    4. ioBroker startet nicht nach Neuinstallation
      Willi-Wunder last edited by Willi-Wunder
      wollte meinen Rasp mal ein neues System gönnen, nachdem Buster in die Jahre gekommen ist.
      Also neue SD Karte mit dem Installer neues Debian Bookworm installiert und dann den iobroker.
      Dieser startet aber leider nicht.
      io diag gibt folgendes aus:
      Skript v.2023-10-10
      *** BASE SYSTEM ***
       Static hostname: raspberrypi
             Icon name: computer
                Kernel: Linux 6.1.0-rpi7-rpi-v8
          Architecture: arm64
      Model           : Raspberry Pi 4 Model B Rev 1.1
      Docker          : false
      Virtualization  : none
      Kernel          : aarch64
      Userland        : arm64
      Systemuptime and Load:
       01:28:39 up  1:27,  4 users,  load average: 0.47, 0.59, 0.46
      CPU threads: 4
      *** RASPBERRY THROTTLING ***
      Current issues:
      Previously detected issues:
      *** Time and Time Zones ***
                     Local time: Fri 2023-12-22 01:28:39 CET
                 Universal time: Fri 2023-12-22 00:28:39 UTC
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      *** User and Groups ***
      pi
      /home/pi
      pi adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
      *** X-Server-Setup ***
      X-Server:       false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Mem:            4.0G        399M        2.5G         16M        1.2G        3.6G
      Total:          4.1G        399M        2.6G
               3793 M total memory
                381 M used memory
                495 M active memory
                719 M inactive memory
               2406 M free memory
                 61 M buffer memory
               1035 M swap cache
                 99 M total swap
                  0 M used swap
                 99 M free swap
      Raspberry only:
      oom events: 0
      *** FAILED SERVICES ***
      0 loaded units listed.
      *** FILESYSTEM ***
      udev           devtmpfs  1.6G     0  1.6G   0% /dev
      tmpfs          tmpfs     380M  1.3M  379M   1% /run
      /dev/mmcblk0p2 ext4       29G  5.1G   23G  19% /
      tmpfs          tmpfs     1.9G  148K  1.9G   1% /dev/shm
      /dev/mmcblk0p1 vfat      510M   73M  438M  15% /boot/firmware
      tmpfs          tmpfs     380M   36K  380M   1% /run/user/1000
      [Fri Dec 22 00:00:57 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:25:C4:21 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=ed1bb1a5-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
      [Fri Dec 22 00:01:00 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
      [Fri Dec 22 00:01:02 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
      TARGET               SOURCE         FSTYPE      OPTIONS
      /                    /dev/mmcblk0p2 ext4        rw,noatime
      |-/run/user/1000/doc portal         fuse.portal rw,nosuid,nodev,relatime,user_id=1000,group_id=1000
      `-/boot/firmware     /dev/mmcblk0p1 vfat        rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
      /var:
      525M    /var/
      192M    /var/cache
      191M    /var/lib
      179M    /var/cache/apt
      132M    /var/lib/apt/lists
      Archived and active journals take up 40.0M in the file system.
      /opt/iobroker/backups:
      du: cannot access '/opt/iobroker/backups/': No such file or directory
      /opt/iobroker/iobroker-data:
      du: cannot access '/opt/iobroker/iobroker-data/': No such file or directory
      find: '/opt/iobroker/iobroker-data': No such file or directory
      USB-Devices by-id:
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v18.19.0
      /usr/bin/node           v18.19.0
      /usr/bin/npm            10.2.3
      /usr/bin/npx            10.2.3
      nodejs:
        Installed: 18.19.0-1nodesource1
        Candidate: 18.19.0-1nodesource1
        Version table:
       *** 18.19.0-1nodesource1 500
              100 /var/lib/dpkg/status
           18.18.2-1nodesource1 500
           18.18.1-1nodesource1 500
           18.18.0-1nodesource1 500
           18.17.1-1nodesource1 500
           18.17.0-1nodesource1 500
           18.16.1-1nodesource1 500
           18.16.0-1nodesource1 500
           18.15.0-1nodesource1 500
           18.14.2-1nodesource1 500
           18.14.1-1nodesource1 500
           18.14.0-1nodesource1 500
           18.13.0+dfsg1-1 500
           18.13.0-1nodesource1 500
           18.12.0-1nodesource1 500
           18.11.0-1nodesource1 500
           18.10.0-1nodesource1 500
           18.9.1-1nodesource1 500
           18.9.0-1nodesource1 500
           18.8.0-1nodesource1 500
           18.7.0-1nodesource1 500
           18.6.0-1nodesource1 500
           18.5.0-1nodesource1 500
           18.4.0-1nodesource1 500
           18.3.0-1nodesource1 500
           18.2.0-1nodesource1 500
           18.1.0-1nodesource1 500
           18.0.0-1nodesource1 500
      No problems detected
      Errors in npm tree:
      npm ERR! code ELSPROBLEMS
      npm ERR! invalid: iobroker.admin@6.12.0 /opt/iobroker/node_modules/iobroker.admin
      npm ERR! invalid: iobroker.backitup@2.8.7 /opt/iobroker/node_modules/iobroker.backitup
      npm ERR! invalid: iobroker.discovery@4.2.0 /opt/iobroker/node_modules/iobroker.discovery
      npm ERR! invalid: iobroker.js-controller@5.0.17 /opt/iobroker/node_modules/iobroker.js-controller
      npm ERR! invalid: fsevents@ /opt/iobroker/node_modules/chokidar/node_modules/fsevents
      npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2023-12-22T00_28_46_319Z-debug-0.log
      *** ioBroker-Installation ***
      ioBroker Status
      Uncaught Rejection: Error: /opt/iobroker/iobroker-data/iobroker.json: ENOENT: no such file or directory, open '/opt/iobroker/iobroker-data/iobroker.json'
          at Object.openSync (node:fs:596:3)
          at Object.readFileSync (node:fs:464:35)
          at Object.readFileSync (/opt/iobroker/node_modules/jsonfile/index.js:50:22)
          at dbConnect (/opt/iobroker/node_modules/@iobroker/js-controller-cli/build/lib/setup/dbConnection.js:63:39)
          at CLIProcess.status (/opt/iobroker/node_modules/@iobroker/js-controller-cli/build/lib/cli/cliProcess.js:194:9)
          at processCommand (/opt/iobroker/node_modules/@iobroker/js-controller-cli/build/lib/setup.js:483:25)
          at Object.execute (/opt/iobroker/node_modules/@iobroker/js-controller-cli/build/lib/setup.js:2705:5)
          at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js:1:40)
          at Module._compile (node:internal/modules/cjs/loader:1356:14)
          at Module._extensions..js (node:internal/modules/cjs/loader:1414:10)
      Core adapters versions
      js-controller:  5.0.17
      admin:          6.12.0
      javascript:     "javascript" not found
      npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2023-12-22T00_28_59_759Z-debug-0.log
      Adapters from github:   0
      Adapter State
          at processCommand (/opt/iobroker/node_modules/@iobroker/js-controller-cli/build/lib/setup.js:1193:42)
          at Module.load (node:internal/modules/cjs/loader:1197:32)
      ioBroker-Repositories
          at processCommand (/opt/iobroker/node_modules/@iobroker/js-controller-cli/build/lib/setup.js:2298:42)
      Installed ioBroker-Instances
          at processCommand (/opt/iobroker/node_modules/@iobroker/js-controller-cli/build/lib/setup.js:498:42)
      Objects and States
      Objects:        0
      States:         0
      Hit:1 http://archive.raspberrypi.com/debian bookworm InRelease
      Hit:2 http://deb.debian.org/debian bookworm InRelease
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14813      769/sshd: /usr/sbin
      tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          14805      734/cupsd
      tcp6       0      0 :::22                   :::*                    LISTEN      0          14815      769/sshd: /usr/sbin
      tcp6       0      0 ::1:631                 :::*                    LISTEN      0          14804      734/cupsd
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        16144      520/avahi-daemon: r
      udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          16841      1085/cups-browsed
      udp        0      0 0.0.0.0:54193           0.0.0.0:*                           104        16146      520/avahi-daemon: r
      udp6       0      0 :::5353                 :::*                                104        16145      520/avahi-daemon: r
      udp6       0      0 :::38688                :::*                                104        16147      520/avahi-daemon: r
      udp6       0      0 fe80::b088:67a0:c62:546 :::*                                0          15211      602/NetworkManager
      tail: cannot open '/opt/iobroker/log/iobroker.current.log' for reading: No such file or directory
      iob diag has finished.
      Press any key for a summary
      danach auch den iob fix ausgeführt, geht trotzdem nicht. Kann mir jemand helfen?
      Vielen Dank.
        Homoran Global Moderator Administrators @Willi-Wunder last edited by
        @willi-wunder ich hab das mal von dem urslt-Thread aus 2018 abgetrennt
          Thomas Braun Most Active @Willi-Wunder last edited by
          @willi-wunder
          Da sieht fast so aus, als wenn da gar nichts installiert wurde.
          Wie hast du denn da ein Backup eingespielt?
            Willi-Wunder @Thomas Braun last edited by
            Ein Backup hab ich hier noch gar nicht eingespielt, soweit bin ich gar nicht gekommen.
            Hab auf eine neue SD Karte mit dem Installer ein neues Debian System Bookworm installiert und danach wollte den iobroker mit den Befehl curl -sLf https://iobroker.net/install.sh | bash - installieren.
            Der erhoffte erfolg trat leider nicht ein. Danach hab ich den Befehl iob diag + iob fix ausgeführt. Irgendetwas scheint schief gelaufen zu sein. Ansonsten mache ich die SD Karte nochmal platt und probiere es nochmal.
            Wollte dann mein bestehendes System updaten, ist aber auch gescheitert. Deine Empfehlung war dann ja trotzdem die Neuinstallation.
              @willi-wunder sagte in ioBroker startet nicht nach Neuinstallation:
              richtig!
              wie @Thomas-Braun schon schrieb sueht es aus, als ob die Installation nicht durchgelaufen wäre OS und node ist ok, aber dann...??
              Standen Neldungen während der Installation in der Ausgabe?
                @willi-wunder
                Wie sieht denn die Installation per
                aus?
                  Willi-Wunder @Homoran last edited by
                  @homoran sagte in ioBroker startet nicht nach Neuinstallation:
                  richtig!
                  Nachdem ich den Befehl curl -sLf https://iobroker.net/install.sh | bash - ausgeführt habe und nach 45 min noch kein Ende kam, hab ich es abgebrochen und dann nochmal neu ausgeführt. Es kam dann zwar die Meldung mit der url:8081, diese konnte ich aber nicht aufrufen. Hab jetzt erstmal mal meine alte SD Karte drin, Buster System läuft.
                  Soll ich nochmal alles platt machen oder erst nochmal curl -sLf https://iobroker.net/install.sh | bash - probieren?
                  ? Homoran 2 Replies Last reply Reply Quote 0
                    A Former User @Willi-Wunder last edited by
                    Moin,
                    mir ist bekannt, dass es noch Beta ist, aber ich würde Dir mal das zu raten -> https://forum.iobroker.net/topic/71157/iobroker-raspberry-os-image-v2
                    VG
                    Bernd
                      und von keinem Versuch auch nur eine Zeile gepostet 😡
                        Sorry, war eine lange Nacht und früh dann der Frust groß. Dachte mit dem Befehl iob diag sieht man was los ist.
                        Leihe mir jetzt einen Rasp damit ich in Ruhe das System neu aufsetzen kann. Dann muss ich mein aktives System jetzt nicht lahm legen. Das Backup einspielen wird dann ja auch eine gewisse Zeit dauern.
                        Die Installation sollte ja eigentlich easy sein, Installer von Debian am PC installieren, System auswählen, neue SD Karte einlegen und installieren, danach mit Putty alle updates ausführen, neustarten und dann den Befehl für iobroker zum Installieren eingeben. Das ist Theorie und Praxis, lach..... Werde später nochmal alles platt machen und neu ausprobieren. Bin gespannt, gebe später noch eine Rückmeldung. Vielleicht nehme ich dann auch nicht die Beta Version. Die 12'er Version ist alles noch Beta? Lieber erst die 11'er nehmen?
                          Thomas Braun Most Active last edited by Thomas Braun
                          Du sprichst vom Raspberry OS Imager?
                          Nein, Raspberry OS 12 'Bookworm' ist stabil, aber das daraus abgeleitete iobroker-Image ist erst noch im Beta-Stage.
                            @thomas-braun sagte in ioBroker startet nicht nach Neuinstallation:
                            Korrekt
                            Heißt ich habe das falsche Image ausgewählt? Wobei das System ja lief, konnte nur den iobroker nicht wirklich zum Laufen bringen. Dann doch lieber auf der raspberrypi.com Seite das Image manuell runterladen?
                              Willi-Wunder @Thomas Braun last edited by Homoran
                              Sieht so aus, gleiche Ergebnis, nur das es relativ schnell beendet war im Gegensatz zu gestern.
                               pi@raspberrypi:~ $ curl -sLf https://iobroker.net/install.sh | bash -
                              library: loaded
                              Library version=2023-10-13
                                  Welcome to the ioBroker installer!
                                  Installer version: 2023-10-13
                                  You might need to enter your password a couple of times.
                                  Installing prerequisites (1/4)
                              Get:3 http://deb.debian.org/debian-security bookworm-security InRelease [48.0 kB        ]
                              Get:4 http://deb.debian.org/debian bookworm-updates InRelease [52.1 kB]
                              Get:6 http://deb.debian.org/debian-security bookworm-security/main arm64 Package        s [127 kB]
                              Get:7 http://deb.debian.org/debian-security bookworm-security/main armhf Package        s [125 kB]
                              Get:8 http://deb.debian.org/debian-security bookworm-security/main Translation-e        n [76.5 kB]
                              Fetched 328 kB in 2s (205 kB/s)
                              Reading package lists... Done
                                  Creating ioBroker user and directory (2/4)
                              Created /etc/sudoers.d/iobroker
                              Directory /opt/iobroker created
                                  Installing ioBroker (3/4)
                              npm ERR! code 24
                              npm ERR! path /opt/iobroker/node_modules/iobroker.js-controller
                              npm ERR! command failed
                              npm ERR! command sh -c node iobroker.js setup first
                              npm ERR! creating conf/iobroker.json
                              npm ERR! Server Cannot start inMem-objects on port 9001: Failed to lock DB file "/opt/iobroker/iobroker-data/objects.jsonl"!
                              npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2023-12-22T14_02_21_951Z-debug-0.log
                                  Finalizing installation (4/4)
                              Enabling autostart...
                              Autostart enabled!
                                  ioBroker was installed successfully
                                  Open http://192.168.2.229:8081 in a browser and start configuring!
                              You need to re-login before doing anything else on the console!
                              Wird einfacher sein jetzt alles platt zu machen oder gibt es hierzu noch einen Kniff?
                                Was hast du denn ausgewählt?
                                Mach es mit dem Imager:
                                https://forum.iobroker.net/topic/51869/installation-auf-raspi-einfacher-geht-s-nicht
                                (Der sieht glaube ich mittlerweile etwas anders aus, aber grundsätzlich noch ganz ähnlich).
                                  Ist das nicht der gleiche? Hatte auch die V1.8.3, man wird ja auch zu der gelichen Seite weitergeleitet.
                                  Hatte gestern dies ausgewählt:
                                  • DJMarc75
                                    DJMarc75 @Willi-Wunder last edited by
                                    @willi-wunder
                                      Willi-Wunder @DJMarc75 last edited by
                                      @djmarc75
                                      Danke habe ich auch gerade im anderen Thread gelesen das man unbedingt die Lite nehmen soll.
                                      Warum geht die mit Desktop nicht wenn ich Fragen darf? 😕
                                        Weil Server immer ohne Desktop laufen.
                                          Okay, gerade nochmal alles neu gemacht, Image Lite ohne Desktop ausgewählt, nach Anleitung @Thomas-Braun
                                          ausgeführt, gleicher Fehler, siehe Log. Ab dem Punkt Installation 3/4 Iobroker hat es ca. 25 min. gedauert, dann kommt zwar ioBroker was installed successfully, kann diesen aber nicht über die Adresse aufrufen.
                                          pi@iobroker:~ $ curl -sLf https://iobroker.net/install.sh | bash -
                                          library: loaded
                                          Hit:3 http://archive.raspberrypi.com/debian bookworm InRelease
                                              Node.js not found. Installing...
                                          Hit:4 http://archive.raspberrypi.com/debian bookworm InRelease
                                          Building dependency tree... Done
                                          ca-certificates is already the newest version (20230311).
                                          curl is already the newest version (7.88.1-10+deb12u4).
                                          gnupg is already the newest version (2.2.40-1.1).
                                          gnupg set to manually installed.
                                          0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
                                          deb [signed-by=/etc/apt/keyrings/nodesource.gpg] https://deb.nodesource.com/node        _18.x nodistro main
                                           Processing triggers for man-db (2.11.2-2) ...ource1_arm64.deb ...led.)
                                          Installed nodejs
                                          Node.js Installed successfully!
                                          Changing npm registry to https://registry.npmjs.org
                                           Processing triggers for man-db (2.11.2-2) ...arm64.deb ... installed.)
                                          Installed acl
                                           Setting up libavahi-compat-libdnssd-dev:arm64 (0.8-10) ...-10_arm64.deb ...
                                          Installed libavahi-compat-libdnssd-dev
                                           Processing triggers for man-db (2.11.2-2) ...1) ...1_arm64.deb ...ed.)
                                          Installed libudev-dev
                                           Processing triggers for man-db (2.11.2-2) ...eb12u1) ...1_arm64.deb ...
                                          Installed libpam0g-dev
                                           Processing triggers for man-db (2.11.2-2) ...m64.deb ......installed.)
                                          Installed git
                                          Extracting templates from packages: 100%
                                           Preparing to unpack .../10-libcairo-script-interpreter2_1.16.0-7+rpt1_arm64.deb        Setting up libcairo2-dev:arm64 (1.16.0-7+rpt1) ....u3) ...t1) .........
                                          Installed libcairo2-dev
                                           Processing triggers for libc-bin (2.36-9+rpt2+deb12u3) ...m64.deb ... ....
                                          Installed libpango1.0-dev
                                           Setting up libjpeg-dev:arm64 (1:2.1.5-2) ...5-2) ...4.deb ....deb ...)
                                          Installed libjpeg-dev
                                           Processing triggers for libc-bin (2.36-9+rpt2+deb12u3) ... installed.)
                                          Installed libgif-dev
                                           Preparing to unpack .../16-libgdk-pixbuf-2.0-dev_2.42.10+dfsg-1+b1_arm64.deb ..        Processing triggers for libgdk-pixbuf-2.0-0:arm64 (2.42.10+dfsg-1+b1) ........
                                          Installed librsvg2-dev
                                           Processing triggers for libc-bin (2.36-9+rpt2+deb12u3) .....nstalled.)
                                          Installed cmake
                                          User iobroker created
                                          npm ERR! code ECONNRESET
                                          npm ERR! network aborted
                                          npm ERR! network This is a problem related to network connectivity.
                                          npm ERR! network In most cases you are behind a proxy or have bad network settin        gs.
                                          npm ERR! network
                                          npm ERR! network If you are behind a proxy, please make sure that the
                                          npm ERR! network 'proxy' config is set properly.  See: 'npm help config'
                                          npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2023-12        -22T16_47_20_580Z-debug-0.log
                                          Created symlink /etc/systemd/system/multi-user.target.wants/iobroker.service → /        lib/systemd/system/iobroker.service.
                                          Autostart enabled!
                                              Open http://192.168.2.230:8081 in a browser and start configuring!
                                          Und jetzt? 😕
                                          Iobroker Status
                                           pi@iobroker:~ $ iobroker status
                                            A Former User last edited by
                                            Und jetzt?
                                            Moin,
                                            kann es sein, dass Deine Netzwerkanbindung nicht gut ist?
                                            Denn da steht ja,
                                            npm ERR! network
                                            Es kann auch mal wieder sein, dass der Server ausgelastet ist, vielleicht später noch einmal mit dem Befehl versuchen,, das Skript sollte dann ja 1 und 2 überspringen.
                                            VG
                                            Bernd
                                            3865
