    4. [gelöst] Vis hat einen wert querliegen und stürzt ab
    • Meistertr
      Guten morgen leute, habe gerade ein wenig herungespielt und habe versucht über object ein JSON zu parsen, war doof wusste ich auch schon vorher…
      `web.0	2017-08-06 10:27:21.190	error	at process._tickCallback (node.js:418:13)
      web.0	2017-08-06 10:27:21.190	error	at nextTickCallbackWith0Args (node.js:489:9)
      web.0	2017-08-06 10:27:21.190	error	at /opt/iobroker/node_modules/iobroker.web/node_modules/iobroker.socketio/node_modules/socket.io/lib/socket.js:503:12
      web.0	2017-08-06 10:27:21.190	error	at Socket.emit (events.js:172:7)
      web.0	2017-08-06 10:27:21.190	error	at emitTwo (events.js:87:13)
      web.0	2017-08-06 10:27:21.190	error	at Socket. (/opt/iobroker/node_modules/iobroker.web/node_modules/iobroker.socketio/lib/socket.js:551:25)
      web.0	2017-08-06 10:27:21.190	error	at subscribe (/opt/iobroker/node_modules/iobroker.web/node_modules/iobroker.socketio/lib/socket.js:203:42)
      web.0	2017-08-06 10:27:21.190	error	at new RegExp (native)
      web.0	2017-08-06 10:27:21.190	error	SyntaxError: Invalid regular expression: /JSON\.parse(getState("landroid-s\.0\.mower\.rawResponse"/.*Battery temperature.*/)\.val\.sc\.d[i][2]/: Unterminated group
      web.0	2017-08-06 10:27:21.184	error	uncaught exception: Invalid regular expression: /JSON\.parse(getState("landroid-s\.0\.mower\.rawResponse"/.*Battery temperature.*/)\.val\.sc\.d[i][2]/: Unterminated group`
      hier ist der fehler in der json:
      `~~[code]~~     "w00108": {
              "tpl": "tplValueString",
              "data": {
                "oid": "JSON.parse(getState(\"landroid-s.0.mower.rawResponse\"/*Battery temperature*/).val.sc.d[i][2]",
                "g_fixed": false,
                "g_visibility": false,
                "g_css_font_text": false,
                "g_css_background": false,
                "g_css_shadow_padding": false,
                "g_css_border": false,
                "g_gestures": false,
                "g_signals": false,
                "visibility-cond": "==",
                "visibility-val": 1,
                "visibility-groups-action": "hide",
                "signals-cond-0": "==",
                "signals-val-0": true,
                "signals-icon-0": "/vis/signals/lowbattery.png",
                "signals-icon-size-0": 0,
                "signals-blink-0": false,
                "signals-horz-0": 0,`
      das ist der fehler. geht nun natürlich nix mehr.. wenn ich in der json datei das widget lösche, startet alles wieder, jedoch sobald ich den editor oder die index aufrufe, stürzt es wieder ab und der fehler ist wieder da, an welchen stellen muss ich das object überall ändern, damit es wieder läuft? habe es jetzt unter : /opt/iobroker/iobroker-data/files/vis.0/main. vis-views.json geändert, aber nach dem aufrufen ist alles wieder drin
      edit: gelöst, hab die ganze zeile mit oid gelöscht, dann fuhr alles wieder hoch[/i][/code][/i][/i]
