      : 1.3.0    , installed 1.3.0
      Adapter    "homeconnect"  : 1.1.1    , installed 1.1.1
      Adapter    "icons-material-svg": 0.1.0, installed 0.1.0
      Adapter    "icons-mfd-png": 1.1.0    , installed 1.1.0
      Adapter    "influxdb"     : 3.2.0    , installed 3.2.0
      Adapter    "iot"          : 2.0.11   , installed 2.0.11
      Adapter    "javascript"   : 7.1.6    , installed 7.1.6
      Controller "js-controller": 5.0.16   , installed 5.0.16
      Adapter    "kostal-piko-ba": 3.0.8   , installed 3.0.8
      Adapter    "lightcontrol" : 0.4.0    , installed 0.4.0
      Adapter    "linux-control": 1.1.5    , installed 1.1.5
      Adapter    "logparser"    : 2.2.0    , installed 2.2.0
      Adapter    "luftdaten"    : 3.1.0    , installed 3.1.0
      Adapter    "meteoalarm"   : 2.3.7    , installed 2.3.7
      Adapter    "modbus"       : 5.0.11   , installed 5.0.11
      Adapter    "mqtt"         : 5.1.0    , installed 5.1.0
      Adapter    "nina"         : 0.0.25   , installed 0.0.26
      Adapter    "nuki-extended": 2.6.5    , installed 2.6.5
      Adapter    "nut"          : 1.6.0    , installed 1.6.0
      Adapter    "odl"          : 3.0.1    , installed 3.0.1
      Adapter    "parcel"       : 0.0.27   , installed 0.2.2
      Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
      Adapter    "proxmox"      : 2.2.1    , installed 2.2.1
      Adapter    "pushover"     : 3.0.3    , installed 3.0.3
      Adapter    "pvforecast"   : 2.9.0    , installed 2.9.0
      Adapter    "rest-api"     : 1.1.0    , installed 1.1.0
      Adapter    "shelly"       : 6.6.1    , installed 6.6.1
      Adapter    "shuttercontrol": 1.6.3   , installed 1.6.3
      Adapter    "smartcontrol" : 2.0.1    , installed 2.0.1
      Adapter    "sprinklecontrol": 0.2.13 , installed 0.2.13
      Adapter    "statistics"   : 2.4.0    , installed 2.4.0
      Adapter    "synology"     : 3.0.1    , installed 3.0.1
      Adapter    "telegram"     : 2.0.1    , installed 2.0.1
      Adapter    "text2command" : 3.0.2    , installed 3.0.2
      Adapter    "traccar"      : 1.1.4    , installed 1.1.4
      Adapter    "trashschedule": 2.3.0    , installed 2.3.0
      Adapter    "tvprogram"    : 1.1.2    , installed 1.1.2
      Adapter    "tvspielfilm"  : 2.0.5    , installed 2.0.5
      Adapter    "viessmann"    : 1.4.6    , installed 1.4.6
      Adapter    "viessmannapi" : 2.3.0    , installed 2.3.2
      Adapter    "vis"          : 1.4.16   , installed 1.4.16
      Adapter    "vis-icontwo"  : 0.97.1   , installed 0.97.1
      Adapter    "vis-justgage" : 2.0.2    , installed 2.0.2
      Adapter    "vis-keyboard" : 0.0.2    , installed 0.0.2
      Adapter    "vis-material" : 0.1.3    , installed 0.1.3
      Adapter    "vis-weather"  : 2.5.6    , installed 2.5.6
      Adapter    "weather-warnings": 0.6.2 , installed 0.6.2
      Adapter    "weatherunderground": 3.6.0, installed 3.6.0
      Adapter    "web"          : 6.1.10   , installed 6.1.10
      Adapter    "ws"           : 2.5.8    , installed 2.5.8
      Adapter    "yamaha"       : 0.5.3    , installed 0.5.3
      Objects and States
      Objects: 	58370
      States: 	53858
      Hit:1 http://security.debian.org/debian-security bookworm-security InRelease
      Hit:2 http://deb.debian.org/debian bookworm InRelease
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 192.168.178.100:2001    0.0.0.0:*               LISTEN      1001       5550858    949693/io.hm-rpc.1
      tcp        0      0 192.168.178.100:2010    0.0.0.0:*               LISTEN      1001       5554135    949783/io.hm-rpc.2
      tcp        0      0 192.168.178.100:8100    0.0.0.0:*               LISTEN      1001       5568916    952431/io.doorbird.
      tcp        0      0 192.168.178.100:8093    0.0.0.0:*               LISTEN      1001       5565177    952002/io.rest-api.
      tcp        0      0 192.168.178.100:8701    0.0.0.0:*               LISTEN      1001       5559440    950117/io.hm-rpc.0
      tcp        0      0 192.168.178.100:9292    0.0.0.0:*               LISTEN      1001       5557312    949798/io.hm-rpc.3
      tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          47338      327/master
      tcp        0      0 0.0.0.0:1080            0.0.0.0:*               LISTEN      1000       5623651    962394/nc
      tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          45436      1/init
      tcp6       0      0 :::61991                :::*                    LISTEN      1001       5558576    950502/io.harmony.0
      tcp6       0      0 ::1:25                  :::*                    LISTEN      0          47339      327/master
      tcp6       0      0 :::8084                 :::*                    LISTEN      1001       5564700    951498/io.ws.0
      tcp6       0      0 :::8087                 :::*                    LISTEN      1001       5564626    951434/io.simple-ap
      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       5553660    949217/io.admin.0
      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       5560299    951044/io.web.0
      tcp6       0      0 :::111                  :::*                    LISTEN      0          45438      1/init
      tcp6       0      0 :::22                   :::*                    LISTEN      0          47232      1/init
      tcp6       0      0 :::51989                :::*                    LISTEN      1001       5561602    950611/io.nuki-exte
      tcp6       0      0 :::3000                 :::*                    LISTEN      1001       5564634    951453/io.fullybrow
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           106        45537      106/avahi-daemon: r
      udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       5553115    949753/io.shelly.0
      udp        0      0 0.0.0.0:61991           0.0.0.0:*                           1001       5558577    950502/io.harmony.0
      udp        0      0 0.0.0.0:45710           0.0.0.0:*                           106        45539      106/avahi-daemon: r
      udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          45437      1/init
      udp        0      0 0.0.0.0:50005           0.0.0.0:*                           1001       5552640    948904/iobroker.js-
      udp6       0      0 :::5353                 :::*                                106        45538      106/avahi-daemon: r
      udp6       0      0 :::111                  :::*                                0          45439      1/init
      udp6       0      0 :::49591                :::*                                106        45540      106/avahi-daemon: r
      2023-12-01 12:15:58.664  - info: viessmann.1 (951331) Got terminate signal TERMINATE_YOURSELF
      2023-12-01 12:15:58.665  - info: viessmann.1 (951331) cleaned everything up...
      2023-12-01 12:15:58.665  - info: viessmann.1 (951331) terminating
      2023-12-01 12:15:58.666  - info: viessmann.1 (951331) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2023-12-01 12:15:58.666  - info: viessmann.1 (951331) Connection with Viessmann system disconnected!
      2023-12-01 12:15:59.166  - info: viessmann.1 (951331) terminating
      2023-12-01 12:16:02.598  - info: viessmann.1 (954492) starting. Version 1.4.6 in /opt/iobroker/node_modules/iobroker.viessmann, node: v18.19.0, js-controller: 5.0.16
      2023-12-01 12:16:02.616  - info: viessmann.1 (954492) Connect with Viessmann sytem!
      2023-12-01 12:18:03.571  - info: viessmann.1 (954492) State value to set for "viessmann.1.get.StatusV1" has to be type "string" but received type "number"
      2023-12-01 12:18:03.635  - info: viessmann.1 (954492) State value to set for "viessmann.1.get.StatusPumpe" has to be type "string" but received type "number"
      2023-12-01 12:18:03.799  - info: viessmann.1 (954492) State value to set for "viessmann.1.get.StatusPumpeZirk" has to be type "string" but received type "number"
      2023-12-01 12:20:02.671  - info: viessmann.1 (954492) State value to set for "viessmann.1.get.StatusV1" has to be type "string" but received type "number"
      2023-12-01 12:20:03.710  - info: viessmann.1 (954492) State value to set for "viessmann.1.get.StatusPumpe" has to be type "string" but received type "number"
      2023-12-01 12:20:03.866  - info: viessmann.1 (954492) State value to set for "viessmann.1.get.StatusPumpeZirk" has to be type "string" but received type "number"
      iob diag has finished.
      Press any key for a summary
      Copy text starting here:
      			v.2023-10-10
        Virtualization: lxc
      Installation: 		lxc
      Kernel: 		x86_64
      Userland: 		amd64
      Timezone: 		Europe/Berlin (CET, +0100)
      User-ID: 		1000
      X-Server: 		false
      Pending OS-Updates: 	0
      Pending iob updates: 	0
      Nodejs-Installation: 	/usr/bin/nodejs 	v18.19.0
      			/usr/bin/npm 		10.2.3
      			/usr/bin/npx 		10.2.3
      Recommended versions are nodejs 18.19.0 and npm 10.2.3
      MEMORY:
      Mem:             10G        4.3G        5.6G        143K        639M        6.2G
      Swap:           5.2G          0B        5.2G
      Total:           15G        4.3G         10G
      Active iob-Instances: 	66
      ioBroker Core: 		js-controller 		5.0.16
      			admin 			6.12.0
      ioBroker Status: 	iobroker is running on this host.
      Objects type: redis
      States  type: redis
      Objects: 		58370
      States: 		53858
      Size of iob-Database:
      52K	/opt/iobroker/iobroker-data/states.jsonl
      === Mark text until here for copying ===
        MartyBr @MartyBr last edited by
        @martybr
        Ich konnte das Problem lösen.
        Instanz und Adapter gelöscht, iob gestoppt und iob fix laufen lassen.
        Nun liess sich die Instanz auf Viessmann.0 installieren.
