    4. IKEA Trådfri The security code is incorrect or
      dg19222 last edited by
      Huhu alle zusammen
      The security code is incorrect or something else went wrong with the authentication.
      Hat wer ne idee habe schon alles möglich probiert. Security code ist definitiv richtig. Mehrere Neustarts des Adapters des Iobrokers, und des getways.
      LG Daniel
        Thomas Braun Most Active @dg19222 last edited by
        @dg19222
        Versionen? Log?
          dg19222 @Thomas Braun last edited by
          @thomas-braun Version V 3.1.3
          2023-12-13 13:10:20.886 - error: tradfri.0 (2090) The security code is incorrect or something else went wrong with the authentication.
          2023-12-13 13:10:20.887 - error: tradfri.0 (2090) Please check your adapter settings and restart the adapter!
          reicht dir das oder brauchst mehr?
          Danke für dein hilfe
            @dg19222 sagte in IKEA Trådfri The security code is incorrect or:
            Das mal getan? Denn hier läuft der Adapter einwandfrei.
            Schau dir ggf.
            iob diag
            an.
              @thomas-braun ```
              dg19222@Iobrocker:~$ curl -sLf https://iobroker.net/diag.sh
              #!/bin/bash
              iobroker diagnostics
              written to help getting information about the environment the ioBroker installation is running in
              DOCKER=/opt/scripts/.docker_config/.thisisdocker
              #if [[ -f "/opt/scripts/.docker_config/.thisisdocker" ]]
              if [ -f "$DOCKER" ]
              then
              echo "";
              elif [ "$(id -u)" = 0 ];
              then
              echo -e "This script must not be run as root! \nPlease use your standard user!"
              exit 1
              fi
              clear;
              echo "*** iob diag is starting up, please wait ***";
              VARIABLES
              export LC_ALL=C;
              SKRIPTV="2023-10-10"; #version of this script
              NODE_MAJOR=18 #this is the recommended major nodejs version for ioBroker, please adjust accordingly if the recommendation changes
              HOST=$(hostname)
              NODERECOM=$(iobroker state getValue system.host."$HOST".versions.nodeNewestNext); #recommended node version
              NPMRECOM=$(iobroker state getValue system.host."$HOST".versions.npmNewestNext); #recommended npm version
              NODEUSED=$(iobroker state getValue system.host."$HOST".versions.nodeCurrent); #current node version in use
              #NPMUSED=$(iobroker state getValue system.host."$HOST".versions.npmCurrent); #current npm version in use
              XORGTEST=0; #test for GUI
              APT=0;
              INSTENV=0;
              INSTENV2=0;
              SYSTDDVIRT="";
              NODENOTCORR=0;
              clear;
              echo "";
              echo -e "\033[34;107m*** ioBroker Diagnosis \033[0m";
              echo "";
              echo "Please stretch the window of your terminal programm (puTTY) as wide as possible or switch to full screen";
              echo "";
              echo "The following checks may give hints to potential malconfigurations or errors, please post them in our forum:";
              echo "";
              echo "https://forum.iobroker.net";
              echo "";
              echo "Just copy and paste the Summary Page, including the ``` characters at start and end.";
              echo "It helps us to help you!"
              echo "";
              # read -p "Press <Enter> to continue";
              echo "Press any key to continue";
              read -r -n 1 -s
              clear;
              echo "";
              echo -e "\033[33m======== Start marking the full check here =========\033[0m";
              echo "";
              echo "```";
              echo "Skript v.$SKRIPTV"
              echo "";
              BASE SYSTEM ***\033[0m";
              if [ -f "$DOCKER" ]; then
              echo -e "Hardware Vendor : $(cat /sys/devices/virtual/dmi/id/sys_vendor)";
              echo -e "Kernel : $(uname -m)";
              echo -e "Userland : $(dpkg --print-architecture)";
              echo -e "Docker : $(cat /opt/scripts/.docker_config/.thisisdocker)"
              else
              hostnamectl | grep -v 'Machine|Boot';
              echo "";
              grep -i model /proc/cpuinfo | tail -1;
              echo -e "Docker : false";
              fi;
              Alternativer DockerCheck - Nicht getestet:
              if [ -f /.dockerenv ]; then
              echo "I'm inside matrix ;(";
              else
              echo "I'm living in real world!";
              fi
              SYSTDDVIRT=$(systemd-detect-virt 2>/dev/null)
              if [ "$SYSTDDVIRT" != "" ]; then
              echo -e "Virtualization : $(systemd-detect-virt)"
              else
              echo "Virtualization : Docker"
              fi;
              echo "";
              echo "Systemuptime and Load:";
              uptime;
              echo "CPU threads: $(grep -c processor /proc/cpuinfo)"
              echo "";
              RASPBERRY only
              if [[ $(type -P "vcgencmd" 2>/dev/null) = *"/vcgencmd" ]]; then
              echo "Raspberry only:";
              vcgencmd get_throttled 2> /dev/null;
              echo "Other values than 0x0 hint to temperature/voltage problems";
              vcgencmd measure_temp;
              vcgencmd measure_volts;
              TEST CODE
              echo "";
              echo -e "\033[34;107m*** RASPBERRY THROTTLING ***\033[0m";
              CODE from https://github.com/alwye/get_throttled under MIT Licence
              ISSUES_MAP=(
              [0]="Under-voltage detected"
              [1]="Arm frequency capped"
              [2]="Currently throttled"
              [3]="Soft temperature limit active"
              [16]="Under-voltage has occurred"
              [17]="Arm frequency capping has occurred"
              [18]="Throttling has occurred"
              [19]="Soft temperature limit has occurred")
              HEX_BIN_MAP=(
              ["0"]="0000"
              ["1"]="0001"
              ["2"]="0010"
              ["3"]="0011"
              ["4"]="0100"
              ["5"]="0101"
              ["6"]="0110"
              ["7"]="0111"
              ["8"]="1000"
              ["9"]="1001"
              ["A"]="1010"
              ["B"]="1011"
              ["C"]="1100"
              ["D"]="1101"
              ["E"]="1110"
              ["F"]="1111"
              THROTTLED_OUTPUT=$(vcgencmd get_throttled)
              IFS='x'
              read -r -a strarr <<< "$THROTTLED_OUTPUT"
              THROTTLED_CODE_HEX=${strarr[1]}
              Display current issues
              echo "Current issues:"
              CURRENT_HEX=${THROTTLED_CODE_HEX:4:1}
              CURRENT_BIN=${HEX_BIN_MAP[$CURRENT_HEX]}
              if [ "$CURRENT_HEX" == "0" ] || [ -z "$CURRENT_HEX" ]; then
              echo "No throttling issues detected."
              else
              bit_n=0
              for (( i=${#CURRENT_BIN}-1; i>=0; i--)); do
              if [ "${CURRENT_BIN:$i:1}" = "1" ]; then
              echo "~ ${ISSUES_MAP[$bit_n]}"
              bit_n=$((bit_n+1))
              fi
              done
              fi
              echo ""
              Display past issues
              echo "Previously detected issues:"
              PAST_HEX=${THROTTLED_CODE_HEX:0:1}
              PAST_BIN=${HEX_BIN_MAP[$PAST_HEX]}
              if [ "$PAST_HEX" = "0" ]; then
              else
              bit_n=16
              for (( i=${#PAST_BIN}-1; i>=0; i--)); do
              if [ "${PAST_BIN:$i:1}" = "1" ]; then
              bit_n=$((bit_n+1))
              fi
              done
              fi
              fi
              if [[ -f "/var/run/reboot-required" ]]; then
              echo "";
              echo "This system needs to be REBOOTED!";
              echo "";
              fi
              echo "";
              echo -e "\033[34;107m*** Time and Time Zones ***\033[0m";
              date -u;
              date;
              date +"%Z %z";
              cat /etc/timezone;
              else
              timedatectl;
              fi;
              echo "";
              echo -e "\033[34;107m*** User and Groups \033[0m";
              whoami;
              echo "$HOME";
              groups;
              echo "";
              X-Server-Setup ***\033[0m";
              XORGTEST=$(pgrep -f "Xorg")
              XORGTEST=$(ps aux | grep -c 'Xorg')
              if [[ "$XORGTEST" -gt 1 ]];
              then
              echo -e "X-Server: \ttrue"
              else
              echo -e "X-Server: \tfalse"
              fi
              echo -e "Desktop: \t$DESKTOP_SESSION";
              echo -e "Terminal: \t$XDG_SESSION_TYPE";
              echo -e "";
              else
              echo -e "Boot Target: \t$(systemctl get-default)";
              fi;
              echo "";
              echo -e "\033[34;107m*** MEMORY ***\033[0m";
              free -th --mega;
              echo "";
              vmstat -S M -s | head -n 10;
              RASPBERRY only
              echo "";
              vcgencmd mem_oom;
              fi;
              echo "";
              else
              echo "";
              echo -e "\033[34;107m*** FAILED SERVICES \033[0m";
              echo "";
              systemctl list-units --failed --no-pager;
              echo "";
              fi;
              FILESYSTEM ***\033[0m";
              df -PTh;
              echo "";
              echo -e "\033[32mMessages concerning ext4 filesystem in dmesg:\033[0m";
              sudo dmesg -T | grep -i ext4;
              echo "";
              echo -e "\033[32mShow mounted filesystems (real ones only):\033[0m";
              findmnt --real;
              echo "";
              if [[ -L "/opt/iobroker/backups" ]]; then
              echo "backups directory is linked to a different directory";
              echo "";
              fi
              echo -e "\033[32mFiles in neuralgic directories:\033[0m";
              echo "";
              echo -e "\033[32m/var:\033[0m";
              sudo du -h /var/ | sort -rh | head -5;
              echo -e "";
              echo -e ""
              else
              journalctl --disk-usage;
              fi;
              echo "";
              echo -e "\033[32m/opt/iobroker/backups:\033[0m";
              du -h /opt/iobroker/backups/ | sort -rh | head -5;
              echo "";
              echo -e "\033[32m/opt/iobroker/iobroker-data:\033[0m";
              du -h /opt/iobroker/iobroker-data/ | sort -rh | head -5;
              echo "";
              echo -e "\033[32mThe five largest files in iobroker-data are:\033[0m";
              find /opt/iobroker/iobroker-data -maxdepth 15 -type f -exec du -sh {} + | sort -rh | head -n 5;
              echo "";
              Detecting dev-links in /dev/serial/by-id
              echo -e "\033[32mUSB-Devices by-id:\033[0m";
              echo "USB-Sticks - Avoid direct links to /dev/* in your adapter setups, please always prefer the links 'by-id':";
              echo "";
              find /dev/serial/by-id/ -maxdepth 1 -mindepth 1;
              echo "";
              echo -e "\033[34;107m*** NodeJS-Installation ***\033[0m";
              echo "";
              echo -e "$(type -p nodejs) \t$(nodejs -v)";
              echo -e "$(type -p node) \t\t$(node -v)";
              echo -e "$(type -p npm) \t\t$(npm -v)";
              echo -e "$(type -p npx) \t\t$(npx -v)";
              echo -e "$(type -p corepack) \t$(corepack -v)";
              PATHAPT=$(type -p apt);
              PATHNODEJS=$(type -p nodejs);
              PATHNODE=$(type -p node);
              PATHNPM=$(type -p npm);
              PATHNPX=$(type -p npx);
              PATHCOREPACK=$(type -p corepack);
              VERNODEJS=$(nodejs -v);
              VERNODE=$(node -v);
              VERNPM=$(npm -v);
              VERNPX=$(npx -v);
              #VERCOREPACK=$(corepack -v);
              if
              [[ $PATHNODEJS != "/usr/bin/nodejs" ]];
              then
              NODENOTCORR=1
              echo -e "\033[0;31m*** nodejs is NOT correctly installed \033[0m";
              elif
              [[ $PATHNODE != "/usr/bin/node" ]];
              then
              NODENOTCORR=1
              echo -e "\033[0;31m
              elif
              [[ $PATHNPM != "/usr/bin/npm" ]];
              then
              NODENOTCORR=1
              echo -e "\033[0;31m
              elif
              [[ $PATHNPX != "/usr/bin/npx" ]];
              then
              NODENOTCORR=1
              echo -e "\033[0;31m
              elif
              [[ $VERNODEJS != "$VERNODE" ]];
              then
              NODENOTCORR=1
              echo -e "\033[0;31m
              elif
              [[ $VERNPM != "$VERNPX" ]];
              then
              NODENOTCORR=1
              echo -e "\033[0;31m
              elif
              [[ $PATHCOREPACK != "/usr/bin/corepack" ]];
              then
              NODENOTCORR=1
              echo -e "\033[0;31m
              nodejs is NOT correctly installed ***\033[0m";
              else
              echo "";
              fi
              echo "";
              apt-cache policy nodejs;
              echo "";
              npm doctor can be misleading, deactivated to avoid confusion
              echo -e "Calling 'npm doctor' for you. \033[32mPlease be patient!\033[0m";
              echo "";
              (cd /opt/iobroker && sudo -H -u iobroker npm doctor);
              echo "";
              echo "The recommended versions for ioBroker are nodeJS v$NODERECOM / npm v$NPMRECOM!";
              echo "Don't trust the doctor if he recommends different versions!"
              echo "";
              ANZNPMTMP=$(find /opt/iobroker/node_modules -type d -iname '.*-????????' ! -iname '.local-chromium' | wc -l);
              echo -e "\033[32mTemp directories causing npm8 problem:\033[0m ""$ANZNPMTMP""";
              if [[ $ANZNPMTMP -gt 0 ]]
              then
              echo -e "Some problems detected, please run \e[031miob fix\e[0m";
              else
              echo "No problems detected"
              fi;
              echo "";
              echo -e "Temp directories being cleaned up now find /opt/iobroker/node_modules -type d -iname ".*-????????" ! -iname ".local-chromium" -exec rm -rf {} \;";
              find /opt/iobroker/node_modules -type d -iname ".*-????????" ! -iname ".local-chromium" -exec rm -rf {} \ &> /dev/null;
              echo -e "\033[32m1 - Temp directories causing npm8 problem:\033[0m `find /opt/iobroker/node_modules -type d -iname '.*-????????' ! -iname '.local-chromium'>e;
              echo "";
              echo "Errors in npm tree:";
              cd /opt/iobroker && npm ls -a | grep ERR;
              echo "";
              echo -e "\033[34;107m*** ioBroker-Installation ***\033[0m";
              echo "";
              echo -e "\033[32mioBroker Status\033[0m";
              iobroker status;
              echo "";
              multihost detection - wip
              iobroker multihost status
              iobroker status all | grep MULTIHOSTSERVICE/enabled
              echo -e "\033[32mCore adapters versions\033[0m"
              echo -e "js-controller: \t$(iob -v)";
              echo -e "admin: \t\t$(iob version admin)";
              echo -e "javascript: \t$(iob version javascript)";
              echo "";
              echo -e "Adapters from github: \t$( (cd /opt/iobroker && npm ls | grep -c 'git') )";
              echo "";
              echo -e "\033[32mAdapter State\033[0m";
              iob list instances;
              echo "";
              echo -e "\033[32mEnabled adapters with bindings\033[0m";
              iob list instances | grep enabled | grep port ;
              echo "";
              echo -e "\033[32mioBroker-Repositories\033[0m";
              iob repo list;
              echo "";
              echo -e "\033[32mInstalled ioBroker-Instances\033[0m";
              iob update -i;
              echo "";
              echo -e "\033[32mObjects and States\033[0m";
              echo "Please stand by - This may take a while";
              IOBOBJECTS=$(iob list objects 2>/dev/null | wc -l);
              echo -e "Objects: \t$IOBOBJECTS";
              IOBSTATES=$(iob list states 2>/dev/null | wc -l);
              echo -e "States: \t$IOBSTATES";
              echo "";
              echo -e "\033[34;107m*** OS-Repositories and Updates ***\033[0m";
              sudo apt-get update 1>/dev/null && sudo apt-get update
              APT=$(apt-get upgrade -s |grep -P '^\d+ upgraded'|cut -d" " -f1)
              echo -e "Pending Updates: $APT";
              echo "";
              echo -e "\033[34;107m*** Listening Ports ***\033[0m";
              sudo netstat -tulpen #| sed -n '1,2p;/LISTEN/p';
              Alternativ - ss ist nicht ueberall installiert
              sudo ss -tulwp | grep LISTEN;
              echo "";
              echo -e "\033[34;107m*** Log File - Last 25 Lines ***\033[0m";
              echo "";
              iobroker logs --lines 25;
              tail -n 25 /opt/iobroker/log/iobroker.current.log;
              echo "";
              echo "```";
              echo "";
              echo -e "\033[33m============ Mark until here for C&P =============\033[0m";
              echo "";
              echo "iob diag has finished.";
              echo "";
              echo "";
              # read -p "For a Summary please press <Enter>";
              echo "Press any key for a summary";
              read -r -n 1 -s
              echo "";
              clear;
              echo "Copy text starting here:";
              echo "";
              echo "```";
              echo "======================= SUMMARY =======================";
              echo -e "\t\t\tv.$SKRIPTV"
              echo "";
              echo "";
              INSTENV=2
              elif [ "$SYSTDDVIRT" != "none" ]; then
              INSTENV=1
              else
              INSTENV=0
              fi;
              INSTENV2=$(
              if [[ $INSTENV -eq 2 ]]; then
              echo "Docker";
              elif [ $INSTENV -eq 1 ]; then
              echo "$SYSTDDVIRT";
              else
              echo "native";
              fi;)
              if [[ -f "$DOCKER" ]]; then
              else
              fi;
              else
              fi;
              echo "";
              echo -e "Installation: \t\t$INSTENV2";
              echo -e "Kernel: \t\t$(uname -m)";
              echo -e "Userland: \t\t$(dpkg --print-architecture)";
              echo -e "Timezone: \t\t$(cat /etc/timezone)"
              else
              echo -e "Timezone: \t\t$(timedatectl | grep zone | cut -c28-80)";
              fi;
              echo -e "User-ID: \t\t$EUID";
              echo -e "X-Server: \t\t$(if [[ $XORGTEST -gt 1 ]]; then echo "true";else echo "false";fi)";
              echo -e "";
              else
              echo -e "Boot Target: \t\t$(systemctl get-default)";
              fi;
              echo "";
              echo -e "Pending OS-Updates: \t$APT";
              echo -e "Pending iob updates: \t$(iob update -u | grep -c 'Updatable|Updateable')";
              echo "";
              echo "This system needs to be REBOOTED NOW!";
              echo "";
              fi
              echo "";
              echo -e "Nodejs-Installation: \t$( type -p nodejs ) \t$( nodejs -v )";
              echo -e "\t\t\t$(type -P node) \t\t$(node -v)";
              echo -e "\t\t\t$(type -P npm) \t\t$(npm -v)";
              echo -e "\t\t\t$(type -P npx) \t\t$(npx -v)";
              echo -e "\t\t\t$(type -P corepack) \t$(corepack -v)";
              echo -e "";
              echo -e "Recommended versions are nodejs ""$NODERECOM"" and npm ""$NPMRECOM""";
              if
              then
              echo "*** nodejs is NOT correctly installed ";
              echo "Wrong installation path detected. This needs to be fixed.";
              elif
              then
              echo -e "\033[0;31m
              elif
              then
              echo -e "\033[0;31m
              elif
              then
              echo -e "\033[0;31m
              elif
              then
              echo -e "\033[0;31m
              echo "Wrong installation path detected. This needs to be fixed";
              elif
              then
              echo -e "\033[0;31m
              echo "nodejs and node versions do not match. This needs to be fixed.";
              elif
              then
              echo -e "\033[0;31mnodejs is NOT correctly installed\033[0m";
              echo "npm and npx versions do not match. This needs to be fixed.";
              else
              echo "Your nodejs installation is correct";
              fi
              if [[ $NODENOTCORR -eq 1 ]];
              then
              echo "";
              echo "Please check";
              echo "https://forum.iobroker.net/topic/35090/howto-nodejs-installation-und-upgrades-unter-debian";
              echo "for more information on how to fix these errors."
              fi;
              echo "";
              echo -e "Total Memory: \t\tfree -h | awk '/^Mem:/{print $2}'";
              echo "MEMORY: ";
              free -ht --mega;
              echo "";
              echo -e "Active iob-Instances: \t$(iob list instances | grep -c ^+)";
              iob repo list | tail -n1;
              echo "";
              echo -e "ioBroker Core: \t\tjs-controller \t\t$(iob -v)";
              echo -e "\t\t\tadmin \t\t\t$(iob version admin)";
              echo "";
              echo -e "ioBroker Status: \t$(iobroker status)";
              echo "";
              iobroker status all | grep MULTIHOSTSERVICE/enabled;
              echo "Status admin and web instance:";
              iobroker list instances | grep 'admin.|system.adapter.web.'
              echo "";
              echo -e "Objects: \t\t$IOBOBJECTS";
              echo -e "States: \t\t$IOBSTATES";
              echo "";
              echo -e "Size of iob-Database:";
              echo "";
              find /opt/iobroker/iobroker-data -maxdepth 1 -type f -name *objects* -exec du -sh {} + |sort -rh | head -n 5;
              find /opt/iobroker/iobroker-data -maxdepth 1 -type f -name *states* -exec du -sh {} + |sort -rh | head -n 5;
              echo "";
              echo "";
              then
              echo -e "";
              echo -e "Some problems detected, please run \e[031miob fix\e[0m and try to have them fixed";
              echo -e "
              echo -e "";
              else
              echo ""
              fi;
              echo "=================== END OF SUMMARY ===================="
              echo -e "```";
              echo "";
              echo "=== Mark text until here for copying ===";
              D Thomas Braun 2 Replies Last reply Reply Quote 0
                dg19222 @dg19222 last edited by
                @dg19222 ich kann damit leider sehr wenig anfangen 🙂
                  @dg19222
                  Wo hab ich denn geschrieben, dass du den Code per curl herunterladen sollst?
                  iob diag
                  eingeben, fertig.
                    @thomas-braun ging net da kam die meldung das ich es runterladen mus
                    wenn ich es jetzt eingeben will will er sudo passwort das ich leider vergessen habe
                      Das ist schlecht. Aber wie pflegst du denn dein System, ohne Passwort?
                      (Ich glaube, ich möchte die Antwort gar nicht wissen...)
                        @thomas-braun das ging bis dato
                          @dg19222 Node is v18.19.0
                          npm is v10.2.3
                            @dg19222
                            Und der Rest vom Fest?
                              sag mir was du brauchst und ich schike es dir
                                @dg19222
                                Die Ausgabe von
                                iob diag
                                  ok da komme ich leider net ran dann mus es halt leider ohne den adapter gehn
                                  danke dir für die mühe
                                    Thomas Braun Most Active @dg19222 last edited by Thomas Braun
                                    Warum nicht?
                                    Wenn da nodejs 18.19.0 installiert ist muss ja ein PW für den root vorhanden sein, sonst bekommt man das nicht ordentlich auf das System.
                                    Und der root kann natürlich neue PW an die user vergeben.
                                      habe das system gestern aufgesetzt ging alles mit meinem pw nur das net
                                        @dg19222
                                        Dann ist das wohl schief aufgesetzt, denn iob diag funktioniert natürlich grundsätzlich.
                                          @thomas-braun ok wenn du meinst komisch das alles andere geht aber trozdem danke
                                            @dg19222 ich kann es netmal als root ausführen
                                            root@Iobrocker:/opt/iobroker# iob diag
                                            root@Iobrocker:/opt/iobroker# su dg19222
                                            dg19222@Iobrocker:/opt/iobroker$ iob diag
                                            [sudo] password for dg19222:
                                            Sorry, user dg19222 is not allowed to execute '/usr/bin/curl -sLf https://ioer.net/diag.sh --output /home/iobroker/.diag.sh' as iobroker on Iobrocker.
                                            1477
