    4. Cannot read properties of null (reading 'native')
    • fAz3rs adventures
      fAz3rs adventures last edited by
      Moinmoin,
      ich habe heute auf die Nodejs 18.19.0 geupdatet und wollte danach meine Adapter (unter anderem Zigbee) updaten.
      Sämtliche Updates sind seit der Umstellung auf nodejs 18 in Iobroker nichtmehr sichtbar und wenn ich über Putty das upgrade laufen lassen will kommt die Meldung Cannot upgrade: Cannot read properties of null (reading 'native').
      Kennt das Problem jemand?
      pi@raspberrypi:/opt/iobroker $ iobroker upgrade zigbee@1.8.25
      • Glasfaser
        Glasfaser @fAz3rs adventures last edited by
        @faz3rs-adventures
        Zeige bitte noch dazu , die Full Ausgabe von
        iob diag
        fAz3rs adventures 1 Reply Last reply Reply Quote 0
        • fAz3rs adventures
          fAz3rs adventures @Glasfaser last edited by
          @glasfaser ```
                                  v.2023-10-10
             Static hostname: raspberrypi
                   Icon name: computer
                      Kernel: Linux 6.1.21-v8+
                Architecture: arm64
          Userland:               armhf
          User-ID:                1000
          X-Server:               true
          Pending OS-Updates:     0
          Error: Object "system.repositories" not found
          Pending iob updates:    0
          Nodejs-Installation:    /usr/bin/nodejs         v18.19.0
                                  /usr/bin/node           v18.19.0
                                  /usr/bin/npm            10.2.3
                                  /usr/local/bin/npx              10.2.3
                                  /usr/local/bin/corepack         0.22.0
          Recommended versions are nodejs 18.19.0 and npm 10.2.3
          *** nodejs is NOT correctly installed ***
          Wrong installation path detected. This needs to be fixed.
          Please check
          https://forum.iobroker.net/topic/35090/howto-nodejs-installation-und-upgrades-unter-debian
          for more information on how to fix these errors.
          MEMORY:
          Mem:            7.8G        1.2G        5.7G         34M        881M        6.4G
          Swap:            99M          0B         99M
          Total:          7.9G        1.2G        5.8G
          Active iob-Instances:   26
          List is empty
          ioBroker Core:          js-controller           5.0.17
          Objects type: jsonl
          States  type: jsonl
          + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
          + system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8082, bind: 0.0.0.0 (SSL), run as: admin
          Objects:                5635
          States:                 4392
          Size of iob-Database:
          31M     /opt/iobroker/iobroker-data/objects.jsonl
          7.5M    /opt/iobroker/iobroker-data/states.jsonl
          Das könne es erklären wobei ich nicht weis was da falsch gelaufen ist.
          ich bin nach der Anleitung (https://www.iobroker.net/#de/documentation/install/nodejs.md) vorgegangen.
          Homoran Glasfaser 3 Replies Last reply Reply Quote 0
            Homoran Global Moderator Administrators @fAz3rs adventures last edited by
            @faz3rs-adventures sagte in Cannot read properties of null (reading 'native'):
            SUMMARY
            ist nicht
            @glasfaser sagte in Cannot read properties of null (reading 'native'):
            die Full Ausgabe
            • Glasfaser
              Glasfaser @fAz3rs adventures last edited by Glasfaser
              FALSCH
              dafür gibt es den Befehl:
              iob nodejs-update
              EDIT:
              Dein System ist schief
              /usr/local/bin/
              richtig .. alles in
              /usr/bin/
              • fAz3rs adventures
                fAz3rs adventures @Homoran last edited by fAz3rs adventures
                @homoran ```
                Skript v.2023-10-10
                *** BASE SYSTEM ***
                         Icon name: computer
                      Architecture: arm64
                Model           : Raspberry Pi 4 Model B Rev 1.4
                Docker          : false
                Virtualization  : none
                Kernel          : aarch64
                Userland        : armhf
                Systemuptime and Load:
                 16:03:53 up  1:53,  3 users,  load average: 0.43, 0.27, 0.25
                CPU threads: 4
                *** RASPBERRY THROTTLING ***
                Current issues:
                Previously detected issues:
                *** Time and Time Zones ***
                               Local time: Fri 2023-12-29 16:03:53 CET
                           Universal time: Fri 2023-12-29 15:03:53 UTC
                                 RTC time: n/a
                              NTP service: active
                          RTC in local TZ: no
                *** User and Groups ***
                pi
                /home/pi
                pi adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
                *** X-Server-Setup ***
                X-Server:       true
                Desktop:
                Terminal:       tty
                *** MEMORY ***
                Mem:            7.8G        1.3G        5.7G         35M        883M        6.4G
                Swap:            99M          0B         99M
                Total:          7.9G        1.3G        5.8G
                         7812 M total memory
                         1254 M used memory
                         1414 M active memory
                          492 M inactive memory
                         5674 M free memory
                          129 M buffer memory
                          753 M swap cache
                           99 M total swap
                            0 M used swap
                           99 M free swap
                Raspberry only:
                oom events: 0
                *** FAILED SERVICES ***
                0 loaded units listed.
                *** FILESYSTEM ***
                /dev/root      ext4       30G   16G   13G  57% /
                devtmpfs       devtmpfs  3.6G     0  3.6G   0% /dev
                tmpfs          tmpfs     1.6G  1.2M  1.6G   1% /run
                /dev/mmcblk0p1 vfat      255M   53M  203M  21% /boot
                tmpfs          tmpfs     782M   24K  782M   1% /run/user/1000
                [Fri Dec 29 14:10:04 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:CB:CB:40 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=cb8f5eed-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
                [Fri Dec 29 14:10:05 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
                [Fri Dec 29 14:10:05 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                [Fri Dec 29 14:10:08 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
                TARGET  SOURCE         FSTYPE OPTIONS
                /       /dev/mmcblk0p2 ext4   rw,noatime
                `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                /var:
                3.3G    /var/
                1.9G    /var/cache/apt
                1.9G    /var/cache
                1.8G    /var/cache/apt/archives
                1.2G    /var/log/journal/a9d90c753d4c4e98916aa8f9a3f582f2
                Archived and active journals take up 1.1G in the file system.
                /opt/iobroker/backups:
                21M     /opt/iobroker/backups/
                /opt/iobroker/iobroker-data:
                395M    /opt/iobroker/iobroker-data/
                329M    /opt/iobroker/iobroker-data/files
                52M     /opt/iobroker/iobroker-data/files/javascript.admin
                45M     /opt/iobroker/iobroker-data/files/devices.admin/static
                35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
                33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
                21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js.map
                18M     /opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.274a4d8d.js.map
                USB-Devices by-id:
                *** NodeJS-Installation ***
                /usr/bin/npm            10.2.3
                nodejs:
                  Installed: 18.19.0-1nodesource1
                  Candidate: 18.19.0-1nodesource1
                  Version table:
                 *** 18.19.0-1nodesource1 600
                        500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
                        100 /var/lib/dpkg/status
                     18.18.2-1nodesource1 600
                     18.18.1-1nodesource1 600
                     18.18.0-1nodesource1 600
                     18.17.1-1nodesource1 600
                     18.17.0-1nodesource1 600
                     18.16.1-1nodesource1 600
                     18.16.0-1nodesource1 600
                     18.15.0-1nodesource1 600
                     18.14.2-1nodesource1 600
                     18.14.1-1nodesource1 600
                     18.14.0-1nodesource1 600
                     18.13.0-1nodesource1 600
                     18.12.0-1nodesource1 600
                     18.11.0-1nodesource1 600
                     18.10.0-1nodesource1 600
                     18.9.1-1nodesource1 600
                     18.9.0-1nodesource1 600
                     18.8.0-1nodesource1 600
                     18.7.0-1nodesource1 600
                     18.6.0-1nodesource1 600
                     18.5.0-1nodesource1 600
                     18.4.0-1nodesource1 600
                     18.3.0-1nodesource1 600
                     18.2.0-1nodesource1 600
                     18.1.0-1nodesource1 600
                     18.0.0-1nodesource1 600
                     12.22.12~dfsg-1~deb11u4 500
                No problems detected
                Errors in npm tree:
                *** ioBroker-Installation ***
                ioBroker Status
                Objects type: jsonl
                States  type: jsonl
                Core adapters versions
                js-controller:  5.0.17
                admin:          6.12.0
                javascript:     7.1.4
                Adapters from github:   6
                Adapter State
                  system.adapter.acme.0                   : acme                  : raspberrypi                              -  enabled, port: 8086, bind: 0.0.0.0
                + system.adapter.alexa-shoppinglist.0     : alexa-shoppinglist    : raspberrypi                              -  enabled
                + system.adapter.alexa2.0                 : alexa2                : raspberrypi                              -  enabled
                + system.adapter.bring.1                  : bring                 : raspberrypi                              -  enabled
                  system.adapter.devices.0                : devices               : raspberrypi                              - disabled
                  system.adapter.discovery.0              : discovery             : raspberrypi                              - disabled
                  system.adapter.dwd.0                    : dwd                   : raspberrypi                              -  enabled
                + system.adapter.email.0                  : email                 : raspberrypi                              -  enabled
                  system.adapter.habpanel.0               : habpanel              : raspberrypi                              - disabled
                  system.adapter.ham.0                    : ham                   : raspberrypi                              - disabled
                  system.adapter.homekit-controller.0     : homekit-controller    : raspberrypi                              - disabled
                  system.adapter.ical.0                   : ical                  : raspberrypi                              -  enabled
                  system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : raspberrypi                              - disabled
                + system.adapter.iot.0                    : iot                   : raspberrypi                              -  enabled
                  system.adapter.iwg-vpn.0                : iwg-vpn               : raspberrypi                              - disabled
                  system.adapter.knx.0                    : knx                   : raspberrypi                              - disabled, bind: 192.168.0.60
                + system.adapter.lovelace.0               : lovelace              : raspberrypi                              -  enabled, port: 8091, bind: 0.0.0.0 (SSL), run as: admin
                + system.adapter.mqtt.0                   : mqtt                  : raspberrypi                              -  enabled, port: 1886, bind: 0.0.0.0
                + system.adapter.net-tools.0              : net-tools             : raspberrypi                              -  enabled
                + system.adapter.nina.0                   : nina                  : raspberrypi                              -  enabled
                  system.adapter.node-red.0               : node-red              : raspberrypi                              - disabled, port: 1880, bind: 0.0.0.0 (SSL)
                + system.adapter.openknx.0                : openknx               : raspberrypi                              -  enabled
                + system.adapter.parcel.0                 : parcel                : raspberrypi                              -  enabled
                + system.adapter.ping.0                   : ping                  : raspberrypi                              -  enabled
                + system.adapter.residents.0              : residents             : raspberrypi                              -  enabled
                + system.adapter.rpi2.0                   : rpi2                  : raspberrypi                              -  enabled
                  system.adapter.sayit.0                  : sayit                 : raspberrypi                              - disabled
                  system.adapter.simple-api.0             : simple-api            : raspberrypi                              - disabled, port: 8088, bind: 0.0.0.0 (SSL), run as: admin
                  system.adapter.snips.0                  : snips                 : raspberrypi                              - disabled, port: 1883
                + system.adapter.socketio.0               : socketio              : raspberrypi                              -  enabled, port: 8084, bind: 0.0.0.0 (SSL), run as: admin
                  system.adapter.sonoff.0                 : sonoff                : raspberrypi                              - disabled, port: 1883, bind: 0.0.0.0
                  system.adapter.synochat.0               : synochat              : raspberrypi                              - disabled
                  system.adapter.synology.0               : synology              : raspberrypi                              - disabled, port: 5001
                  system.adapter.tapo.0                   : tapo                  : raspberrypi                              - disabled
                + system.adapter.telegram.0               : telegram              : raspberrypi                              -  enabled, port: 8443, bind: 0.0.0.0
                  system.adapter.text2command.0           : text2command          : raspberrypi                              - disabled
                + system.adapter.tr-064.0                 : tr-064                : raspberrypi                              -  enabled
                  system.adapter.tuya.0                   : tuya                  : raspberrypi                              - disabled
                  system.adapter.vis-2-beta.0             : vis-2-beta            : raspberrypi                              - disabled
                  system.adapter.vis-history.0            : vis-history           : raspberrypi                              - disabled
                  system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              - disabled
                  system.adapter.vis-icontwo.0            : vis-icontwo           : raspberrypi                              - disabled
                  system.adapter.vis-inventwo.0           : vis-inventwo          : raspberrypi                              - disabled
                  system.adapter.vis-keyboard.0           : vis-keyboard          : raspberrypi                              - disabled
                  system.adapter.vis-map.0                : vis-map               : raspberrypi                              - disabled
                  system.adapter.vis-material-advanced.0  : vis-material-advanced : raspberrypi                              - disabled
                  system.adapter.vis-metro.0              : vis-metro             : raspberrypi                              - disabled
                  system.adapter.vis-players.0            : vis-players           : raspberrypi                              - disabled
                  system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              - disabled
                  system.adapter.vis-weather.0            : vis-weather           : raspberrypi                              - disabled
                  system.adapter.vis.0                    : vis                   : raspberrypi                              - disabled
                  system.adapter.weatherunderground.0     : weatherunderground    : raspberrypi                              -  enabled
                  system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : raspberrypi                              - disabled
                  system.adapter.ws.0                     : ws                    : raspberrypi                              - disabled, port: 8084, bind: 0.0.0.0 (SSL), run as: admin
                + system.adapter.yahka.0                  : yahka                 : raspberrypi                              -  enabled
                  system.adapter.yahka.1                  : yahka                 : raspberrypi                              - disabled
                + system.adapter.zigbee.0                 : zigbee                : raspberrypi                              -  enabled, port: /dev/serial/by-path/platform-fd500000.pcie-pci-0000:01:00.0-usb-0:1.1:1.0-port0
                + system.adapter.zigbee2mqtt.0            : zigbee2mqtt           : raspberrypi                              -  enabled
                + instance is alive
                ioBroker-Repositories
                List is empty
                Installed ioBroker-Instances
                Objects and States
                Objects:        5635
                States:         4392
                Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
                Hit:3 https://deb.nodesource.com/node_18.x nodistro InRelease
                Reading package lists...
                Pending Updates: 0
                *** Listening Ports ***
                tcp        0      0 0.0.0.0:1886            0.0.0.0:*               LISTEN      1001       41163      4776/io.mqtt.0
                tcp        0      0 0.0.0.0:1887            0.0.0.0:*               LISTEN      1001       41164      4776/io.mqtt.0
                tcp        0      0 0.0.0.0:45077           0.0.0.0:*               LISTEN      1001       43594      5200/io.yahka.0
                tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          15734      580/sshd: /usr/sbin
                tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          3742       544/cupsd
                tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       40992      4641/iobroker.js-co
                tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       42024      4641/iobroker.js-co
                tcp6       0      0 ::1:631                 :::*                    LISTEN      0          3741       544/cupsd
                tcp6       0      0 :::22                   :::*                    LISTEN      0          15736      580/sshd: /usr/sbin
                tcp6       0      0 :::4369                 :::*                    LISTEN      0          12813      1/init
                tcp6       0      0 :::8091                 :::*                    LISTEN      1001       41470      5026/io.lovelace.0
                tcp6       0      0 :::8084                 :::*                    LISTEN      1001       43522      5147/io.socketio.0
                tcp6       0      0 :::8081                 :::*                    LISTEN      1001       42078      4659/io.admin.0
                tcp6       0      0 :::8082                 :::*                    LISTEN      1001       41646      5178/io.web.0
                udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          13132      603/cups-browsed
                udp        0      0 0.0.0.0:37851           0.0.0.0:*                           1001       40497      4791/io.openknx.0
                udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        15658      391/avahi-daemon: r
                udp        0      0 0.0.0.0:36860           0.0.0.0:*                           108        15660      391/avahi-daemon: r
                udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          3764       523/dhcpcd
                udp6       0      0 :::546                  :::*                                0          3776       523/dhcpcd
                udp6       0      0 :::5353                 :::*                                108        15659      391/avahi-daemon: r
                udp6       0      0 :::58918                :::*                                108        15661      391/avahi-daemon: r
                2023-12-29 15:54:30.833  - info: javascript.0 (4716) script.js.Schlafen.GoToSleep: setTimeout(ms=5000)
                2023-12-29 15:54:35.833  - info: javascript.0 (4716) script.js.Schlafen.GoToSleep: getState(id=iot.0.services.custom_Schlafenszeit, timerId=undefined) => {"val":"false","ack":true,"ts":1703861670821,"q":0,"from":"system.adapter.iot.0","user":"system.user.admin","lc":1703861670821}
                2023-12-29 15:55:00.003  - warn: javascript.0 (4716) getState "tr-064.0.devices.Dani.active" not found (3)
                2023-12-29 15:55:00.010  - warn: javascript.0 (4716)     at Object.cb (script.js.Sichereheitsfunktionen.Wetterwarnungen.DWD_Warnungen_WoZi_1:5:221)
                2023-12-29 15:55:00.011  - warn: javascript.0 (4716)     at Immediate._onImmediate (/opt/iobroker/node_modules/iobroker.javascript/lib/scheduler.js:96:109)
                2023-12-29 15:55:00.012  - warn: javascript.0 (4716)     at processImmediate (node:internal/timers:478:21)
                2023-12-29 15:55:00.056  - info: host.raspberrypi instance system.adapter.dwd.0 started with pid 9406
                2023-12-29 15:55:03.069  - info: dwd.0 (9406) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.19.0, js-controller: 5.0.17
                2023-12-29 15:55:05.706  - info: dwd.0 (9406) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                2023-12-29 15:55:06.254  - info: host.raspberrypi instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                2023-12-29 16:00:00.003  - info: javascript.0 (4716) script.js.Sichereheitsfunktionen.Wetterwarnungen.DWD_Warnung_Telegram: getState(id=dwd.0.numberOfWarnings, timerId=undefined) => {"val":2,"ack":true,"ts":1703861705369,"q":0,"from":"system.adapter.dwd.0","user":"system.user.admin","lc":1703853855155}
                2023-12-29 16:00:00.004  - info: javascript.0 (4716) script.js.Sichereheitsfunktionen.Wetterwarnungen.DWD_Warnung_Telegram: getState(id=javascript.0.VariablenSkripte.DWDAlarmSchonGesendetTelegram, timerId=undefined) => {"val":2,"ack":false,"ts":1703854520019,"q":0,"c":"script.js.Sichereheitsfunktionen.Wetterwarnungen.DWD_Warnung_Telegram","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1703854520019}
                2023-12-29 16:00:00.005  - info: javascript.0 (4716) script.js.Sichereheitsfunktionen.Wetterwarnungen.DWD_Warnung_Telegram: getState(id=dwd.0.numberOfWarnings, timerId=undefined) => {"val":2,"ack":true,"ts":1703861705369,"q":0,"from":"system.adapter.dwd.0","user":"system.user.admin","lc":1703853855155}
                2023-12-29 16:00:00.076  - info: host.raspberrypi instance system.adapter.dwd.0 started with pid 10346
                2023-12-29 16:00:02.673  - info: dwd.0 (10346) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.19.0, js-controller: 5.0.17
                2023-12-29 16:00:04.090  - info: host.raspberrypi instance system.adapter.ical.0 started with pid 10406
                2023-12-29 16:00:06.868  - info: ical.0 (10406) starting. Version 1.13.3 in /opt/iobroker/node_modules/iobroker.ical, node: v18.19.0, js-controller: 5.0.17
                2023-12-29 16:00:06.970  - info: dwd.0 (10346) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                2023-12-29 16:00:07.505  - info: host.raspberrypi instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                2023-12-29 16:00:07.893  - info: ical.0 (10406) processing URL: Gmail
                2023-12-29 16:00:28.613  - info: ical.0 (10406) processing URL: Gmail
                2023-12-29 16:00:37.277  - info: ical.0 (10406) Terminated (NO_ERROR): Without reason
                2023-12-29 16:00:37.864  - info: host.raspberrypi instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
                2023-12-29 16:05:00.025  - info: host.raspberrypi instance system.adapter.dwd.0 started with pid 11280
                2023-12-29 16:05:03.231  - info: dwd.0 (11280) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.19.0, js-controller: 5.0.17
                iob diag has finished.
                Press any key for a summary
                • Glasfaser
                  processing URL: Gmail Privat
                  processing URL: Gmail Geschäft
                  Lösche den Link ... im Log !
                  • fAz3rs adventures
                    bekomm ich das so hin oder ist es weniger aufwand es platt zu machen und neu einzuspielen mit einem backup von davor?
                    • Glasfaser
                      @faz3rs-adventures
                      Alles gut ... nimm den Befehl
                      • Glasfaser
                        Dazu müssen wir gleich mal schauen !
                        • fAz3rs adventures
                          @glasfaser ```
                          Damit müsste zumindest das wieder passen oder?
                                                  v.2023-10-10
                                   Icon name: computer
                                Architecture: arm64
                          Userland:               armhf
                          User-ID:                1000
                          X-Server:               true
                                                  /usr/bin/npm            10.2.3
                                                  /usr/bin/npx            10.2.3
                          MEMORY:
                          Mem:            7.8G        1.3G        5.7G         35M        888M        6.4G
                          Swap:            99M          0B         99M
                          List is empty
                          Objects type: jsonl
                          States  type: jsonl
                          Objects:                5635
                          States:                 4391
                          9.2M    /opt/iobroker/iobroker-data/states.jsonl
                          • Glasfaser
                            @faz3rs-adventures
                            passt
                            zeige
                            iob repo list
                            • fAz3rs adventures
                              @glasfaser
                              pi@raspberrypi:~ $ iob repo list
                              List is empty
                              • Glasfaser
                                @faz3rs-adventures
                                dann
                                iob repo del beta
                                iob repo del stable
                                iob repo add stable http://download.iobroker.net/sources-dist.json
                                iob repo add beta http://download.iobroker.net/sources-dist-latest.json
                                iob repo list
                                • fAz3rs adventures
                                  @glasfaser
                                  pi@raspberrypi:~ $ iob repo del beta
                                  Repository "beta" deleted.
                                  List is empty
                                  pi@raspberrypi:~ $ iob repo del stable
                                  Cannot remove repository: Cannot delete active repository: stable
                                  soll ich den rest trotzdem laufen lassen wenn die stable nicht entfernt werden kann?
                                  • Glasfaser
                                    @faz3rs-adventures
                                    alles nacheinander ... del ist nur zur Sicherheit
                                    • fAz3rs adventures
                                      @glasfaser
                                      pi@raspberrypi:~ $ iob repo add stable http://download.iobroker.net/sources-dist.json
                                      Cannot add repository location: Repository "stable" yet exists: http://download.iobroker.net/sources-dist.json
                                      pi@raspberrypi:~ $ iob repo add beta http://download.iobroker.net/sources-dist-latest.json
                                      Cannot add repository location: Repository "beta" yet exists: http://download.iobroker.net/sources-dist-latest.json
                                      List is empty
                                      • Glasfaser
                                        @faz3rs-adventures
                                        iob stop
                                        iob setup first
                                        sudo reboot
                                        • fAz3rs adventures
                                          fAz3rs adventures @Glasfaser last edited by fAz3rs adventures
                                          @glasfaser
                                          pi@raspberrypi:~ $ iob stop
                                          pi@raspberrypi:~ $ iob setup first
                                          Successfully migrated 5683 objects to Redis Sets
                                          object system.repositories created
                                          object _design/system updated
                                            "defaultPrivate": "-----BEGIN RSA PRIVATE KEY-----
                                            "defaultPublic": "-----BEGIN CERTIFICATE-----
                                          Update certificate defaultPrivate
                                          The object "system.certificates" was updated successfully.
                                          Update certificate defaultPublic
                                          pi@raspberrypi:~ $ sudo reboot
                                          Active repo(s): stable
                                          • Glasfaser
                                            @faz3rs-adventures
                                            sieht gut aus 🙂
                                            1041
