    4. Zigbee Problem mit ZB-SW01
    • jmeister79
      jmeister79 last edited by jmeister79
      Moin,
      Nach Update auf den neuen Zigbee Adapter v 1.8.25 habe ich bei Zwei Schaltern ein Problem. Beide vom selben Typ:
      Das haben die vorher nicht gemacht.
      Folgendes kommt im Minutentakt im Log:
      zigbee.0
      2023-12-20 15:20:47.934	error	DeviceConfigure:Failed to DeviceConfigure.configure 0x00124b0022ecf8f3 ZB-SW01 (Error: ConfigureReporting 0x00124b0022ecf8f3/1 genOnOff([{"minimumReportInterval":0,"maximumReportInterval":65000,"reportableChange":1,"attribute":"onOff"}], {"sendWhen":"immediate","timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":true,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false}) failed (Timeout - 29387 - 1 - 255 - 6 - 7 after 10000ms) at Timeout._onTimeout (/opt/iobroker/node_modules/zigbee-herdsman/src/utils/waitress.ts:64:35) at listOnTimeout (node:internal/timers:569:17) at processTimers (node:internal/timers:512:7))
      zigbee.0
      2023-12-20 15:20:47.761	error	DeviceConfigure:Failed to DeviceConfigure.configure 0x00124b0022fda538 ZB-SW01 (Error: ConfigureReporting 0x00124b0022fda538/1 genOnOff([{"minimumReportInterval":0,"maximumReportInterval":65000,"reportableChange":1,"attribute":"onOff"}], {"sendWhen":"immediate","timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":true,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false}) failed (Timeout - 18232 - 1 - 254 - 6 - 7 after 10000ms) at Timeout._onTimeout (/opt/iobroker/node_modules/zigbee-herdsman/src/utils/waitress.ts:64:35) at listOnTimeout (node:internal/timers:569:17) at processTimers (node:internal/timers:512:7))
