    4. Zigbee Adapter Update Node Version nicht unterstützt
    • spicer
      spicer last edited by spicer
      Hallo Gemeinde
      Erst mal frohe Weihnachten.
      Wenn ich den Zigbee Adapter updaten will, erscheint folgendes:
      $ iobroker upgrade zigbee@1.8.25 --debug
      This upgrade of "zigbee" will introduce the following changes:
      -> 1.8.25:
      zhc 16.x
      corr group from exclude dialog
      Would you like to upgrade zigbee from @1.8.24 to @1.8.25 now? [(y)es, (n)o]: y
      Update zigbee from @1.8.24 to @1.8.25
      NPM version: 8.19.4
      Installing iobroker.zigbee@1.8.25... (System call)
      npm ERR! code EBADENGINE
      npm ERR! engine Unsupported engine
      npm ERR! engine Not compatible with your version of node/npm: debounce@2.0.0
      npm ERR! notsup Not compatible with your version of node/npm: debounce@2.0.0
      npm ERR! notsup Required: {"node":">=18"}
      npm ERR! notsup Actual:   {"npm":"8.19.4","node":"v16.20.2"}
      npm ERR!     /home/iobroker/.npm/_logs/2023-12-25T12_04_51_106Z-debug-0.log
      host.raspberrypi Cannot install iobroker.zigbee@1.8.25: 1
      Kann ich den Node bedenkenlos auf 18 upgraden? Läuft dann noch alles?
      Oder gibt's eine bessere Möglichkeit?
      Hier noch der detailierte Auszug aus dem Log:
      148 verbose stack Error: Unsupported engine
      148 verbose stack     at checkEngine (/usr/lib/node_modules/npm/node_modules/npm-install-checks/lib/index.js:14:25)
      148 verbose stack     at Arborist.[checkEngineAndPlatform] (/usr/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/arborist/build-ideal-tree.js:228:11)
      148 verbose stack     at Arborist.buildIdealTree (/usr/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/arborist/build-ideal-tree.js:214:42)
      148 verbose stack     at async Promise.all (index 1)
      148 verbose stack     at async Arborist.reify (/usr/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/arborist/reify.js:154:5)
      148 verbose stack     at async Install.exec (/usr/lib/node_modules/npm/lib/commands/install.js:145:5)
      148 verbose stack     at async module.exports (/usr/lib/node_modules/npm/lib/cli.js:78:5)
      149 verbose pkgid debounce@2.0.0
      150 verbose cwd /opt/iobroker
      151 verbose Linux 6.1.21-v7+
      152 verbose node v16.20.2
      153 verbose npm  v8.19.4
      154 error code EBADENGINE
      155 error engine Unsupported engine
      156 error engine Not compatible with your version of node/npm: debounce@2.0.0
      157 error notsup Not compatible with your version of node/npm: debounce@2.0.0
      157 error notsup Required: {"node":">=18"}
      157 error notsup Actual:   {"npm":"8.19.4","node":"v16.20.2"}
      158 verbose exit 1
      159 timing npm Completed in 18206ms
      160 verbose unfinished npm timer reify 1703505891932
      161 verbose unfinished npm timer reify:loadTrees 1703505891950
      162 verbose code 1
      163 error A complete log of this run can be found in:
      163 error     /home/iobroker/.npm/_logs/2023-12-25T12_04_51_106Z-debug-0.log
      • Glasfaser
        Glasfaser @spicer last edited by
        @spicer sagte in Zigbee Adapter Update Node Version nicht unterstützt:
        Das kann ich dir jetzt ohne weitere Infos von dir nicht sagen ,
        ob du sonst mit allem UpToDate bist
        Node 18 ... ist auch empfohlen .
        zu Upgrade z.B :
        https://forum.iobroker.net/post/1098353
        spicer 1 Reply Last reply Reply Quote 0
        • spicer
          spicer @Glasfaser last edited by
          @glasfaser
          $ iobroker update
          Used repository: stable
          Adapter    "backitup"     : 2.9.8    , installed 2.9.8
          Adapter    "deconz"       : 1.3.23   , installed 1.3.23
          Adapter    "echarts"      : 1.5.4    , installed 1.5.4
          Adapter    "email"        : 1.2.1    , installed 1.2.1
          Adapter    "javascript"   : 7.1.6    , installed 7.1.6
          Controller "js-controller": 5.0.17   , installed 5.0.17
          Adapter    "mqtt"         : 5.1.0    , installed 5.1.0
          Adapter    "shelly"       : 6.6.1    , installed 6.6.1
          Adapter    "solarmanpv"   : 0.5.1    , installed 0.5.1
          Adapter    "telegram"     : 3.0.1    , installed 3.0.1
          Adapter    "web"          : 6.1.10   , installed 6.1.10
          Adapter    "ws"           : 2.5.8    , installed 2.5.8
          Adapter    "zigbee"       : 1.8.25   , installed 1.8.24 [Updatable]
          • Glasfaser
            @spicer
            der Schnipsel sieht erstmal gut aus ...
            • spicer
              @glasfaser
              Ok, ich klone mal die SSD und upgrade dann den Node auf V18.
              • Glasfaser
                Ich hoffe das ist nicht immer deine Backup Lösung !
                ... so schleppst du nur immer Fehler mit !
                • spicer
                  @glasfaser sagte in Zigbee Adapter Update Node Version nicht unterstützt:
                  Nein, natürlich nicht. Mache regelmässig mit dem Backup Adapter Backups.
                  Hatte aber mal das Problem, dass ich das System mit solch einem Upgrade zerrschoss.
                  Mag nicht wieder alles neu aufsetzen 😉
                  • spicer
                    So, hab nun v18 drauf.
                    iobroker upgrade-nodejs funktionierte leider nicht. Habe dann nach
                    https://forum.iobroker.net/topic/22867/how-to-node-js-für-iobroker-richtig-updaten
                    gearbeitet.
                    • Glasfaser
                      Glasfaser @spicer last edited by Glasfaser
                      deshalb von mir :
                      kenne dein System nicht ...
                      sollte eigentlich nach
                      iob fix
                      funktionieren wenn ,
                      zuvor nicht als Befehl geht
                      Oder hast du ein Docker Image !?
                      Habe dann nach
                      gearbeitet.
                      das ist eine alte Anleitung , da kann viel schief gehen ! !
                      • spicer
                        @glasfaser
                        Nein. Kein Docker.
                        Er fand den Befehl nicht. Darum hab ich den fix vorher gemacht.
                        Brachte nichts.
                        • Glasfaser
                          Brachte nichts.
                          Dann stimmt etwas nicht mit deinem ioBroker , denn er sollte danach den Befehl erkennen .
                          spicer Thomas Braun 2 Replies Last reply Reply Quote 0
                          • spicer
                            @glasfaser
                            Ja. Aber ich konnte das ja dann von Hand machen.
                            Was da nicht stimmen sollte, entzieht sich meiner Kenntnis.
                            Habe eigentlich immer alles auf aktuellem Stand.
                            • Glasfaser
                              Zeige mal bitte die obere Ausgabe von "iob fix" , da steht ein Datum drin .
                              siehe hier :
                              FIXER_VERSION="2023-10-13"
                              https://github.com/ioBroker/ioBroker/blob/master/CHANGELOG_FIXER_LINUX.md
                              https://github.com/ioBroker/ioBroker/blob/master/fix_installation.sh
                              • spicer
                                spicer @Glasfaser last edited by spicer
                                @glasfaser
                                Und wie kriege ich diese Ausgabe, ohne den fixer unnötig laufen zulassen?
                                  ticaki Developer @spicer last edited by ticaki
                                  @spicer
                                  Vielleicht hab ich es überlesen, aber welche js-controller version? Jap habs überlesen.
                                  lol, Befehl ging bei mir auch nicht... mal nachgelesen und:
                                  iob nodejs-update
                                    Thomas Braun Most Active @Glasfaser last edited by Thomas Braun
                                    Da steht leider ein falscher Befehl in der Anleitung.
                                    Das muss
                                    iob nodejs-update
                                    lauten. Sollte @Dutchman mal ändern.
                                    @spicer Schau mal ob das nun funktioniert.
                                    spicer Glasfaser 2 Replies Last reply Reply Quote 1
                                    • spicer
                                      spicer @Thomas Braun last edited by
                                      Hab's ja nun bereits updated.
                                      Werd dann wohl erst das nächste mal probieren.
                                      Vielleicht ist die Anleitung bis dahin dann auch korrigiert 😉
                                      • Glasfaser
                                        Glasfaser @Thomas Braun last edited by Glasfaser
                                        @thomas-braun sagte in Zigbee Adapter Update Node Version nicht unterstützt:
                                        ... selber darauf reingefallen ... ist mir bei Ihm nicht aufgefallen das er dann selber den falschen genommen und auch gepostet hat !
                                        .... habe aber zuvor ein Link von dir gepostet , da ist er richtig und wollte keine Anleitung posten !
                                        zu Upgrade z.B :
                                          Thomas Braun Most Active @spicer last edited by
                                          @spicer
                                          Zeig bitte die Ausgabe von
                                          iob nodejs-update
                                          Wenn es passt würde das entsprechend drin stehen.
                                          • spicer
                                            ioBroker nodejs fixer 2023-10-13
                                            Recommended nodejs-version is: 18.19.0
                                            Checking your installation now. Please be patient!
                                            Your current setup is:
                                            /usr/bin/nodejs 	v18.17.1
                                            /usr/bin/node 		v18.17.1
                                            /usr/bin/npm 		9.6.7
                                            /usr/bin/npx 		9.6.7
                                            /usr/bin/corepack 	0.18.0
                                            We found these nodejs versions available for installation:
                                            nodejs:
                                              Installed: 18.17.1-deb-1nodesource1
                                              Candidate: 18.17.1-deb-1nodesource1
                                              Version table:
                                             *** 18.17.1-deb-1nodesource1 500
                                                    500 https://deb.nodesource.com/node_18.x bullseye/main armhf Packages
                                                    100 /var/lib/dpkg/status
                                                 12.22.12~dfsg-1~deb11u4 500
                                            Nothing to do - Your installation is using the correct paths.
                                            You are running nodejs v18.17.1. Do you want to install recommended version 18.19.0?
                                            Press <y> to continue or any other key to quit
                                            Trying to update your installation now. Please be patient.
                                            find: '/run/user/1000/gvfs': Permission denied
                                            Waiting for ioBroker to shut down - Give me a minute...
                                            Glasfaser 2 Replies Last reply Reply Quote 0
                                            1924
