    4. Node Red startet immer neu
    • N
      NetFritz last edited by
      Hallo
      Habe in Node Red den
      node-red-contrib-telegrambot 15.1.7
      über die Palette installiert.
      Beim Einrichten ist Node Red von der Weboberfläche nicht mehr erreichbar,
      Als Fehlermeldung kommt.
      2024-01-02 11:43:06.136 - info: node-red.0 (142065) Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
      2024-01-02 11:43:10.240 - warn: node-red.0 (142065) 2 Jan 11:43:10 - [warn] Projekte deaktiviert: editorTheme.projects.enabled=false
      2024-01-02 11:43:10.536 - error: node-red.0 (142365) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      2024-01-02 11:43:10.538 - error: node-red.0 (142365) unhandled promise rejection: ETELEGRAM: 404 Not Found
      2024-01-02 11:43:10.538 - error: node-red.0 (142365) Error: ETELEGRAM: 404 Not Found
      at /opt/iobroker/iobroker-data/node-red/node_modules/node-telegram-bot-api/src/telegram.js:299:15
      at tryCatcher (/opt/iobroker/iobroker-data/node-red/node_modules/bluebird/js/release/util.js:16:23)
      at Promise._settlePromiseFromHandler (/opt/iobroker/iobroker-data/node-red/node_modules/bluebird/js/release/promise.js:547:31)
      at Promise._settlePromise (/opt/iobroker/iobroker-data/node-red/node_modules/bluebird/js/release/promise.js:604:18)
      at Promise._settlePromise0 (/opt/iobroker/iobroker-data/node-red/node_modules/bluebird/js/release/promise.js:649:10)
      at Promise._settlePromises (/opt/iobroker/iobroker-data/node-red/node_modules/bluebird/js/release/promise.js:729:18)
      at _drainQueueStep (/opt/iobroker/iobroker-data/node-red/node_modules/bluebird/js/release/async.js:93:12)
      at _drainQueue (/opt/iobroker/iobroker-data/node-red/node_modules/bluebird/js/release/async.js:86:9)
      at Async._drainQueues (/opt/iobroker/iobroker-data/node-red/node_modules/bluebird/js/release/async.js:102:5)
      at Async.drainQueues [as _onImmediate] (/opt/iobroker/iobroker-data/node-red/node_modules/bluebird/js/release/async.js:15:14)
      at process.processImmediate (node:internal/timers:478:21)
      2024-01-02 11:43:10.539 - error: node-red.0 (142365) Exception-Code: ETELEGRAM: ETELEGRAM: 404 Not Found
      2024-01-02 11:43:11.044 - info: node-red.0 (142365) terminating
      2024-01-02 11:43:11.045 - warn: node-red.0 (142365) Terminated (UNCAUGHT_EXCEPTION): Without reason
      2024-01-02 11:43:11.581 - info: node-red.0 (142065) node-red exited with 6
      Habe dann in der Konsole den node-red-contrib-telegrambot deinstalliert.
      npm remove node-red-contrib-telegrambot
      removed 141 packages, and audited 1 package in 860ms
      found 0 vulnerabilities
      Danach die Fehlermeldung von oben weiter.
      Wie bekomme ich Node Red wieder zum laufen?
      Die letzte Lösung ist ein Backup, dann fehlt mir einiges von Gestern.
      Das letzte von Heute Nacht enthält ja den Fehler.
      Gruß NetFritz
      • Marc Berg
        Marc Berg Most Active last edited by
        @netfritz sagte in Node Red startet immer neu:
        Den Sicherheitmodus aktivieren
        und speichen, danach Node Red aufrufen und Telegram über den Pallettenmanager wieder entfernen. Danach den Sicherheitmodus wieder deaktivieren.
        N 1 Reply Last reply Reply Quote 1
        • N
          NetFritz @Marc Berg last edited by
          @marc-berg
          Hallo Danke
          Habe ich vor kurzen in einem anderen Beitrag auch gefunden.
          Sicherheitsmodus aktiviert
          Node Rede Start
          Telegram war im Flows nicht mehr drin.
          Dann Telegram Node im Palettenmanager deinstalliert.
          Dann Sicherheitsmodus deaktiviert.
          Node Red startet wieder.
          Alles Gut.
          Gruß NetFritz
