    4. Einbindung von Geräten
    5. PTM 215Z funktioniert nur während des Joining
      Basti189 last edited by Basti189
      ich besitze 8 von den batterielosen Friends of hue Tastern PTM 215Z.
      6 dieser Geräte sind erfolgreich über den zigbee Adapter eingebunden.
      2 dieser Geräte machen nur über den Zigbee Adapter Probleme.
      Ich kann die Geräte joinen, das klappt wunderbar, sie werden erkannt, sie werden angezeigt, alles super.
      2023-12-29 15:21:46.059  - debug: zigbee.0 (28498) handleDeviceJoined. {"device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":2,"_type":"GreenPower","_ieeeAddr":"0x0000000001765c98","_networkAddress":23704,"_manufacturerID":null,"_endpoints":[],"_modelID":"GreenPower_2","_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":false,"_skipTimeResponse":false,"meta":{},"_lastSeen":null,"_defaultSendRequestWhen":"immediate","_pendingRequestTimeout":0}}
      2023-12-29 15:21:46.062  - debug: zigbee.0 (28498) handleDeviceInterview. {"status":"successful","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":2,"_type":"GreenPower","_ieeeAddr":"0x0000000001765c98","_networkAddress":23704,"_manufacturerID":null,"_endpoints":[],"_modelID":"GreenPower_2","_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":false,"_skipTimeResponse":false,"meta":{},"_lastSeen":null,"_defaultSendRequestWhen":"immediate","_pendingRequestTimeout":0}}
      2023-12-29 15:21:46.063  - info: zigbee.0 (28498) Successfully interviewed '0x0000000001765c98', device has successfully been paired
      2023-12-29 15:21:46.063  - info: zigbee.0 (28498) Device '0x0000000001765c98' is supported, identified as: EnOcean Pushbutton transmitter module (PTM 215Z)
      Solange das joining noch läuft sehe ich auch die Tastendrücke.
      2023-12-29 15:22:07.303  - debug: zigbee.0 (28498) Publish {"action":"unknown_104"} to "0000000001765c98"
      2023-12-29 15:22:34.424  - debug: zigbee.0 (28498) Publish {"action":"press_1"} to "0000000001765c98"
      2023-12-29 15:22:34.764  - debug: zigbee.0 (28498) Publish {"action":"release_1"} to "0000000001765c98"
      Endet das Joining des Adapters nichts mehr - 0.
      Den einzigen Hinweis, der auf einen Fehler deutet ist dieser:
      2023-12-29 15:43:37.554  - debug: zigbee.0 (29314) Failed to execute LQI for '0x0000000001765c98'. "Error: AREQ - ZDO - mgmtLqiRsp after 10000ms\n    at Timeout._onTimeout (/opt/iobroker/node_modules/zigbee-herdsman/src/utils/waitress.ts:64:35)\n    at listOnTimeout (node:internal/timers:569:17)\n    at processTimers (node:internal/timers:512:7)"
      2023-12-29 15:43:37.554  - debug: zigbee.0 (29314) LQI succeeded for '0x0000000001765c98'
      2023-12-29 15:43:47.562  - debug: zigbee.0 (29314) Failed to execute routing table for '0x0000000001765c98'. "Error: AREQ - ZDO - mgmtRtgRsp after 10000ms\n    at Timeout._onTimeout (/opt/iobroker/node_modules/zigbee-herdsman/src/utils/waitress.ts:64:35)\n    at listOnTimeout (node:internal/timers:569:17)\n    at processTimers (node:internal/timers:512:7)"
      2023-12-29 15:43:47.562  - debug: zigbee.0 (29314) Routing for '0x0000000001765c98': undefined
      2023-12-29 15:43:47.563  - debug: zigbee.0 (29314) Routing table succeeded for '0x0000000001765c98'
      Wenn man die Geräte testweise an die HueBridge bindet, dann laufen sie einwandfrei.
      Hat jemand einen Tipp wie man das Problem beheben kann?
      Adapterversion: v1.8.25
      Coordinator: zStack3x0 2-1.2.7.1. 20230507 CC26X2R1
        Andy200877 @Basti189 last edited by
        @basti189
        Hast Du für dieses Problem eine Lösung gefunden ?
        1.5k
