    4. RPI2 - GPIO is not initialized
    • Thisoft
      Thisoft last edited by
      Systemdata Bitte Ausfüllen
      Hardwaresystem: Raspberry Pi 2 Model B Rev 1.1
      Arbeitsspeicher: 1GB
      Festplattenart: SD-Karte
      Betriebssystem: Linux 9 (stretch)
      Node-Version: 16.20.1
      Nodejs-Version: 16.20.1
      NPM-Version: 8.19.4
      Installationsart: Skript - Slave
      Image genutzt: Nein
      Weitere Software: pivCCU
      wie im Thema angegeben bekomme ich die GPIO's nicht mehr zum Laufen. Folgendes Log beim Start des RPI2-Adapters:
      admin.0
      	2023-12-02 17:49:21.116	warn	Cannot read file ("rpi2.admin"/"rpi.png"): Not exists
      admin.0
      	2023-12-02 17:49:21.081	warn	Cannot read file ("rpi2.admin"/"rpi.png"): Not exists
      rpi2.0
      	2023-12-02 17:49:20.794	error	Cannot initialize/setMode GPIO: Error: Could not locate the bindings file. Tried: → /opt/iobroker/node_modules/rpi-gpio/node_modules/epoll/build/epoll.node → /opt/iobroker/node_modules/rpi-gpio/node_modules/epoll/build/Debug/epoll.node → /opt/iobroker/node_modules/rpi-gpio/node_modules/epoll/build/Release/epoll.node → /opt/iobroker/node_modules/rpi-gpio/node_modules/epoll/out/Debug/epoll.node → /opt/iobroker/node_modules/rpi-gpio/node_modules/epoll/Debug/epoll.node → /opt/iobroker/node_modules/rpi-gpio/node_modules/epoll/out/Release/epoll.node → /opt/iobroker/node_modules/rpi-gpio/node_modules/epoll/Release/epoll.node → /opt/iobroker/node_modules/rpi-gpio/node_modules/epoll/build/default/epoll.node → /opt/iobroker/node_modules/rpi-gpio/node_modules/epoll/compiled/16.20.1/linux/arm/epoll.node → /opt/iobroker/node_modules/rpi-gpio/node_modules/epoll/addon-build/release/install-root/epoll.node → /opt/iobroker/node_modules/rpi-gpio/node_modules/epoll/addon-build/debug/install-root/epoll.node → /opt/iobroker/node_modules/rpi-gpio/node_modules/epoll/addon-build/default/install-root/epoll.node → /opt/iobroker/node_modules/rpi-gpio/node_modules/epoll/lib/binding/node-v93-linux-arm/epoll.node
      Außerdem - wenn ich die Einstellungen des RPI2-Adapters aufrufen will erhalte ich einen "Fehler 404".
      Rebuild des Adapters hab ich bereits gemacht. Was könnte ich noch tun? Oder ist meine Linux-Version zu alt dafür? Weiß auch nicht genau seit welchem Update oder so das nicht mehr funktioniert - brauche die GPIO's halt nur zu Weihnachten... dafür jetzt um so dringender 😞
      Vielen Dank schon mal...
        Homoran Global Moderator Administrators @Thisoft last edited by
        @thisoft sagte in RPI2 - GPIO is not initialized:
        Linux 9 (stretch)
        ist das dein Ernst?
        wir sind bei 12 (bookworm)
        für 9 gibt's nix mehr
        Thisoft 1 Reply Last reply Reply Quote 0
        • Thisoft
          Thisoft @Homoran last edited by
          Ja, ist mein Ernst. Ist ja "nur" n Slave und lief bis jetzt unauffällig. Außerdem scheue ich mich vor Linux-Upgrades weil ich da bisher schon mehrmals den Fall hatte dass die Kiste Schrott war und ich komplett neu aufsetzen musste 😞 Läuft das Aktuelle dann überhaupt noch auf dem Pi2?
          Außerdem - ist es möglich in kurzen Worten zu erklären warum da jetzt plötzlich der GPIO-Zugriff nicht mehr funktioniert?
            Thomas Braun Most Active @Thisoft last edited by
            @thisoft
            Installier da was lebendiges.
              Homoran Global Moderator Administrators @Thisoft last edited by Homoran
              warum nicht?
              EDIT:
              lediglich 64Bit gehen nicht bei pi2
              sieh mal mit sudo raspi-config nach
              • Thisoft
                @homoran sagte in RPI2 - GPIO is not initialized:
                Hmm, hab ich gemacht und hab da den "Remote-Access for GPIO" Enabled was angeblich auch erfolgreich war. Aber nach verlassen des Config-Tools kam diese Fehlermeldung:
                pi@piPivCCU:~ $ sudo raspi-config
                Failed to get unit file state for pigpiod.service: No such file or directory
                Mag ja sein dass mein System nicht ganz frisch ist... trotzdem würde ich gern verstehen wieso das voriges Jahr noch funktioniert hat und jetzt nicht mehr...
                  @thisoft
                  Weil dein System tot ist wird da nichts mehr dran getan. Bei den gpios wurde da in den letzen Jahren was umgestellt, bei deiner Antiquität aber nicht mehr.
                  Installier es neu...
                  • Thisoft
                    Thisoft @Thomas Braun last edited by
                    Tja - dann frag ich mich nur mal wieder warum Linux-Jünger immer behaupten dass Linux gerade für so Steuerungs-Systeme vieeel besser wäre als Windows? Wegen der Windows-Updates wird ja gemunkelt - aber wenn bei Linux auch ständig dranrum-geupdatet werden muss... wo ist da der Vorteil?
                      Thomas Braun Most Active @Thisoft last edited by Thomas Braun
                      Das ständig Verbesserungen einfließen ist der Vorteil.
                      Du partizipierst daran, wenn du dein System pflegen würdest.
                      Ist so ähnlich wie mit einem Auto, das will auch gewartet werden. Bei Oldtimern wird das aber zunehmend schwerer mit passenden Teilen.
                      Hier vermute ich, daß ein aktuelles 'raspi-config' aus dem raspberryOS stable verwendet wird. Das setzt aber auch voraus, das das Betriebssystem auch stable ist und nicht wie bei dir mausetot.
                      Nein, 'never tatsch ä rannink süstähm' war noch nie richtig.
                      • Thisoft
                        So, der ioBroker-Slave auf dem neuen Bookworm-System läuft wieder. Ist ja schön dass ständig verbessert wird - macht es aber nicht unbedingt einfacher wenn es inzwischen gefühlt 10 verschiedene Möglichkeiten gibt eine feste IP und sonstige Netzwerkeinstellungen zu definieren. Wobei das nmcli ja schon nicht schlecht ist, man muss nur mal wieder alles anders machen 😉 Damit sind wir bei meinem Problem was ich noch habe - die piVCCU läuft zwar, ist aber von außen nicht erreichbar was entsprechend der IP-Konfiguration für mich auch erklärbar ist - ich bin aber mit meinem Latein etwas am Ende wie ich jetzt die Bridge definieren müsste, habe auch im einschlägigen Forum noch keine Anleitung für nmcli gefunden... 🙂 Kann mir hier jemand vielleicht mehr dazu sagen?
                        pi@piPivCCU:~ $ sudo systemctl status pivccu
                        ● pivccu.service - piVCCU
                             Loaded: loaded (/lib/systemd/system/pivccu.service; enabled; preset: enabled)
                             Active: active (running) since Mon 2023-12-04 04:47:02 CET; 5h 38min ago
                           Main PID: 6432 (lxc-start)
                              Tasks: 0 (limit: 1571)
                                CPU: 2.947s
                             CGroup: /system.slice/pivccu.service
                                     ‣ 6432 /usr/bin/lxc-start --lxcpath /var/lib/piVCCU3 --name lxc --pidfile /var/run/pivccu3.pid --daemon
                        Dec 04 04:46:53 piPivCCU systemd[1]: Starting pivccu.service - piVCCU...
                        Dec 04 04:47:01 piPivCCU start_container.sh[6429]: kernel.sched_rt_runtime_us = -1
                        Dec 04 04:47:02 piPivCCU systemd[1]: Started pivccu.service - piVCCU.
                        pi@piPivCCU:~ $ ip addr
                        1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
                            link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
                            inet 127.0.0.1/8 scope host lo
                               valid_lft forever preferred_lft forever
                            inet6 ::1/128 scope host noprefixroute
                        2: eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast master br0 state UP group default qlen 1000
                            link/ether b8:27:eb:7d:64:a4 brd ff:ff:ff:ff:ff:ff
                            inet 192.168.137.61/24 brd 192.168.137.255 scope global noprefixroute eth0
                            inet6 fe80::2750:188a:6cf8:9854/64 scope link noprefixroute
                        4: br0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP group default qlen 1000
                            inet 192.168.137.94/24 brd 192.168.137.255 scope global br0
                            inet6 fe80::ba27:ebff:fe7d:64a4/64 scope link
                        5: lxcbr0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue state DOWN group default qlen 1000
                            link/ether 00:16:3e:00:00:00 brd ff:ff:ff:ff:ff:ff
                            inet 10.0.3.1/24 brd 10.0.3.255 scope global lxcbr0
                        6: vethpivccu@if2: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue master br0 state UP group default qlen 1000
                            link/ether fe:75:2c:88:46:99 brd ff:ff:ff:ff:ff:ff link-netnsid 0
                            inet6 fe80::fc75:2cff:fe88:4699/64 scope link
                        pi@piPivCCU:~ $
                        rpi2 gpio
                        749
