    4. Problem mit Sonoff Zigbee USB Stick
      rsw2004 last edited by
      ich habe seit ein paar Tagen den Sonoff Zigbee USB Stick -E am Raspi hängen. Hat anfänglich problemlos funktioniert.
      Nach Firmware-Update des Sticks und Raspi-Updates startet der Adapter zwar anfänglich und verbindet sich mit den Geräten allerdings wird dieser wohl fehlerbedingt neugestartet bis er in die Fehlerschleife kommt.
      Hat jemand eine Idee?
      host.raspberrypi4
      2023-12-03 11:58:54.055	warn	Do not restart adapter system.adapter.zigbee.0 because restart loop detected
      host.raspberrypi4
      2023-12-03 11:58:54.054	info	Restart adapter system.adapter.zigbee.0 because enabled
      host.raspberrypi4
      2023-12-03 11:58:54.054	error	instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
      host.raspberrypi4
      2023-12-03 11:58:54.054	error	Caught by controller[1]: at Queue.executeNext (/opt/iobroker/node_modules/zigbee-herdsman/src/utils/queue.ts:32:32)
      host.raspberrypi4
      2023-12-03 11:58:54.054	error	Caught by controller[1]: at /opt/iobroker/node_modules/zigbee-herdsman/src/adapter/ezsp/driver/uart.ts:299:23
      host.raspberrypi4
      2023-12-03 11:58:54.053	error	Caught by controller[1]: Error: Reset error: Error: {"sequence":-1} after 10000ms
      host.raspberrypi4
      2023-12-03 11:58:54.052	error	Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
      zigbee.0
      2023-12-03 11:58:53.810	info	terminating
      zigbee.0
      2023-12-03 11:58:53.707	info	debug devices set to []
      zigbee.0
      2023-12-03 11:58:53.451	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
      zigbee.0
      2023-12-03 11:58:53.449	info	terminating
      zigbee.0
      2023-12-03 11:58:53.448	warn	Failed to stop zigbee during startup
      zigbee.0
      2023-12-03 11:58:53.369	info	Zigbee: disabling joining new devices.
      zigbee.0
      2023-12-03 11:58:53.308	info	cleaned everything up...
      zigbee.0
      2023-12-03 11:58:53.285	error	Reset error: Error: {"sequence":-1} after 10000ms
      zigbee.0
      2023-12-03 11:58:53.285	error	Error: Reset error: Error: {"sequence":-1} after 10000ms at /opt/iobroker/node_modules/zigbee-herdsman/src/adapter/ezsp/driver/uart.ts:299:23 at Queue.executeNext (/opt/iobroker/node_modules/zigbee-herdsman/src/utils/queue.ts:32:32)
      zigbee.0
      2023-12-03 11:58:53.242	error	unhandled promise rejection: Reset error: Error: {"sequence":-1} after 10000ms
      zigbee.0
      2023-12-03 11:58:53.242	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      zigbee.0
      2023-12-03 11:58:42.795	info	Installed Version: iobroker.zigbee@1.8.24
      zigbee.0
      2023-12-03 11:58:42.482	info	Starting Zigbee npm ...
      zigbee.0
      2023-12-03 11:58:42.480	info	delete old Backup files. keep only last 10
      zigbee.0
      2023-12-03 11:58:42.373	info	starting. Version 1.8.24 in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.19.0, js-controller: 5.0.16
      host.raspberrypi4
      2023-12-03 11:58:37.763	info	instance system.adapter.zigbee.0 started with pid 3872
      host.raspberrypi4
      2023-12-03 11:58:07.664	info	Restart adapter system.adapter.zigbee.0 because enabled
        Thomas Braun Most Active @rsw2004 last edited by
        @rsw2004 sagte in Problem mit Sonoff Zigbee USB Stick:
        Welche Versionen?
          rsw2004 @Thomas Braun last edited by
          Stick:
          SDK Version 4.3.1
          EZSP Version 7.3.1.0 build 176
          Raspi:
          Node 18.19.0
          NPM 10.2.3
          • Meister Mopper
            Meister Mopper last edited by Meister Mopper
            @rsw2004
            Ich glaube, gemeint ist sowas:
              rsw2004 @Meister Mopper last edited by
              @meister-mopper
              @Thomas-Braun
                rsw2004 @rsw2004 last edited by
                ls -la /dev/serial/by-id/
                total 0
                drwxr-xr-x 2 root root 60 Dec  3 19:50 .
                drwxr-xr-x 4 root root 80 Dec  3 19:50 ..
                lrwxrwxrwx 1 root root 13 Dec  3 19:50 usb-ITEAD_SONOFF_Zigbee_3.0_USB_Dongle_Plus_V2_20230831103249-if00 -> ../../ttyACM0
                  arteck Developer Most Active @rsw2004 last edited by arteck
                  das ist kein ezsp . wie kommst du dadrauf... und deshalb startet der nicht
                    rsw2004 @arteck last edited by
                    @arteck
                    Sollte passen, das ist der Typ E
                    Wenn ich den Raspi neustarte, läuft der Adapter problemlos hoch und der Stick verbindet sich mit den Geräten. Nach mehreren Minuten tritt aber dann ein Problem auf.
                      @rsw2004
                      dann fläch mal ne andere Firmaware die 20230831 ist nicht so prikelnd
                      https://github.com/Koenkk/Z-Stack-firmware/discussions/474
                        @arteck
                        kam jetzt erst dazu den Stick zu downgraden. Habe die 6.7.10 aufgespielt, das war auch die Version die original bei Auslieferung aufgespielt war.
                        Seit einer Stunde läuft alles problemlos.
                        Ich denke der Fehler ist behoben.
                        Vielen Dank
                        R arteck 2 Replies Last reply Reply Quote 0
                          @arteck
                          zu früh gefreut.. nach etlichen Stunden Normalbetrieb fängt schon wieder etwas an zu spinnen.. Aus dem Nichts heraus:
                          host.raspberrypi4
                          2023-12-05 17:23:49.365	warn	Do not restart adapter system.adapter.zigbee.0 because restart loop detected
                          host.raspberrypi4
                          2023-12-05 17:23:49.365	info	Restart adapter system.adapter.zigbee.0 because enabled
                          host.raspberrypi4
                          2023-12-05 17:23:49.365	error	instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                          host.raspberrypi4
                          2023-12-05 17:23:49.365	error	Caught by controller[1]: at Queue.executeNext (/opt/iobroker/node_modules/zigbee-herdsman/src/utils/queue.ts:32:32)
                          host.raspberrypi4
                          2023-12-05 17:23:49.365	error	Caught by controller[1]: at /opt/iobroker/node_modules/zigbee-herdsman/src/adapter/ezsp/driver/uart.ts:299:23
                          host.raspberrypi4
                          2023-12-05 17:23:49.364	error	Caught by controller[1]: Error: Reset error: Error: {"sequence":-1} after 10000ms
                          host.raspberrypi4
                          2023-12-05 17:23:49.364	error	Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
                          zigbee.0
                          2023-12-05 17:23:49.100	info	terminating
                          zigbee.0
                          2023-12-05 17:23:49.025	info	debug devices set to []
                          zigbee.0
                          2023-12-05 17:23:48.759	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                          zigbee.0
                          2023-12-05 17:23:48.758	info	terminating
                          zigbee.0
                          2023-12-05 17:23:48.756	warn	Failed to stop zigbee during startup
                          zigbee.0
                          2023-12-05 17:23:48.651	info	Zigbee: disabling joining new devices.
                          zigbee.0
                          2023-12-05 17:23:48.598	info	cleaned everything up...
                          zigbee.0
                          2023-12-05 17:23:48.567	error	Reset error: Error: {"sequence":-1} after 10000ms
                          zigbee.0
                          2023-12-05 17:23:48.566	error	Error: Reset error: Error: {"sequence":-1} after 10000ms at /opt/iobroker/node_modules/zigbee-herdsman/src/adapter/ezsp/driver/uart.ts:299:23 at Queue.executeNext (/opt/iobroker/node_modules/zigbee-herdsman/src/utils/queue.ts:32:32)
                          zigbee.0
                          2023-12-05 17:23:48.505	error	unhandled promise rejection: Reset error: Error: {"sequence":-1} after 10000ms
                          zigbee.0
                          2023-12-05 17:23:48.504	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                          zigbee.0
                          2023-12-05 17:23:38.040	info	Installed Version: iobroker.zigbee@1.8.24
                          zigbee.0
                          2023-12-05 17:23:37.709	info	Starting Zigbee npm ...
                          zigbee.0
                          2023-12-05 17:23:37.707	info	delete old Backup files. keep only last 10
                          zigbee.0
                          2023-12-05 17:23:37.598	info	starting. Version 1.8.24 in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.19.0, js-controller: 5.0.16
                          host.raspberrypi4
                          2023-12-05 17:23:33.136	info	instance system.adapter.zigbee.0 started with pid 3006
                          host.raspberrypi4
                          2023-12-05 17:23:03.085	info	Restart adapter system.adapter.zigbee.0 because enabled
                          host.raspberrypi4
                          2023-12-05 17:23:03.084	error	instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                          host.raspberrypi4
                          2023-12-05 17:23:03.084	error	Caught by controller[0]: at Queue.executeNext (/opt/iobroker/node_modules/zigbee-herdsman/src/utils/queue.ts:32:32)
                          host.raspberrypi4
                          2023-12-05 17:23:03.084	error	Caught by controller[0]: at /opt/iobroker/node_modules/zigbee-herdsman/src/adapter/ezsp/driver/uart.ts:299:23
                          host.raspberrypi4
                          2023-12-05 17:23:03.083	error	Caught by controller[0]: Error: Reset error: Error: {"sequence":-1} after 10000ms
                          host.raspberrypi4
                          2023-12-05 17:23:03.082	error	Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
                          zigbee.0
                          2023-12-05 17:23:02.824	info	terminating
                          zigbee.0
                          2023-12-05 17:23:02.724	info	debug devices set to []
                          zigbee.0
                          2023-12-05 17:23:02.478	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                          zigbee.0
                          2023-12-05 17:23:02.476	info	terminating
                          zigbee.0
                          2023-12-05 17:23:02.475	warn	Failed to stop zigbee during startup
                          zigbee.0
                          2023-12-05 17:23:02.364	info	Zigbee: disabling joining new devices.
                          zigbee.0
                          2023-12-05 17:23:02.321	info	cleaned everything up...
                          zigbee.0
                          2023-12-05 17:23:02.296	error	Reset error: Error: {"sequence":-1} after 10000ms
                          zigbee.0
                          2023-12-05 17:23:02.296	error	Error: Reset error: Error: {"sequence":-1} after 10000ms at /opt/iobroker/node_modules/zigbee-herdsman/src/adapter/ezsp/driver/uart.ts:299:23 at Queue.executeNext (/opt/iobroker/node_modules/zigbee-herdsman/src/utils/queue.ts:32:32)
                          zigbee.0
                          2023-12-05 17:23:02.252	error	unhandled promise rejection: Reset error: Error: {"sequence":-1} after 10000ms
                          zigbee.0
                          2023-12-05 17:23:02.251	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                          zigbee.0
                          2023-12-05 17:22:52.234	info	Installed Version: iobroker.zigbee@1.8.24
                          zigbee.0
                          2023-12-05 17:22:51.467	info	Starting Zigbee npm ...
                          zigbee.0
                          2023-12-05 17:22:51.464	info	delete old Backup files. keep only last 10
                          zigbee.0
                          2023-12-05 17:22:51.355	info	starting. Version 1.8.24 in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.19.0, js-controller: 5.0.16
                          host.raspberrypi4
                          2023-12-05 17:22:46.800	info	instance system.adapter.zigbee.0 started with pid 2990
                          host.raspberrypi4
                          2023-12-05 17:22:16.705	info	Restart adapter system.adapter.zigbee.0 because enabled
                          host.raspberrypi4
                          2023-12-05 17:22:16.705	error	instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                          host.raspberrypi4
                          2023-12-05 17:22:16.704	error	Caught by controller[0]: at Queue.executeNext (/opt/iobroker/node_modules/zigbee-herdsman/src/utils/queue.ts:32:32)
                          host.raspberrypi4
                          2023-12-05 17:22:16.704	error	Caught by controller[0]: at /opt/iobroker/node_modules/zigbee-herdsman/src/adapter/ezsp/driver/uart.ts:299:23
                          host.raspberrypi4
                          2023-12-05 17:22:16.704	error	Caught by controller[0]: Error: Reset error: Error: {"sequence":-1} after 10000ms
                          host.raspberrypi4
                          2023-12-05 17:22:16.702	error	Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
                          zigbee.0
                          2023-12-05 17:22:16.305	info	terminating
                          zigbee.0
                          2023-12-05 17:22:16.118	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                          zigbee.0
                          2023-12-05 17:22:16.116	info	terminating
                          zigbee.0
                          2023-12-05 17:22:16.115	error	Failed to stop zigbee (Error: Connection not initialized at Ezsp.execCommand (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/ezsp/driver/ezsp.ts:551:19) at Ezsp.version (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/ezsp/driver/ezsp.ts:349:35) at EZSPAdapterBackup.createBackup (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/ezsp/adapter/backup.ts:21:56) at EZSPAdapter.backup (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/ezsp/adapter/ezspAdapter.ts:609:31) at Controller.backup (/opt/iobroker/node_modules/zigbee-herdsman/src/controller/controller.ts:328:47) at Controller.stop (/opt/iobroker/node_modules/zigbee-herdsman/src/controller/controller.ts:308:9) at ZigbeeController.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:456:13) at Zigbee.onUnload (/opt/iobroker/node_modules/iobroker.zigbee/main.js:908:17))
                          zigbee.0
                          2023-12-05 17:22:15.841	info	Zigbee: disabling joining new devices.
                          zigbee.0
                          2023-12-05 17:22:15.804	info	cleaned everything up...
                          zigbee.0
                          2023-12-05 17:22:15.769	error	Reset error: Error: {"sequence":-1} after 10000ms
                          zigbee.0
                          2023-12-05 17:22:15.768	error	Error: Reset error: Error: {"sequence":-1} after 10000ms at /opt/iobroker/node_modules/zigbee-herdsman/src/adapter/ezsp/driver/uart.ts:299:23 at Queue.executeNext (/opt/iobroker/node_modules/zigbee-herdsman/src/utils/queue.ts:32:32)
                          zigbee.0
                          2023-12-05 17:22:15.710	error	unhandled promise rejection: Reset error: Error: {"sequence":-1} after 10000ms
                          zigbee.0
                          2023-12-05 17:22:15.709	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                            ?????????????????????????? was denn für 6.7.10 ?
                              @arteck
                              Ich weiß gerade nicht so genau was du von mir hören möchtest..
                              Aber das ist die Firmware-Version, welche bei der Auslieferung auf dem Stick war.. 6.7.10.
                              Es ist der Typ -E nicht -P..
                              Ich versuche es gleich noch mit der 6.10.3., meine letzte Hoffnung.
                              Ansonsten geht das Teil halt zurück.
                              622
