    5. Problem mit Adapter_Infos
      dg19222 last edited by dg19222
      Hallo alle Zusammen
      ich habe Probleme mit dem Adapter_Info Skript
      15:29:45.863	warn	javascript.0 (834) script.js.java.abfragen.adapter_infos: Object "system.adapter.vis.0.alive" does not exist
      15:29:45.866	error	javascript.0 (834) at script.js.java.abfragen.adapter_infos:14:39
      15:29:45.866	error	javascript.0 (834) at Object.<anonymous> (script.js.java.abfragen.adapter_infos:13:19)
      // Liest die ioBroker Adapter aus und legt verschiedenen State's an.
      //on({id:"system.adapter.admin.0.uptime",change:'any'}, function (obj) {
          createState('Adapter.Anzahl', 0, { name: 'Anzahl', desc: 'Anzahl der Adapter', type: 'number', unit: '', min: '0', max: '255', role: '',read: true, write: true });
          createState('Adapter.AdapterNummer', 0, { name: 'Adapter zum schalten', desc: 'Adapter zum schalten', type: 'number', unit: '', min: '0', max: '255', role: '',read: true, write: true });
          //var counterAlt = getState("javascript.0.Adapter.Anzahl").val;
          var counter =0;
      	var on = 0
      	var manuell=0
          var cacheSelector = $('[id=system.adapter.*.alive]');
          cacheSelector.each(function(id, i) {
              var devicename = getObject(id).common.name;
      		//Instanzen ausklammern
      		instanz0 = devicename.indexOf('daswetter');
      		instanz1 = devicename.indexOf('dwd');
              instanz2 = devicename.indexOf('ical');
      		instanz3 = devicename.indexOf('feiertage');
      		instanz4 = devicename.indexOf('snmp.1');
              instanz5 = devicename.indexOf('synology');
              instanz6 = devicename.indexOf('vis');
      		if(instanz0 !=0 && instanz1 != 0 && instanz2 !=0 && instanz3 != 0 && instanz4 != 0 && instanz5 !=0 && instanz6 != 0){
      			var devicenameName=devicename;
      			var instanzname=getObject(id).common.name;
      			var test = devicenameName;
      			var devicename_array = devicenameName.split(' ');
      			devicenameName = devicename_array[0];
      			counter = counter+1;
      			var strStatePath = "system.adapter." + devicenameName + ".alive";
      			if (isState(strStatePath, true)) {
      				var uptime = getState("system.adapter." + devicenameName + ".uptime").val;
      				var tage = Math.floor(uptime / (24*3600));
      				var stunden = Math.floor((uptime % (24*3600))/3600);
      				var minuten = Math.floor((uptime % (3600))/60);
      				//var sekunden = Math.floor(uptime % 60);
      				if (stunden < 10) {stunden = "0"+stunden};
                      if (minuten < 10) {minuten = "0"+minuten};
      				if (tage == 1) {uptime = tage.toString()+" Tag, "+stunden.toString()+" Std, "+minuten.toString()+" Min ";};
      				if (tage != 1) {uptime = tage.toString()+" Tage, "+stunden.toString()+" Std, "+minuten.toString()+" Min ";}
      				//var total = getState("system.adapter." + devicenameName + ".memHeapTotal").val;
      				//var used = getState("system.adapter." + devicenameName + ".memHeapUsed").val;
      				//var rss = getState("system.adapter." + devicenameName + ".memRss").val;
      				var connect = getState("system.adapter." + devicenameName + ".alive").val;
      				if(connect == false){var con = 0;}
      				else {
      					var con = 1;
      					var strStatePath = devicenameName + ".info.connection";
      						var connectS = getState(devicenameName + ".info.connection").val;
      						if (connectS == false) {
      							con = 2;
      				if(con==1) {on = on + 1}
      			devicename="Adapter.Adapter"+counter.toString()+".KompletterNameAdapter";
      			createState(devicename, 'empty', { name: 'Kompletter Name des Adapters', desc: '', type: 'string', role: '',read: true, write: true });
      			setStateDelayed(devicename, devicenameName, 800);
      			var contentstring = devicenameName;
      			var suchstring = /(ical)/g;
      			var suchergebnis = suchstring.test( contentstring );
      			if (suchergebnis != true) {
      				var devicename_array = devicenameName.split('.');
      			if (devicenameName == "daswetter") {
      				var bild = "/" + devicenameName + ".admin/" + devicenameName + "com.png";
      			} else if (suchergebnis != false) {
      				var icalName = devicename_array[0];
      				var bild = "/" + icalName + ".admin/" + icalName + ".png";
      			} else {
      				var bild = "/" + devicenameName + ".admin/" + devicenameName + ".png";
      			//Alexa2
      			if (devicenameName == 'alexa2') {var bild = "/" + devicenameName + ".admin/" + "alexa.png";}
      			//FritzDECT
      			if (devicenameName == 'fritzdect') {var bild = "/" + devicenameName + ".admin/" + "fritzdect_logo.png";}
      			//FullyBrowser
      			if (devicenameName == 'fullybrowser') {var bild = "/" + devicenameName + ".admin/" + "fully.png";}
      			//HM-Rega
      			//if (devicenameName == 'hm-rega') {var bild = "/" + devicenameName + ".admin/" + "homematic.png";}
      			if (devicenameName == 'hm-rega') {var bild = "/vis.0/VIS/Meine_Icons/Adapter_Icons/homematic.gif";}
      			//HomeMatic
      			//if (instanzname == 'hm-rpc.0 alive') {var bild = "/" + devicenameName + ".admin/" + "homematic.png";}
      			if (instanzname == 'hm-rpc.0 alive') {var bild = "/vis.0/VIS/Meine_Icons/Adapter_Icons/homematic.gif";}
      			//HomeMatic-IP
      			//if (instanzname == 'hm-rpc.1 alive') {var bild = "/" + devicenameName + ".admin/" + "homematic.png";}
      			if (instanzname == 'hm-rpc.1 alive') {var bild = "/vis.0/VIS/Meine_Icons/Adapter_Icons/homematic_ip.jpg";}
      			//UPNP
      			if (devicenameName == 'upnp') {var bild = "/" + devicenameName + ".admin/" + "upnp-discovery.png";}
                  //Pushover.1
      			if (instanzname == 'pushover.1 alive') {var bild = "/mihome-vacuum.admin/mihome-vacuum.png";}
                  //Pushover.2
      			if (instanzname == 'pushover.2 alive') {var bild = "/daswetter.admin/daswettercom.png";}
      			//AdapterName anpassen
      			//DasWetter
      			if (instanzname == 'daswetter.0 alive') {devicenameName='DasWetter'; manuell=1}
      			//DWD
      			if (instanzname == 'dwd.0 alive') {devicenameName='DWD'; manuell=1}
      			//HM-REGA
      			if (instanzname == 'hm-rega.0 alive') {devicenameName='HM-Rega'; manuell=1}
      			//HM-RPC.0
      			if (instanzname == 'hm-rpc.0 alive') {devicenameName='HomeMatic'; manuell=1}
      			//HM-RPC.1
      			if (instanzname == 'hm-rpc.1 alive') {devicenameName='HM-IP'; manuell=1}
      			//MiHome-Vacuum
      			if (instanzname == 'mihome-vacuum.0 alive') {devicenameName='Nono'; manuell=1}
      			//Pushover
      			if (instanzname == 'pushover.0 alive') {devicenameName='Pushover.0'; manuell=1}
      			if (instanzname == 'pushover.1 alive') {devicenameName='Pushover.1'; manuell=1}
      			if (instanzname == 'pushover.2 alive') {devicenameName='Pushover.2'; manuell=1}
      			//Simple-API
      			if (instanzname == 'simple-api.0 alive') {devicenameName='Simple-API'; manuell=1}
      			//SNMP.0
      			if (instanzname == 'snmp.0 alive') {devicenameName='SNMP.0'; manuell=1}
      			//SNMP.1
      			if (instanzname == 'snmp.1 alive') {devicenameName='SNMP.1'; manuell=1}
      			//TR-064.0
      			if (instanzname == 'tr-064.0 alive') {devicenameName='TR-064.0'; manuell=1}
      			//TR-064.1
      			if (instanzname == 'tr-064.1 alive') {devicenameName='TR-064.1'; manuell=1}
      			//Instanz-Namen setzen
      			if(manuell!=1) {devicenameName = devicenameName.substring(0, 1).toUpperCase() + devicenameName.substring(1).toLowerCase();}
                  //devicenameName = devicenameName.substring(0, 1).toUpperCase() + devicenameName.substring(1).toLowerCase();
      			devicename="Adapter.Adapter"+counter.toString()+".NameInstanz";
      			createState(devicename, 'empty', { name: 'Name des Geräts', desc: '', type: 'string', role: '',read: true, write: true });
      			//Bild Pfad setzen
      			devicename="Adapter.Adapter"+counter.toString()+".Bild";
      			createState(devicename, 'empty', { name: 'Speicherort Bild', desc: '', type: 'string', role: '',read: true, write: true });
      			setStateDelayed(devicename, bild, 800);
      			//Uptime setzen
      			devicename="Adapter.Adapter"+counter.toString()+".Uptime";
      			createState(devicename, 'empty', { name: 'Uptime', desc: '', type: 'string', role: '',read: true, write: true });
      			setStateDelayed(devicename, uptime, 800);
      			//MemUsed setzen
      			//devicename="Adapter.Adapter"+counter.toString()+".MemUsed";
      			//createState(devicename, 0, { name: 'Link MemUsed', desc: '', type: 'number', role: '',read: true, write: true });
      			//setStateDelayed(devicename, used, 800);
      			//MemToal setzen
      			//devicename="Adapter.Adapter"+counter.toString()+".MemTotal";
      			//createState(devicename, 0, { name: 'Link MemTotal', desc: '', type: 'number', role: '',read: true, write: true });
      			//setStateDelayed(devicename, total, 800);
      			//MemRSS setzen
      			//devicename="Adapter.Adapter"+counter.toString()+".MemRSS";
      			//createState(devicename, 0, { name: 'Link MemRSS', desc: '', type: 'number', role: '',read: true, write: true });
      			//setStateDelayed(devicename, rss, 800);
      			//Connected setzen
      			devicename="Adapter.Adapter"+counter.toString()+".Connected";
      			createState(devicename, 0, { name: 'Status Adapter', desc: '', type: 'number', role: '',read: true, write: true });
      			setStateDelayed(devicename, con, 800);
                  //Wert zurücksetzen
                  var manuell=0
      	//Adaptet Icon Übersicht
          visstatus="javascript.0.VIS-Status.alle_adapter_gestartet";
          if(on == counter){setState(visstatus, true);}
          if(on == counter -1){setState(visstatus, true);}
          if(on < counter -1){setState(visstatus, false);}
          setStateDelayed('Adapter.Anzahl', counter, 800);
          function isState(strStatePath, strict) {
              let mSelector;
              if (strict) {
                  mSelector = $('state[id=' + strStatePath + '$]');
              } else {
                  mSelector = $('state[id=' + strStatePath + ']');
              if (mSelector.length > 0) {
                  return true;
              } else {
                  return false;
      on({id:"javascript.0.Adapter.AdapterNummer", change: 'any'}, function (dpobj) {
          if (getState("javascript.0.Adapter.AdapterNummer").val != 0) {
              const instanz = "javascript." + instance;
              var adapterNummer = getState(instanz + ".Adapter.AdapterNummer").val;
              var adapter = getState(instanz + ".Adapter.Adapter" + adapterNummer + ".KompletterNameAdapter").val; // Name und Instanz des Adapters
              var idAdapter = "system.adapter." + adapter;
              var obj = getObject(idAdapter);
              if (dpobj.state.val == false) {
                  obj.common.enabled = true;  // Adapter einschalten
              } else if (dpobj.state.val == true) {
                  obj.common.enabled = false;  // Adapter ausschalten
              setObject(idAdapter, obj);
              setStateDelayed('javascript.0.Adapter.AdapterNummer', 0, 800);
      Kann mir hier jemand sagen was ich falsch mache ??
      LG Daniel
        MCU last edited by
        @dg19222 sagte in Problem mit Adapter_Infos:
        Du willst sie ausklammern
        instanz0 <0 && instanz1 <0....
          dg19222 @MCU last edited by
          @mcu
          Stehe grad auf em Schlauch
            MCU @dg19222 last edited by
            @dg19222 Wo und wie?
              @mcu
              ich habe das skript übernommen ich kenne mich mit Java Skripten nur sehr wenig aus
                paul53 @dg19222 last edited by
                @dg19222 sagte: Object "system.adapter.vis.0.alive" does not exist
                Starte mal die Javascript-Instanz neu. Offenbar hat sie noch ungültige Zustände im Puffer.
                  dg19222 @paul53 last edited by dg19222
                  Danke für den tip Jetzt ist der fehler weg
                  Die ordner werden Erstellt allerdings liefert das Skript nur den Namen der Adapter aber leider keine zahlenwerte hier giebt er nur {"ack":false} aus
                  Hast du da noch ne idee?
                  81.1k
