    5. Errormeldung Blockly Skript (compile failed: at)
    • NinjaTurtle85
      NinjaTurtle85 last edited by
      Ich bekomme diese Error Meldungen nicht in den Griff:
      javascript.0
      	2023-12-16 07:20:39.802	error	at processImmediate (node:internal/timers:478:21)
      javascript.0
      	2023-12-16 07:20:39.802	error	at Immediate._onImmediate (/opt/iobroker/node_modules/iobroker.javascript/main.js:1671:17)
      javascript.0
      	2023-12-16 07:20:39.802	error	at /opt/iobroker/node_modules/iobroker.javascript/main.js:2197:17
      javascript.0
      	2023-12-16 07:20:39.802	error	at prepareScript (/opt/iobroker/node_modules/iobroker.javascript/main.js:2099:37)
      javascript.0
      	2023-12-16 07:20:39.802	error	at createVM (/opt/iobroker/node_modules/iobroker.javascript/main.js:1846:21)
      javascript.0
      	2023-12-16 07:20:39.802	error	at new Script (node:vm:94:7)
      javascript.0
      	2023-12-16 07:20:39.802	error	SyntaxError: Unexpected token ')'
      javascript.0
      	2023-12-16 07:20:39.802	error	^
      javascript.0
      	2023-12-16 07:20:39.802	error	setState('javascript.0.zeiten.sonnenaufgang_minute' /* sonnenaufgang_minute */, ('' + getDateObject(getAstroDate('sunrise', undefined, 0)).getMinutes())));
      javascript.0
      	2023-12-16 07:20:39.802	error	script.js.common.Allgemein.RollladenZeit compile failed: at script.js.common.Allgemein.RollladenZeit:67
      Java Adater: V7.5.0
      Kann mir jemand Helfen?
      NinjaTurtle85 1 Reply Last reply Reply Quote 0
      • NinjaTurtle85
        NinjaTurtle85 @NinjaTurtle85 last edited by NinjaTurtle85
        Es lag an der Astrozeit abfrage.
          <block type="schedule" id="~.j87+foPnE#n)eT93rn" x="-1762" y="2063">
            <field name="SCHEDULE">5 */12 * * *</field>
              <block type="comment" id="[ExTzdI8@Eg{./04DsBY">
                <field name="COMMENT">Sonnenaufgang</field>
                  <block type="control" id="`Uk,BQ[wWYb#-0}{j`}!">
                    <field name="OID">javascript.0.zeiten.sonnenaufgang</field>
                      <block type="convert_tostring" id="U%F?0xBqF3XHitKMY|TV">
                          <block type="convert_from_date" id="B|lK0?j|-5%?m(HN{hl%">
                            <field name="OPTION">hh:mm</field>
                              <block type="time_astro" id=";)0;TglnL9egMLO*vC7)">
                                <field name="TYPE">sunrise</field>
                                <field name="OFFSET">0</field>
                      <block type="control" id="|:Vl-]3?9}!X}/`^`)y+">
                        <field name="OID">javascript.0.zeiten.sonnenaufgang_stunde</field>
                          <block type="convert_tostring" id="9vIr`eyxF9dePKZwv)2f">
                              <block type="convert_from_date" id="hji=xV`a)m=E`atGYY!|">
                                <field name="OPTION">h</field>
                                  <block type="time_astro" id="8T:N1EK)%XW;;!|v;*:{">
                          <block type="control" id=".z@;VfpW?SZ`d`!B4]Vd">
                            <field name="OID">javascript.0.zeiten.sonnenaufgang_minute</field>
                              <block type="convert_tostring" id="(O2/!Po?ho@(qOy1GwMh">
                                  <block type="convert_from_date" id=")U.KaOF-=-xS0/dVKt.b">
                                    <field name="OPTION">m</field>
                                      <block type="time_astro" id="v%eiPa;4WFeOCft6E|((">
                              <block type="comment" id="dNle~;20WNfWoR2qv+JF">
                                <field name="COMMENT">Sonnenuntergang</field>
                                  <block type="control" id="o,-P^2k,pO.XL5jRJU@{">
                                    <field name="OID">javascript.0.zeiten.sonnenuntergang</field>
                                      <block type="convert_tostring" id="oc+^#b,A.i[6cT;gC}3r">
                                          <block type="convert_from_date" id="1ZmHC7@@y21}ih5Glz@Z">
                                              <block type="time_astro" id="tbVuLpYX,jE^!!BGqP0-">
                                                <field name="TYPE">sunset</field>
        • MartinP
          MartinP @NinjaTurtle85 last edited by
          @ninjaturtle85 Ist das die korrigierte Version, oder die, die den Fehler erzeugt?
          • NinjaTurtle85
            NinjaTurtle85 @MartinP last edited by
            @martinp Diese Erzeugt den Fehler.
            Ich habe den Block jetzt gelöscht da ich den Datenpunkt sowieso nicht mehr brauche.
            • MartinP
              @ninjaturtle85 "Java Adapter 7.5"? Bist Du nicht im Stable Repository? Wenn man Adapter aus dem experimental Repository zieht, kann so etwas schon einmal passiereren. Wäre dann ggfs. einen Issue in Github wert ...
              ich bin in stable, und bei mir sieht das so aus:
              • NinjaTurtle85
                @martinp das stimmt. Werde ich tun.
                • MartinP
                  MartinP @NinjaTurtle85 last edited by MartinP
                  @ninjaturtle85 Habe mal dein XML importiert - das erzeugte Javascript sieht unauffällig aus ...
                  schedule("5 */12 * * *", async () => {
                    // Sonnenaufgang
                    setState('javascript.0.zeiten.sonnenaufgang', ('' + formatDate(getDateObject(getAstroDate('sunrise', undefined, 0)), "hh:mm")));
                    setState('javascript.0.zeiten.sonnenaufgang_stunde', ('' + getDateObject(getAstroDate('sunrise', undefined, 0)).getHours()));
                    setState('javascript.0.zeiten.sonnenaufgang_minute', ('' + (getDateObject(getAstroDate('sunrise', undefined, 0)).getMinutes())));
                    // Sonnenuntergang
                    setState('javascript.0.zeiten.sonnenuntergang', ('' + formatDate(getDateObject(getAstroDate('sunset', undefined, 0)), "hh:mm")));
                  Edit, laut Fehlermeldung hat die Zeile 4 in Deiner Version des aus dem Blockly generierten Javascript-Quellcodes am Zeilenende eine schließende Klammer mehr.
                  Da verhaspelt sich der Codegenerator des Blockly wohl ein wenig im experimental release ...
                  Quatsch - habe mich verguckt, die Zeile sieht genauso aus ... in meinem Javascript Editor von 7.1.xx
                  Quatsch2 da fehlt doch eine öffnende Klammer - hier die beiden Zeilen im Vergleich (oben fehlermeldung vs. unten bei mir erzeugter Code) :
                  setState('javascript.0.zeiten.sonnenaufgang_minute', ('' + getDateObject(getAstroDate('sunrise', undefined, 0)).getMinutes())));
                    ticaki Developer @MartinP last edited by ticaki
                    @martinp
                    Bitte Issue eröffnen, wegen der fehlenden Klammer. bzw. die schließende scheint zu viel.
                    MartinP 1 Reply Last reply Reply Quote 2
                    • MartinP
                      MartinP @ticaki last edited by MartinP
                      @ticaki Erledigt https://github.com/ioBroker/ioBroker.javascript/issues/1463 - vielleicht kann @NinjaTurtle85 auch noch etwas ausfüllen - Die Umgebung zur Reproduktion des Fehlers kenne ich nicht ...
                      MartinP1 created this issue in ioBroker/ioBroker.javascript
                      closed Blockly script creates inpaired round brackets #1463
