    4. Einbindung von Geräten
    5. [gelöst] ShellyPro 3EM Verbindung zu ioBroker nicht möglich
    • MSc
      MSc last edited by MSc
      Das Problem wird hier ja oft beschrieben, aber leider keine Lösung dazu gefunden.
      ioBroker läuft in einem Docker-Container
      Verbindung zu externem Testbroker broker.hivemq.com:1883
      curl -X POST -d '{"id":1, "method":"Mqtt.SetConfig", "params":{"config":{"enable":true, "server":"broker.hivemq.com:1883"}}}' http://${SHELLY}/rpc
      {"id":1,"src":"shellypro3em-3ce90e6eb924","result":{"restart_required":true}}%
      curl -X POST -d '{"id":1, "method":"Shelly.Reboot"}' http://${SHELLY}/rpc
      {"id":1,"src":"shellypro3em-3ce90e6eb924","result":null}%
      curl -X POST -d '{"id":1, "method":"Mqtt.GetStatus"}' http://${SHELLY}/rpc
      {"id":1,"src":"shellypro3em-3ce90e6eb924","result":{"connected":true}}%
      funktioniert also.
      Verbindung zu ioBroker funktioniert nicht.
      curl -X POST -d '{"id":1, "method":"Mqtt.SetConfig", "params":{"config":{"enable":true, "server":"192.168.0.12:1882"}}}' http://${SHELLY}/rpc
      {"id":1,"src":"shellypro3em-3ce90e6eb924","result":{"connected":false}}%
      Die Einstellungen:
      Das ioBroker log:
      2023-12-03 13:24:37.166 - info: host.cdbb76fac596 stopInstance system.adapter.shelly.0 (force=false, process=true)
      2023-12-03 13:24:37.168 - info: shelly.0 (397) Got terminate signal TERMINATE_YOURSELF
      2023-12-03 13:24:37.169 - info: shelly.0 (397) terminating
      2023-12-03 13:24:37.170 - info: shelly.0 (397) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2023-12-03 13:24:37.209 - info: host.cdbb76fac596 stopInstance system.adapter.shelly.0 send kill signal
      2023-12-03 13:24:37.670 - info: shelly.0 (397) terminating
      2023-12-03 13:24:37.702 - info: host.cdbb76fac596 instance system.adapter.shelly.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-12-03 13:24:40.223 - info: host.cdbb76fac596 instance system.adapter.shelly.0 started with pid 1558
      2023-12-03 13:24:40.891 - info: shelly.0 (1558) starting. Version 6.6.1 in /opt/iobroker/node_modules/iobroker.shelly, node: v18.19.0, js-controller: 5.0.16
      2023-12-03 13:24:40.960 - info: shelly.0 (1558) Starting in MQTT mode. Listening on 0.0.0.0:1882 (QoS 0)
      Es bleibt die übliche Fehlermeldung mit dem roten Kreuz: Verbunden mit Gerät oder Dienst.
      Der shelly taucht auch nicht in den Objekten auf.
      Mehrfaches Neuinstallieren der Instanz und des Adapters ohne Änderung
      Versucht habe ich weiterhin eine Portweiterleitung von host auf Container des ports 1882 udp
      Ich finde den Fehler nicht, wer kann mich in die richtige Richtung stupsen?
      • haus-automatisierung
        haus-automatisierung Developer Most Active @MSc last edited by haus-automatisierung
        @michael-schütt sagte in ShellyPro 3EM Verbindung zu ioBroker nicht möglich:
        Siehe Doku. Der Shelly-Adapter stellt selbst einen MQTT-Broker bereit und verbindet sich nicht zu einem externen Broker. Du kannst so arbeiten, aber nur mit dem MQTT-Adapter und ohne den Shelly-Adapter.
        Oder war das nur ein Beispiel? Danach auf den Screenshots sieht es ja richtig aus.
        Hast Du Port 1882 im Container freigegeben?
        MSc 1 Reply Last reply Reply Quote 0
        • MSc
          MSc @haus-automatisierung last edited by MSc
          @haus-automatisierung sagte in ShellyPro 3EM Verbindung zu ioBroker nicht möglich:
          Meine Denkweise (kann falsch sein): Das war ein Test, ob das Problem am shelly oder am ioBroker liegt. Wenn der Test zu einem anderem broker funktioniert, liegt es nicht am shelly. Danach habe ich per
          und nachfolgendem reboot des shelly wieder versucht, auf meinen ioBroker (192.168.0.12:1882) zu schalten.
          Was fehlschlägt.
          Mmmh. Ich habe (wie oben beschrieben) eine Portweiterleitung auf 1882/UDP im container eingerichtet.
          Falsch? Nicht ausreichend?
          • MSc
            MSc @MSc last edited by
            Okay, 1882/TCP eingerichtet und es scheint zu funktionieren. War der Meinung, das es UDP sein muss.
