    4. Cannot read properties of null (reading 'native')
    • Glasfaser
      Glasfaser @fAz3rs adventures last edited by
      @faz3rs-adventures
      passt
      zeige
      iob repo list
      fAz3rs adventures 1 Reply Last reply Reply Quote 0
      • fAz3rs adventures
        fAz3rs adventures @Glasfaser last edited by
        @glasfaser
        pi@raspberrypi:~ $ iob repo list
        List is empty
        • Glasfaser
          @faz3rs-adventures
          dann
          iob repo del beta
          iob repo del stable
          iob repo add stable http://download.iobroker.net/sources-dist.json
          iob repo add beta http://download.iobroker.net/sources-dist-latest.json
          iob repo list
          • fAz3rs adventures
            @glasfaser
            pi@raspberrypi:~ $ iob repo del beta
            Repository "beta" deleted.
            List is empty
            pi@raspberrypi:~ $ iob repo del stable
            Cannot remove repository: Cannot delete active repository: stable
            soll ich den rest trotzdem laufen lassen wenn die stable nicht entfernt werden kann?
            • Glasfaser
              @faz3rs-adventures
              alles nacheinander ... del ist nur zur Sicherheit
              • fAz3rs adventures
                @glasfaser
                pi@raspberrypi:~ $ iob repo add stable http://download.iobroker.net/sources-dist.json
                Cannot add repository location: Repository "stable" yet exists: http://download.iobroker.net/sources-dist.json
                pi@raspberrypi:~ $ iob repo add beta http://download.iobroker.net/sources-dist-latest.json
                Cannot add repository location: Repository "beta" yet exists: http://download.iobroker.net/sources-dist-latest.json
                List is empty
                • Glasfaser
                  @faz3rs-adventures
                  iob stop
                  iob setup first
                  sudo reboot
                  • fAz3rs adventures
                    fAz3rs adventures @Glasfaser last edited by fAz3rs adventures
                    @glasfaser
                    pi@raspberrypi:~ $ iob stop
                    pi@raspberrypi:~ $ iob setup first
                    Successfully migrated 5683 objects to Redis Sets
                    object system.repositories created
                    object _design/system updated
                      "defaultPrivate": "-----BEGIN RSA PRIVATE KEY-----
                      "defaultPublic": "-----BEGIN CERTIFICATE-----
                    Update certificate defaultPrivate
                    The object "system.certificates" was updated successfully.
                    Update certificate defaultPublic
                    pi@raspberrypi:~ $ sudo reboot
                    Active repo(s): stable
                    • Glasfaser
                      @faz3rs-adventures
                      sieht gut aus 🙂
                      • fAz3rs adventures
                        @glasfaser
                        Sau stark es passt👍
                        Kann die Updates für die Adapter laden
                        Vielen Dank👍 💪
                        Glasfaser 1 Reply Last reply Reply Quote 1
                        • Glasfaser
                          Glasfaser @fAz3rs adventures last edited by Glasfaser
                          @faz3rs-adventures sagte in Cannot read properties of null (reading 'native'):
                          Vielen Dank
                          Sehr gerne .... 😉
                          1041
