    4. Zigbee Stick spinnt *gelöst*
    • G
      gluecksmann last edited by gluecksmann
      Guten Morgen Forum, wenn ich die Instanz des Zigbee aufrufe, kommt diese Fehlermeldung.
      Skript v.2023-10-10
      *** BASE SYSTEM ***
         Static hostname: raspberrypi
               Icon name: computer
        Operating System: Raspbian GNU/Linux 10 (buster)
                  Kernel: Linux 5.10.103-v7l+
            Architecture: arm
      Model           : Raspberry Pi 4 Model B Rev 1.4
      Docker          : false
      Virtualization  : none
      Kernel          : armv7l
      Userland        : armhf
      Systemuptime and Load:
       05:52:39 up  8:04,  1 user,  load average: 1.01, 0.86, 0.71
      CPU threads: 4
      *** RASPBERRY THROTTLING ***
      Current issues:
      Previously detected issues:
      *** Time and Time Zones ***
                     Local time: Tue 2023-12-26 05:52:40 CET
                 Universal time: Tue 2023-12-26 04:52:40 UTC
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      *** User and Groups ***
      pi
      /home/pi
      pi adm dialout cdrom sudo audio video plugdev games users input netdev lpadmin gpio i2c spi iobroker
      *** X-Server-Setup ***
      X-Server:       false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Mem:           7.9G        1.6G        4.2G         32M        2.0G        6.0G
      Swap:           99M          0B         99M
      Total:         8.0G        1.6G        4.3G
               7898 M total memory
               1632 M used memory
                380 M active memory
               3078 M inactive memory
               4233 M free memory
                192 M buffer memory
               1840 M swap cache
                 99 M total swap
                  0 M used swap
                 99 M free swap
      Raspberry only:
      oom events: 0
      *** FAILED SERVICES ***
        UNIT            LOAD   ACTIVE SUB    DESCRIPTION
      * lightdm.service loaded failed failed Light Display Manager
      1 loaded units listed. Pass --all to see loaded but inactive units, too.
      To show all installed unit files use 'systemctl list-unit-files'.
      *** FILESYSTEM ***
      /dev/root      ext4       29G   14G   15G  50% /
      devtmpfs       devtmpfs  3.7G     0  3.7G   0% /dev
      tmpfs          tmpfs     3.9G   33M  3.9G   1% /run
      tmpfs          tmpfs     3.9G     0  3.9G   0% /sys/fs/cgroup
      /dev/mmcblk0p1 vfat      253M   49M  204M  20% /boot
      tmpfs          tmpfs     790M     0  790M   0% /run/user/1000
      [Mon Dec 25 21:47:50 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=E4:5F:01:3D:9B:6E vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  dwc_otg.lpm_enable=0 console=ttyS0,115200 console=tty1 root=PARTUUID=a372f35c-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
      [Mon Dec 25 21:47:51 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
      [Mon Dec 25 21:47:51 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
      [Mon Dec 25 21:47:53 2023] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
      TARGET        SOURCE         FSTYPE OPTIONS
      /             /dev/mmcblk0p2 ext4   rw,noatime
      |-/sys/fs/bpf none           bpf    rw,nosuid,nodev,noexec,relatime,mode=700
      `-/boot       /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
      /var:
      407M    /var/
      118M    /var/lib
      102M    /var/cache
      90M     /var/cache/apt
      85M     /var/log
      Archived and active journals take up 32.0M in the file system.
      /opt/iobroker/backups:
      60M     /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      621M    /opt/iobroker/iobroker-data/
      329M    /opt/iobroker/iobroker-data/files
      143M    /opt/iobroker/iobroker-data/backup-objects
      93M     /opt/iobroker/iobroker-data/sonosCache
      67M     /opt/iobroker/iobroker-data/files/javascript.admin
      35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
      33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
      26M     /opt/iobroker/iobroker-data/objects.jsonl
      21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js.map
      12M     /opt/iobroker/iobroker-data/objects.json.migrated
      USB-Devices by-id:
      /dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B001CDD3388-if00
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v18.19.0
      /usr/bin/node           v18.19.0
      /usr/bin/npm            10.2.3
      /usr/bin/npx            10.2.3
      nodejs:
        Installed: 18.19.0-1nodesource1
        Candidate: 18.19.0-1nodesource1
        Version table:
       *** 18.19.0-1nodesource1 1001
              500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
              100 /var/lib/dpkg/status
           18.18.2-1nodesource1 1001
           18.18.1-1nodesource1 1001
           18.18.0-1nodesource1 1001
           18.17.1-1nodesource1 1001
           18.17.0-1nodesource1 1001
           18.16.1-1nodesource1 1001
           18.16.0-1nodesource1 1001
           18.15.0-1nodesource1 1001
           18.14.2-1nodesource1 1001
           18.14.1-1nodesource1 1001
           18.14.0-1nodesource1 1001
           18.13.0-1nodesource1 1001
           18.12.0-1nodesource1 1001
           18.11.0-1nodesource1 1001
           18.10.0-1nodesource1 1001
           18.9.1-1nodesource1 1001
           18.9.0-1nodesource1 1001
           18.8.0-1nodesource1 1001
           18.7.0-1nodesource1 1001
           18.6.0-1nodesource1 1001
           18.5.0-1nodesource1 1001
           18.4.0-1nodesource1 1001
           18.3.0-1nodesource1 1001
           18.2.0-1nodesource1 1001
           18.1.0-1nodesource1 1001
           18.0.0-1nodesource1 1001
           10.24.0~dfsg-1~deb10u3 500
      No problems detected
      Errors in npm tree:
      npm ERR! code ELSPROBLEMS
      npm ERR! invalid: iobroker.govee@0.0.5 /opt/iobroker/node_modules/iobroker.govee
      npm ERR! invalid: iobroker.icons-ultimate-png@1.0.1 /opt/iobroker/node_modules/iobroker.icons-ultimate-png
      npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2023-12-26T04_52_49_143Z-debug-0.log
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Core adapters versions
      js-controller:  5.0.17
      admin:          6.12.0
      javascript:     7.1.6
      npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2023-12-26T04_53_11_135Z-debug-0.log
      Adapters from github:   2
      Adapter State
      + system.adapter.alexa2.0                 : alexa2                : raspberrypi                              -  enabled
        system.adapter.alias-manager.0          : alias-manager         : raspberrypi                              - disabled
        system.adapter.awtrix-light.0           : awtrix-light          : raspberrypi                              - disabled
      + system.adapter.ble.0                    : ble                   : raspberrypi                              -  enabled
        system.adapter.chromecast.0             : chromecast            : raspberrypi                              - disabled
        system.adapter.daswetter.0              : daswetter             : raspberrypi                              -  enabled
        system.adapter.devices.0                : devices               : raspberrypi                              - disabled
        system.adapter.dwd.0                    : dwd                   : raspberrypi                              -  enabled
      + system.adapter.fullybrowser.0           : fullybrowser          : raspberrypi                              -  enabled
      + system.adapter.govee.0                  : govee                 : raspberrypi                              -  enabled
      + system.adapter.gruenbeck.0              : gruenbeck             : raspberrypi                              -  enabled
        system.adapter.history.0                : history               : raspberrypi                              - disabled
      + system.adapter.hue.0                    : hue                   : raspberrypi                              -  enabled, port: 443
        system.adapter.ical.0                   : ical                  : raspberrypi                              -  enabled
        system.adapter.icons-mfd-png.0          : icons-mfd-png         : raspberrypi                              - disabled
        system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : raspberrypi                              - disabled
        system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : raspberrypi                              - disabled
      + system.adapter.iot.0                    : iot                   : raspberrypi                              -  enabled
      + system.adapter.meross.0                 : meross                : raspberrypi                              -  enabled
      + system.adapter.mielecloudservice.0      : mielecloudservice     : raspberrypi                              -  enabled
      + system.adapter.musiccast.0              : musiccast             : raspberrypi                              -  enabled
      + system.adapter.net-tools.0              : net-tools             : raspberrypi                              -  enabled
      + system.adapter.netatmo.0                : netatmo               : raspberrypi                              -  enabled
      + system.adapter.philips-air.0            : philips-air           : raspberrypi                              -  enabled
      + system.adapter.philips-air.1            : philips-air           : raspberrypi                              -  enabled
      + system.adapter.ping.0                   : ping                  : raspberrypi                              -  enabled
      + system.adapter.pollenflug.0             : pollenflug            : raspberrypi                              -  enabled
      + system.adapter.scenes.0                 : scenes                : raspberrypi                              -  enabled
        system.adapter.shuttercontrol.0         : shuttercontrol        : raspberrypi                              - disabled
      + system.adapter.smartcontrol.0           : smartcontrol          : raspberrypi                              -  enabled
      + system.adapter.sonoff.0                 : sonoff                : raspberrypi                              -  enabled, port: 1883, bind: 0.0.0.0
      + system.adapter.sonos.0                  : sonos                 : raspberrypi                              -  enabled
      + system.adapter.trashschedule.0          : trashschedule         : raspberrypi                              -  enabled
      + system.adapter.tuya.0                   : tuya                  : raspberrypi                              -  enabled
        system.adapter.vis-colorpicker.0        : vis-colorpicker       : raspberrypi                              -  enabled
        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              -  enabled
        system.adapter.vis-icontwo.0            : vis-icontwo           : raspberrypi                              -  enabled
      + system.adapter.vis-inventwo.0           : vis-inventwo          : raspberrypi                              -  enabled
        system.adapter.vis-material-advanced.0  : vis-material-advanced : raspberrypi                              -  enabled
        system.adapter.vis-metro.0              : vis-metro             : raspberrypi                              -  enabled
        system.adapter.vis-players.0            : vis-players           : raspberrypi                              -  enabled
        system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              -  enabled
        system.adapter.weatherunderground.0     : weatherunderground    : raspberrypi                              -  enabled
      + system.adapter.zigbee.0                 : zigbee                : raspberrypi                              -  enabled, port: /dev/ttyACM0
      + instance is alive
      ioBroker-Repositories
      Active repo(s): stable
      Installed ioBroker-Instances
      Used repository: stable
      Adapter    "alexa2"       : 3.26.3   , installed 3.26.3
      Adapter    "awtrix-light" : 0.10.0   , installed 0.10.0
      Adapter    "backitup"     : 2.9.8    , installed 2.9.8
      Adapter    "ble"          : 0.13.4   , installed 0.13.4
      Adapter    "chromecast"   : 3.0.3    , installed 3.0.3
      Adapter    "daswetter"    : 3.1.11   , installed 3.1.11
      Adapter    "fullybrowser" : 3.0.6    , installed 3.0.6
      Adapter    "gruenbeck"    : 0.0.42   , installed 0.0.42
      Adapter    "hue"          : 3.10.1   , installed 3.10.1
      Adapter    "icons-mfd-png": 1.1.0    , installed 1.1.0
      Adapter    "iot"          : 2.0.11   , installed 2.0.11
      Adapter    "javascript"   : 7.1.6    , installed 7.1.6
      Controller "js-controller": 5.0.17   , installed 5.0.17
      Adapter    "meross"       : 1.15.1   , installed 1.15.1
      Adapter    "mielecloudservice": 6.5.4, installed 6.5.4
      Adapter    "mihome-vacuum": 4.1.0    , installed 4.1.0
      Adapter    "musiccast"    : 1.1.3    , installed 1.1.3
      Adapter    "netatmo"      : 3.1.0    , installed 3.1.0
      Adapter    "philips-air"  : 1.0.3    , installed 1.0.3
      Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
      Adapter    "shelly"       : 6.6.1    , installed 6.6.1
      Adapter    "shuttercontrol": 1.6.3   , installed 1.6.3
      Adapter    "smartcontrol" : 2.0.1    , installed 2.0.1
      Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
      Adapter    "sonos"        : 3.0.0    , installed 3.0.0
      Adapter    "trashschedule": 2.3.0    , installed 2.3.0
      Adapter    "tuya"         : 3.14.2   , installed 3.14.2
      Adapter    "vis-icontwo"  : 1.0.0    , installed 1.0.0
      Adapter    "weatherunderground": 3.6.0, installed 3.6.0
      Adapter    "web"          : 6.1.10   , installed 6.1.10
      Adapter    "ws"           : 2.5.8    , installed 2.5.8
      Adapter    "zigbee"       : 1.8.25   , installed 1.8.25
      Objects and States
      Objects:        11301
      States:         9374
      Hit:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
      Hit:2 http://archive.raspberrypi.org/debian buster InRelease
      Hit:3 https://deb.nodesource.com/node_18.x nodistro InRelease
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          19502      650/sshd
      tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          775037     2448/cupsd
      tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       21081      1074/io.sonoff.0
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       19713      642/iobroker.js-con
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       19706      642/iobroker.js-con
      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       18097      762/io.admin.0
      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       26014      2151/io.web.0
      tcp6       0      0 :::22                   :::*                    LISTEN      0          19504      650/sshd
      tcp6       0      0 ::1:631                 :::*                    LISTEN      0          775036     2448/cupsd
      tcp6       0      0 :::3500                 :::*                    LISTEN      1001       20991      1056/io.sonos.0
      udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       20223      1112/io.tuya.0
      udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       20224      1112/io.tuya.0
      udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       19939      894/io.shelly.0
      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          15322      639/dhcpcd
      udp        0      0 0.0.0.0:40006           0.0.0.0:*                           1001       20196      1092/io.philips-air
      udp        0      0 0.0.0.0:56941           0.0.0.0:*                           108        15073      397/avahi-daemon: r
      udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          773958     2449/cups-browsed
      udp        0      0 0.0.0.0:41100           0.0.0.0:*                           1001       24729      1340/io.musiccast.0
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        15071      397/avahi-daemon: r
      udp        0      0 0.0.0.0:39675           0.0.0.0:*                           1001       19387      970/io.philips-air.
      udp6       0      0 :::54275                :::*                                108        15074      397/avahi-daemon: r
      udp6       0      0 :::546                  :::*                                0          17520      639/dhcpcd
      udp6       0      0 :::5353                 :::*                                108        15072      397/avahi-daemon: r
      2023-12-26 05:53:28.566  - info: philips-air.0 (970) State value to set for "philips-air.0.device.uptime" has to be type "number" but received type "string"
      2023-12-26 05:53:28.626  - info: philips-air.0 (970) State value to set for "philips-air.0.status.pm25" has to be type "number" but received type "string"
      2023-12-26 05:53:28.652  - info: philips-air.0 (970) State value to set for "philips-air.0.control.timerHours" has to be type "number" but received type "string"
      2023-12-26 05:53:28.699  - info: philips-air.0 (970) State value to set for "philips-air.0.status.timerMinutes" has to be type "number" but received type "string"
      2023-12-26 05:53:28.715  - info: philips-air.0 (970) State value to set for "philips-air.0.filter.preFilterCleanInHours" has to be type "number" but received type "string"
      2023-12-26 05:53:28.790  - info: philips-air.0 (970) State value to set for "philips-air.0.filter.hepaFilterReplaceInHours" has to be type "number" but received type "string"
      2023-12-26 05:53:28.797  - info: philips-air.0 (970) State value to set for "philips-air.0.filter.activeCarbonFilterReplaceInHours" has to be type "number" but received type "string"
      2023-12-26 05:53:36.263  - error: govee.0 (1253) AxiosError: Request failed with status code 429
      2023-12-26 05:53:39.973  - error: philips-air.1 (1092) Error by sending: Error: No reply in 247 seconds.
      2023-12-26 05:53:51.400  - error: govee.0 (1253) AxiosError: Request failed with status code 429
      2023-12-26 05:53:56.958  - warn: sonoff.0 (1074) Client [tasmota2] has invalid password or username
      2023-12-26 05:54:06.383  - error: govee.0 (1253) AxiosError: Request failed with status code 429
      2023-12-26 05:54:09.974  - error: philips-air.1 (1092) Error by sending: Error: No reply in 247 seconds.
      2023-12-26 05:54:14.574  - info: philips-air.0 (970) State value to set for "philips-air.0.control.lightBrightness" has to be type "number" but received type "string"
      2023-12-26 05:54:14.581  - info: philips-air.0 (970) State value to set for "philips-air.0.control.airQualityNotificationThreshold" has to be type "number" but received type "string"
      2023-12-26 05:54:14.615  - info: philips-air.0 (970) State value to set for "philips-air.0.status.allergenIndex" has to be type "number" but received type "string"
      2023-12-26 05:54:14.669  - info: philips-air.0 (970) State value to set for "philips-air.0.control.childLock" has to be type "boolean" but received type "string"
      2023-12-26 05:54:14.740  - info: philips-air.0 (970) State value to set for "philips-air.0.device.uptime" has to be type "number" but received type "string"
      2023-12-26 05:54:14.798  - info: philips-air.0 (970) State value to set for "philips-air.0.status.pm25" has to be type "number" but received type "string"
      2023-12-26 05:54:14.822  - info: philips-air.0 (970) State value to set for "philips-air.0.control.timerHours" has to be type "number" but received type "string"
      2023-12-26 05:54:14.832  - info: philips-air.0 (970) State value to set for "philips-air.0.status.timerMinutes" has to be type "number" but received type "string"
      2023-12-26 05:54:14.889  - info: philips-air.0 (970) State value to set for "philips-air.0.filter.preFilterCleanInHours" has to be type "number" but received type "string"
      2023-12-26 05:54:14.896  - info: philips-air.0 (970) State value to set for "philips-air.0.filter.hepaFilterReplaceInHours" has to be type "number" but received type "string"
      2023-12-26 05:54:14.903  - info: philips-air.0 (970) State value to set for "philips-air.0.filter.activeCarbonFilterReplaceInHours" has to be type "number" but received type "string"
      2023-12-26 05:54:21.397  - error: govee.0 (1253) AxiosError: Request failed with status code 429
      Meister Mopper Thomas Braun 3 Replies Last reply Reply Quote 0
      • Meister Mopper
        Meister Mopper @gluecksmann last edited by
        @gluecksmann sagte in Zigbee Stick spinnt:
        Dieser Hinweis kommt, wenn keine Verbindung zum USB-Stick möglich ist. Versuch mal
        als COM-Anschlussname einzutragen.
        Bei mir muss teilweise der Adapter mehrmals neu gestartet werden, bis es funktioniert.
        • Zudem reitest du mit Debian buster einen toten Gaul. Installier das aktuelle 64-bit bookworm lite Image.
        • Dein govee-Adapter muckt rum
        • G
          gluecksmann @Meister Mopper last edited by
          @meister-mopper sagte in Zigbee Stick spinnt:
          hab es eingetragen...Adapter..Raspberry mehrmals neu gestartet...kein Erfolg...
            Thomas Braun Most Active @gluecksmann last edited by Thomas Braun
            @gluecksmann
            Buster ist tot, installier da ganz NEU!
            ein Raspberry OS 12 'Bookworm' in der 64Bit Lite Version.
            • G
              gluecksmann @Thomas Braun last edited by
              Ich glaube das wäre für das Forum zuviel... Wenn dann bräuchte ich einen persönlichen 1:1 Support...
              Aber das kann ja nicht das Problem mit dem Zigbee sein, oder?
                @gluecksmann
                Nee, das ist ein grundsätzliches Problem.
                • G
                  Also so ganz kann ich den Fehler nicht verstehen...einige Zigbee Komponenten funktionieren normal... In der Geräteansicht ändert sich sogar der Status der nicht funktionierenden Geräte wenn ich sie z.B. über Alexa schalte...aber Hardwareseitig passiert nix..
                  • Meister Mopper
                    Geh mal auf den 1.8.24 zurück, da gibt es im Forum mittlerweile mehrere Beiträge. Da ist noch was buggy.
                    G Phantomkommander 2 Replies Last reply Reply Quote 0
                    • G
                      @meister-mopper Ähm..und das mache ich wie??
                      amg_666 Meister Mopper 2 Replies Last reply Reply Quote 0
                      • amg_666
                        amg_666 @gluecksmann last edited by
                        @gluecksmann indem du im Reiter Adapter auf die Zigbee Kachel klickst und da unten rechts auf das Plus klickst, dann kannst du eine bestimmte Version auswählen
                        • Phantomkommander
                          Phantomkommander @Meister Mopper last edited by
                          @meister-mopper gab es nicht auch mal ein Fehler, bei dem der Stick nicht mehr richtig erkannt wurde?
                          Thomas Braun Meister Mopper 2 Replies Last reply Reply Quote 0
                          • Meister Mopper
                            Meister Mopper @gluecksmann last edited by Meister Mopper
                            Oder über die Konsole:
                            iobroker install zigbee@1.8.24
                              Thomas Braun Most Active @Phantomkommander last edited by
                              @phantomkommander
                              Ja, das Problem mit udev ist allerdings in aktuellen Versionen behoben.
                              Phantomkommander 1 Reply Last reply Reply Quote 0
                              • Meister Mopper
                                Meister Mopper @Phantomkommander last edited by
                                @phantomkommander sagte in Zigbee Stick spinnt:
                                KA, ich nutze das TI-Board.
                                • Phantomkommander
                                  Phantomkommander @Thomas Braun last edited by
                                  @thomas-braun ah ok, hatte ich nicht mitbekommen.
                                  • Meister Mopper
                                    Das udev Problem hatte ich auch, allerdings auf einem bullseye 32-Bit System auf dem Raspberrypi.
                                    Seit 64-Bit bookworm ist das Geschichte. 😊
                                    • G
                                      @meister-mopper
                                      Konsole will er scheinbar nicht... sagt das es schon installiert ist... Die Kachel habe ich merkwürdigerweise nicht...
                                      • Meister Mopper
                                        Das scheint ein Verständnisproblem zu sein. Mit Konsole meine ich über ssh (Putty oder sonstwas) auf dem iob-Server einloggen und den Befehl eingeben.
                                        • G
                                          @meister-mopper
                                          adapter "zigbee" already installed. Use "upgrade" to upgrade to a newer version.
                                          R Meister Mopper 2 Replies Last reply Reply Quote 0
                                            reutli @gluecksmann last edited by
                                            @gluecksmann
                                            Bitte immer komplette Ein- und Ausgaben der Konsole in CodeTags sonst kann hier keiner sehen, was Du machst und was das Ergebnis ist!
                                            3274
