    4. Info Adapter rot nach Update
    • amg_666
      amg_666 last edited by amg_666
      Hi, ich habe grade über die Konsole mit sudo apt update und dann sudo apt-get dist-upgrade den iob aktualisiert. Da kam dann eine Mewldung (sinngemäß) das iobroker.system neu gestartet werden muss, was ich bestätigt habe.
      System läuft auch wieder hoch, nur der info-adapter bleibt rot.
      host.iobroker
      	2023-12-28 13:32:10.279	error	Caught by controller[0]: /bin/sh: 1: npm: not found
      host.iobroker
      	2023-12-28 13:32:10.279	error	Caught by controller[0]: /opt/iobroker/node_modules/iobroker.info/main.js:89
      host.iobroker
      	2023-12-28 13:32:10.280	error	Caught by controller[0]: adapter.log.error("Could not check npm version: " + e);
      host.iobroker
      	2023-12-28 13:32:10.280	error	Caught by controller[0]: ^
      host.iobroker
      	2023-12-28 13:32:10.280	error	Caught by controller[0]: TypeError: Cannot read properties of undefined (reading 'log')
      host.iobroker
      	2023-12-28 13:32:10.280	error	Caught by controller[0]: at getSystemVersions (/opt/iobroker/node_modules/iobroker.info/main.js:89:11)
      host.iobroker
      	2023-12-28 13:32:10.280	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.info/main.js:58:18)
      host.iobroker
      	2023-12-28 13:32:10.281	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1356:14)
      host.iobroker
      	2023-12-28 13:32:10.281	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1414:10)
      host.iobroker
      	2023-12-28 13:32:10.281	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1197:32)
      host.iobroker
      	2023-12-28 13:32:10.281	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1013:12)
      host.iobroker
      	2023-12-28 13:32:10.281	error	Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12)
      host.iobroker
      	2023-12-28 13:32:10.281	error	Caught by controller[0]: at node:internal/main/run_main_module:28:49
      host.iobroker
      	2023-12-28 13:32:10.281	error	Caught by controller[0]: Node.js v18.19.0
      host.iobroker
      	2023-12-28 13:32:10.282	error	instance system.adapter.info.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      host.iobroker
      	2023-12-28 13:32:10.282	info	Restart adapter system.adapter.info.0 because enabled
      ich hab dann den iob nochmal gestoppt und den fixer drüber laufen lassen, das hat aber nichts gebracht, gleiche Fehlermeldungen im Protokoll.
      iob auf proxmox container, Debian12, js-controller 5.0.17, node.js 18.19.0, bin im beta repository.
      iob diag meckert rum, dass npm nicht bekannt ist (???)
      Skript v.2023-10-10
      *** BASE SYSTEM ***
       Static hostname: iobroker
             Icon name: computer-container
               Chassis: container ☐
        Virtualization: lxc
                Kernel: Linux 6.5.11-7-pve
          Architecture: x86-64
      model name      : Intel(R) Celeron(R) CPU J3455 @ 1.50GHz
      Docker          : false
      Virtualization  : lxc
      Kernel          : x86_64
      Userland        : amd64
      Systemuptime and Load:
       13:39:04 up 7 days, 16:25,  2 users,  load average: 1.76, 2.26, 2.15
      CPU threads: 4
      *** Time and Time Zones ***
                     Local time: Thu 2023-12-28 13:39:05 CET
                 Universal time: Thu 2023-12-28 12:39:05 UTC
                       RTC time: n/a
                    NTP service: inactive
                RTC in local TZ: no
      *** User and Groups ***
      andreas
      /home/andreas
      andreas sudo iobroker
      *** X-Server-Setup ***
      X-Server:       false
      Desktop:
      Terminal:
      *** MEMORY ***
      Mem:             12G        3.3G        2.3G         49K        7.3G        9.6G
      Swap:           4.3G        1.7M        4.3G
      Total:           17G        3.3G        6.6G
              12288 M total memory
               3126 M used memory
               3239 M active memory
               6428 M inactive memory
               2202 M free memory
                  0 M buffer memory
               6958 M swap cache
               4096 M total swap
                  1 M used swap
               4094 M free swap
      *** FAILED SERVICES ***
        UNIT                    LOAD   ACTIVE SUB    DESCRIPTION
      * run-rpc_pipefs.mount    loaded failed failed RPC Pipe File System
      * sys-kernel-config.mount loaded failed failed Kernel Configuration File System
      * bluetooth.service       loaded failed failed Bluetooth service
      3 loaded units listed.
      *** FILESYSTEM ***
      Filesystem                       Type      Size  Used Avail Use% Mounted on
      /dev/mapper/pve-vm--100--disk--1 ext4      147G   49G   91G  35% /
      none                             tmpfs     492K  4.0K  488K   1% /dev
      udev                             devtmpfs  7.7G     0  7.7G   0% /dev/tty
      tmpfs                            tmpfs     7.8G     0  7.8G   0% /dev/shm
      tmpfs                            tmpfs     3.1G   92K  3.1G   1% /run
      tmpfs                            tmpfs     5.0M     0  5.0M   0% /run/lock
      dmesg: read kernel buffer failed: Operation not permitted
      TARGET SOURCE                           FSTYPE OPTIONS
      /      /dev/mapper/pve-vm--100--disk--1 ext4   rw,relatime,stripe=16
      /var:
      1.9G    /var/
      1.3G    /var/cache/apt
      1.3G    /var/cache
      1.2G    /var/cache/apt/archives
      320M    /var/log
      Archived and active journals take up 72.4M in the file system.
      /opt/iobroker/backups:
      15G     /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      15G     /opt/iobroker/iobroker-data/
      14G     /opt/iobroker/iobroker-data/history
      503M    /opt/iobroker/iobroker-data/files
      159M    /opt/iobroker/iobroker-data/backup-objects
      91M     /opt/iobroker/iobroker-data/files/vis-2-beta
      46M     /opt/iobroker/iobroker-data/objects.jsonl
      33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
      30M     /opt/iobroker/iobroker-data/states.jsonl
      24M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.2b7495c2.js.map
      24M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.2b7495c2.js.map
      USB-Devices by-id:
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v18.19.0
      /usr/bin/node           v18.19.0
      /home/iobroker/.diag.sh: line 279: npm: command not found
      /home/iobroker/.diag.sh: line 280: npx: command not found
      /home/iobroker/.diag.sh: line 281: corepack: command not found
      /home/iobroker/.diag.sh: line 290: npm: command not found
      /home/iobroker/.diag.sh: line 291: npx: command not found
      *** nodejs is NOT correctly installed ***
      nodejs:
        Installed: 18.19.0+dfsg-6~deb12u1
        Candidate: 18.19.0+dfsg-6~deb12u1
        Version table:
       *** 18.19.0+dfsg-6~deb12u1 500
              500 http://security.debian.org/debian-security bookworm-security/main amd64 Packages
              100 /var/lib/dpkg/status
           18.19.0-1nodesource1 500
              500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
           18.18.2-1nodesource1 500
           18.18.1-1nodesource1 500
           18.18.0-1nodesource1 500
           18.17.1-1nodesource1 500
           18.17.0-1nodesource1 500
           18.16.1-1nodesource1 500
           18.16.0-1nodesource1 500
           18.15.0-1nodesource1 500
           18.14.2-1nodesource1 500
           18.14.1-1nodesource1 500
           18.14.0-1nodesource1 500
           18.13.0+dfsg1-1 500
              500 http://deb.debian.org/debian bookworm/main amd64 Packages
           18.13.0-1nodesource1 500
           18.12.0-1nodesource1 500
           18.11.0-1nodesource1 500
           18.10.0-1nodesource1 500
           18.9.1-1nodesource1 500
           18.9.0-1nodesource1 500
           18.8.0-1nodesource1 500
           18.7.0-1nodesource1 500
           18.6.0-1nodesource1 500
           18.5.0-1nodesource1 500
           18.4.0-1nodesource1 500
           18.3.0-1nodesource1 500
           18.2.0-1nodesource1 500
           18.1.0-1nodesource1 500
           18.0.0-1nodesource1 500
      No problems detected
      Errors in npm tree:
      /home/iobroker/.diag.sh: line 360: npm: command not found
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Core adapters versions
      js-controller:  5.0.17
      admin:          6.13.11
      javascript:     7.5.1
      /home/iobroker/.diag.sh: line 375: npm: command not found
      Adapters from github:   0
      Adapter State
      + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
        system.adapter.alias-manager.0          : alias-manager         : iobroker                                 -  enabled
      + system.adapter.awtrix-light.0           : awtrix-light          : iobroker                                 -  enabled
      + system.adapter.awtrix-light.1           : awtrix-light          : iobroker                                 -  enabled
      + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
      + system.adapter.backitup.1               : backitup              : iobroker                                 -  enabled
      + system.adapter.bmw.0                    : bmw                   : iobroker                                 -  enabled
        system.adapter.daswetter.0              : daswetter             : iobroker                                 -  enabled
      + system.adapter.device-watcher.0         : device-watcher        : iobroker                                 -  enabled
        system.adapter.discovery.0              : discovery             : iobroker                                 - disabled
      + system.adapter.echarts.0                : echarts               : iobroker                                 -  enabled
        system.adapter.feiertage.0              : feiertage             : iobroker                                 -  enabled
        system.adapter.flot.0                   : flot                  : iobroker                                 -  enabled
      + system.adapter.history.0                : history               : iobroker                                 -  enabled
      + system.adapter.hm-rega.0                : hm-rega               : iobroker                                 -  enabled
      + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 -  enabled, port: 0
      + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker                                 -  enabled, port: 0
      + system.adapter.hm-rpc.2                 : hm-rpc                : iobroker                                 -  enabled, port: 0
      + system.adapter.hm-rpc.3                 : hm-rpc                : iobroker                                 -  enabled, port: 0
        system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
        system.adapter.ical.1                   : ical                  : iobroker                                 -  enabled
        system.adapter.ical.2                   : ical                  : iobroker                                 -  enabled
        system.adapter.ical.3                   : ical                  : iobroker                                 -  enabled
        system.adapter.ical.6                   : ical                  : iobroker                                 -  enabled
        system.adapter.info.0                   : info                  : iobroker                                 -  enabled
      + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
      + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
      + system.adapter.klf200.0                 : klf200                : iobroker                                 -  enabled
      + system.adapter.lgtv.0                   : lgtv                  : iobroker                                 -  enabled
      + system.adapter.lgtv.1                   : lgtv                  : iobroker                                 -  enabled
      + system.adapter.milight-smart-light.0    : milight-smart-light   : iobroker                                 -  enabled
      + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1884, bind: 0.0.0.0
      + system.adapter.nina.0                   : nina                  : iobroker                                 -  enabled
      + system.adapter.ping.0                   : ping                  : iobroker                                 -  enabled
      + system.adapter.plenticore.0             : plenticore            : iobroker                                 -  enabled, port: 80
      + system.adapter.proxmox.0                : proxmox               : iobroker                                 -  enabled, port: 8006
      + system.adapter.proxmox.1                : proxmox               : iobroker                                 -  enabled, port: 8006
      + system.adapter.rpi2.0                   : rpi2                  : iostrom                                  -  enabled
      + system.adapter.rssfeed.0                : rssfeed               : iobroker                                 -  enabled
        system.adapter.schoolfree.0             : schoolfree            : iobroker                                 -  enabled
      + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
      + system.adapter.shuttercontrol.0         : shuttercontrol        : iobroker                                 -  enabled
      + system.adapter.smartmeter.0             : smartmeter            : iostrom                                  -  enabled
      + system.adapter.snmp.0                   : snmp                  : iobroker                                 -  enabled
      + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
      + system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker                                 -  enabled
      + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
      + system.adapter.tr-064.0                 : tr-064                : iobroker                                 -  enabled
      + system.adapter.tr-064.2                 : tr-064                : iobroker                                 -  enabled
        system.adapter.trashschedule.0          : trashschedule         : iobroker                                 - disabled
      + system.adapter.unifi.0                  : unifi                 : iobroker                                 -  enabled
      + system.adapter.vis-2-beta.0             : vis-2-beta            : iobroker                                 -  enabled
        system.adapter.vis-2-widgets-gauges.0   : vis-2-widgets-gauges  : iobroker                                 -  enabled
        system.adapter.vis-bars.0               : vis-bars              : iobroker                                 - disabled
        system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : iobroker                                 - disabled
        system.adapter.vis-colorpicker.0        : vis-colorpicker       : iobroker                                 - disabled
        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 - disabled
        system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker                                 -  enabled
      + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
        system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker                                 -  enabled
        system.adapter.vis-justgage.0           : vis-justgage          : iobroker                                 - disabled
        system.adapter.vis-map.0                : vis-map               : iobroker                                 - disabled
        system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 -  enabled
        system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
      + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      + system.adapter.web.1                    : web                   : iobroker                                 -  enabled, port: 20002, bind: 0.0.0.0, run as: admin
        system.adapter.wifilight.0              : wifilight             : iobroker                                 - disabled
      + system.adapter.wolf.0                   : wolf                  : iobroker                                 -  enabled, port: 12004, bind: 0.0.0.0
      + system.adapter.zigbee.0                 : zigbee                : iobroker                                 -  enabled, port: /dev/ttyUSB0
      + instance is alive
      ioBroker-Repositories
      Active repo(s): beta
      Installed ioBroker-Instances
      Used repository: beta
      Cannot download repository hash file from "http://download.iobroker.net/sources-dist-latest-hash.json": timeout of 10000ms exceeded
      Adapter    "admin"        : 6.13.11  , installed 6.13.11
      Adapter    "alexa2"       : 3.26.3   , installed 3.26.3
      Adapter    "awtrix-light" : 0.10.2   , installed 0.10.2
      Adapter    "backitup"     : 2.9.8    , installed 2.9.8
      Adapter    "bmw"          : 2.7.2    , installed 2.7.2
      Adapter    "daswetter"    : 3.1.12   , installed 3.1.12
      Adapter    "device-watcher": 2.9.11  , installed 2.9.11
      Adapter    "echarts"      : 1.7.2    , installed 1.7.2
      Adapter    "feiertage"    : 1.1.4    , installed 1.1.4
      Adapter    "hm-rpc"       : 1.16.0   , installed 1.16.0
      Adapter    "ical"         : 1.13.6   , installed 1.13.6
      Adapter    "iot"          : 2.0.11   , installed 2.0.11
      Adapter    "javascript"   : 7.5.1    , installed 7.5.1
      Controller "js-controller": 5.0.17   , installed 5.0.17
      Adapter    "klf200"       : 1.1.2    , installed 1.1.2
      Adapter    "lgtv"         : 2.1.2    , installed 2.1.2
      Adapter    "milight-smart-light": 1.2.2, installed 1.2.2
      Adapter    "mqtt"         : 5.1.0    , installed 5.1.0
      Adapter    "nina"         : 0.0.26   , installed 0.0.26
      Adapter    "plenticore"   : 2.3.1    , installed 2.3.1
      Adapter    "proxmox"      : 2.2.2    , installed 2.2.2
      Adapter    "rssfeed"      : 2.8.1    , installed 2.8.1
      Adapter    "schoolfree"   : 1.1.3    , installed 1.1.3
      Adapter    "shelly"       : 6.7.0    , installed 6.7.0
      Adapter    "shuttercontrol": 1.6.3   , installed 1.6.3
      Adapter    "snmp"         : 3.1.0    , installed 3.1.0
      Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
      Adapter    "telegram"     : 3.0.1    , installed 3.0.1
      Adapter    "trashschedule": 3.1.3    , installed 3.1.3
      Adapter    "unifi"        : 0.6.7    , installed 0.6.7
      Adapter    "vis-2-widgets-gauges": 1.0.1, installed 1.0.1
      Adapter    "vis-icontwo"  : 1.2.1    , installed 1.2.1
      Adapter    "vis-justgage" : 2.1.0    , installed 2.1.0
      Adapter    "vis-map"      : 1.0.4    , installed 1.0.4
      Adapter    "web"          : 6.2.3    , installed 6.2.3
      Adapter    "wifilight"    : 1.1.4    , installed 1.1.4
      Adapter    "wolf"         : 1.7.0    , installed 1.7.0
      Adapter    "ws"           : 2.5.10   , installed 2.5.10
      Adapter    "zigbee"       : 1.9.3    , installed 1.9.3
      Objects and States
      Objects:        24646
      States:         21596
      Hit:2 http://deb.debian.org/debian bookworm-updates InRelease
      Hit:3 http://security.debian.org/debian-security bookworm-security InRelease
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 0.0.0.0:12004           0.0.0.0:*               LISTEN      1001       27673973   261190/io.wolf.0
      tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          26624      287/master
      tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       27672755   260929/io.sonoff.0
      tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1001       27673587   261155/io.mqtt.0
      tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       27670583   260807/iobroker.js-
      tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       27668160   260807/iobroker.js-
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          21210500   196637/sshd: /usr/s
      tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          29062      1/init
      tcp        0      0 192.168.1.23:8701       0.0.0.0:*               LISTEN      1001       27672347   261027/io.hm-rpc.1
      tcp        0      0 192.168.1.23:9292       0.0.0.0:*               LISTEN      1001       27670499   261057/io.hm-rpc.3
      tcp        0      0 192.168.1.23:2001       0.0.0.0:*               LISTEN      1001       27672258   261011/io.hm-rpc.0
      tcp        0      0 192.168.1.23:2010       0.0.0.0:*               LISTEN      1001       27671368   261042/io.hm-rpc.2
      tcp6       0      0 :::20002                :::*                    LISTEN      1001       27681182   261545/io.web.1
      tcp6       0      0 :::22                   :::*                    LISTEN      0          21210502   196637/sshd: /usr/s
      tcp6       0      0 :::111                  :::*                    LISTEN      0          29064      1/init
      tcp6       0      0 ::1:25                  :::*                    LISTEN      0          31745      287/master
      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       27668263   260825/io.admin.0
      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       27676610   261389/io.web.0
      tcp6       0      0 :::4400                 :::*                    LISTEN      1001       27676259   261290/io.milight-s
      udp        0      0 0.0.0.0:34553           0.0.0.0:*                           1001       27677735   261341/io.snmp.0
      udp        0      0 0.0.0.0:35076           0.0.0.0:*                           1001       27677235   261290/io.milight-s
      udp        0      0 0.0.0.0:45815           0.0.0.0:*                           1001       27677497   261341/io.snmp.0
      udp        0      0 192.168.1.23:5353       0.0.0.0:*                           1001       27672080   260943/io.tr-064.0
      udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       27672045   260893/io.shelly.0
      udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          29063      1/init
      udp6       0      0 :::111                  :::*                                0          29065      1/init
      2023-12-28 13:39:45.909  - error: host.iobroker Caught by controller[1]: Node.js v18.19.0
      2023-12-28 13:39:45.909  - error: host.iobroker instance system.adapter.info.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      2023-12-28 13:39:45.909  - info: host.iobroker Restart adapter system.adapter.info.0 because enabled
      2023-12-28 13:40:00.085  - info: host.iobroker instance system.adapter.ical.2 started with pid 262188
      2023-12-28 13:40:08.678  - info: ical.2 (262188) starting. Version 1.13.6 in /opt/iobroker/node_modules/iobroker.ical, node: v18.19.0, js-controller: 5.0.17
      2023-12-28 13:40:14.581  - info: ical.2 (262188) processing URL: Geburtstag https://calendar.google.com/calendarxxxxxxx/basic.ics
      2023-12-28 13:40:16.509  - info: host.iobroker instance system.adapter.info.0 started with pid 262228
      2023-12-28 13:40:18.694  - error: host.iobroker Caught by controller[0]: /bin/sh: 1: npm: not found
      2023-12-28 13:40:18.694  - error: host.iobroker Caught by controller[0]: /opt/iobroker/node_modules/iobroker.info/main.js:89
      2023-12-28 13:40:18.694  - error: host.iobroker Caught by controller[0]:                adapter.log.error("Could not check npm version: " + e);
      2023-12-28 13:40:18.694  - error: host.iobroker Caught by controller[0]:                        ^
      2023-12-28 13:40:18.695  - error: host.iobroker Caught by controller[0]: TypeError: Cannot read properties of undefined (reading 'log')
      2023-12-28 13:40:18.695  - error: host.iobroker Caught by controller[0]:     at getSystemVersions (/opt/iobroker/node_modules/iobroker.info/main.js:89:11)
      2023-12-28 13:40:18.695  - error: host.iobroker Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.info/main.js:58:18)
      2023-12-28 13:40:18.695  - error: host.iobroker Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1356:14)
      2023-12-28 13:40:18.695  - error: host.iobroker Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1414:10)
      2023-12-28 13:40:18.695  - error: host.iobroker Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1197:32)
      2023-12-28 13:40:18.695  - error: host.iobroker Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:1013:12)
      2023-12-28 13:40:18.695  - error: host.iobroker Caught by controller[0]:     at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12)
      2023-12-28 13:40:18.695  - error: host.iobroker Caught by controller[0]:     at node:internal/main/run_main_module:28:49
      2023-12-28 13:40:18.695  - error: host.iobroker Caught by controller[0]: Node.js v18.19.0
      2023-12-28 13:40:18.696  - error: host.iobroker instance system.adapter.info.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      2023-12-28 13:40:18.696  - info: host.iobroker Restart adapter system.adapter.info.0 because enabled
      2023-12-28 13:40:19.963  - info: ical.2 (262188) Terminated (NO_ERROR): Without reason
      2023-12-28 13:40:20.501  - info: host.iobroker instance system.adapter.ical.2 terminated with code 0 (NO_ERROR)
      iob diag has finished.
        Thomas Braun Most Active @amg_666 last edited by
        @amg_666 sagte in Info Adapter rot nach Update:
        Damit wärst du der erste... Das geht nämlich nicht.
        Installier da nochmal per
        iob nodejs-update 18
        das nodesource-Repo drüber.
        amg_666 2 Replies Last reply Reply Quote 0
        • amg_666
          amg_666 @Thomas Braun last edited by
          @thomas-braun sagte in Info Adapter rot nach Update:
          das hats leider nicht gebracht:
          oBroker nodejs fixer 2023-10-13
          You requested to intall latest version from nodejs v18 tree.
          Your current setup is:
          /home/iobroker/.nodejs-update.sh: line 130: npm: command not found
          /home/iobroker/.nodejs-update.sh: line 131: npx: command not found
          /home/iobroker/.nodejs-update.sh: line 147: npm: command not found
          /home/iobroker/.nodejs-update.sh: line 148: npx: command not found
          We found these nodejs versions available for installation:
          nodejs:
            Version table:
               18.13.0+dfsg1-1 500
          Your nodejs-Installation seems to be faulty. Shall we try to fix it?
          Press <y> to continue or any other key to quit
          Fixing your nodejs setup
          *** Deleting  ***
          rm: cannot remove '': No such file or directory
          *** Deleting  ***
          Wrong paths have been fixed. Run 'iob diag' or 'iob node-fix' again to check if your installation is fine now
          You are running nodejs v18.19.0. Do you want to install latest version from nodejs v.18 tree?
          Trying to update your installation now. Please be patient.
          Virtualization: lxc
          Waiting for ioBroker to shut down - Give me a minute...
          *** These repos are active on your system:
          Get:3 http://security.debian.org/debian-security bookworm-security InRelease [48.0 kB]
          Get:4 http://security.debian.org/debian-security bookworm-security/main Sources [68.7 kB]
          Get:5 http://security.debian.org/debian-security bookworm-security/main amd64 Packages [132 kB]
          Get:6 http://security.debian.org/debian-security bookworm-security/main Translation-en [78.2 kB]
          Fetched 327 kB in 5s (60.8 kB/s)
          Reading package lists... Done
          *** Installing ca-certificates, curl and gnupg, just in case they are missing.
          *** Creating new /etc/apt/sources.list.d/nodesource.list and pinning source
          deb [signed-by=/etc/apt/keyrings/nodesource.gpg] https://deb.nodesource.com/node_18.x nodistro main
          Package: nodejs
          Pin: origin deb.nodesource.com
          Pin-Priority: 1001
          *** These repos are active after the adjustments:
          Hit:2 http://security.debian.org/debian-security bookworm-security InRelease
          Get:4 https://deb.nodesource.com/node_18.x nodistro InRelease [12.1 kB]
          Get:5 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages [6634 B]
          Fetched 18.8 kB in 6s (3156 B/s)
          Installing the recommended nodejs version now!
          Installing the recommended nodejs version!
          E: Broken packages
          *** You need to manually restart your container/virtual machine now! ***
          We tried our best to fix your nodejs. Please run 'iob diag' again to verify.
          ich habe danach den Container neu gestartet, info ist weiterhin rot und dieselben Fhlermeldungen im logfile
            @amg_666
            Das Repo ist nun aber richtig.
            sudo apt update
            apt policy nodejs
            amg_666 1 Reply Last reply Reply Quote 0
            • amg_666
              apt policy nodejs
              andreas@iobroker:~$ sudo apt update
              [sudo] Passwort fr andreas:
              OK:1 http://security.debian.org/debian-security bookworm-security InRelease
              OK:2 http://deb.debian.org/debian bookworm InRelease
              OK:3 https://deb.nodesource.com/node_18.x nodistro InRelease
              OK:4 http://deb.debian.org/debian bookworm-updates InRelease
              Abhngigkeitsbaum wird aufgebaut... Fertig
              Statusinformationen werden eingelesen... Fertig
              Alle Pakete sind aktuell.
              andreas@iobroker:~$ apt policy nodejs
              nodejs:
                Installiert:           18.19.0+dfsg-6~deb12u1
                Installationskandidat: 18.19.0-1nodesource1
                Versionstabelle:
                   18.19.0-1nodesource1 1001
                   18.18.2-1nodesource1 1001
                   18.18.1-1nodesource1 1001
                   18.18.0-1nodesource1 1001
                   18.17.1-1nodesource1 1001
                   18.17.0-1nodesource1 1001
                   18.16.1-1nodesource1 1001
                   18.16.0-1nodesource1 1001
                   18.15.0-1nodesource1 1001
                   18.14.2-1nodesource1 1001
                   18.14.1-1nodesource1 1001
                   18.14.0-1nodesource1 1001
                   18.13.0+dfsg1-1 500
                   18.13.0-1nodesource1 1001
                   18.12.0-1nodesource1 1001
                   18.11.0-1nodesource1 1001
                   18.10.0-1nodesource1 1001
                   18.9.1-1nodesource1 1001
                   18.9.0-1nodesource1 1001
                   18.8.0-1nodesource1 1001
                   18.7.0-1nodesource1 1001
                   18.6.0-1nodesource1 1001
                   18.5.0-1nodesource1 1001
                   18.4.0-1nodesource1 1001
                   18.3.0-1nodesource1 1001
                   18.2.0-1nodesource1 1001
                   18.1.0-1nodesource1 1001
                   18.0.0-1nodesource1 1001
              andreas@iobroker:~$
              und jetzt ?
                installieren:
                sudo apt install nodejs=18.19.0-1nodesource1
                • amg_666
                  Danke für die Hilfe, läuft jetzt wieder rund...
                  Trotzdem ein (dumme?) Frage: Du hast im ersten Post geschrieben ich wäre da der erste. Ich hab iob wie gesagt als proxmox Container und gehe über proxmox regelmäßig auf die iob Konsole um auf updates zu prüfen. Gefühlt "schon ewig" mit diesen beiden Befehlen:
                  sudo apt update
                  Was ist daran falsch und wie mache ich es zukünftig richtig?
                    Das ist nicht falsch, updated aber nicht den iobroker sondern nur das Betriebssystem/Container.
                    Ich würde allerdings da
                    sudo apt
                    sudo apt full-upgrade
                    empfehlen.
                    Den ioBroker könnte man dann aber per
                    iob update
                    iob upgrade all
                    aktuell halten.
                    amg_666 1 Reply Last reply Reply Quote 1
                    • amg_666
                      @thomas-braun Alles klar, dann habe ich mich missverständlich ausgedrückt. Über die Konsole halte ich natürlich nur den iob Container up-to-date. iobroker updates mache ich eigentlcih immer über die admin oberfläche.
                      Nochmals danke für den support.
                      • Agrippinenser
                        Agrippinenser last edited by
                        sorry das ich hier so reinplatze. Ich habe heute morgen nach Update der VM mit
                        sudo apt update
                        gleiches Verhalten gehabt und bin dankbar hier die Lösung gefunden habe. !
                          Thomas Braun Most Active @Agrippinenser last edited by
                          @agrippinenser @amg_666
                          Stellt die Priority für das nodesource-Repo höher.
                          Geht so:
                          echo "Package: nodejs" | sudo tee /etc/apt/preferences.d/nodejs.pref
                          echo "Pin: origin deb.nodesource.com" | sudo tee -a /etc/apt/preferences.d/nodejs.pref
                          echo "Pin-Priority: 1001" | sudo tee -a /etc/apt/preferences.d/nodejs.pref
                          sudo apt update
                          Agrippinenser 1 Reply Last reply Reply Quote 0
                          • Agrippinenser
                            Agrippinenser @Thomas Braun last edited by
                            habe da vorher mal reingeguckt - das steht darin:
                            Package: nodejs
                            Pin-Priority: 1001
                            Pin-Priority ist demnach schon 1001. Soll ich die 4 Zeilen dennoch ausführen?
                              @agrippinenser
                              Dann dürftest du dir aber nicht die dfsg-Version eingehandelt haben.
                              sudo apt update
                              apt policy nodejs
                              sagt auf deinem System?
                                Thomas Braun Most Active @Agrippinenser last edited by Thomas Braun
                                @agrippinenser
                                Ich sehe gerade, du hantierst da mit apt-get...
                                Das würde ich nicht machen, das tickt anders und berücksichtigt die gesetzten priorities nicht, soweit ich weiß.
                                Besser:
                                sudo apt update
                                • Agrippinenser
                                  Besser:
                                  sudo apt update sudo apt full-upgrade
                                  unter uns 🙂 - ich habe eine PIN-Wand vor mir. Daran klebt ein Zettel mit Inhalt:
                                  sudo apt update
                                  sudo full-upgrade
                                  sudo reboot
                                  heute Morgen habe ich folgendes im Werkzeugkasten gelesen und daraufhin "blind" sudo apt dist-upgrade ausgeführt.
                                  Systemupdate
                                  Seinen Debian-basierten Server (dazu gehört z. B. auch das Raspberry OS vom Raspberry Pi, Ubuntu, Armbian) aktuell und 'auf Stand' zu halten braucht es nur wenig Handwerkszeug. Die installierte Software (im Idealfall auch zusätzliche Pakete von Drittanbietern wie deconz, nodeJS von nodesource) wird sehr komfortabel und zentral über den Paketmanager gehandhabt.
                                  Mit diesem 'Dreisatz' wird automatisch ein System inkl. aller über den Paketmanager installierten Software auf den aktuellen Stand gebracht:
                                  sudo apt update
                                  sudo reboot
                                  Das sollte man regelmäßig so ein oder zweimal im Monat machen. So bleiben die Upgrades übersichtlich und Sicherheitslücken werden einigermaßen zeitnah gestopft. Generell gilt: Je häufiger ich das mache desto weniger Trouble gibt es. 'Never change a running system' ist grundfalsch.
                                    @agrippinenser sagte in Info Adapter rot nach Update:
                                    sudo apt update
                                    Da schreibst du was von apt-get.
                                    • Agrippinenser
                                      .. schreibst du was von apt-get.
                                      sorry, nach Rechercheversuchen sitze ich gerade ratlos in meinem Sessel. In der Regel nutze ich bei Updates "Copy/Paste" kann aber nicht mehr richtig nachvollziehen, wie "apt-get" in den Tastaturspeicher kam.
                                      Ich bin glücklich das alles wieder läuft wie es soll und möchte nur Fehler beim zukünftigen Upgrades nicht wiederholen.
                                        @agrippinenser
                                        Das ist ja auch kein Fehler, weil apt bzw apt-get genau das richtige gemäß deren Konfiguration getan haben: Die aktuellste Version nach Priorität eingespielt.
                                        • amg_666
                                          amg_666 @Agrippinenser last edited by
                                          @agrippinenser ich glaube du musst deinen Pinwand-Zettel korrigieren 🙂
                                          sudo full-upgrade führt bei mir zur Fehlermeldung Befehl nicht gefunden.
                                          Ich bleibe bei
                                          • Agrippinenser
                                            Agrippinenser @amg_666 last edited by
                                            sudo full-upgrade
                                            hast recht - hier klebt laut und deutlich apt full-upgrade an der Pinwand 🙂
                                            npm info
                                            1781
