    4. fritzbox dect update 2.5.9 - Fehler im log
    • bahnuhr
      Habe eben update auf 2.5.9 gemacht.
      kennwort neu eingegeben.
      Instanz wird grün.
      Aber im log kommt:
      fritzdect.0
      2023-12-10 10:33:45.773	error	API err => {"msg":"AHA request error","function":"fritzAHA_Request","error":400,"status":400}
      fritzdect.0
      2023-12-10 10:33:45.773	error	no response part in returned error message
      fritzdect.0
      2023-12-10 10:33:45.772	error	API funct => executeCommand2
      fritzdect.0
      2023-12-10 10:33:45.772	error	API msg => relogin failed, or status400/500
      fritzdect.0
      2023-12-10 10:33:45.772	error	--------------- error calling the fritzbox -----------
      Jemand eine Idee ?
      • bahnuhr
        Hier mal das komplette log beim Start der Instanz:
        fritzdect.0
        2023-12-10 10:39:03.570	info	finished initial updating devices/groups
        fritzdect.0
        2023-12-10 10:39:02.944	info	start initial updating devices/groups
        fritzdect.0
        2023-12-10 10:39:02.944	info	finished creating routines (if any)
        fritzdect.0
        2023-12-10 10:39:02.944	error	API err => {"msg":"AHA request error","function":"fritzAHA_Request","error":400,"status":400}
        fritzdect.0
        2023-12-10 10:39:02.943	error	no response part in returned error message
        fritzdect.0
        2023-12-10 10:39:02.943	error	API funct => executeCommand2
        fritzdect.0
        2023-12-10 10:39:02.943	error	API msg => relogin failed, or status400/500
        fritzdect.0
        2023-12-10 10:39:02.943	error	--------------- error calling the fritzbox -----------
        fritzdect.0
        2023-12-10 10:39:01.946	info	start creating routines
        fritzdect.0
        2023-12-10 10:39:01.946	info	routines are used(false)
        fritzdect.0
        2023-12-10 10:39:01.946	info	finished creating templates (if any)
        fritzdect.0
        2023-12-10 10:39:01.298	info	start creating templates
        fritzdect.0
        2023-12-10 10:39:01.298	info	templates are used(false)
        fritzdect.0
        2023-12-10 10:39:01.297	info	finished creating devices/groups (if any)
        fritzdect.0
        2023-12-10 10:39:01.217	info	create Main object DECT_ 087610949675 FRITZ!DECT Rep 100 #2 thermo
        fritzdect.0
        2023-12-10 10:39:01.217	info	____________________________________________
        fritzdect.0
        2023-12-10 10:39:01.216	info	CREATE Devices 1
        fritzdect.0
        2023-12-10 10:39:00.329	info	start creating devices/groups
        fritzdect.0
        2023-12-10 10:39:00.329	info	finished creating global values
        fritzdect.0
        2023-12-10 10:39:00.319	info	create Main object global channel list
        fritzdect.0
        2023-12-10 10:39:00.319	info	____________________________________________
        fritzdect.0
        2023-12-10 10:39:00.319	info	start creating global values
        fritzdect.0
        2023-12-10 10:39:00.318	info	the rights are : {"Rights":{"Name":["Dial","App","HomeAuto","BoxAdmin","Phone","NAS"],"Access":["2","2","2","2","2","2"]}}
        fritzdect.0
        2023-12-10 10:38:59.852	info	checking user permissions
        fritzdect.0
        2023-12-10 10:38:56.213	info	fritzdect uses USER: didi-m
        fritzdect.0
        2023-12-10 10:38:56.191	info	fritzdect entered ready
        fritzdect.0
        2023-12-10 10:38:56.173	info	starting. Version 2.5.9 in /opt/iobroker/node_modules/iobroker.fritzdect, node: v18.18.2, js-controller: 5.0.16
        • bahnuhr
          So, dieser Fehler kommt alle 5 Minuten.
          fritzdect.0
          2023-12-10 12:29:08.725	error	API err => {"msg":"AHA request error","function":"fritzAHA_Request","error":400,"status":400}
          fritzdect.0
          2023-12-10 12:29:08.725	error	no response part in returned error message
          fritzdect.0
          2023-12-10 12:29:08.724	error	API funct => executeCommand2
          fritzdect.0
          2023-12-10 12:29:08.724	error	API msg => relogin failed, or status400/500
          fritzdect.0
          2023-12-10 12:29:08.724	error	--------------- error calling the fritzbox -----------
          Und da ich offenbar der Einzige bin damit, gehe ich wieder zurück.
          • bahnuhr
            So, alte V ging nicht installieren.
            Dann Instanz und Adapter komplett gelöscht.
            Und über npm wieder die 2.5.9 installiert.
            Daten eingegeben.
            Fehler bleibt.
            Schlecht.
              Thomas Braun Most Active @bahnuhr last edited by
              @bahnuhr sagte in fritzbox dect update 2.5.9 - Fehler im log:
              Fehler bleibt.
              Schlecht.
              Und wo findet man dein Issue dazu?
              So bleibt der Fehler mit Sicherheit bestehen...
              Hier ist jedenfalls nix zu finden:
              https://github.com/foxthefox/ioBroker.fritzdect/issues
              • bahnuhr
                bahnuhr Forum Testing Most Active @Thomas Braun last edited by
                @thomas-braun sagte in fritzbox dect update 2.5.9 - Fehler im log:
                Nicht schlimm. Habe den Adapter deinstalliert. Fertig.
                Wenn du magst kannst du gerne ein issue eröffnen.
                  Warum sollte ich für DEINE Probleme ein Issue eröffnen?
                  • bahnuhr
                    DEINE Probleme
                    Ich habe keine Probleme.
                    Adapter ist weg.
                      KiloByte @bahnuhr last edited by KiloByte
                      Seit dem Update auf 2.5.9 habe ich die gleichen Fehlermeldungen in den Logs.
                      In der Zwischenzeit habe ich:
                      • einen neuen ioBroker User in der Fritzbox eingerichtet
                      • den Adapter downgegraded auf die Version 2.5.7
                      • das Polling-Intervall mal auf 300 Sek. erhöht
                      • die Fritzbox und den ioBroker rebootet
                      alles ohne Erfolg.
                      Vielleicht gibt es hier noch weitere Ideen?
                        wg @KiloByte last edited by
                        @kilobyte Neuer User in der Fritzbox hat mir geholfen: Sonderzeichen raus aus dem Passwort (und möglicherweise nicht länger als 13 Zeichen machen). Polling ist bei mir auf 10s. Adapteroptionen alle an (also exclude aktiviert). Damit läuft 2.5.9 bei mir (2 Instanzen, Fritzen sind 7590er).
                          KiloByte @wg last edited by
                          @wg Bingo!! Die "Adapter Options" waren es. Ich habe bei allen ein Häkchen gesetzt und nun scheint es OK zu sein. Danke.
                          • mcm1957
                            mcm1957 @KiloByte last edited by
                            Und nochmal die Frage an alle die hier von Problemen berichten:
                            Warum eröffnet ihr kein Issue beim Adapter?
                            Wie denkt ihr dass das Maintainer von einem Problem erfährt?
                            Also BITTE eröffnet doch ein Issue wenn ihr ein Problem habt. (Ok deinstallieren ist auch ein Weg erinnert mich aber - nicht bös sein - ein wenig an das Verhalten meines trotzigen Enkerls...)
                            81.1k
                            error fritzdect log
                            1212
