    4. Bekomme nervigen Error zu Rpi2.0 [gelöst]
      Jojo1900 last edited by Jojo1900
      Unter iobroker/Protokolle/logs erhalte ich die Errormeldung
      Quelle Rpi2.0, debug error
      erscheint jede Minute 2x
      Cannot evaluate: Filesystem 1K-blocks Used Available Use% Mounted on /dev/mmcblk0p2 30227472 3400232 25272652 12% / /1024
      Kann mir jemand weiterhelfen......
      Thomas Braun J 2 Replies Last reply Reply Quote 0
        Thomas Braun Most Active @Jojo1900 last edited by
        @jojo1900
        Schalte die Überwachung des Datenträgers im Adapter aus.
          Jojo1900 @Jojo1900 last edited by
          @jojo1900
          iob diag
          Copy text starting here:
                                  v.2023-10-10
           Static hostname: raspberrypi
                 Icon name: computer
                    Kernel: Linux 6.1.0-rpi7-rpi-v8
              Architecture: arm64
          Userland:               arm64
          User-ID:                1000
          X-Server:               false
          Pending OS-Updates:     0
          Pending iob updates:    0
          Nodejs-Installation:    /usr/bin/nodejs         v18.19.0
                                  /usr/bin/node           v18.19.0
                                  /usr/bin/npm            10.2.3
                                  /usr/bin/npx            10.2.3
          Recommended versions are nodejs 18.19.0 and npm 10.2.3
          MEMORY:
          Mem:            4.0G        1.5G        824M        1.2M        1.7G        2.4G
          Total:          4.1G        1.5G        929M
          Active iob-Instances:   14
          Active repo(s): stable
          ioBroker Core:          js-controller           5.0.17
                                  admin                   6.13.9
          Objects type: jsonl
          States  type: jsonl
          Objects:                4385
          States:                 4883
          Size of iob-Database:
          23M     /opt/iobroker/iobroker-data/objects.jsonl
          9.5M    /opt/iobroker/iobroker-data/objects.json.migrated
          9.5M    /opt/iobroker/iobroker-data/objects.json.bak.migrated
          5.5M    /opt/iobroker/iobroker-data/states.jsonl
          848K    /opt/iobroker/iobroker-data/states.json.migrated
          848K    /opt/iobroker/iobroker-data/states.json.bak.migrated
          840K    /opt/iobroker/iobroker-data/states.json.broken
          === Mark text until here for copying ===
          pi@raspberrypi:~ $
            Jojo1900 @Thomas Braun last edited by
            Danke.....ist erledigt......und gelöst
