    4. Sonoff Zigbee Stick und Proxmox
      lustig29 last edited by
      Habe das Problem das mein Sonoff Zigbee Stick an meinem Proxmox nicht läuft. Habe es nach der Anleitung von Eddy gemacht. Und nach den Ausgaben her stimmt auch alles. Leider bekomme ich aber den Zigbee Adapter nicht grün.
      2023-12-27 18:43:08.015	error	Error herdsman start
      zigbee.0
      	2023-12-27 18:43:08.015	error	Failed to start Zigbee
      zigbee.0
      	2023-12-27 18:43:08.014	error	Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
      zigbee.0
      	2023-12-27 18:43:07.893	info	Installed Version: iobroker.zigbee@1.8.25
      zigbee.0
      	2023-12-27 18:43:07.888	info	Starting Zigbee npm ...
      zigbee.0
      	2023-12-27 18:43:07.887	info	Try to reconnect. 1 attempts left
      zigbee.0
      	2023-12-27 18:42:57.884	error	Error herdsman start
      zigbee.0
      	2023-12-27 18:42:57.884	error	Failed to start Zigbee
      zigbee.0
      	2023-12-27 18:42:57.884	error	Starting zigbee-herdsman problem : "startup failed - configuration-adapter mismatch - see logs above for more information"
      zigbee.0
      	2023-12-27 18:42:57.822	error	Re-commissioning your network will require re-pairing of all devices!
      zigbee.0
      	2023-12-27 18:42:57.822	error	If you wish to re-commission your network, please remove coordinator backup at /opt/iobroker/iobroker-data/zigbee_0/nvbackup.json.
      zigbee.0
      	2023-12-27 18:42:57.822	error	Please update configuration to prevent further issues.
      zigbee.0
      	2023-12-27 18:42:57.821	error	- Channel List: configured=11, adapter=11
      zigbee.0
      	2023-12-27 18:42:57.821	error	- Network Key: configured=01030507090b0d0f00020406080a0c0d, adapter=01030507090b0d0f00020406080a0c0d
      zigbee.0
      	2023-12-27 18:42:57.821	error	- Extended PAN ID: configured=00124b0024c6aa98, adapter=00124b0024c6aa98
      zigbee.0
      	2023-12-27 18:42:57.821	error	- PAN ID: configured=6754, adapter=6742
      zigbee.0
      	2023-12-27 18:42:57.820	error	Configuration is not consistent with adapter state/backup!
      DJMarc75 F 2 Replies Last reply Reply Quote 0
      • DJMarc75
        DJMarc75 @lustig29 last edited by
        @lustig29 sagte in Sonoff Zigbee Stick und Proxmox:
        Wer ist Eddy und gibt es dazu einen Link ?
          lustig29 @DJMarc75 last edited by
          @djmarc75 https://youtu.be/1U7Sl8mfjDE?si=8WFJij5l6F03zGol
            Frank579 @lustig29 last edited by Frank579
            Nimm als erstes mal die 1.8.24 .. mit der .25 gabs hier schon einige diverser Probleme
            • DJMarc75
              ok, youtube ... da bin ich raus
              • Meister Mopper
                Meister Mopper @Frank579 last edited by
                @frank579 sagte in Sonoff Zigbee Stick und Proxmox:
                8.1.24 .. mit der .25
                @lustig29
                Falsche Ziffer, richtig: 1.8.24
                  Frank579 @Meister Mopper last edited by
                  @meister-mopper
                  Danke hab's angepasst 👼
                  • Meister Mopper
                    Besser ist es, dem eigenen Beitrag ein edit mit den geänderten Informationen anzufügen, dann können später Lesende den sinnigen Verlauf nachvollziehen. 😉
