    4. Vis-2 installiert nicht
      Heino last edited by
      Hallo
      ich habe jetzt schon mehrfach versucht die VIS-2 zu installieren. Die Vis-1 ist bei mir am laufen.
      Wenn ich aber die VIS-2 installiere endet das immer wie folgt:
      ERROR: Process exited with code null
      weniger
      mehr
      $ iobroker add vis-2 2 --host iobroker --debug
      host.iobroker install adapter vis-2
      upload [12] vis-2.admin /opt/iobroker/node_modules/iobroker.vis-2/admin/i18n/de/translations.json i18n/de/translations.json application/json
      upload [10] vis-2.admin /opt/iobroker/node_modules/iobroker.vis-2/admin/i18n/es/translations.json i18n/es/translations.json application/json
      upload [9] vis-2.admin /opt/iobroker/node_modules/iobroker.vis-2/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
      upload [6] vis-2.admin /opt/iobroker/node_modules/iobroker.vis-2/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
      upload [3] vis-2.admin /opt/iobroker/node_modules/iobroker.vis-2/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
      upload [1] vis-2.admin /opt/iobroker/node_modules/iobroker.vis-2/admin/jsonConfig.json jsonConfig.json application/json
      upload [0] vis-2.admin /opt/iobroker/node_modules/iobroker.vis-2/admin/vis-2.png vis-2.png image/png
      upload [685] vis-2 /opt/iobroker/node_modules/iobroker.vis-2/www/asset-manifest.json asset-manifest.json application/json
      upload [650] vis-2 /opt/iobroker/node_modules/iobroker.vis-2/www/img/favicon.png img/favicon.png image/png
      upload [600] vis-2 /opt/iobroker/node_modules/iobroker.vis-2/www/lib/css/themes/jquery-ui/cupertino/images/ui-bg_flat_15_cd0a0a_40x100.png lib/css/themes/jquery-ui/cupertino/images/ui-bg_flat_15_cd0a0a_40x100.png image/png
      upload [550] vis-2 /opt/iobroker/node_modules/iobroker.vis-2/www/lib/css/themes/jquery-ui/dark-hive/images/ui-bg_highlight-soft_80_eeeeee_1x100.png lib/css/themes/jquery-ui/dark-hive/images/ui-bg_highlight-soft_80_eeeeee_1x100.png image/png
      upload [500] vis-2 /opt/iobroker/node_modules/iobroker.vis-2/www/lib/css/themes/jquery-ui/eggplant/images/ui-icons_ffffff_256x240.png lib/css/themes/jquery-ui/eggplant/images/ui-icons_ffffff_256x240.png image/png
      upload [450] vis-2 /opt/iobroker/node_modules/iobroker.vis-2/www/lib/css/themes/jquery-ui/hot-sneaks/images/ui-icons_ffffff_256x240.png lib/css/themes/jquery-ui/hot-sneaks/images/ui-icons_ffffff_256x240.png image/png
      upload [400] vis-2 /opt/iobroker/node_modules/iobroker.vis-2/www/lib/css/themes/jquery-ui/redmond/images/ui-icons_6da8d5_256x240.png lib/css/themes/jquery-ui/redmond/images/ui-icons_6da8d5_256x240.png image/png
      upload [350] vis-2 /opt/iobroker/node_modules/iobroker.vis-2/www/lib/css/themes/jquery-ui/sunny/images/ui-bg_inset-soft_30_ffffff_1x100.png lib/css/themes/jquery-ui/sunny/images/ui-bg_inset-soft_30_ffffff_1x100.png image/png
      upload [300] vis-2 /opt/iobroker/node_modules/iobroker.vis-2/www/lib/css/themes/jquery-ui/vader/images/ui-bg_highlight-soft_35_adadad_1x100.png lib/css/themes/jquery-ui/vader/images/ui-bg_highlight-soft_35_adadad_1x100.png image/png
      upload [250] vis-2 /opt/iobroker/node_modules/iobroker.vis-2/www/signals/motionColor.png signals/motionColor.png image/png
      Weis jemand weiter? Vielen Dank schon mal
      Gruß Heino
        Homoran Global Moderator Administrators @Heino last edited by
        @heino ist dazu im Betatester Thread nichts bekannt?
          Thomas Braun Most Active @Heino last edited by
          @heino
          iob diag
          sagt?
            Heino @Thomas Braun last edited by
            sorry Thomas ich verstehe nicht was du meinst
            Homoran H 2 Replies Last reply Reply Quote 0
              @heino sagte in Vis-2 installiert nicht:
              Bitte die Ausgabe von iob diag in der Langfassung hier in code-tags posten
                Heino @Heino last edited by
                @heino
                Hallo Thomas ich hoffe es hilft weiter. Ich stecke noch nicht so tief drin und musste auch das mit dem iob diag erstmal rausfinden.
                Skript v.2023-10-25
                *** BASE SYSTEM ***
                 Static hostname: iobroker
                       Icon name: computer-container
                         Chassis: container
                  Virtualization: lxc
                Operating System: Ubuntu 22.04.3 LTS
                          Kernel: Linux 5.15.104-1-pve
                    Architecture: x86-64
                model name      : Intel(R) Celeron(R) J4125 CPU @ 2.00GHz
                Docker          : false
                Virtualization  : lxc
                Kernel          : x86_64
                Userland        : amd64
                Systemuptime and Load:
                 10:58:46 up 41 days, 13:52,  1 user,  load average: 0.04, 0.03, 0.00
                CPU threads: 4
                *** Time and Time Zones ***
                               Local time: Wed 2023-12-13 10:58:46 CET
                           Universal time: Wed 2023-12-13 09:58:46 UTC
                                 RTC time: n/a
                              NTP service: inactive
                          RTC in local TZ: no
                *** User and Groups ***
                root
                /root
                root
                *** X-Server-Setup ***
                X-Server:       false
                Desktop:
                Terminal:
                *** MEMORY ***
                Mem:            4.1G        2.8G        584M        0.0K        750M        1.3G
                Swap:           1.0G        347M        676M
                Total:          5.1G        3.1G        1.3G
                         4096 M total memory
                         2761 M used memory
                          727 M active memory
                         2667 M inactive memory
                          583 M free memory
                            0 M buffer memory
                          750 M swap cache
                         1024 M total swap
                          347 M used swap
                          676 M free swap
                *** FAILED SERVICES ***
                  UNIT                 LOAD   ACTIVE SUB    DESCRIPTION
                * run-rpc_pipefs.mount loaded failed failed RPC Pipe File System
                1 loaded units listed.
                *** FILESYSTEM ***
                Filesystem                       Type   Size  Used Avail Use% Mounted on
                /dev/mapper/pve-vm--200--disk--0 ext4    20G  4.5G   15G  24% /
                none                             tmpfs  492K  4.0K  488K   1% /dev
                tmpfs                            tmpfs  7.8G     0  7.8G   0% /dev/shm
                tmpfs                            tmpfs  3.1G  120K  3.1G   1% /run
                tmpfs                            tmpfs  5.0M     0  5.0M   0% /run/lock
                Check not possible in LXC or Docker
                Show mounted filesystems:
                TARGET                                        SOURCE                           FSTYPE      OPTIONS
                /                                             /dev/mapper/pve-vm--200--disk--0 ext4        rw,relatime,stripe=16
                |-/run                                        tmpfs                            tmpfs       rw,nosuid,nodev,size=3241100k,nr_inodes=819200,mode=755,uid=100000,gid=100000,inode64
                | |-/run/lock                                 tmpfs                            tmpfs       rw,nosuid,nodev,noexec,relatime,size=5120k,uid=100000,gid=100000,inode64
                | `-/run/credentials/systemd-sysusers.service none                             ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
                |-/dev                                        none                             tmpfs       rw,relatime,size=492k,mode=755,uid=100000,gid=100000,inode64
                | |-/dev/shm                                  tmpfs                            tmpfs       rw,nosuid,nodev,uid=100000,gid=100000,inode64
                | |-/dev/mqueue                               mqueue                           mqueue      rw,relatime
                | |-/dev/.lxc/proc                            proc                             proc        rw,relatime
                | |-/dev/.lxc/sys                             sys                              sysfs       rw,relatime
                | |-/dev/full                                 udev[/full]                      devtmpfs    rw,nosuid,relatime,size=8068024k,nr_inodes=2017006,mode=755,inode64
                | |-/dev/null                                 udev[/null]                      devtmpfs    rw,nosuid,relatime,size=8068024k,nr_inodes=2017006,mode=755,inode64
                | |-/dev/random                               udev[/random]                    devtmpfs    rw,nosuid,relatime,size=8068024k,nr_inodes=2017006,mode=755,inode64
                | |-/dev/tty                                  udev[/tty]                       devtmpfs    rw,nosuid,relatime,size=8068024k,nr_inodes=2017006,mode=755,inode64
                | |-/dev/urandom                              udev[/urandom]                   devtmpfs    rw,nosuid,relatime,size=8068024k,nr_inodes=2017006,mode=755,inode64
                | |-/dev/zero                                 udev[/zero]                      devtmpfs    rw,nosuid,relatime,size=8068024k,nr_inodes=2017006,mode=755,inode64
                | |-/dev/pts                                  devpts                           devpts      rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
                | |-/dev/ptmx                                 devpts[/ptmx]                    devpts      rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
                | |-/dev/console                              devpts[/0]                       devpts      rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
                | |-/dev/tty1                                 devpts[/1]                       devpts      rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
                | `-/dev/tty2                                 devpts[/2]                       devpts      rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
                |-/proc                                       proc                             proc        rw,nosuid,nodev,noexec,relatime
                | |-/proc/sys                                 proc[/sys]                       proc        ro,relatime
                | | |-/proc/sys/net                           proc[/sys/net]                   proc        rw,nosuid,nodev,noexec,relatime
                | | |-/proc/sys/kernel/random/boot_id         none[/.lxc-boot-id]              tmpfs       ro,nosuid,nodev,noexec,relatime,size=492k,mode=755,uid=100000,gid=100000,inode64
                | | `-/proc/sys/fs/binfmt_misc                binfmt_misc                      binfmt_misc rw,nosuid,nodev,noexec,relatime
                | |-/proc/sysrq-trigger                       proc[/sysrq-trigger]             proc        ro,relatime
                | |-/proc/cpuinfo                             lxcfs[/proc/cpuinfo]             fuse.lxcfs  rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
                | |-/proc/diskstats                           lxcfs[/proc/diskstats]           fuse.lxcfs  rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
                | |-/proc/loadavg                             lxcfs[/proc/loadavg]             fuse.lxcfs  rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
                | |-/proc/meminfo                             lxcfs[/proc/meminfo]             fuse.lxcfs  rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
                | |-/proc/slabinfo                            lxcfs[/proc/slabinfo]            fuse.lxcfs  rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
                | |-/proc/stat                                lxcfs[/proc/stat]                fuse.lxcfs  rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
                | |-/proc/swaps                               lxcfs[/proc/swaps]               fuse.lxcfs  rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
                | `-/proc/uptime                              lxcfs[/proc/uptime]              fuse.lxcfs  rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
                `-/sys                                        sysfs                            sysfs       ro,nosuid,nodev,noexec,relatime
                  |-/sys/fs/fuse/connections                  fusectl                          fusectl     rw,nosuid,nodev,noexec,relatime
                  |-/sys/devices/virtual/net                  sysfs[/devices/virtual/net]      sysfs       rw,nosuid,nodev,noexec,relatime
                  |-/sys/kernel/debug                         debugfs                          debugfs     rw,nosuid,nodev,noexec,relatime
                  |-/sys/kernel/security                      securityfs                       securityfs  rw,nosuid,nodev,noexec,relatime
                  |-/sys/fs/pstore                            pstore                           pstore      rw,nosuid,nodev,noexec,relatime
                  |-/sys/fs/cgroup                            none                             cgroup2     rw,nosuid,nodev,noexec,relatime
                  `-/sys/devices/system/cpu                   lxcfs[/sys/devices/system/cpu]   fuse.lxcfs  rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
                /var:
                642M    /var/
                264M    /var/cache
                259M    /var/cache/apt
                255M    /var/lib
                168M    /var/cache/apt/archives
                Archived and active journals take up 120.0M in the file system.
                /opt/iobroker/backups:
                56M     /opt/iobroker/backups/
                /opt/iobroker/iobroker-data:
                559M    /opt/iobroker/iobroker-data/
                456M    /opt/iobroker/iobroker-data/files
                99M     /opt/iobroker/iobroker-data/files/vis-2
                88M     /opt/iobroker/iobroker-data/files/echarts.admin
                70M     /opt/iobroker/iobroker-data/backup-objects
                35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
                28M     /opt/iobroker/iobroker-data/objects.jsonl
                27M     /opt/iobroker/iobroker-data/files/vis-2/customWidgets.js.map
                23M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.eb0afecd.js.map
                23M     /opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.7952f0f7.js.map
                USB-Devices by-id:
                /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_7a8ffe778629ec119544757840c9ce8d-if00-port0
                *** NodeJS-Installation ***
                ./iob_diag: line 283: nodejs: command not found
                /usr/bin/node           v18.17.1
                /usr/bin/npm            9.6.7
                /usr/bin/npx            9.6.7
                /usr/bin/corepack       0.18.0
                ./iob_diag: line 294: nodejs: command not found
                *** nodejs is NOT correctly installed ***
                Run ob nodejs-update to fix it.
                nodejs:
                  Installed: 18.17.1-deb-1nodesource1
                  Candidate: 18.17.1-deb-1nodesource1
                  Version table:
                 *** 18.17.1-deb-1nodesource1 500
                        500 https://deb.nodesource.com/node_18.x jammy/main amd64 Packages
                        100 /var/lib/dpkg/status
                     12.22.9~dfsg-1ubuntu3.2 500
                        500 http://archive.ubuntu.com/ubuntu jammy-updates/universe amd64 Packages
                        500 http://archive.ubuntu.com/ubuntu jammy-security/universe amd64 Packages
                     12.22.9~dfsg-1ubuntu3 500
                        500 http://archive.ubuntu.com/ubuntu jammy/universe amd64 Packages
                No problems detected
                Errors in npm tree:
                *** ioBroker-Installation ***
                ioBroker Status
                Objects type: jsonl
                States  type: jsonl
                Core adapters versions
                js-controller:  5.0.16
                admin:          6.12.0
                javascript:     7.1.6
                Adapters from github:   2
                Adapter State
                + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
                  system.adapter.devices.0                : devices               : iobroker                                 -  enabled
                + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
                + system.adapter.energiefluss.0           : energiefluss          : iobroker                                 -  enabled
                + system.adapter.fritzdect.0              : fritzdect             : iobroker                                 -  enabled
                + system.adapter.history.0                : history               : iobroker                                 -  enabled
                  system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
                + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
                + system.adapter.modbus.0                 : modbus                : iobroker                                 -  enabled
                + system.adapter.ping.0                   : ping                  : iobroker                                 -  enabled
                  system.adapter.pylontech.0              : pylontech             : iobroker                                 - disabled, port: 23
                + system.adapter.sayit.0                  : sayit                 : iobroker                                 -  enabled
                + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
                + system.adapter.tr-064.0                 : tr-064                : iobroker                                 -  enabled
                + system.adapter.tr-064.1                 : tr-064                : iobroker-slave                           -  enabled
                + system.adapter.tr-064.2                 : tr-064                : iobroker-slave                           -  enabled
                + system.adapter.tr-064.3                 : tr-064                : iobroker-slave                           -  enabled
                + system.adapter.trashschedule.0          : trashschedule         : iobroker                                 -  enabled
                  system.adapter.vis-homekittiles.0       : vis-homekittiles      : iobroker                                 -  enabled
                  system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 -  enabled
                  system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
                + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                + system.adapter.zigbee.0                 : zigbee                : iobroker-slave                           -  enabled, port: /dev/ttyUSB0
                + instance is alive
                ioBroker-Repositories
                Active repo(s): stable
                Installed ioBroker-Instances
                Used repository: stable
                Adapter    "backitup"     : 2.8.7    , installed 2.8.7
                Adapter    "bidirectional-counter": 2.1.3, installed 2.1.0 [Updatable]
                Adapter    "deyeidc"      : 0.0.14   , installed 0.0.11 [Updatable]
                Adapter    "discovery"    : 4.2.0    , installed 3.1.0  [Updatable]
                Adapter    "echarts"      : 1.5.4    , installed 1.5.1  [Updatable]
                Adapter    "fritzdect"    : 2.5.9    , installed 2.5.9
                Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
                Adapter    "javascript"   : 7.1.6    , installed 7.1.6
                Controller "js-controller": 5.0.17   , installed 5.0.16 [Updatable]
                Adapter    "modbus"       : 5.0.11   , installed 5.0.11
                Adapter    "proxmox"      : 2.2.2    , installed 1.3.4  [Updatable]
                Adapter    "pylontech"    : 0.0.7    , installed 0.0.7
                Adapter    "sayit"        : 3.0.5    , installed 3.0.5
                Adapter    "smartmeter"   : 3.3.4    , installed 3.3.4
                Adapter    "solarmanpv"   : 0.5.1    , installed 0.5.0  [Updatable]
                Adapter    "solax"        : 0.8.0    , installed 0.6.0  [Updatable]
                Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
                Adapter    "trashschedule": 2.3.0    , installed 2.3.0
                Adapter    "vis"          : 1.4.16   , installed 1.4.16
                Adapter    "web"          : 6.1.10   , installed 6.1.10
                Adapter    "ws"           : 2.5.8    , installed 2.5.8
                Adapter    "zigbee"       : 1.8.24   , installed 1.8.24
                Objects and States
                Objects:        1736
                States:         1466
                Hit:1 https://repos.influxdata.com/debian stable InRelease
                Hit:2 https://deb.nodesource.com/node_18.x jammy InRelease
                Hit:3 http://archive.ubuntu.com/ubuntu jammy InRelease
                Hit:4 http://archive.ubuntu.com/ubuntu jammy-updates InRelease
                Hit:5 http://archive.ubuntu.com/ubuntu jammy-security InRelease
                Reading package lists...
                Pending Updates: 67
                *** Listening Ports ***
                Netid State  Recv-Q Send-Q       Local Address:Port  Peer Address:PortProcess
                udp   UNCONN 0      0            127.0.0.53%lo:53         0.0.0.0:*    users:(("systemd-resolve",pid=109,fd=13))
                udp   UNCONN 0      0      192.168.188.87%eth0:68         0.0.0.0:*    users:(("systemd-network",pid=92,fd=17))
                udp   UNCONN 0      0                  0.0.0.0:111        0.0.0.0:*    users:(("rpcbind",pid=97,fd=5),("systemd",pid=1,fd=58))
                udp   UNCONN 0      0                  0.0.0.0:41599      0.0.0.0:*    users:(("rpc.statd",pid=183867,fd=8))
                udp   UNCONN 0      0                127.0.0.1:875        0.0.0.0:*    users:(("rpc.statd",pid=183867,fd=5))
                udp   UNCONN 0      0           192.168.188.87:5353       0.0.0.0:*    users:(("io.tr-064.0",pid=1857189,fd=29))
                udp   UNCONN 0      0                  0.0.0.0:5678       0.0.0.0:*    users:(("io.discovery.0",pid=1586716,fd=29))
                udp   UNCONN 0      0                     [::]:111           [::]:*    users:(("rpcbind",pid=97,fd=7),("systemd",pid=1,fd=60))
                udp   UNCONN 0      0                     [::]:33742         [::]:*    users:(("rpc.statd",pid=183867,fd=10))
                tcp   LISTEN 0      4096               0.0.0.0:52715      0.0.0.0:*    users:(("rpc.statd",pid=183867,fd=9))
                tcp   LISTEN 0      4096               0.0.0.0:111        0.0.0.0:*    users:(("rpcbind",pid=97,fd=4),("systemd",pid=1,fd=57))
                tcp   LISTEN 0      4096         127.0.0.53%lo:53         0.0.0.0:*    users:(("systemd-resolve",pid=109,fd=14))
                tcp   LISTEN 0      100              127.0.0.1:25         0.0.0.0:*    users:(("master",pid=308,fd=13))
                tcp   LISTEN 0      511                0.0.0.0:1883       0.0.0.0:*    users:(("io.sonoff.0",pid=1717855,fd=34))
                tcp   LISTEN 0      511                0.0.0.0:9000       0.0.0.0:*    users:(("iobroker.js-con",pid=1586525,fd=27))
                tcp   LISTEN 0      511                0.0.0.0:9001       0.0.0.0:*    users:(("iobroker.js-con",pid=1586525,fd=21))
                tcp   LISTEN 0      4096                  [::]:111           [::]:*    users:(("rpcbind",pid=97,fd=6),("systemd",pid=1,fd=59))
                tcp   LISTEN 0      511                      *:8081             *:*    users:(("io.admin.0",pid=1586543,fd=30))
                tcp   LISTEN 0      511                      *:8082             *:*    users:(("io.web.0",pid=1586778,fd=29))
                tcp   LISTEN 0      128                      *:8086             *:*    users:(("influxd",pid=132,fd=9))
                tcp   LISTEN 0      4096                     *:22               *:*    users:(("systemd",pid=1,fd=61))
                tcp   LISTEN 0      100                  [::1]:25            [::]:*    users:(("master",pid=308,fd=14))
                tcp   LISTEN 0      4096                  [::]:41309         [::]:*    users:(("rpc.statd",pid=183867,fd=11))
                2023-12-13 10:59:00.005  - silly: sonoff.0 (1717855) States user redis pmessage sonoff.0.*/sonoff.0.Tasmota-67.POWER:{"val":false,"ack":false,"ts":1702461540002,"q":0,"c":"script.js.Haus.Steuerung_Warmwasser","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1702461240002}
                2023-12-13 10:59:00.005  - debug: sonoff.0 (1717855) stateChange sonoff.0.Tasmota-67.POWER: {"val":false,"ack":false,"ts":1702461540002,"q":0,"c":"script.js.Haus.Steuerung_Warmwasser","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1702461240002}
                2023-12-13 10:59:00.005  - debug: sonoff.0 (1717855) onStateChange sonoff.0.Tasmota-67.POWER: {"val":false,"ack":false,"ts":1702461540002,"q":0,"c":"script.js.Haus.Steuerung_Warmwasser","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1702461240002}
                2023-12-13 10:59:00.006  - debug: sonoff.0 (1717855) Send to "Tasmota-67": tele/tasmota_F7C950/POWER = OFF
                2023-12-13 10:59:00.116  - debug: sonoff.0 (1717855) [Tasmota-67] Received: stat/tasmota_F7C950/RESULT = {"POWER":"OFF"}
                2023-12-13 10:59:00.116  - debug: sonoff.0 (1717855) [Tasmota-67] Received: stat/tasmota_F7C950/POWER = OFF
                2023-12-13 10:59:00.116  - debug: sonoff.0 (1717855) updateState sonoff.0.Tasmota-67.POWER - 1
                2023-12-13 10:59:00.116  - debug: sonoff.0 (1717855) process task: {"type":"addObject","id":"sonoff.0.Tasmota-67.POWER","data":{"_id":"sonoff.0.Tasmota-67.POWER","common":{"type":"boolean","role":"switch","read":true,"write":true,"storeMap":true,"name":"Tasmota-67 POWER"},"native":{},"type":"state"}}
                2023-12-13 10:59:00.162  - silly: sonoff.0 (1717855) States user redis pmessage sonoff.0.*/sonoff.0.Tasmota-67.POWER:{"val":false,"ack":true,"ts":1702461540161,"q":0,"from":"system.adapter.sonoff.0","user":"system.user.admin","lc":1702461240002}
                2023-12-13 10:59:00.163  - debug: sonoff.0 (1717855) stateChange sonoff.0.Tasmota-67.POWER: {"val":false,"ack":true,"ts":1702461540161,"q":0,"from":"system.adapter.sonoff.0","user":"system.user.admin","lc":1702461240002}
                2023-12-13 10:59:00.850  - debug: sonoff.0 (1717855) Client [Tasmota79-HaustuerLED] pingreq
                2023-12-13 10:59:02.652  - debug: sonoff.0 (1717855) Client [Tasmota111-Tannenbaum] pingreq
                2023-12-13 10:59:03.209  - debug: sonoff.0 (1717855) Client [Tasmota112-Tim] pingreq
                2023-12-13 10:59:04.967  - error: tr-064.0 (1857189) Cannot start callmonitor: Error: connect ECONNREFUSED 192.168.188.1:1012
                2023-12-13 10:59:05.307  - debug: sonoff.0 (1717855) Client [Tasmota114-Pflanze] pingreq
                2023-12-13 10:59:10.168  - error: tr-064.0 (1857189) Cannot start callmonitor: Error: connect ECONNREFUSED 192.168.188.1:1012
                2023-12-13 10:59:11.749  - debug: sonoff.0 (1717855) Client [Tasmota78-LuefterPV] pingreq
                2023-12-13 10:59:15.175  - error: tr-064.0 (1857189) Cannot start callmonitor: Error: connect ECONNREFUSED 192.168.188.1:1012
                2023-12-13 10:59:17.787  - debug: sonoff.0 (1717855) Client [Tasmota36-Trockner] pingreq
                2023-12-13 10:59:20.289  - error: tr-064.0 (1857189) Cannot start callmonitor: Error: connect ECONNREFUSED 192.168.188.1:1012
                2023-12-13 10:59:25.295  - error: tr-064.0 (1857189) Cannot start callmonitor: Error: connect ECONNREFUSED 192.168.188.1:1012
                2023-12-13 10:59:27.433  - debug: sonoff.0 (1717855) Client [Tasmota25-Garage] pingreq
                2023-12-13 10:59:30.095  - debug: sonoff.0 (1717855) Client [Tasmota-67] pingreq
                2023-12-13 10:59:30.300  - error: tr-064.0 (1857189) Cannot start callmonitor: Error: connect ECONNREFUSED 192.168.188.1:1012
                2023-12-13 10:59:30.852  - debug: sonoff.0 (1717855) Client [Tasmota79-HaustuerLED] pingreq
                Copy text starting here:
                                        v.2023-10-25
                         Chassis: container
                  Virtualization: lxc
                Installation:           lxc
                Userland:               amd64
                User-ID:                0
                X-Server:               false
                Pending OS-Updates:     67
                Pending iob updates:    8
                ./iob_diag: line 498: nodejs: command not found
                Nodejs-Installation:
                                        /usr/bin/npm            9.6.7
                                        /usr/bin/npx            9.6.7
                Recommended versions are nodejs 18.19.0 and npm 10.2.3
                Wrong installation path detected. This needs to be fixed.
                Please check
                https://forum.iobroker.net/topic/35090/howto-nodejs-installation-und-upgrades-unter-debian
                for more information on how to fix these errors or run:
                iobroker nodejs-update
                MEMORY:
                Mem:            4.1G        2.8G        520M        0.0K        773M        1.3G
                Total:          5.1G        3.2G        1.2G
                Active iob-Instances:   19
                ioBroker Core:          js-controller           5.0.16
                Objects type: jsonl
                States  type: jsonl
                Objects:                1736
                States:                 1466
                Size of iob-Database:
                36M     /opt/iobroker/iobroker-data/objects.jsonl
                7.3M    /opt/iobroker/iobroker-data/states.jsonl
                                        v.2023-10-25
                         Chassis: container
                  Virtualization: lxc
                Installation:           lxc
                Userland:               amd64
                User-ID:                0
                X-Server:               false
                                        /usr/bin/npm            9.6.7
                                        /usr/bin/npx            9.6.7
                Please check
                MEMORY:
                Objects type: jsonl
                States  type: jsonl
                Objects:                1736
                States:                 1466
                  root
                  Hampel da nicht als root durch den Container. Wie man einen user anlegt steht u. a. in der Installationsanleitung zum ioBroker drin.
                  Mit dem frischen User:
                  sudo apt update
                  sudo apt full-upgrade
                  Updates einspielen.
                  iob nodejs-update
                  richtet das richtig ein.
                    Hallo Thomas
                    ich denke das ich soweit alles gemacht habe, alledings wenn ich Vis-2 installiere stürzt der ioB ab und startet sofort wieder
                    Skript v.2023-10-10
                    *** BASE SYSTEM ***
                             Chassis: container
                      Virtualization: lxc
                    Docker          : false
                    Kernel          : x86_64
                    Userland        : amd64
                     19:52:19 up  1:10,  2 users,  load average: 0.18, 0.23, 0.18
                    CPU threads: 4
                                   Local time: Wed 2023-12-13 19:52:19 CET
                               Universal time: Wed 2023-12-13 18:52:19 UTC
                                     RTC time: n/a
                              RTC in local TZ: no
                    heiko
                    /home/heiko
                    heiko sudo iobroker
                    X-Server:       false
                    Desktop:
                    Terminal:
                    *** MEMORY ***
                    Mem:            4.1G        136M        3.2G        0.0K        756M        4.0G
                    Swap:           1.0G         25M        998M
                    Total:          5.1G        161M        4.2G
                             4096 M total memory
                              136 M used memory
                              452 M active memory
                              367 M inactive memory
                             3203 M free memory
                                0 M buffer memory
                              756 M swap cache
                             1024 M total swap
                               25 M used swap
                              998 M free swap
                    * iobroker.service     loaded failed failed ioBroker Server
                    2 loaded units listed.
                    *** FILESYSTEM ***
                    /dev/mapper/pve-vm--200--disk--0 ext4    20G  4.4G   15G  24% /
                    dmesg: read kernel buffer failed: Operation not permitted
                    /var:
                    690M    /var/
                    295M    /var/cache
                    290M    /var/cache/apt
                    256M    /var/lib
                    199M    /var/cache/apt/archives
                    Archived and active journals take up 8.0M in the file system.
                    536M    /opt/iobroker/iobroker-data/
                    23M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.eb0afecd.js.map
                    USB-Devices by-id:
                    /usr/bin/nodejs         v18.19.0
                    /usr/bin/node           v18.19.0
                    /usr/bin/npm            10.2.3
                    /usr/bin/npx            10.2.3
                    nodejs:
                      Installed: 18.19.0-1nodesource1
                      Candidate: 18.19.0-1nodesource1
                      Version table:
                     *** 18.19.0-1nodesource1 1001
                            500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
                         18.18.2-1nodesource1 1001
                         18.18.1-1nodesource1 1001
                         18.18.0-1nodesource1 1001
                         18.17.1-1nodesource1 1001
                         18.17.0-1nodesource1 1001
                         18.16.1-1nodesource1 1001
                         18.16.0-1nodesource1 1001
                         18.15.0-1nodesource1 1001
                         18.14.2-1nodesource1 1001
                         18.14.1-1nodesource1 1001
                         18.14.0-1nodesource1 1001
                         18.13.0-1nodesource1 1001
                         18.12.0-1nodesource1 1001
                         18.11.0-1nodesource1 1001
                         18.10.0-1nodesource1 1001
                         18.9.1-1nodesource1 1001
                         18.9.0-1nodesource1 1001
                         18.8.0-1nodesource1 1001
                         18.7.0-1nodesource1 1001
                         18.6.0-1nodesource1 1001
                         18.5.0-1nodesource1 1001
                         18.4.0-1nodesource1 1001
                         18.3.0-1nodesource1 1001
                         18.2.0-1nodesource1 1001
                         18.1.0-1nodesource1 1001
                         18.0.0-1nodesource1 1001
                    Errors in npm tree:
                    ioBroker Status
                    Server Configured backup period 7200000 is larger than the supported maximum of 35791 minutes. Defaulting to 120 minutes.
                    iobroker is not running on this host.
                    Objects type: jsonl
                    States  type: jsonl
                    admin:          6.12.0
                    javascript:     7.1.6
                    Adapter State
                    + instance is alive
                    Objects and States
                    Objects:        1738
                    States:         1297
                    Hit:2 https://deb.nodesource.com/node_18.x nodistro InRelease
                    Pending Updates: 0
                    tcp        0      0 0.0.0.0:59945           0.0.0.0:*               LISTEN      111        98303819   519/rpc.statd
                    tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          98300533   309/master
                    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          98298769   1/init
                    tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      106        98302081   112/systemd-resolve
                    tcp6       0      0 :::51255                :::*                    LISTEN      111        98303823   519/rpc.statd
                    tcp6       0      0 :::22                   :::*                    LISTEN      0          98302993   1/init
                    tcp6       0      0 :::111                  :::*                    LISTEN      0          98298771   1/init
                    tcp6       0      0 ::1:25                  :::*                    LISTEN      0          98300534   309/master
                    tcp6       0      0 :::8086                 :::*                    LISTEN      999        98301266   132/influxd
                    udp        0      0 127.0.0.53:53           0.0.0.0:*                           106        98302080   112/systemd-resolve
                    udp        0      0 192.168.188.87:68       0.0.0.0:*                           105        98301105   92/systemd-networkd
                    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          98298770   1/init
                    udp        0      0 127.0.0.1:695           0.0.0.0:*                           0          98303813   519/rpc.statd
                    udp        0      0 0.0.0.0:37882           0.0.0.0:*                           111        98303817   519/rpc.statd
                    udp6       0      0 :::111                  :::*                                0          98298772   1/init
                    udp6       0      0 :::54874                :::*                                111        98303821   519/rpc.statd
                    2023-12-13 19:49:25.131  - info: trashschedule.0 (4973) terminating
                    2023-12-13 19:49:25.133  - info: web.0 (4990) terminating
                    2023-12-13 19:49:25.134  - info: fritzdect.0 (5061) terminating
                    2023-12-13 19:49:25.135  - info: discovery.0 (4935) terminating
                    2023-12-13 19:49:25.136  - info: energiefluss.0 (5035) terminating
                    2023-12-13 19:49:25.231  - info: host.iobroker instance system.adapter.tr-064.0 terminated with code 0 (NO_ERROR)
                    2023-12-13 19:49:25.286  - info: host.iobroker instance system.adapter.history.0 terminated with code 0 (NO_ERROR)
                    2023-12-13 19:49:25.288  - info: host.iobroker instance system.adapter.javascript.0 terminated with code 0 (NO_ERROR)
                    2023-12-13 19:49:25.288  - info: host.iobroker instance system.adapter.fritzdect.0 terminated with code 0 (NO_ERROR)
                    2023-12-13 19:49:25.320  - info: host.iobroker instance system.adapter.energiefluss.0 terminated with code 0 (NO_ERROR)
                    2023-12-13 19:49:25.352  - info: host.iobroker instance system.adapter.admin.0 terminated with code 0 (NO_ERROR)
                    2023-12-13 19:49:25.352  - info: host.iobroker instance system.adapter.sayit.0 terminated with code 0 (NO_ERROR)
                    2023-12-13 19:49:25.355  - silly: sonoff.0 (4814) States system redis pmessage system.adapter.*.logging/system.adapter.javascript.0.logging:{"val":false,"ack":true,"ts":1702493365338,"q":0,"from":"system.host.iobroker","lc":1698784769164}
                    2023-12-13 19:49:25.355  - silly: sonoff.0 (4814) system.adapter.javascript.0: logging false
                    2023-12-13 19:49:25.369  - silly: sonoff.0 (4814) States system redis pmessage system.adapter.*.logging/system.adapter.admin.0.logging:{"val":false,"ack":true,"ts":1702493365364,"q":0,"from":"system.host.iobroker","lc":1702493365364}
                    2023-12-13 19:49:25.369  - silly: sonoff.0 (4814) system.adapter.admin.0: logging false
                    2023-12-13 19:49:25.424  - info: host.iobroker instance system.adapter.modbus.0 terminated with code 0 (NO_ERROR)
                    2023-12-13 19:49:25.424  - info: host.iobroker instance system.adapter.discovery.0 terminated with code 0 (NO_ERROR)
                    2023-12-13 19:49:25.425  - info: host.iobroker instance system.adapter.backitup.0 terminated with code 0 (NO_ERROR)
                    2023-12-13 19:49:25.425  - info: host.iobroker instance system.adapter.trashschedule.0 terminated with code 0 (NO_ERROR)
                    2023-12-13 19:49:25.464  - info: host.iobroker instance system.adapter.web.0 terminated with code 0 (NO_ERROR)
                    2023-12-13 19:49:25.658  - info: host.iobroker instance system.adapter.ping.0 terminated with code 0 (NO_ERROR)
                    2023-12-13 19:49:25.669  - info: host.iobroker instance system.adapter.sonoff.0 terminated with code 0 (NO_ERROR)
                    2023-12-13 19:49:25.669  - info: host.iobroker All instances are stopped.
                    2023-12-13 19:49:25.860  - info: host.iobroker terminated
                    iob diag has finished.
                      @heino
                      systemctl status iobroker
                      sagt?
                        @thomas-braun said in Vis-2 installiert nicht:
                        * iobroker.service - ioBroker Server
                             Loaded: loaded (/lib/systemd/system/iobroker.service; enabled; vendor preset: enabled)
                             Active: active (running) since Wed 2023-12-13 20:00:59 CET; 1h 18min ago
                               Docs: http://iobroker.net
                           Main PID: 7983 (iobroker.js-con)
                              Tasks: 166 (limit: 18909)
                             Memory: 1.1G
                                CPU: 6min 12.439s
                             CGroup: /system.slice/iobroker.service
                                     |- 7983 iobroker.js-controller "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" ">
                                     |- 8001 io.admin.0 "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" ">
                                     |- 8028 io.history.0 "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "">
                                     |- 8043 io.javascript.0 "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "">
                                     |- 8073 io.sonoff.0 "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" >
                                     |- 8088 io.modbus.0 "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" >
                                     |- 8103 io.ping.0 "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "">
                                     |- 8124 io.tr-064.0 "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" >
                                     |- 8143 io.discovery.0 "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" >
                                     |- 8160 io.backitup.0 "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" ">
                                     |- 8181 io.trashschedule.0 "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "">
                                     |- 8198 io.web.0 "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" >
                                     |- 8240 io.sayit.0 "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" ">
                                     |- 8258 io.energiefluss.0 "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" >
                                     |- 8285 io.fritzdect.0 "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" >
                                     `-11667 /bin/ping -n -w 2 -c 1 192.168.188.33
                        lines 1-25/25 (END)
                          @heino
                          iob update
                          iob upgrade all -y
                            Mit welchen Meldungen?
                              wo sehe ich die Meldung
                                @heino
                                Im Log-File.
                                iob logs --watch | uniq
                                anschauen und in einem zweiten Terminal den Adapter installieren und den Absturz provozieren.
                                iob add vis-2 --debug
                                  Hallo Thomas ich hoffe das hilft weiter
                                  heiko@iobroker:~$ iob add vis-2 --debug
                                  upload [11] vis-2.admin /opt/iobroker/node_modules/iobroker.vis-2/admin/i18n/en/translations.json i18n/en/translations.json application/json
                                  upload [8] vis-2.admin /opt/iobroker/node_modules/iobroker.vis-2/admin/i18n/it/translations.json i18n/it/translations.json application/json
                                  upload [7] vis-2.admin /opt/iobroker/node_modules/iobroker.vis-2/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                                  upload [5] vis-2.admin /opt/iobroker/node_modules/iobroker.vis-2/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                                  upload [4] vis-2.admin /opt/iobroker/node_modules/iobroker.vis-2/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                                  upload [2] vis-2.admin /opt/iobroker/node_modules/iobroker.vis-2/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                                   Objects database error: connect ECONNREFUSED 0.0.0.0:9001
                                   States database error: connect ECONNREFUSED 0.0.0.0:9000
                                  2023-12-17 20:38:51.143  - debug: sonoff.0 (183902) Client [Tasmota78-LuefterPV] pingreq
                                  2023-12-17 20:38:51.330  - debug: sonoff.0 (183902) Client [Tasmota-67] pingreq
                                  2023-12-17 20:38:51.369  - debug: sonoff.0 (183902) Client [Tasmota79-HaustuerLED] pingreq
                                  2023-12-17 20:38:51.658  - debug: sonoff.0 (183902) Client [Tasmota114-Pflanze] pingreq
                                  2023-12-17 20:38:51.765  - debug: sonoff.0 (183902) Client [Tasmota36-Trockner] pingreq
                                  2023-12-17 20:38:52.145  - debug: sonoff.0 (183902) Client [Tasmota112-Tim] pingreq
                                  2023-12-17 20:38:59.574  - debug: sonoff.0 (183902) Client [Tasmota25-Garage] pingreq
                                  2023-12-17 20:39:14.832  - info: host.iobroker iobroker add vis-2 --host iobroker
                                  2023-12-17 20:39:15.879  - info: host.iobroker iobroker host.iobroker install adapter vis-2
                                  2023-12-17 20:39:15.990  - info: host.iobroker iobroker upload [12] vis-2.admin /opt/iobroker/node_modules/iobroker.vis-2/admin/i18n/de/translations.json i18n/de/translations.json application/json
                                  2023-12-17 20:39:16.002  - info: host.iobroker iobroker upload [11] vis-2.admin /opt/iobroker/node_modules/iobroker.vis-2/admin/i18n/en/translations.json i18n/en/translations.json application/json
                                  2023-12-17 20:39:16.007  - info: host.iobroker iobroker upload [10] vis-2.admin /opt/iobroker/node_modules/iobroker.vis-2/admin/i18n/es/translations.json i18n/es/translations.json application/json
                                  2023-12-17 20:39:16.013  - info: host.iobroker iobroker upload [9] vis-2.admin /opt/iobroker/node_modules/iobroker.vis-2/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                                  2023-12-17 20:39:16.020  - info: host.iobroker iobroker upload [8] vis-2.admin /opt/iobroker/node_modules/iobroker.vis-2/admin/i18n/it/translations.json i18n/it/translations.json application/json
                                  2023-12-17 20:39:16.026  - info: host.iobroker iobroker upload [7] vis-2.admin /opt/iobroker/node_modules/iobroker.vis-2/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                                  2023-12-17 20:39:16.032  - info: host.iobroker iobroker upload [6] vis-2.admin /opt/iobroker/node_modules/iobroker.vis-2/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                                  2023-12-17 20:39:16.038  - info: host.iobroker iobroker upload [5] vis-2.admin /opt/iobroker/node_modules/iobroker.vis-2/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                                  2023-12-17 20:39:16.044  - info: host.iobroker iobroker upload [4] vis-2.admin /opt/iobroker/node_modules/iobroker.vis-2/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                                  2023-12-17 20:39:16.051  - info: host.iobroker iobroker upload [3] vis-2.admin /opt/iobroker/node_modules/iobroker.vis-2/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
                                  2023-12-17 20:39:16.062  - info: host.iobroker iobroker upload [2] vis-2.admin /opt/iobroker/node_modules/iobroker.vis-2/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                                  2023-12-17 20:39:16.067  - info: host.iobroker iobroker upload [1] vis-2.admin /opt/iobroker/node_modules/iobroker.vis-2/admin/jsonConfig.json jsonConfig.json application/json
                                  2023-12-17 20:39:16.074  - info: host.iobroker iobroker upload [0] vis-2.admin /opt/iobroker/node_modules/iobroker.vis-2/admin/vis-2.png vis-2.png image/png
                                  2023-12-17 20:39:17.803  - info: host.iobroker iobroker upload [685] vis-2 /opt/iobroker/node_modules/iobroker.vis-2/www/asset-manifest.json asset-manifest.json application/json
                                  2023-12-17 20:39:21.196  - debug: sonoff.0 (183902) Client [Tasmota78-LuefterPV] pingreq
                                  2023-12-17 20:39:21.333  - debug: sonoff.0 (183902) Client [Tasmota-67] pingreq
                                  2023-12-17 20:39:21.379  - debug: sonoff.0 (183902) Client [Tasmota79-HaustuerLED] pingreq
                                  2023-12-17 20:39:21.685  - debug: sonoff.0 (183902) Client [Tasmota114-Pflanze] pingreq
                                  2023-12-17 20:39:21.798  - debug: sonoff.0 (183902) Client [Tasmota36-Trockner] pingreq
                                  2023-12-17 20:39:22.198  - debug: sonoff.0 (183902) Client [Tasmota112-Tim] pingreq
                                  2023-12-17 20:39:29.906  - debug: sonoff.0 (183902) Client [Tasmota25-Garage] pingreq
                                  2023-12-17 20:39:30.929  - info: host.iobroker iobroker upload [650] vis-2 /opt/iobroker/node_modules/iobroker.vis-2/www/img/favicon.png img/favicon.png image/png
                                  2023-12-17 20:39:31.156  - info: host.iobroker iobroker upload [600] vis-2 /opt/iobroker/node_modules/iobroker.vis-2/www/lib/css/themes/jquery-ui/cupertino/images/ui-bg_flat_15_cd0a0a_40x100.png lib/css/themes/jquery-ui/cupertino/images/ui-bg_flat_15_cd0a0a_40x100.png image/png
                                  2023-12-17 20:39:31.441  - info: host.iobroker iobroker upload [550] vis-2 /opt/iobroker/node_modules/iobroker.vis-2/www/lib/css/themes/jquery-ui/dark-hive/images/ui-bg_highlight-soft_80_eeeeee_1x100.png lib/css/themes/jquery-ui/dark-hive/images/ui-bg_highlight-soft_80_eeeeee_1x100.png image/png
                                  2023-12-17 20:39:31.683  - info: host.iobroker iobroker upload [500] vis-2 /opt/iobroker/node_modules/iobroker.vis-2/www/lib/css/themes/jquery-ui/eggplant/images/ui-icons_ffffff_256x240.png lib/css/themes/jquery-ui/eggplant/images/ui-icons_ffffff_256x240.png image/png
                                  2023-12-17 20:39:31.934  - info: host.iobroker iobroker upload [450] vis-2 /opt/iobroker/node_modules/iobroker.vis-2/www/lib/css/themes/jquery-ui/hot-sneaks/images/ui-icons_ffffff_256x240.png lib/css/themes/jquery-ui/hot-sneaks/images/ui-icons_ffffff_256x240.png image/png
                                  2023-12-17 20:39:32.213  - info: host.iobroker iobroker upload [400] vis-2 /opt/iobroker/node_modules/iobroker.vis-2/www/lib/css/themes/jquery-ui/redmond/images/ui-icons_6da8d5_256x240.png lib/css/themes/jquery-ui/redmond/images/ui-icons_6da8d5_256x240.png image/png
                                  2023-12-17 20:39:32.497  - info: host.iobroker iobroker upload [350] vis-2 /opt/iobroker/node_modules/iobroker.vis-2/www/lib/css/themes/jquery-ui/sunny/images/ui-bg_inset-soft_30_ffffff_1x100.png lib/css/themes/jquery-ui/sunny/images/ui-bg_inset-soft_30_ffffff_1x100.png image/png
                                  2023-12-17 20:39:32.772  - info: host.iobroker iobroker upload [300] vis-2 /opt/iobroker/node_modules/iobroker.vis-2/www/lib/css/themes/jquery-ui/vader/images/ui-bg_highlight-soft_35_adadad_1x100.png lib/css/themes/jquery-ui/vader/images/ui-bg_highlight-soft_35_adadad_1x100.png image/png
                                  2023-12-17 20:39:34.881  - info: host.iobroker iobroker upload [250] vis-2 /opt/iobroker/node_modules/iobroker.vis-2/www/signals/motionColor.png signals/motionColor.png image/png
                                  2023-12-17 20:39:42.170  - error: energiefluss.0 (183971) States database error: read ECONNRESET
                                  2023-12-17 20:39:42.195  - info: admin.0 (183802) terminating http server on port 8081
                                  2023-12-17 20:39:42.261  - info: javascript.0 (183888) Stop script script.js.Arbeitszimmer_Szene
                                  2023-12-17 20:39:42.262  - error: trashschedule.0 (183953) States database error: read ECONNRESET
                                  2023-12-17 20:39:42.236  - error: fritzdect.0 (183982) States database error: read ECONNRESET
                                  2023-12-17 20:39:42.259  - error: web.0 (183959) States database error: read ECONNRESET
                                  2023-12-17 20:39:42.313  - info: trashschedule.0 (183953) cleaned everything up...
                                  2023-12-17 20:39:42.285  - error: sayit.0 (183993) States database error: read ECONNRESET
                                  2023-12-17 20:39:42.321  - error: backitup.0 (183931) States database error: read ECONNRESET
                                  2023-12-17 20:39:42.346  - info: fritzdect.0 (183982) cleaned everything up...
                                  2023-12-17 20:39:42.309  - info: javascript.0 (183888) Stop script script.js.Fernsehszene
                                  2023-12-17 20:39:42.320  - info: javascript.0 (183888) Stop script script.js.Haus.Schalter_Lampe_AZ
                                  2023-12-17 20:39:42.329  - info: javascript.0 (183888) Stop script script.js.Haus.Zeit
                                  2023-12-17 20:39:42.355  - info: javascript.0 (183888) Stop script script.js.Haus.Zeitschaltuhr_WZ
                                  2023-12-17 20:39:42.356  - info: javascript.0 (183888) Stop script script.js.Haus.Zeitschaltuhr_AZ
                                  2023-12-17 20:39:42.357  - info: javascript.0 (183888) Stop script script.js.Haus.Steuerung_Warmwasser
                                  2023-12-17 20:39:42.360  - info: javascript.0 (183888) Stop script script.js.Haus.Schalter_WZ
                                  2023-12-17 20:39:42.393  - info: sayit.0 (183993) stopping...
                                  2023-12-17 20:39:42.393  - info: backitup.0 (183931) cleaned everything up...
                                  2023-12-17 20:39:42.857  - warn: web.0 (183959) Timeout by termination of web-extensions!
                                  2023-12-17 20:39:42.871  - info: web.0 (183959) terminated http server on port 8082
                                  2023-12-17 20:39:43.643  - info: tr-064.0 (183941) terminating with timeout
                                  2023-12-17 20:39:43.667  - info: tr-064.0 (183941) Terminated (NO_ERROR): Without reason
                                  2023-12-17 20:39:43.690  - info: ping.0 (183920) terminating with timeout
                                  2023-12-17 20:39:43.692  - info: modbus.0 (183895) terminating with timeout
                                  2023-12-17 20:39:43.708  - info: ping.0 (183920) Terminated (NO_ERROR): Without reason
                                  2023-12-17 20:39:43.710  - info: modbus.0 (183895) Terminated (NO_ERROR): Without reason
                                  2023-12-17 20:39:43.741  - info: energiefluss.0 (183971) terminating with timeout
                                  2023-12-17 20:39:43.745  - info: javascript.0 (183888) terminating with timeout
                                  2023-12-17 20:39:43.745  - info: energiefluss.0 (183971) Terminated (NO_ERROR): Without reason
                                  2023-12-17 20:39:43.751  - info: sonoff.0 (183902) terminating with timeout
                                  2023-12-17 20:39:43.753  - info: javascript.0 (183888) Terminated (NO_ERROR): Without reason
                                  2023-12-17 20:39:43.757  - debug: sonoff.0 (183902) Plugin sentry destroyed
                                  2023-12-17 20:39:43.759  - info: sonoff.0 (183902) Terminated (NO_ERROR): Without reason
                                  2023-12-17 20:39:43.756  - info: discovery.0 (183909) terminating with timeout
                                  2023-12-17 20:39:43.785  - info: discovery.0 (183909) Terminated (NO_ERROR): Without reason
                                  2023-12-17 20:39:43.817  - info: trashschedule.0 (183953) terminating with timeout
                                  2023-12-17 20:39:43.824  - info: trashschedule.0 (183953) Terminated (NO_ERROR): Without reason
                                  2023-12-17 20:39:43.846  - info: admin.0 (183802) terminating with timeout
                                  2023-12-17 20:39:43.852  - info: admin.0 (183802) Terminated (NO_ERROR): Without reason
                                  2023-12-17 20:39:43.857  - info: fritzdect.0 (183982) terminating with timeout
                                  2023-12-17 20:39:43.861  - info: fritzdect.0 (183982) Terminated (NO_ERROR): Without reason
                                  2023-12-17 20:39:43.874  - info: web.0 (183959) terminating with timeout
                                  2023-12-17 20:39:43.880  - info: web.0 (183959) Terminated (NO_ERROR): Without reason
                                  2023-12-17 20:39:43.897  - info: backitup.0 (183931) terminating with timeout
                                  2023-12-17 20:39:43.897  - info: sayit.0 (183993) terminating with timeout
                                  2023-12-17 20:39:43.904  - info: sayit.0 (183993) Terminated (NO_ERROR): Without reason
                                  2023-12-17 20:39:43.905  - info: backitup.0 (183931) Terminated (NO_ERROR): Without reason
                                  2023-12-17 20:39:47.144  - error: tr-064.0 (183941) Objects database error: connect ECONNREFUSED 0.0.0.0:9001
                                  2023-12-17 20:39:47.153  - warn: tr-064.0 (183941) get state error: Connection is closed.
                                  2023-12-17 20:39:47.198  - error: modbus.0 (183895) Objects database error: connect ECONNREFUSED 0.0.0.0:9001
                                  2023-12-17 20:39:47.206  - warn: modbus.0 (183895) get state error: Connection is closed.
                                  2023-12-17 20:39:47.207  - warn: modbus.0 (183895) get state error: DB closed
                                  2023-12-17 20:39:47.216  - error: ping.0 (183920) Objects database error: connect ECONNREFUSED 0.0.0.0:9001
                                  2023-12-17 20:39:47.223  - warn: ping.0 (183920) get state error: Connection is closed.
                                  2023-12-17 20:39:47.215  - info: modbus.0 (183895) terminating
                                  2023-12-17 20:39:47.219  - info: modbus.0 (183895) terminating
                                  2023-12-17 20:39:47.229  - info: ping.0 (183920) terminating
                                  2023-12-17 20:39:47.249  - error: energiefluss.0 (183971) Objects database error: connect ECONNREFUSED 0.0.0.0:9001
                                  2023-12-17 20:39:47.256  - error: discovery.0 (183909) Objects database error: connect ECONNREFUSED 0.0.0.0:9001
                                  2023-12-17 20:39:47.259  - error: sonoff.0 (183902) Objects database error: connect ECONNREFUSED 0.0.0.0:9001
                                  2023-12-17 20:39:47.265  - warn: sonoff.0 (183902) get state error: Connection is closed.
                                  2023-12-17 20:39:47.265  - warn: energiefluss.0 (183971) get state error: Connection is closed.
                                  2023-12-17 20:39:47.271  - info: sonoff.0 (183902) terminating
                                  2023-12-17 20:39:47.282  - warn: discovery.0 (183909) get state error: Connection is closed.
                                  2023-12-17 20:39:47.292  - error: history.0 (183725) Objects database error: connect ECONNREFUSED 0.0.0.0:9001
                                  2023-12-17 20:39:47.320  - error: history.0 (183725) States database error: connect ECONNREFUSED 0.0.0.0:9000
                                  2023-12-17 20:39:47.324  - error: trashschedule.0 (183953) Objects database error: connect ECONNREFUSED 0.0.0.0:9001
                                  2023-12-17 20:39:47.334  - warn: trashschedule.0 (183953) get state error: Connection is closed.
                                  2023-12-17 20:39:47.367  - error: fritzdect.0 (183982) Objects database error: connect ECONNREFUSED 0.0.0.0:9001
                                  2023-12-17 20:39:47.370  - error: web.0 (183959) Objects database error: connect ECONNREFUSED 0.0.0.0:9001
                                  2023-12-17 20:39:47.376  - error: javascript.0 (183888) Objects database error: connect ECONNREFUSED 0.0.0.0:9001
                                  2023-12-17 20:39:47.378  - warn: fritzdect.0 (183982) get state error: Connection is closed.
                                  2023-12-17 20:39:47.385  - warn: sayit.0 (183993) get state error: DB closed
                                  2023-12-17 20:39:47.389  - warn: javascript.0 (183888) get state error: DB closed
                                  2023-12-17 20:39:47.390  - warn: javascript.0 (183888) get state error: DB closed
                                  2023-12-17 20:39:47.395  - info: javascript.0 (183888) terminating
                                  2023-12-17 20:39:47.396  - info: javascript.0 (183888) terminating
                                  2023-12-17 20:39:47.405  - error: backitup.0 (183931) Objects database error: connect ECONNREFUSED 0.0.0.0:9001
                                  2023-12-17 20:39:47.411  - warn: backitup.0 (183931) get state error: Connection is closed.
                                  2023-12-17 20:39:47.430  - error: admin.0 (183802) Objects database error: connect ECONNREFUSED 0.0.0.0:9001
                                  ^C
                                  heiko@iobroker:~$
                                    @heino
                                    Da ist die Datenbank wohl hin oder nicht zu erreichen.
                                    1398
