    4. Fehler beim Update des Telegram Adapters
    • Andreas Stürzer
      Andreas Stürzer last edited by
      Hallo zusammen, ich habe versucht den Telegram Adapter auf die neuste Version abzudaten (sowohl via CLI als auch via GUI)
      Folgenden Fehler erhalte ich hier:
      Would you like to upgrade telegram from @1.16.0 to @3.0.0 now? [(y)es, (n)o]: y
      Update telegram from @1.16.0 to @3.0.0
      Cannot upgrade: Cannot read properties of undefined (reading 'enabled')
      Danke für eure Hilfe
      Andreas
      • DJMarc75
        DJMarc75 @Andreas Stürzer last edited by
        @andreas-stürzer
        und wie bist Du so prinzipiell unterwegs ?
        iob diag
        mal in der Langfassung bitte zeigen
        Andreas Stürzer 1 Reply Last reply Reply Quote 0
        • Andreas Stürzer
          107*** BASE SYSTEM ***
             Static hostname: iobroker-prod
                   Icon name: computer-container
                     Chassis: container
              Virtualization: lxc
            Operating System: Ubuntu 20.04.6 LTS
                      Kernel: Linux 6.2.16-3-pve
                Architecture: x86-64
          model name    : AMD Ryzen 5 5600U with Radeon Graphics
          Docker          : false
          Virtualization  : lxc
          Kernel          : x86_64
          Userland        : amd64
          Systemuptime and Load:
          16:49:03 up 1 day, 20:19,  0 users,  load average: 1.77, 1.95, 1.98
          CPU threads: 6
          107*** Time and Time Zones ***
                         Local time: Wed 2023-12-13 16:49:03 UTC
                     Universal time: Wed 2023-12-13 16:49:03 UTC
                           RTC time: n/a
                          Time zone: Etc/UTC (UTC, +0000)
                        NTP service: inactive
                    RTC in local TZ: no
          107*** User and Groups ***
          iobroker
          /home/iobroker
          iobroker tty dialout audio video
          107*** X-Server-Setup ***
          X-Server:     false
          Desktop:
          Terminal:
          Boot Target:     graphical.target
          107*** MEMORY ***
          Mem:             9G        2.7G        6.3G        0.0K        1.0G        7.3G
          Swap:          1.0G          0B        1.0G
          Total:          11G        2.7G        7.3G
                   9980 M total memory
                   2698 M used memory
                    467 M active memory
                   2999 M inactive memory
                   6262 M free memory
                      0 M buffer memory
                   1018 M swap cache
                   1024 M total swap
                      0 M used swap
                   1024 M free swap
          107*** FAILED SERVICES ***
            UNIT                 LOAD   ACTIVE SUB    DESCRIPTION
          * run-rpc_pipefs.mount loaded failed failed RPC Pipe File System
          1 loaded units listed.
          107*** FILESYSTEM ***
          Filesystem                       Type      Size  Used Avail Use% Mounted on
          /dev/mapper/pve-vm--102--disk--0 ext4       18G  4.7G   12G  28% /
          none                             tmpfs     492K  4.0K  488K   1% /dev
          udev                             devtmpfs  7.5G     0  7.5G   0% /dev/tty
          tmpfs                            tmpfs     7.6G     0  7.6G   0% /dev/shm
          tmpfs                            tmpfs     1.6G  120K  1.6G   1% /run
          tmpfs                            tmpfs     5.0M     0  5.0M   0% /run/lock
          sudo: a terminal is required to read the password; either use the -S option to read from standard input or configure an askpass helper
          TARGET                    SOURCE                           FSTYPE     OPTIONS
          /                         /dev/mapper/pve-vm--102--disk--0 ext4       rw,relatime,stripe=16
          |-/proc/cpuinfo           lxcfs[/proc/cpuinfo]             fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
          |-/proc/diskstats         lxcfs[/proc/diskstats]           fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
          |-/proc/loadavg           lxcfs[/proc/loadavg]             fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
          |-/proc/meminfo           lxcfs[/proc/meminfo]             fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
          |-/proc/slabinfo          lxcfs[/proc/slabinfo]            fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
          |-/proc/stat              lxcfs[/proc/stat]                fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
          |-/proc/swaps             lxcfs[/proc/swaps]               fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
          |-/proc/uptime            lxcfs[/proc/uptime]              fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
          `-/sys/devices/system/cpu lxcfs[/sys/devices/system/cpu]   fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
          /var:
          Archived and active journals take up 424.0M in the file system.
          /opt/iobroker/backups:
          33M    /opt/iobroker/backups/
          /opt/iobroker/iobroker-data:
          399M    /opt/iobroker/iobroker-data/
          203M    /opt/iobroker/iobroker-data/files
          126M    /opt/iobroker/iobroker-data/backup-objects
          67M    /opt/iobroker/iobroker-data/files/javascript.admin
          48M    /opt/iobroker/iobroker-data/files/javascript.admin/static
          21M    /opt/iobroker/iobroker-data/objects.jsonl
          21M    /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js.map
          18M    /opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.274a4d8d.js.map
          9.5M    /opt/iobroker/iobroker-data/states.jsonl
          8.3M    /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js
          USB-Devices by-id:
          107*** NodeJS-Installation ***
          /usr/bin/nodejs     v18.17.1
          /usr/bin/node         v18.17.1
          /usr/bin/npm         9.6.7
          /usr/bin/npx         9.6.7
          /usr/bin/corepack     0.18.0
          nodejs:
            Installed: 18.17.1-deb-1nodesource1
            Candidate: 18.17.1-deb-1nodesource1
            Version table:
          *** 18.17.1-deb-1nodesource1 500
                  500 https://deb.nodesource.com/node_18.x focal/main amd64 Packages
                  100 /var/lib/dpkg/status
               10.19.0~dfsg-3ubuntu1.3 500
                  500 http://archive.ubuntu.com/ubuntu focal-updates/universe amd64 Packages
                  500 http://archive.ubuntu.com/ubuntu focal-security/universe amd64 Packages
               10.19.0~dfsg-3ubuntu1 500
                  500 http://archive.ubuntu.com/ubuntu focal/universe amd64 Packages
          No problems detected
          Errors in npm tree:
          107*** ioBroker-Installation ***
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          Core adapters versions
          js-controller:     5.0.16
          admin:         6.12.1
          javascript:     7.1.6
          Adapters from github:     1
          Adapter State
          + system.adapter.admin.1                  : admin                 : iobroker-prod                            -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
          + system.adapter.backitup.0               : backitup              : iobroker-prod                            -  enabled
          + system.adapter.discovery.0              : discovery             : iobroker-prod                            -  enabled
          + system.adapter.evcc.0                   : evcc                  : iobroker-prod                            -  enabled, port: 7070
            system.adapter.ham.0                    : ham                   : iobroker-prod                            - disabled
          + system.adapter.hmip.0                   : hmip                  : iobroker-prod                            -  enabled
          + system.adapter.hue.0                    : hue                   : iobroker-prod                            -  enabled, port: 80
            system.adapter.ico-cloud.0              : ico-cloud             : iobroker-prod                            -  enabled
          + system.adapter.influxdb.1               : influxdb              : iobroker-prod                            -  enabled, port: 8086
          + system.adapter.info.0                   : info                  : iobroker-prod                            -  enabled
          + system.adapter.javascript.0             : javascript            : iobroker-prod                            -  enabled
          + system.adapter.knx.0                    : knx                   : iobroker-prod                            -  enabled, bind: 192.168.188.76
          + system.adapter.modbus.0                 : modbus                : iobroker-prod                            -  enabled
          + system.adapter.modbus.1                 : modbus                : iobroker-prod                            -  enabled
          + system.adapter.modbus.2                 : modbus                : iobroker-prod                            -  enabled
          + system.adapter.moma.0                   : moma                  : iobroker-prod                            -  enabled
          + system.adapter.mqtt.1                   : mqtt                  : iobroker-prod                            -  enabled, port: 1884, bind: 0.0.0.0
          + system.adapter.mqtt.2                   : mqtt                  : iobroker-prod                            -  enabled, port: 1883, bind: 0.0.0.0
          + system.adapter.mywallbox.0              : mywallbox             : iobroker-prod                            -  enabled
          + system.adapter.netatmo.0                : netatmo               : iobroker-prod                            -  enabled
          + system.adapter.node-red.0               : node-red              : iobroker-prod                            -  enabled, port: 1880, bind: 0.0.0.0
          + system.adapter.philips-tv.0             : philips-tv            : iobroker-prod                            -  enabled
          + system.adapter.pushbullet.0             : pushbullet            : iobroker-prod                            -  enabled
          + system.adapter.pvforecast.0             : pvforecast            : iobroker-prod                            -  enabled
          + system.adapter.shelly.0                 : shelly                : iobroker-prod                            -  enabled, port: 1882, bind: 0.0.0.0
            system.adapter.shelly.1                 : shelly                : iobroker-prod                            - disabled, port: 1882, bind: 0.0.0.0
          + system.adapter.simple-api.0             : simple-api            : iobroker-prod                            -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
          + system.adapter.sma-em.0                 : sma-em                : iobroker-prod                            -  enabled
          + system.adapter.sonoff.0                 : sonoff                : iobroker-prod                            -  enabled, port: 1889, bind: 0.0.0.0
          + system.adapter.sonos.0                  : sonos                 : iobroker-prod                            -  enabled
          + system.adapter.tahoma.0                 : tahoma                : iobroker-prod                            -  enabled
          + system.adapter.telegram.0               : telegram              : iobroker-prod                            -  enabled, port: 8443, bind: 0.0.0.0
          + system.adapter.terminal.0               : terminal              : iobroker-prod                            -  enabled, port: 8088, bind: 0.0.0.0, run as: admin
          + system.adapter.text2command.0           : text2command          : iobroker-prod                            -  enabled
          + system.adapter.web.0                    : web                   : iobroker-prod                            -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
          + system.adapter.zigbee.0                 : zigbee                : iobroker-prod                            -  enabled, port: /dev/ttyACM0
          + instance is alive
          ioBroker-Repositories
          Stable (default): http://download.iobroker.net/sources-dist.json
          Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
          Installed ioBroker-Instances
          Adapter    "admin"        : 6.12.0   , installed 6.12.1
          Adapter    "backitup"     : 2.8.7    , installed 2.8.7
          Adapter    "evcc"         : 0.0.10   , installed 0.0.10
          Adapter    "ham"          : 5.3.1    , installed 5.3.1
          Adapter    "hmip"         : 1.20.0   , installed 1.20.0
          Adapter    "hue"          : 3.10.1   , installed 3.10.1
          Adapter    "ico-cloud"    : 1.1.0    , installed 1.1.0
          Adapter    "influxdb"     : 3.2.0    , installed 3.2.0
          Adapter    "javascript"   : 7.1.6    , installed 7.1.6
          Controller "js-controller": 5.0.17   , installed 5.0.16 [Updatable]
          Adapter    "knx"          : 2.0.23   , installed 2.0.23
          Adapter    "modbus"       : 5.0.11   , installed 5.0.11
          Adapter    "moma"         : 1.2.9    , installed 1.2.9
          Adapter    "mqtt"         : 5.1.0    , installed 2.7.4  [Updatable]
          Adapter    "netatmo"      : 3.1.0    , installed 3.1.0
          Adapter    "node-red"     : 4.0.3    , installed 4.0.3
          Adapter    "philips-tv"   : 0.5.3    , installed 0.5.3
          Adapter    "pushbullet"   : 2.0.1    , installed 2.0.1
          Adapter    "pvforecast"   : 2.9.0    , installed 2.9.0
          Adapter    "shelly"       : 6.6.1    , installed 6.6.1
          Adapter    "sma-em"       : 1.0.0    , installed 1.0.0
          Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
          Adapter    "sonos"        : 3.0.0    , installed 3.0.0
          Adapter    "tahoma"       : 0.10.2   , installed 0.10.2
          Adapter    "telegram"     : 3.0.0    , installed 1.16.0 [Updatable]
          Adapter    "terminal"     : 1.0.0    , installed 1.0.0
          Adapter    "text2command" : 3.0.2    , installed 3.0.2
          Adapter    "web"          : 6.1.10   , installed 6.1.10
          Adapter    "ws"           : 2.5.8    , installed 2.5.8
          Adapter    "zigbee"       : 1.8.24   , installed 1.8.24
          Objects and States
          Objects:     4839
          States:     4027
          107*** OS-Repositories and Updates ***
          Hit:1 http://archive.ubuntu.com/ubuntu focal InRelease
          Hit:2 http://archive.ubuntu.com/ubuntu focal-updates InRelease
          Hit:3 http://archive.ubuntu.com/ubuntu focal-security InRelease
          Hit:4 https://deb.nodesource.com/node_18.x focal InRelease
          Reading package lists...
          Pending Updates: 45
          107*** Listening Ports ***
          107*** Log File - Last 25 Lines ***
          2023-12-13 16:49:30.254  - info: knx.0 (3245502) ( 3.6a ) Received L_DATA.con  06 10 04 20 00 15 04 01 bd 00 2e 00 bc e0 11 fa 72 00 01 00 00  was successfully processed by receiver.
          2023-12-13 16:49:30.254  - info: knx.0 (3245502) Change state from STATE_READY(7) to STATE_TUNNELLING_REQUEST(13)
          2023-12-13 16:49:30.254  - info: knx.0 (3245502) Change state from STATE_TUNNELLING_REQUEST(13) to STATE_TUNNELLING_ACK(14)
          2023-12-13 16:49:30.254  - info: knx.0 (3245502) =====> STATE_TUNNELING_ACK
          2023-12-13 16:49:30.254  - info: knx.0 (3245502) ( 4 ) Sending Tunnel_Request ACK  : 06 10 04 21 00 0a 04 01 bd 00   ChID : 1 SeqCntIN : 189 SeqCntOUT : 153 queue length : 1
          2023-12-13 16:49:30.254  - info: knx.0 (3245502) ( 4.b ) return to STATE_READY, processing : false
          2023-12-13 16:49:30.254  - info: knx.0 (3245502) Change state from STATE_TUNNELLING_ACK(14) to STATE_READY(7)
          2023-12-13 16:49:30.254  - info: knx.0 (3245502)  Has todo still 1 tasks, just processing : false
          2023-12-13 16:49:30.454  - info: knx.0 (3245502) Change state from STATE_READY(7) to STATE_TUNNELLING_SENDING_DATA(8)
          2023-12-13 16:49:30.455  - info: knx.0 (3245502) ( 1 ) Sending : GroupValueWrite :   06 10 04 20 00 19 04 01 99 00 11 00 bc e0 11 fa 72 01 05 00 80 46 c6 16 20    sent to 192.168.188.26:3671  ChID: 1 SeqCntIN : 189 SeqCntOUT : 153 GA : 14/2/1 conCheck.conected : true
          2023-12-13 16:49:30.455  - info: knx.0 (3245502) easy-knx: task.data : 06 10 04 20 00 19 04 01 99 00 11 00 bc e0 11 fa 72 01 05 00 80 46 c6 16 20  byteLen : 25
          2023-12-13 16:49:30.455  - info: knx.0 (3245502) Change state from STATE_TUNNELLING_SENDING_DATA(8) to STATE_TUNNELLING_WAIT_SENT_ACK(9)
          2023-12-13 16:49:30.455  - info: knx.0 (3245502) ( 2 ) Received TUNNEL_ACK      :             06 10 04 21 00 0a 04 01 99 00    from 192.168.188.26:3671 SeqCntIN : 189 SeqCntOUT : 154 GA : 0/0/0
          2023-12-13 16:49:30.455  - info: knx.0 (3245502) Change state from STATE_TUNNELLING_WAIT_SENT_ACK(9) to STATE_TUNNELLING_SENT_DATA_ACK_RECV(11)
          2023-12-13 16:49:30.455  - info: knx.0 (3245502) STATE_TUNNELLING_WAIT_SENT_ACK: received ACK for previous self sent package
          2023-12-13 16:49:30.455  - info: knx.0 (3245502)  ==>  successful acknowledged previous package... processing next of 0
          2023-12-13 16:49:30.455  - info: knx.0 (3245502) Change state from STATE_TUNNELLING_SENT_DATA_ACK_RECV(11) to STATE_READY(7)
          2023-12-13 16:49:30.455  - info: knx.0 (3245502)  ==> easy-knx.js: signal runtime : 0s  1.013398ms
          2023-12-13 16:49:30.484  - info: knx.0 (3245502) ( 3.6a ) Received L_DATA.con  06 10 04 20 00 19 04 01 be 00 2e 00 bc e0 11 fa 72 01 05 00 80 46 c6 16 20  was successfully processed by receiver.
          2023-12-13 16:49:30.484  - info: knx.0 (3245502) Change state from STATE_READY(7) to STATE_TUNNELLING_REQUEST(13)
          2023-12-13 16:49:30.484  - info: knx.0 (3245502) Change state from STATE_TUNNELLING_REQUEST(13) to STATE_TUNNELLING_ACK(14)
          2023-12-13 16:49:30.484  - info: knx.0 (3245502) =====> STATE_TUNNELING_ACK
          2023-12-13 16:49:30.484  - info: knx.0 (3245502) ( 4 ) Sending Tunnel_Request ACK  : 06 10 04 21 00 0a 04 01 be 00   ChID : 1 SeqCntIN : 190 SeqCntOUT : 154 queue length : 0
          2023-12-13 16:49:30.484  - info: knx.0 (3245502) ( 4.b ) return to STATE_READY, processing : false
          2023-12-13 16:49:30.484  - info: knx.0 (3245502) Change state from STATE_TUNNELLING_ACK(14) to STATE_READY(7)
          • Andreas Stürzer
            Andreas Stürzer @DJMarc75 last edited by
            @djmarc75
                       Chassis: container
                Virtualization: lxc
            Docker          : false
            Kernel          : x86_64
            Userland        : amd64
            CPU threads: 6
                             RTC time: n/a
                      RTC in local TZ: no
            iobroker
            /home/iobroker
            X-Server:     false
            Desktop:
            Terminal:
            107*** MEMORY ***
            Swap:          1.0G          0B        1.0G
                     9980 M total memory
                     2698 M used memory
                      467 M active memory
                     6262 M free memory
                        0 M buffer memory
                     1018 M swap cache
                     1024 M total swap
                        0 M used swap
                     1024 M free swap
            /var:
            USB-Devices by-id:
            /usr/bin/npm         9.6.7
            /usr/bin/npx         9.6.7
            nodejs:
              Version table:
            Errors in npm tree:
            ioBroker Status
            Objects type: jsonl
            States  type: jsonl
            admin:         6.12.1
            javascript:     7.1.6
            Adapter State
            + instance is alive
            Objects and States
            Objects:     4839
            States:     4027
            Pending Updates: 45
              Thomas Braun Most Active @Andreas Stürzer last edited by Thomas Braun
              @andreas-stürzer
              Falsche Zeitzone.
              Nodejs nicht aktuell.
              sudo kaputt.
              Ausstehende Updates.
              • DJMarc75
                @andreas-stürzer und der User "iobroker" ist eine denkbar schlechte Wahl.
                Hat denn hier niemand einen Vornamen welchen man als User anlegt ? 😉
                • Andreas Stürzer
                  Mhm danke für eure Rückmeldung aber so richtig weiter hilft mir das nicht.
                  Gibt es die Möglichkeit hier weitere Details zu bekommen wo denn genau das Problem beim Update herkommt. Logs etc...
                  Danke Andreas
                    @andreas-stürzer
                    Richte das System erstmal richtig ein.
                    • Andreas Stürzer
                      Andreas Stürzer @Thomas Braun last edited by
                      Habe die meisten deiner Vorschläge schon umgesetzt bis auf das sudo Thema, das Problem ist leider aber nach wie vor das Gleiche....
                        @andreas-stürzer
                        Wie genau greifst du auf der Container zu, dass der kein Terminal haben soll?
                        • Andreas Stürzer
                          Andreas Stürzer @Thomas Braun last edited by Andreas Stürzer
                          @thomas-braun direkt aus dem iobroker via simple terminal adapter oder via proxmox console
                          Alle anderen Adapter lassen sich ohne Probleme Updaten nur der Telegram eben nicht
                            @andreas-stürzer
                            Dann geh da per Terminalprogramm via ssh rein.
                            Dann gibt es da auch ein terminal für den Prozess
                              @andreas-stürzer
                              Dann setzt du den User noch in die Gruppe 'adm' rein und lässt
                              iob diag
                              nochmal laufen.
                              • Andreas Stürzer
                                *** BASE SYSTEM ***
                                           Chassis: container
                                    Virtualization: lxc
                                Docker          : false
                                Kernel          : x86_64
                                Userland        : amd64
                                 23:22:16 up  3:25,  1 user,  load average: 1.99, 2.13, 2.02
                                CPU threads: 6
                                               Local time: Wed 2023-12-13 23:22:16 CET
                                           Universal time: Wed 2023-12-13 22:22:16 UTC
                                                 RTC time: n/a
                                          RTC in local TZ: no
                                Andreas
                                Andreas sudo
                                X-Server:       false
                                Desktop:
                                Terminal:
                                *** MEMORY ***
                                Mem:             9G        2.3G        7.0G        0.0K        690M        7.6G
                                Swap:          1.0G          0B        1.0G
                                Total:          11G        2.3G        8.0G
                                         9980 M total memory
                                         2337 M used memory
                                          437 M active memory
                                         2360 M inactive memory
                                         6951 M free memory
                                            0 M buffer memory
                                          690 M swap cache
                                         1024 M total swap
                                            0 M used swap
                                         1024 M free swap
                                *** FILESYSTEM ***
                                /dev/mapper/pve-vm--102--disk--0 ext4       18G  4.8G   12G  29% /
                                tmpfs                            tmpfs     1.6G  116K  1.6G   1% /run
                                dmesg: read kernel buffer failed: Operation not permitted
                                /var:
                                1.5G    /var/
                                810M    /var/log
                                809M    /var/log/journal/b354c482f7cc342776f020ee5ea440c3
                                351M    /var/cache
                                Archived and active journals take up 8.0M in the file system.
                                385M    /opt/iobroker/iobroker-data/
                                16M     /opt/iobroker/iobroker-data/objects.jsonl
                                8.0M    /opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.274a4d8d.js
                                USB-Devices by-id:
                                /usr/bin/nodejs         v18.19.0
                                /usr/bin/node           v18.19.0
                                /usr/bin/npm            10.2.3
                                /usr/bin/npx            10.2.3
                                nodejs:
                                  Installed: 18.19.0-1nodesource1
                                  Candidate: 18.19.0-1nodesource1
                                  Version table:
                                 *** 18.19.0-1nodesource1 1001
                                        500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
                                     18.18.2-1nodesource1 1001
                                     18.18.1-1nodesource1 1001
                                     18.18.0-1nodesource1 1001
                                     18.17.1-1nodesource1 1001
                                     18.17.0-1nodesource1 1001
                                     18.16.1-1nodesource1 1001
                                     18.16.0-1nodesource1 1001
                                     18.15.0-1nodesource1 1001
                                     18.14.2-1nodesource1 1001
                                     18.14.1-1nodesource1 1001
                                     18.14.0-1nodesource1 1001
                                     18.13.0-1nodesource1 1001
                                     18.12.0-1nodesource1 1001
                                     18.11.0-1nodesource1 1001
                                     18.10.0-1nodesource1 1001
                                     18.9.1-1nodesource1 1001
                                     18.9.0-1nodesource1 1001
                                     18.8.0-1nodesource1 1001
                                     18.7.0-1nodesource1 1001
                                     18.6.0-1nodesource1 1001
                                     18.5.0-1nodesource1 1001
                                     18.4.0-1nodesource1 1001
                                     18.3.0-1nodesource1 1001
                                     18.2.0-1nodesource1 1001
                                     18.1.0-1nodesource1 1001
                                     18.0.0-1nodesource1 1001
                                Errors in npm tree:
                                ioBroker Status
                                Objects type: jsonl
                                States  type: jsonl
                                js-controller:  5.0.17
                                admin:          6.12.1
                                javascript:     7.1.6
                                Adapter State
                                + system.adapter.ico-cloud.0              : ico-cloud             : iobroker-prod                            -  enabled
                                + instance is alive
                                Controller "js-controller": 5.0.17   , installed 5.0.17
                                Objects and States
                                Objects:        4839
                                States:         4028
                                Pending Updates: 0
                                tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          256387468  135/sshd: /usr/sbin
                                tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          256385754  1/init
                                tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          256386963  285/master
                                tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       256389980  1483/iobroker.js-co
                                tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       256389973  1483/iobroker.js-co
                                tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1000       256401570  1629/io.mqtt.1
                                tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1000       256390126  1558/node-red
                                tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1000       256400023  1674/io.shelly.0
                                tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1000       256401641  1644/io.mqtt.2
                                tcp        0      0 0.0.0.0:1889            0.0.0.0:*               LISTEN      1000       256402667  1787/io.sonoff.0
                                tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      106        256388408  96/systemd-resolved
                                tcp6       0      0 :::8088                 :::*                    LISTEN      1000       256411530  3304/io.terminal.0
                                tcp6       0      0 :::8087                 :::*                    LISTEN      1000       256405617  2236/io.simple-api.
                                tcp6       0      0 :::8081                 :::*                    LISTEN      1000       256400456  1501/io.admin.1
                                tcp6       0      0 :::8082                 :::*                    LISTEN      1000       256405810  2489/io.web.0
                                tcp6       0      0 :::22                   :::*                    LISTEN      0          256387470  135/sshd: /usr/sbin
                                tcp6       0      0 :::111                  :::*                    LISTEN      0          256385756  1/init
                                tcp6       0      0 ::1:25                  :::*                    LISTEN      0          256386964  285/master
                                tcp6       0      0 :::3500                 :::*                    LISTEN      1000       256402598  1696/io.sonos.0
                                udp        0      0 192.168.188.76:40004    0.0.0.0:*                           1000       256399260  2188/io.knx.0
                                udp        0      0 127.0.0.53:53           0.0.0.0:*                           106        256388407  96/systemd-resolved
                                udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          256385755  1/init
                                udp6       0      0 :::111                  :::*                                0          256385757  1/init
                                2023-12-13 22:22:40.253  - info: knx.0 (2188) ( 3.6a ) Received L_DATA.con  06 10 04 20 00 15 04 01 bc 00 2e 00 bc e0 11 fa 72 00 01 00 00  was successfully processed by receiver.
                                2023-12-13 22:22:40.253  - info: knx.0 (2188) Change state from STATE_READY(7) to STATE_TUNNELLING_REQUEST(13)
                                2023-12-13 22:22:40.253  - info: knx.0 (2188) Change state from STATE_TUNNELLING_REQUEST(13) to STATE_TUNNELLING_ACK(14)
                                2023-12-13 22:22:40.253  - info: knx.0 (2188) =====> STATE_TUNNELING_ACK
                                2023-12-13 22:22:40.253  - info: knx.0 (2188) ( 4 ) Sending Tunnel_Request ACK  : 06 10 04 21 00 0a 04 01 bc 00   ChID : 1 SeqCntIN : 188 SeqCntOUT : 197 queue length : 1
                                2023-12-13 22:22:40.253  - info: knx.0 (2188) ( 4.b ) return to STATE_READY, processing : false
                                2023-12-13 22:22:40.253  - info: knx.0 (2188) Change state from STATE_TUNNELLING_ACK(14) to STATE_READY(7)
                                2023-12-13 22:22:40.253  - info: knx.0 (2188)  Has todo still 1 tasks, just processing : false
                                2023-12-13 22:22:40.453  - info: knx.0 (2188) Change state from STATE_READY(7) to STATE_TUNNELLING_SENDING_DATA(8)
                                2023-12-13 22:22:40.454  - info: knx.0 (2188) ( 1 ) Sending : GroupValueWrite :   06 10 04 20 00 19 04 01 c5 00 11 00 bc e0 11 fa 72 01 05 00 80 46 c6 16 20    sent to 192.168.188.26:3671  ChID: 1 SeqCntIN : 188 SeqCntOUT : 197 GA : 14/2/1 conCheck.conected : true
                                2023-12-13 22:22:40.454  - info: knx.0 (2188) easy-knx: task.data : 06 10 04 20 00 19 04 01 c5 00 11 00 bc e0 11 fa 72 01 05 00 80 46 c6 16 20  byteLen : 25
                                2023-12-13 22:22:40.454  - info: knx.0 (2188) Change state from STATE_TUNNELLING_SENDING_DATA(8) to STATE_TUNNELLING_WAIT_SENT_ACK(9)
                                2023-12-13 22:22:40.455  - info: knx.0 (2188) ( 2 ) Received TUNNEL_ACK      :             06 10 04 21 00 0a 04 01 c5 00    from 192.168.188.26:3671 SeqCntIN : 188 SeqCntOUT : 198 GA : 0/0/0
                                2023-12-13 22:22:40.455  - info: knx.0 (2188) Change state from STATE_TUNNELLING_WAIT_SENT_ACK(9) to STATE_TUNNELLING_SENT_DATA_ACK_RECV(11)
                                2023-12-13 22:22:40.455  - info: knx.0 (2188) STATE_TUNNELLING_WAIT_SENT_ACK: received ACK for previous self sent package
                                2023-12-13 22:22:40.455  - info: knx.0 (2188)  ==>  successful acknowledged previous package... processing next of 0
                                2023-12-13 22:22:40.455  - info: knx.0 (2188) Change state from STATE_TUNNELLING_SENT_DATA_ACK_RECV(11) to STATE_READY(7)
                                2023-12-13 22:22:40.455  - info: knx.0 (2188)  ==> easy-knx.js: signal runtime : 0s  1.33787ms
                                2023-12-13 22:22:40.483  - info: knx.0 (2188) ( 3.6a ) Received L_DATA.con  06 10 04 20 00 19 04 01 bd 00 2e 00 bc e0 11 fa 72 01 05 00 80 46 c6 16 20  was successfully processed by receiver.
                                2023-12-13 22:22:40.484  - info: knx.0 (2188) Change state from STATE_READY(7) to STATE_TUNNELLING_REQUEST(13)
                                2023-12-13 22:22:40.484  - info: knx.0 (2188) Change state from STATE_TUNNELLING_REQUEST(13) to STATE_TUNNELLING_ACK(14)
                                2023-12-13 22:22:40.484  - info: knx.0 (2188) =====> STATE_TUNNELING_ACK
                                2023-12-13 22:22:40.484  - info: knx.0 (2188) ( 4 ) Sending Tunnel_Request ACK  : 06 10 04 21 00 0a 04 01 bd 00   ChID : 1 SeqCntIN : 189 SeqCntOUT : 198 queue length : 0
                                2023-12-13 22:22:40.484  - info: knx.0 (2188) ( 4.b ) return to STATE_READY, processing : false
                                2023-12-13 22:22:40.484  - info: knx.0 (2188) Change state from STATE_TUNNELLING_ACK(14) to STATE_READY(7)
                                  @andreas-stürzer
                                  Warum hat der User Andreas kein home?
                                    @andreas-stürzer
                                    iob update
                                    iob upgrade telegram --debug
                                    sagt?
                                    • Andreas Stürzer
                                      @thomas-braun Wurde wahrscheinlich bei der Anlage nicht gesetzt
                                      • Andreas Stürzer
                                        This upgrade of "telegram" will introduce the following changes:
                                        -> 3.0.0:
                                        BREAKING CHANGE: Socks5 support has been removed.
                                        Extended and improved the returned list of processed messages.
                                        -> 2.0.2:
                                        Dependencies have been updated.
                                        -> 2.0.1:
                                        Incorrect trailing zero in callback of sendTo() has been fixed. [#680]
                                        -> 2.0.0:
                                        Packets were updated.
                                        BREAKING CHANGE: The minimal node.js version is 16
                                        BREAKING CHANGE: Return an object with chatId and messageId instead of the message count
                                        BE CAREFUL: THIS IS A MAJOR UPGRADE, WHICH WILL MOST LIKELY INTRODUCE BREAKING CHANGES!
                                          @andreas-stürzer
                                          Dann setz den in die Gruppen rein:
                                          sudo usermod -a -G adm,dialout,iobroker Andreas
                                          • Andreas Stürzer
                                            @thomas-braun ist erledigt
                                            851
